Komatsu Hydraulic Excavator PC750-7 PC800-7 Shop Manual SEBM031314
Type of Manual: Shop Manual
Model: Komatsu PC750-7 PC800-7 Hydraulic Excavator
Serial Number:
20001 and up
40001 and up
Form Number: SEBM031314
Publication Date: 01.2021
Number of Pages: 870 Pages
Safety
Safety Notice
Foreword
General
How To Read The Shop Manual
Hoisting Instructions
Method Of Disassembling, Connecting Push-Pull Type Coupler
Coating Materials
Standard Tightening Torque
Electric Wire Code
Conversion Table
Units
01 General
Specification Drawings
Specifications
Weight Table
Fuel Coolant And Lubricants
10 Structure, Function And Maintenance Standard
Pto
Pto Lubrication System
Power Train
Swing Machinery
Swing Circle
Final Drive
Sprocket
Track Frame And Recoil Spring
Idler
Carrier Roller
Track Roller
Track Shoe
Motor Grease Pump
Hydrauuc Tank
Return Oil Filter
Une Oil Filter
Pilot Oil Filter
Drain Oil Filter
Lh. 5-Spool Control Valve
R.H. 4-Spool Control Valve
Straight-Travel Valve
Swing Motor
Center Sw1veljoint
Travel Motor
Ppc Control Reuef Valve
Ppc Accumulator
Valve Control
Work Equipment, Swing Ppc Valve
Travel Ppc Valve
Solenoid Valve
Hydrauuc Cyunder
Work Equipment
Dimensions Of Work Equipment
Air Conditioner
Engine Control
Machine Control System
Monitor System
Sensors
20 Testing And Adjusting
Standard Value Table For Engine
Standard Value Table For Chassis
Troubleshooting
30 Disassembly And Assembly
90 Others
Hydraulic Circuit Diagram (P050-7, Pc75ose-7, Pcboo-7, Pc800se-7)
Hydraulic Circuit Diagram (Loading Shovel Specification, P050-7, Po5ose-7)
Electrical Circuit Diagram (1/6) (P050-7. Pc750se-7, Pc800-7. Pcb00se-7)
Electrical Circuit Diagram (2/6) (P050-7, Po50se-7, Pc800-7, Pcboose-7)
Electrical Circuit Diagram (3/6) (P050-7, P0505e-7, Pc800-7, Pcboose-7)
Electrical Circuit Diagram (4/6) (P050-7, P0505e-7, Pc800-7, Pc800se-7)
Electrical Circuit Diagram (5/6) (P050-7, Po5ose-7, Pc800-7, Pc800se-7)
Electrical Circuit Diagram (6/6) (Loading Shovel Specification, P050-7, Po5ose-7)
Serial Number:
20001 and up
40001 and up
Safety
Safety Notice
Foreword
General
Coating Materials
Electric Wire Code
Conversion Table
Units
01 General
Specifications
Weight Table
Pto
Power Train
Swing Machinery
Swing Circle
Final Drive
Sprocket
Idler
Carrier Roller
Track Roller
Track Shoe
Motor Grease Pump
Hydrauuc Tank
Return Oil Filter
Une Oil Filter
Pilot Oil Filter
Drain Oil Filter
Swing Motor
Center Sw1veljoint
Travel Motor
Ppc Accumulator
Valve Control
Travel Ppc Valve
Solenoid Valve
Hydrauuc Cyunder
Work Equipment
Air Conditioner
Engine Control
Monitor System
Sensors
Troubleshooting
90 Others
- KOMATSU Fault Codes
