Komatsu Hydraulic Excavator PC70-8 Parts Book YEPB202900-00 2026
Type of Manual: Parts Book
Model: Komatsu PC70-8 Hydraulic Excavator
Engine: SAA4D95LE-5L-W
Serial Number:
PC70-8 : DBBTM001 And Up, DBBWM001 And Up
SAA4D95LE-5L-W : 531217 And Up
Part Number: YEPB202900-00
Publication Date: 2026
Number of Pages: 610 Pages
ENGINE
Cylinder Head(#531217-)
Lifting Bracket(#511213-)
Head Cover(#511213-)
Breather(#511213-)
Air Intake Connector(#511213-)
Air Intake Heater
Air Intake Connector Mounting(#511213-)
Exhaust Muffler Mounting
Turbocharger(#511213-)
Exhaust Manifold
Turbocharger Oil Piping
Air intake
Air Transfer Connection(#511213-)
Muffler(#511213-)
Muffler Pipe(#511213-)
Thermostat
Water Outlet Connector
Oil Pressure Switch Plug (#531217)
Front Gear
Front Gear Cover
Cylinder Block Biind Plug
Oil Filier(#511213-)
Oil Filler(#511213-)
Oil Filler(#511213-572860)
Oil Pan(#511213-)
Oil Level Gauge(#511213-)
Flywheel Housing (#511213-)
Flywheel Mounting
Damper(#511213-539279)
Damper(#511213-)
Piston
Piston(#531217-)
RockerArrn
Camshaft
Oil Filter(#511213)
Oil Cooler(#511213-)
Fuel Pump
Fuel Filter(#511213-)
Fuel Filter Piping(#511213-)
Common Rail
Common Rail(#531217-)
Injector
Injector(#531217—)
Engine Controller (Chassis Mount)
Engine Controller (#511213)
Engine Control Moduie(#511213-)
Fuel Controller (Bracket) (#511213)
Water Pump(#511213-)
Water Pump Adapter(#511213—)
Cooling Fan Drive Pulley(#511213-)
Cooling Fan(#511213-)
Fan Spacer(#511213-)
Alternator (35A)
Inner Parts
Alternator Mounting (35A) (#511213)
Fan Belt(#511213-)
Starting Motor (4.5kw)
Starting Motor
Inner Parts(#500001-561854)
Inner Parts (#561855)
Starting Motor Mounting (4.5Kw)
Wiring Hamess(#511213-)
Repair Parts
Engine Name PIate(#511213-)
Approval Caution Plate (Except Japan)(#531217-)
Starter Relay(#511213)
Fuel Pre-Fiiter
Spare Parts(#511213-)
Air CIeaner(#511213-)
ENGINE ASSEMBLY
Engine Assembly (35 Amp.,4.5KW)
Engine Assembly (35 Amp.,4.5KW) (For Bio Diesel Fuel, B30)
Engine Assembly
Muffler
ENGINE RELATED PARTS
Engine Mount
Air Cleaner (Double Element Type)
Air Cleaner (Double Element Type) (With Pre-Cleaner)
COOLING SYSTEM
Cooling
Radiator And After Cooler
Fuel Cooler
Net
Cover And Seal
Air Conditioner, Condenser
Radiator Piping
Sub Tank
Fan Guard
Cooling (For Bio Diesel Fuel, 830)
FUEL TANK AND RELATED PARTS
Fuel Tank (For Bio Diesel Fuel, 330)
Fuel Piping
Suction Piping
Return Piping
Prefilter And Mounting
Water Separator And Mounting
Fuel Piping (For Bio Diesel Fuel, 820)
Fuel Piping (For Bio Diesel Fuel, 830)
ELECTRICAL SYSTEM
Battery (Battery And Cable)
Electrical
Main Wiring Hamess
Bracket And Cover
Collar And Clip
Main Wiring Hamess Mounting, 113
Main Wiring Hamess Mounting, 213
Main Wiring Hamess Mounting, 313
Fuse Holder
Battery Relay Switch And Grand Cable
Hom
Heater Switch And Relay
Electrical (With Anti-Theft Bolt)
Main Wiring Harness Mounting, 113
Main Wiring Harness Mounting, 213
Main Wiring Harness Mounting, 313
Horn
Additional Work Lamp
Back-Up Alarm
HYDRAULIC SYSTEM
Hydraulic Oil Tank
Hydraulic Oil Tank, With Breather
Main Control Valve
6-Valve, Inner Parts, 1116
6-Valve, Inner Parts, 2116
6-Valve, Inner Parts, 3116
6-Valve, Inner Parts, 4116
6-Valve, Inner Parts, 5116
6-Valve, Inner Parts, 6116
6-Valve, Inner Parts, 7116
6-Valve, Inner Parts, 8116
6-Valve, Inner Parts, 9116
6-Valve, Inner Parts, 10/16
6-Valve, Inner Parts, 11116
6-Valve, Inner Parts, 12116
6-Valve, Inner Parts, 13/16
6-Valve, Inner Parts, 14/16
6-Valve, Inner Parts, 15/16
6-Valve, Inner Parts, 16/16
Main Control Valve (Provision For 1-Additional Actuator Piping)
7-Vaive, Inner Parts, 1118
7-Vaive, Inner Parts, 2118
7-Vaive, Inner Parts, 3118
7-Vaive, Inner Parts, 4118
7-Vaive, Inner Parts, 5118
7-Vaive, Inner Parts, 6118
7-Vaive, Inner Parts, 7118
7-Valve, Inner Parts, 8118
7-Valve, Inner Parts, 9118
7-Valve, Inner Parts, 10/18
7-Valve, Inner Parts, 11118
7-Valve, Inner Parts, 12118
7-Valve, Inner Parts, 13/18
7-Valve, Inner Parts, 14/18
7-Valve, Inner Parts, 15118
7-Valve, Inner Parts, 16/18
7-Valve, Inner Parts, 17/18
7-Valve, Inner Parts, 18/18
Main Control Valve (Blade Spec.)
7-Vaive, Inner Parts, 8118
7-Vaive, Inner Parts, 9118
7-Vaive, Inner Parts, 10/18
7-Vaive, Inner Parts, 11118
7-Vaive, Inner Parts, 12118
7-Vaive, Inner Parts, 13/18
7-Vaive, Inner Parts, 14/18
7-Vaive, Inner Parts,15118
7-Vaive, Inner Parts, 16/18
7-Vaive, Inner Parts, 17/18
7-Vaive, Inner Parts, 18/18
Main Control Valve (1-Additionai Actuator Piping, Blade Spec.)
8—Vaive, Inner Parts, 1120
8—Vaive, Inner Parts, 2120
8—Vaive, Inner Parts, 3120
8—Vaive, Inner Parts, 4120
8—Vaive, Inner Parts, 5120
8—Vaive, Inner Parts, 6120
8—Vaive, Inner Parts, 7120
8—Vaive, Inner Parts, 8120
8—Vaive, Inner Parts, 9120
8—Vaive, Inner Parts, 10/20
8—Vaive, Inner Parts, 11120
8—Vaive, Inner Parts, 12120
8—Vaive, Inner Parts, 13/20
8—Vaive, Inner Parts, 14/20
8-Vaive, Inner Parts, 15/20
8-Vaive, Inner Parts, 16/20
8-Vaive, Inner Parts, 17/20
8-Vaive, Inner Parts, 18/20
8-Vaive, Inner Parts, 19/20
8-Vaive, Inner Parts, 20/20
Main Control Valve (Provision For 1-Service Valve)
Mounting Bracket
7-Valve, Inner Parts, 7118
7-Vaive, Inner Parts, 15/18
Main Control Valve (1-Service Valve, Blade Spec)
8-Valve, Inner Parts, 1120
8-Valve, Inner Parts, 2120
8-Valve, Inner Parts, 3120
8-Vaive, Inner Parts, 4120
8-Vaive, Inner Parts, 5120
8-Vaive, Inner Parts, 6120
8-Vaive, Inner Parts, 7120
8-Vaive, Inner Parts, 8120
8-Vaive, Inner Parts, 9120
8-Vaive, Inner Parts, 10/20
8-Valve, Inner Parts, 11120
8-Valve, Inner Parts, 12120
8-Valve, Inner Parts, 13120
8-Valve, Inner Parts, 14/20
8-Valve, Inner Parts, 15120
8-Valve, Inner Parts, 17/20
8-Valve, Inner Parts, 18120
Main Pump
Inner Parts, 114
Inner Parts, 214
Inner Parts, 314
Inner Parts, 414
Main Pump (Blade Spec.)
Inner Parts,114
Inner Parts,214
Inner Parts,314
Inner Parts,414
Suction Piping (Blade Spec.)
Delivery Piping
Delivery Piping (Blade Spec.)
Oil Cooler Piping
Oil Cooler To Main Valve
Oil Cooler To Hydraulic Oil Tank
Oil Cooler Piping (Provision For 1-Additionai Actuator Piping)
Drain Piping
Drain Piping (With Additional Drain Piping)
Boom Drift Piping
Arm And Bucket Piping
Attachment Piping
Main Valve Piping
Connecting Parts
Directional Valve, 112
Directional Valve, 212
Filter
Mounting
Safety Valve, Inner Parts, For Attachment
Attachment Piping Less Plug
Attachment Piping (With Additional Drain Piping)
Attachment Piping Kit
Joint G. P,T Block
Floor, Attachment Control Pedal, 112
Floor, Atachment Control Pedal, 212
Attachment Piping (Plug) (For 1-Service Valve)
Blade Piping
Travel Piping
Travel Piping (Blade Spec.)
Solenoid Valve Piping
Solenoid Valve
Solenoid Valve Mounting
Main Valve To PPC Valve Piping
PPC Piping (Blade Spec.)
MAIN/REVOLVING FRAME AND RELATED PARTS
Revolving Frame
Boom Foot Pin
I
OPERATOR S COMPARTMENT AND CONTROL SYSTEM
Operator's Seat
Mounting Parts
Seat Belt
Operators Cab (With GPRS, 46, Radio MP3)
Window
Front Window
Front Lower Glass
Door
Door Lock
Door Open Lock
RoofVentilator
Wiper
Window Washer
Cap And Plug
Floor, Base
Floor, Travel Control
PPC Valve Inner Parts, For Travel
Floor, Attachment Control, Travel PPC Piping
Floor, T-Block And P-Block
Floor, Lever, L.H.
Floor, Console, L.H.
Floor, Work Equipment Lock Lever
Floor, Arm Rest, L.H.
Lever R.H.
Floor, Console, R.H.
Floor, Arm Rest, R.H.
Monitor Panel
Floor, P.P.C. Valve, L.H.
Floor, P.P.C. Valve Piping, L.H.
Floor, P.P.C. Valve, R.H.
Floor, P.P.C. Valve Piping, R.H.
PPC Valve Inner Parts,For Work Equipment,L.H. And R.H.
Floor, Wiring Harness
Cab In Parts, Pump Controller
Cab In Parts, Roof And Rear Cover
Cab In Parts, Monitor Cover
Cab In Parts, Luggage Cover
Floor, Air Duct Seal
Cab In Parts, Air Conditioner And Level Sensor
Cab In Parts, Monitor Duct
Cab In Parts, Air Duct And Fresh Air Filter
Floor, Foot Rest
Controller
Radio Antenna And Speaker
RubberAntenna Inner Parts
Floor, Radio
Cab In Parts, Rear Cover
Floor, Base Front Cover
Air Conditioner Unit, Inner Parts, 112
Air Conditioner Unit, Inner Parts, 212
Operator'S Cab (Blade Spec.)
Blade Control
Operator'S Cab (Provision For 1-Additional Actuator Piping)
Floor, PPC Valve
Operator'S Cab (Wlth GPRS)
Operator'S Cab (With KOMTRAX, Radio AUX)
KOMTRAX, OPBCOMM Type
Radio
Top Guard
Front Guard, Full (Level 2)
Front Guard (Full) (Level 2)
Floor Mat
Floor Mat (Provision for 1-Additional Actuator Piping)
Air Conditione
V-Belt
Mode Selection Connectors
GUARD
Hood
Left Side Cover
Right Side Cover
Partition
Frame, For ISO Visibility
Cover, For ISO Visibility
Partition (For Iso Visibility, Pre-Cleaner)
Frame
Cover
Work Lamp And Case
Handrail
Rear View Mirror L.H.
Rear View Mirror R.H.
Rear View Mirror (For ISO Visibility)
Counterweight
Counterweight Mounting
Under Cover
SWING CIRCLE AND RELATED PARTS
Swing Circle
Swing Machinery
Swing Machinery, Inner Parts
Swing Motor Related Parts
Swing Motor, Inner Parts, 113
Swing Motor, Inner Parts, 213
Swing Motor, Inner Parts, 313
Swivel Joint
TRAVEL AND LOWER PIPING
Lower Hydraulic Piping
Lower Hydraulic Piping (Blade Spec.)
Final Drive
Travel Motor, Inner Parts, 113
Travel Motor, Inner Parts, 213
Travel Motor, Inner Parts, 313
UNDER CARRIAGE
Front Idler
Idler Cushion
Track Roller
Carrier Roller
Track Shoe (Triple Grouser With Hole) (450mm Wide)
Track Frame
Track Frame With Track Roller Guard
Track Frame (With Strength Under Cover)
Track Frame (Blade Spec.)
Track Frame (With Strength Under Cover, Blade Spec.)
Track Roller Guard
Plug (Track Roller Guard Less)
WORK EQUIPMENT
Boom (3710mm)
Boom
Working Lamp
Boom Pin
Arm And Bucket Cylinder Piping
Boom (3710mm, Provision For ‘I-Additionai Actuator Piping)
Aim And Bucket Cylinder Piping
Additional Piping
Boom (3710mm, For 1-Additionai Actuator Piping, With Drain Piping)
Boom Cylinder
Arm Cylinder
Arm (1.7m, Provision For 1-Additional Actuator Piping)
Arm (1.7m, Strengthened, Provision For 1-Additionai Actuator Piping)
Arm (1.7m, For 1-Additional Actuator, With Drain Piping)
Additional and Drain Piping
Bucket Cylinder
Bucket Link
Bucket Pin
Bucket (0.18m3, 544mm Width)
Bucket (0.37m3, 930mm Width)
Bucket (0.37m3, 930mm Width, With Hook)
Blade
Blade Lift Cylinder
MARKS AND PLATES
Marks And Plates, English
Marks And Plates, English, Blade Spec
Plate, Caution, Bucket Hook, Thai
Plate, Caution , Bucket Hook, English
KOMTRAX Plate, GPRS, 3G, TC630
Caution Plates (Top Guard) (English)
Caution Plate (Front Guard) (English)
Caution Plate (Top Guard) (Front Guard)(English)
ROPS Plates (English)
ACCESSORY
Spare Parts
Spare Parts (With Hydraulic Tank Breather)
Tooi
OTHER EQUIPMENT
Vandalism Protection (Monitor and Pump Controller Guard)
FIELD REPAIR SERVICE PARTS
Shoe Bolt And Nut Service Kit
Serial Number:
ENGINE
Breather(#511213-)
Air Intake Heater
Exhaust Manifold
Air intake
Muffler(#511213-)
Thermostat
Front Gear
Front Gear Cover
Oil Pan(#511213-)
Flywheel Mounting
Damper(#511213-)
Piston
Piston(#531217-)
RockerArrn
Camshaft
Oil Filter(#511213)
Fuel Pump
Common Rail
Injector
Injector(#531217—)
Alternator (35A)
Inner Parts
Fan Belt(#511213-)
Starting Motor
Repair Parts
Fuel Pre-Fiiter
ENGINE ASSEMBLY
Engine Assembly
Muffler
Engine Mount
COOLING SYSTEM
Cooling
Fuel Cooler
Net
Cover And Seal
Radiator Piping
Sub Tank
Fan Guard
Fuel Piping
Suction Piping
Return Piping
ELECTRICAL SYSTEM
Electrical
Main Wiring Hamess
Bracket And Cover
Collar And Clip
Fuse Holder
Hom
Horn
Back-Up Alarm
HYDRAULIC SYSTEM
Hydraulic Oil Tank
Main Control Valve
Mounting Bracket
Main Pump
Inner Parts, 114
Inner Parts, 214
Inner Parts, 314
Inner Parts, 414
Inner Parts,114
Inner Parts,214
Inner Parts,314
Inner Parts,414
Delivery Piping
Oil Cooler Piping
Drain Piping
Boom Drift Piping
Attachment Piping
Main Valve Piping
Connecting Parts
Filter
Mounting
Joint G. P,T Block
Blade Piping
Travel Piping
Solenoid Valve
Revolving Frame
Boom Foot Pin
I
Operator's Seat
Mounting Parts
Seat Belt
Window
Front Window
Front Lower Glass
Door
Door Lock
Door Open Lock
RoofVentilator
Wiper
Window Washer
Cap And Plug
Floor, Base
Floor, Lever, L.H.
Lever R.H.
Monitor Panel
Floor, Foot Rest
Controller
Floor, Radio
Blade Control
Floor, PPC Valve
Radio
Top Guard
Floor Mat
Air Conditione
V-Belt
GUARD
Hood
Left Side Cover
Right Side Cover
Partition
Frame
Cover
Work Lamp And Case
Handrail
Counterweight
Under Cover
Swing Circle
Swing Machinery
Swivel Joint
Final Drive
UNDER CARRIAGE
Front Idler
Idler Cushion
Track Roller
Carrier Roller
Track Frame
Track Roller Guard
WORK EQUIPMENT
Boom (3710mm)
Boom
Working Lamp
Boom Pin
Additional Piping
Boom Cylinder
Arm Cylinder
Bucket Cylinder
Bucket Link
Bucket Pin
Blade
Blade Lift Cylinder
MARKS AND PLATES
ACCESSORY
Spare Parts
Tooi
OTHER EQUIPMENT
- KOMATSU Fault Codes
