Komatsu Hydraulic Excavator PC8000-11E-12128-FS Parts Book 2024
Type of Manual: Parts Book
Model: Komatsu PC8000-11E-12128-FS Hydraulic Excavator
Serial Number: 12128
Publication Date: 2024
Number of Pages: 933 Pages
General View
General View – Excavator
Superstructure
Maintenance Parts
General View – Undercarriage
General View – Bullclam Equipment
Superstructure
Superstructure Platform And Boom Pin
Counterweight Arrangement
Rail And Steps
Emergency Ladder – Cab
Hydraulic Cylinder With Accumulator
Hydraulic Cylinder
Front Cover
Emergency Ladder – Machine Covering
Hydraulic Cylinder
Catwalks – Engine Housing
Doors – Machine Covering
Engine Housing Roof
Hydraulic Cylinder
Ladder Stopper
Winch Installation
Step Pad Mounting
Slew Ring Arrangement
Slew Ring Protection
Slew Gear Arrangement
Hydraulic Motor
Slew Brake Valve
Power Frame Arrangement
Drive Arrangement
Pump Distributor Gear
Engine Switch Box Modification
Motor Disconnect Box
Variable Displacement Pump
Distributor Gear Oil Cooling
Hydraulic
Main Oil Tank Arrangement
Main Oil Tank – Filter
Return Oil Filter
Aeration Filter
Return Oil Filter
Piping – Main Oil Tank
Pressure Relief Valve
Suction Tank
Main Oil Tank – Pump Unit
Gear Pump Unit
Hydraulic Filter
Connection, Main Oil Tank And Suction Tank
Piston Accumulator Arrangement
Suction Lines
Oil Cooler System Arrangement
Oil Cooler Arrangement
Oil Cooler – Fan Drive Above
Hydraulic Motor
Oil Cooler – Fan Drive Down
Hydraulic Motor
Oil Cooler – Hoses Assembly
Oil Cooler – Hose Attachments
Pressure Lines – Fan Motors – Oil Cooler
Return Lines – Fan Motors – Oil Cooler
Pressure Lines – Main Pumps – Hp Filter
Hoses Assembly – Hp Filter – Control Blocks
Main Pump – Control (Xlr)
Main Pump – Control (Pst)
Return Lines – Main Pumps
Main Pumps Control (P/U)
Pressure Lines – Pilot Oil Pump
Mounting – Control And Filter Plates
Filter And Control Plate – Front
Hydraulic Filter
Pressure Accumulator
Cartridge Block
Valve – Load Limitation
Valve – Pilot Oil Block 1 Drive
Valve – Pump Regulation
Valve – Travelling Gear
Valve – Slew Gear
Valve – Ladder 60 Bar
Valve – Refueling 60 Bar
Control And Filter Plate – Pdg With Piping
Hydraulic Filter
Hydraulic Filter
Valve Block
Piping – Control And Filter Plate Pdg
Return Lines – Control And Filter Plates
Hp Filter Arrangement
Control Blocks – Return Lines
Pipes – Control Blocks
Pipes – Remote Control Manifold
Control Plate
Pipes And Hoses Assembly – Control Blocks – Rotary Joint
Hydraulic Lines – Rotary Joint
Piping – Manifold
Return Line – Manifold
Pressure Lines – Slew Gear
Control And Tank Lines – Slew Gear
Control Blocks Arrangement – Kls
Control Block
Control Block
Anti-Cavitation Valve
Piping – Secondary Valves – Bullclam Bucket Equipment
Pipes Assembly – Manifold – Distribution Block Kse
Pipes – Control Blocks Kse
Hoses Assembly – Distribution Block – Boom Kse
Manifold Arrangement
Non-Return Valve
Non-Return Valve
Non-Return Valve
Non-Return Valve
Throttle Check Valve
Manifold – Valves – Bbe
Secondary Pressure Relief Valve
Piping – Manifold – Bullclam Bucket Equipment
Auxiliary Oil Cooler Arrangement
Fan Crosshead Assembly
Hydraulic Motor
Hose Mounting Parts – Piping Plan
Hose Mounting Parts – Pvg
Hose Mounting Parts – Piping Plane
Pump Control
Operator's Cab
Cab Support Mounting
Cab Support With Switch Cabinet
Operator's Cab Part 1
Operator's Cab Part 2
Operator's Cab – Glazing Front Window Glued
Windscreen Washing Assembly
Driver's Seat / Co-Driver's Seat Arrangement
Operator's Seat
Co-Driver Seat
Cabin – Operation Elements – Location 20
Manipulator
Manipulator
Cabin – Electric Harnesses
Camera System Cable Supply
Cdm Vision Camera System – Cabin, Cab Support, Cab Podium
Kom Vision Camera System – Fuel Tank And Cooler Machine Covering
Counterweight
Air Conditioning Equipment And Heater
Electric Heater Assembly (Collectorless)
Electric Heater (Collectorless)
Air Conditioning Arrangement
Air Conditioning Unit
Air Conditioning Arrangement – Cab Support
Compact Air Conditioning Equipment
Air Conditioning Arrangement – Switch Cabinet
Electric
Lighting Equipment – Machine House
Lighting Equipment And Gps Stage
E-Parts Socket
Lighting Equipment – Machine House Left / Right
Lighting Equipment – Oil Cooler
Lighting Equipment – Counterweight
Batteries With Cables
Electric Cables – Switch Cabinet
Electric – Cab Support
Switch Framing Location Ii
Horn Illumination
Cable – Cab Support
Mounting Plate – Cab Support – Location 12
Electric – Oil Tank
Drive Motor – Leakage Lines
Drive Gearbox – Brake Control
Hydraulic Track Adjusting
Valve Block
Hydraulic Cylinder
Rod Protection – Boom Cylinder
Sticks – 7.5 M
Stick Cylinder With Piping
Hydraulic Cylinder
Stick Cylinder – Rod Protection
Pipes – Bucket Cylinder Rh And Lh
Hydraulic Cylinder
Bullclam Bucket 42.0 Cbm
Clam Cylinder Rh And Lh
Hydraulic Cylinder
Wear And Tear Parts – Back Panels Bcb Mwp4
Wear Parts – Bullclam Bbd Cbm
Pin Sealing – Bullclam Bucket
Annex
O-Ring Kit
Electro Kit – Deutsch
Toolbox With Electro Kit (Deutsch)
* Variations From Page 2
General View
Superstructure
Maintenance Parts
Superstructure
Rail And Steps
Hydraulic Cylinder
Front Cover
Hydraulic Cylinder
Engine Housing Roof
Hydraulic Cylinder
Ladder Stopper
Winch Installation
Step Pad Mounting
Hydraulic Motor
Slew Brake Valve
Drive Arrangement
Hydraulic
Return Oil Filter
Aeration Filter
Return Oil Filter
Suction Tank
Gear Pump Unit
Hydraulic Filter
Suction Lines
Hydraulic Motor
Hydraulic Motor
Hydraulic Filter
Cartridge Block
Valve – Slew Gear
Hydraulic Filter
Hydraulic Filter
Valve Block
Control Plate
Piping – Manifold
Control Block
Control Block
Non-Return Valve
Non-Return Valve
Non-Return Valve
Non-Return Valve
Hydraulic Motor
Pump Control
Operator's Cab
Operator's Seat
Co-Driver Seat
Manipulator
Manipulator
Counterweight
Electric
E-Parts Socket
Horn Illumination
Cable – Cab Support
Electric – Oil Tank
Valve Block
Hydraulic Cylinder
Sticks – 7.5 M
Hydraulic Cylinder
Hydraulic Cylinder
Hydraulic Cylinder
Annex
O-Ring Kit
- KOMATSU Fault Codes
