Momed80
150
35,046
Komatsu Hydraulic Excavator PC70-8 Parts Book YEPB203200-00 2025
Type of Manual: Parts Book
Model: Komatsu PC70-8 Hydraulic Excavator
Engine: SAA4D95LE-5L-W
Serial Number:
PC70-8 DBBWV001 And Up
SAA4D95LE-5L-W 531217 And Up
Part Number: YEPB203200-00
Publication Date: 2025
Number of Pages: 611 Pages
ENGINE
Lifting Bracket
Head Cover
Breather
Air Intake Connector
Air Intake Heater
Air Intake Connector Mounting
Exhaust Muffler Mounting
Turbocharger
Exhaust Manifold
Turbocharger Oil Piping
Air Intake
Air Transfer Connection
Muffler
Muffler Pipe
Thermostat
Water Outlet Connector
Oil Pressure Switch Plug
Front Gear
Front Gear Cover
Cylinder Block Blind Plug
Oil Filler
Oil Filler
Oil Filler
Oil Pan
Oil Level Gauge
Flywheel Housing
Flywheel
Flywheel Mounting
Damper
Damper
Piston
Piston
Rocker Arm
Camshaft
Oil Filter
Fuel Pump
Fuel Filter Piping
Fuel Filter Piping
Common Rail
Common Rail
Injector
Injector
Engine Controller
Engine Controller
Engine Control Module
Fuel Controller (Bracket)
Water Pump Adapter
Cooling Fan Drive Pulley
Cooling Fan
Fan Spacer
Inner Parts
Alternator Mounting
Fan Belt
Starting Motor
Starting Motor
Inner Parts
Inner Parts
Starting Motor Mounting
Wiring Harness
Repair Parts
Engine Name Plate
Approval Caution Plate
Starter Relay
Fuel Pre-Filter
Spare Parts
Air Cleaner
ENGINE ASSEMBLY
Engine Assembly
Engine Assembly
Engine Assembly
Muffler
ENGINE RELATED PARTS
Engine Mount
Air Cleaner (Double Element Type)
Air Cleaner (Double Element Type) (With Pre-Cleaner)
COOLING SYSTEM
Cooling
Radiator And After Cooler
Fuel Cooler
Net
Cover And Seal
Air Conditioner Condenser
Radiator Piping
Sub Tank
Fan Guard
Cooling
Fuel Cooler
Net
Cover And Seal
Radiator Piping
Sub Tank
Fan Guard
FUEL TANK AND RELATED PARTS
Fuel Piping
Suction Piping
Return Piping
Prefilter And Mounting
Water Separator And Mounting
Fuel Piping
Suction Piping
Return Piping
Fuel Piping
Suction Piping
Return Piping
ELECTRICAL SYSTEM
Battery (Battery And Cable)
Electrical
Main Wiring Harness
Bracket And Cover
Collar And Clip
Main Wiring Harness Mounting
Fuse Holder
Battery Relay Switch And Ground Cable
Horn
Heater Switch And Relay
Electrical (With Anti-Theft Bolt)
Main Wiring Harness
Bracket And Cover
Collar And Clip
Fuse Holder
Horn
Additional Work Lamp
Back-Up Alarm
HYDRAULIC SYSTEM
Hydraulic Oil Tank
Hydraulic Oil Tank With Breather
Main Control Valve
Main Control Valve
6-Valve Inner Parts
Main Control Valve (Provision For Additional Actuator Piping)
Main Control Valve
7-Valve Inner Parts
Main Control Valve (Blade Spec.)
Main Control Valve
7-Valve Inner Parts
Main Control Valve (Additional Actuator Piping, Blade Spec.)
Main Control Valve
8-Valve Inner Parts
Main Control Valve (Provision For Service Valve)
Mounting Bracket
Main Control Valve (Service Valve, Blade Spec.)
Mounting Bracket
Main Pump
Main Pump
Inner Parts
Inner Parts
Inner Parts
Inner Parts
Main Pump (Blade Spec.)
Main Pump
Inner Parts
Inner Parts
Inner Parts
Inner Parts
Suction Piping
Suction Piping (Blade Spec.)
Delivery Piping
Delivery Piping (Blade Spec.)
Oil Cooler Piping
Oil Cooler To Main Valve
Oil Cooler To Hydraulic Oil Tank
Oil Cooler Piping (Additional Actuator Piping)
Return Piping
Drain Piping
Drain Piping (With Additional Drain Piping)
Boom Drift Piping
Arm And Bucket Piping
Attachment Piping
Main Valve Piping
Connecting Parts
Directional Valve
Directional Valve
Filter
Mounting
Safety Valve Inner Parts
Attachment Piping Less Plug
Attachment Piping (With Additional Drain Piping)
Main Valve Piping
Connecting Parts
Directional Valve
Directional Valve
Filter
Mounting
Attachment Piping Kit
Main Valve Piping
Connecting Parts
Directional Valve
Directional Valve
Filter
Mounting
Joint Block
Attachment Control Pedal
Attachment Piping (Plug)
Blade Piping
Travel Piping
Travel Piping (Blade Spec.)
Solenoid Valve Piping
Solenoid Valve
Solenoid Valve Mounting
Main Valve To PPC Valve Piping
Connecting Parts
PPC Piping
MAIN / REVOLVING FRAME AND RELATED PARTS
Revolving Frame
Boom Foot Pin
OPERATOR'S COMPARTMENT AND CONTROL SYSTEM
Operator Seat
Inner Parts
Mounting Parts
Seat Belt
Operator Cab
Window
Front Window
Front Lower Glass
Door
Door Lock
Door Open Lock
Roof Ventilator
Wiper
Window Washer
Floor Base
Floor Travel Control
PPC Valve Inner Parts For Travel
Attachment Control
Lever LH
Console LH
Work Equipment Lock Lever
Arm Rest LH
Lever RH
Console RH
Arm Rest RH
Monitor Panel
PPC Valve LH
PPC Valve Piping LH
PPC Valve RH
PPC Valve Piping RH
PPC Valve Inner Parts For Work Equipment
Floor Wiring Harness
Cab Parts Pump Controller
Cab Parts Roof And Rear Cover
Cab Parts Monitor Cover
Cab Parts Luggage Cover
Air Duct Seal
Cab Parts Air Conditioner And Level Sensor
Cab Parts Monitor Duct
Cab Parts Air Duct And Fresh Air Filter
Foot Rest
GPRS Controller
Radio Antenna And Speaker
Rubber Antenna Inner Parts
Radio
Rear Cover
Base Front Cover
Air Conditioner Unit Inner Parts
Operator Cab (Blade Spec.)
Blade Control
Operator Cab (Additional Actuator Piping)
Operator Cab (With GPRS)
Operator Cab (With KOMTRAX)
KOMTRAX System
Radio
Top Guard
Front Guard
Floor Mat
Window Washer
Air Conditioner
V-Belt
Mode Selection Connectors
GUARD
Hood
Left Side Cover
Right Side Cover
Partition
Frame For ISO Visibility
Cover For ISO Visibility
Work Lamp And Case
Handrail
Rear View Mirror LH
Rear View Mirror RH
Rear View Mirror
Counterweight
Counterweight Mounting
Under Cover
SWING CIRCLE AND RELATED PARTS
Swing Circle
Swing Machinery
Swing Machinery Inner Parts
Swing Motor Related Parts
Swing Motor Inner Parts
Swivel Joint
Swivel Joint
Inner Parts
Swivel Joint
Swivel Joint
Inner Parts
TRAVEL AND LOWER PIPING
Lower Hydraulic Piping
Lower Hydraulic Piping (Blade Spec.)
Travel Piping
Blade Piping
Final Drive
Final Drive
Travel Motor Inner Parts
UNDERCARRIAGE
Front Idler
Idler Cushion
Track Roller
Carrier Roller
Track Shoe
Track Frame
Track Roller
Cover
Strength Under Cover
Track Roller Guard
WORK EQUIPMENT
Boom
Working Lamp
Boom Pin
Arm And Bucket Cylinder Piping
Boom Cylinder
Boom Cylinder
Inner Parts
Arm Cylinder
Arm Cylinder
Inner Parts
Arm
Bucket Cylinder
Bucket Cylinder
Inner Parts
Bucket Link
Bucket Less Link
Bucket
Blade
Blade Lift Cylinder
Blade Lift Cylinder
Inner Parts
Marks And Plates
Caution Plate Bucket Hook
KOMTRAX Plate
ROPS Plates
ACCESSORY
Spare Parts
Spare Parts (With Hydraulic Tank Breather)
Tool
OTHER EQUIPMENT
Vandalism Protection
FIELD REPAIR SERVICE PARTS
Shoe Bolt And Nut Service Kit
