Komatsu Hydraulic Excavator PC500LC-10R Parts Book YEPB203900-00 2025
Type of Manual: Parts Book
Model: Komatsu PC500LC-10R Hydraulic Excavator
Serial Number: DBCX0001 And Up
Part Number: YEPB203900-00
Publication Date: 2025
Number of Pages: 856 Pages
Rocker Arm Housing Cover
Rocker Arm Housing Cover Accessory
Exhaust Muffler and Mounting Bracket
Air Intake Manifold and Connection
Exhaust Manifold
Turbocharger
Inner Parts
Mounting
EGR Valve and Cooler Mounting (112)
Inner Parts, EGR Oil Pump
EGR Valve and Cooler Mounting (212)
EGR Cooler Piping and Air Vent
EGR Valve Lubricating Oil Piping
Heat Shield
Cylinder Block Accessory
Front Cover
Front Cover Accessory
Idle Gears
Cam Follower Cover
Engine Oil Pan
Flywheel Housing
Flywheel
Engine Mounting
Vibration Damper
Damper
Piston and Connecting Rod
Crank Pulley
Camshaft
Camshaft
Rocker Arm and Housing
ENGINE LUBRICATION SYSTEM
Engine Oil Pump
Engine Oil Filter
Engine Oil Cooler
Engine Oil Cooler Related Parts
Water Drain Valve
ENGINE FUEL SYSTEM
Fuel Supply Pump
Inner Parts, Pump
Inner Parts, Feed Pump
Pump Mounting
Inner Parts, Common Rail
Common Rail Mounting
Fuel Supply Pump Drive
Fuel Injector
Fuel Supply Piping and Lubricating oil Piping
Fuel Priming Pump
Fuel Block Related Parts
Tube
Fuel Return
ENGINE COOLING SYSTEM
Thermostat and Thermostat Housing
Water Temperature Sensor
Cooling Fan Pulley and Drive Belt
Cooling Fan Drive
Water Piping
Water Pump Mounting and Air Vent
ENGINE ELECTRICAL SYSTEM
Inner Parts
Inner Parts (60Amp.)
Freon Compressor
Freon Compressor (60Amp.)
Starting Motor
Inner Parts, Starting Motor
Mounting Parts
Wiring Harness
ENGINE ACCESSORIES AND OTHERS
Engine Controller
ENGINE MARKS AND PLATES
Name Plate and Caution Plate
(For Turkey 3A UNECER96 Certified)
ENGINE RELATED PARTS
Engine Mounting
Engine Related Parts
Inner Parts, Air Cleaner
Air Cleaner Mounting
Coolant Filter
Mounting
Water Filter Head
Related Parts
COOLING SYSTEM
Radiator (For China)
Aftercooler and Condenser
Stay and Air Piping
Reservoir Tank Piping
Oil Cooler Piping
Stay
Stay (For China)
Reservoir Tank
Reservoir Tank
Guard and Shroud
Fan Clutch
FUEL SYSTEM
(Direct Fuel Drain)
(Refueling Pump)
Fuel Piping
Hose
Hose (Direct Fuel Drain)
Bracket and Clip (112)
Bracket and Clip (112) (Refueling Pump)
Bracket and Clip (212)
Inner Parts, Fuel Prefilter
Fuel Prefilter Related Parts
Fuel Filter Head
Fuel Filter Head
EI£CTRICAL SYSTEM
Battery
(Large Capacity Maintenance-free)
Electric Wiring Harness
Starting Wiring Harness Clamp
Main Wiring Harness Clamp (115)
Main Wiring Harness Clamp (115) (1-Additionai Actuator Piping, Accumulator)
Main Wiring Harness Clamp (215)
Main Wiring Harness Clamp (315)
Main Wiring Harness Clamp (415)
Main Wiring Harness Clamp (515)
Battery Cable for Disconnect Switch
Mounting Parts
Blowby Sensor
KOMTRAX Wiring Harness
Vehicle Lamp
Headlamp
Boom
Additional Working Lamp
(Cab Front Full Guard LV1)
(Cab Front Full Guard LV1,LED Lamp)
(Cab Front Full Guard LV2,LED Lamp)
(Cab Front Half Guard)
(Cab Front Half Guard,LED Lamp)
(Cab Front Full Guard LV2)
Additional Rear Working Lamp
(LED Lamp)
Beacon Lamp
Cab (Additional Rear Working Lamp)
Rear
Rear (Additional Rear Working Lamp)
Horn
Travel Alarm
KomVision Camera
Center
Rear
Rearview Camera
(1-Camera)
L.H. (2-Camera)
R.H. (2-Camera)
HYDRAULIC SYSTEM
Hydraulic Tank
Tank (With Catwalk)
Tank
Breather
Bypass Valve
Bypass Valve
Cover
Cover (With Catwalk)
Control Valve
Connecting Parts (1-Additional Actuator Piping, Accumulator)
Connecting Parts (For 1-Service Valve)
Valve Bracket and Sensor (1-Additionai Actuator Piping, Accumulator)
Valve Bracket and Sensor (For1 Servrce ave
Valve Bracket and Sensor (For 1 Servrce Valve)
Hydraulic Pump e ate arts
(Pressure Regulator Valve, 210kg/cm2) .
(Pressure Regulator Valve, 250kg/cm2)
Pilot Filter
Solenoid Valve
Inner Parts (1-Additionai Actuator Piping, Accumulator)
Inner Parts (For 1-Servioe Valve)
Related Parts (i-Additional Actuator Piping, Accumulator)
Related Parts (For 1-Service Valve)
Piping (1-Additionai Actuator Piping, Accumulator)
Piping (For i-Service Valve)
Pressure Switch Block
Slow Return Valve (112)
Related Parts
Slow Return Valve (212)
Bracket
Proportional Pressure Control (PPC) Travel Piping
FRAME AND ITS RELATED PARTS
Revolving Frame
(China Exhaust Information Disclosure System)
(For KomVision)
(With Catwalk,For KomVision)
Boom Foot Pin
OPERATOR'S COMPARTMENT AND CONTROL SYSTEM
Operator's Seat
(Mechanical Suspension Type, Fabric, Tilt)
(Mechanical Suspension Type, Fabric, Tilt, Hi-Back Type)
Seat Belt
(50mm, 2-Point Type, Rigid Type Operator‘s Seat)
(78mm, 2-Point Type, Rigid Type Operator‘s Seat)
Top Guard
(With Catwalk)
Front Guard
(Full Guard LV1)
(Full Guard LV2)
(Half Guard)
Floor Mat
Rain Visor
Roller Shades
Front
Front (With Sunvisor)
Sunvisor
(Ceiling Window)
(Front Window,Ceiiing Window)
Window Washer
Air Conditioner Unit
Receiver Tank
Cooler Piping
Heater Piping Clamp
Cab Body and Vlfindow
Cab Body and Window
Cab Body and Window
Cab Body and Window
Cab Body and Window
Cab Body and Window
Cab Body and Window
Front Window
Front Lower Window
Front Lower Window
Roof Ventilator
Door
Door
Door
Door
Door Lock
Open Lock and Door Catch
Wiper and Room Lamp
Wiper and Room Lamp
Wiper and Room Lamp
Wiper and Room Lamp
Wiper and Room Lamp
Inner Parts, Rubber Antenna
Speaker and Window Washer Hose
Speaker and Window Washer Hose (For Gateway Function Controller)
Roof Cover and Air Intake
KOMTRAX Antenna (KOMTRAX, 4G, China)
KOMTRAX Antenna (KOMTRAX, ORBCOMM)
KOMTRAX Antenna (KOMTRAX, IRIDIUM, Russia)
Gateway Function Controller Antenna
Gateway Function Controller Antenna (Gateway Function Controller, IRIDIUM)
KOMATSU Mark
Cab In Parts, Console Cover, Front, R.H.
Cab In Parts, Monitor Cover
Cab In Parts, Washer Hose Mounting
Cab In Parts, Luggage Plate and Cigarette Lighter
Cab In Parts, Luggage Plate and Cigarette Lighter (For Gateway Function Controller)
Cab In Parts, Air Duct
Cab In Parts, Air Duct and Fresh Air Filter
Cab In Parts, Partition and Recirculation Air Filter
Cab In Parts, Partition and Recirculation Air Filter (For Gateway Function Controller)
Cab In Parts, Partition and Recirculation Air Filter (Vlfith KomVision,For Gateway Function
Controller)
Cab In Parts, Partition and Recirculation Air Filter (\Mth KomVision,For Gateway Function
Controller)
Cab In Parts, Pump Controller and Relay
Cab In Parts, Air Conditioner Controller
Cab In Parts, Air Conditioner Controller (For Gateway Function Controller)
Cab In Parts, Air Conditioner Controller (KOMTRAX, 4G, China)
Cab In Parts, Air Conditioner Controller (With Revolving Lamp Switch,For KO MTRAX, IRIDIUM,
Russia)
Cab In Parts, Main Wiring Harness Clamp
Cab In Parts, Main Wiring Harness Clamp (With KomVision)
Cab In Parts, Rear Cover
Cab In Parts, Rear Cover, With 12V Converter
Cab In Parts, Cab Mounting
Cab In Parts, KomVision Cover
Controller and Monitor (KOMTRAX, ORBCOMM)
Controller and Monitor (KOMTRAX, 46, China)
Controller and Monitor (For Gateway Function Controller)
Controller and Monitor (KOMTRAX, IRIDIUM, Russia)
Controller and Monitor (With KomVision,For Gateway Function Controller)
Controller and Monitor (With KomVision,For Gateway Function Controller, IRIDIU M)
Controller and Monitor (With Revolving Lamp Switch,For KOMTRAX, IRIDIUM, Russia)
Controller and Monitor (With KomWsionFor Gateway Function Controller, IRIDIUM)
Controller and Monitor (KOMTRAX, IRIDIUM, Russia,Provision For Gateway Function Controller)
Floor, Frame
Floor, Frame
Floor, Frame
PPC Valve (114)
PPC Valve (113)
PPC Valve (114)
PPC Valve (114)
PPC Valve (113)
Floor, Travel Control Lever
Floor, Footrest, L.H.
PPC Valve (214)
PPC Valve (214)
PPC Valve (214)
Floor, Footrest, R.H.
Floor, ist Attachment Control
Air Conditioner Unit (313)
Floor, Air Conditioner Mounting and Secondary Engine Stop Switch
Floor, Air Conditioner Piping
Floor, PPC Valve Piping for Travel
Floor, PPC Valve Piping for Work Equipment
Floor, Piping Mounting
Floor, P, T Block (1-Additional Actuator Piping, Accumulator)
Floor, P, T Block
Floor, Seal
Floor Mounting
Proportional Pressure Control (PPC) Piping Clamp
Mode Selection Connectors
GUARDS AND COVERS
Engine Hood
Frame
Side Cover L.H.
(Key Cylinder with Cover)
Side Cover RH.
Frame
Frame
Frame (For KomVision)
Cover and Sheet
Cover and Sheet
Cover and Sheet (Key Cylinder with Cover)
Machine Cab Partition
Machine Cab Frame
(113) (With Catwalk)
(213) (With Catwalk)
(313) (With Catwalk)
Right Side Case
Handrail
(Additional Handrail)
(Additional HandraiI,With Catwalk)
(With Catwalk)
Rearview Mirror L.H.
Rearview Mirror RH.
Rearview Mirror
Counterweight
(Rearview Camera, 2 Set)
Counterweight Mounting
Under Cover
(Refueling Pump)
SWING CIRCLE AND ITS RELATED PARTS
Suing Circle
Swing Machinery and Motor
Inner Parts, Swing Motor (113)
Inner Parts, Swing Motor (213)
Inner Parts, Swing Motor (313)
Swing MJtor Connecting Parts
Swivel Joint
Inner Parts, Swivel Joint
Related Parts
TRAVEL SYSTEM AND ITS RELATED PARTS
Travel Motor and Final Drive
Travel Motor, L.H. (113)
Travel Motor, L.H. (213)
Travel Motor, L.H. (313)
1st and 2nd Carrier, L.H.
Travel Motor, RH. (113)
Travel Motor, RH. (213)
Travel Motor, RH. (313)
1st and 2nd Carrier, RH.
UNDERCARRIAGE
Front Idler and Idler Cushion
Cushion
Cushion (Rustproof Spring LV1)
Cushion (Rustproof Spring LV2)
Track Roller
Carrier Roller
Track Shoe Assembly
(Holed Triple Grouser Shoe, 600mm Width, Grease Sealed Type, 98 Set, T=15.0mm)
(Holed Triple Grouser Shoe, 600mm Width, Grease Sealed Type, 98 Set, T=18.0mm)
(Holed Triple Grouser Shoe, 700mm Width, Grease Sealed Type, 98 Set, T=15.0mm)
(Holed Triple Grouser Shoe, 700mm Width, Grease Sealed Type, 98 Set, T=18.0mm)
(Holed Triple Grouser Shoe, 800mm Width, Grease Sealed Type, 98 Set, T=15.0mm)
(Holed Triple Grouser Shoe, 800mm Width, Grease Sealed Type, 98 Set, T=18.0mm)
(Holed Triple Grouser Shoe, 900mm Width, Grease Sealed Type, 98 Set)
(Round Hoied Double Grouser Shoe, 600mm Width, Grease Sealed Type, 98 Set)
Track Link Assembly
(Supply Only, 98 Set,Grease Sealed Type)
Track Frame
Frame
Grease Bath and Mounting Parts
Track Frame Under Cover
Track Roller Guard
(Full Length)
(Track Roller Guard)
WORK EQUIPMENT
Boom
Boom and Bushing (6670mm, Heavy Duty Type, 1-At1achment, SE)
Boom and Bushing (6670mm, Heavy Duty Type, SE)
Boom and Bushing (7000mm Heavy Duty Type)
Boom and Bushing (7000mm Heavy Duty Type, 1-Attachment)
Top Pin and Bottom Pin
Bucket Cylinder Piping (6670mm, Heavy Duty Type, SE)
Bucket Cylinder Piping (7000mm Heavy Duty Type)
Arm Cylinder Piping (6670mm, Heavy Duty Type, SE)
Arm Cylinder Piping (7000mm Heavy Duty Type)
Blind Parts (112)
Blind Parts
Bucket Less Link (6670mm, Heavy Duty Type, SE)
Bucket Less Link (7000mm Heavy Duty Type)
Working Lamp Wiring Harness
Additional Piping (6670mm, Heavy Duty Type, 1-Attachment, SE)
Additional Piping (7000mm, 1-Attachment)
Clamp
Blind Parts (212)
Boom Cylinder
Inner Parts, Boom Cylinder, L.H.
Inner Parts, Boom Cylinder, RH.
Boom Cylinder Head Pin
Arm Cylinder
Inner Parts, Arm Cylinder (6670mm, Heavy Duty Type, 1-Attachment, SE)
Inner Parts, Arm Cylinder (7000mm Heavy Duty Type, 1-Attachment)
Arm and Pin (2400mm, Heavy Duty Type, 1-Attachment, SE)
Arm and Pin (2400mm, Heavy Duty Type, SE)
Arm and Pin (2900mm, Heavy Duty Type, 1-Attachment, SE)
Arm and Pin (2900mm, Heavy Duty Type, SE)
Arm and Pin (3400mm, Heavy Duty Type)
Arm and Pin (3400mm, Heavy Duty Type, 1-Attachment)
Inner Parts, Bucket Cylinder
Exhaust Manifold
Turbocharger
Inner Parts
Mounting
Heat Shield
Front Cover
Idle Gears
Cam Follower Cover
Engine Oil Pan
Flywheel Housing
Flywheel
Engine Mounting
Vibration Damper
Damper
Crank Pulley
Camshaft
Camshaft
Engine Oil Pump
Engine Oil Filter
Engine Oil Cooler
Water Drain Valve
ENGINE FUEL SYSTEM
Fuel Supply Pump
Inner Parts, Pump
Pump Mounting
Fuel Injector
Fuel Priming Pump
Tube
Fuel Return
Cooling Fan Drive
Water Piping
Inner Parts
Freon Compressor
Starting Motor
Mounting Parts
Wiring Harness
Engine Controller
Engine Mounting
Coolant Filter
Mounting
Water Filter Head
Related Parts
COOLING SYSTEM
Stay and Air Piping
Oil Cooler Piping
Stay
Stay (For China)
Reservoir Tank
Reservoir Tank
Guard and Shroud
Fan Clutch
FUEL SYSTEM
(Direct Fuel Drain)
(Refueling Pump)
Fuel Piping
Hose
Fuel Filter Head
Fuel Filter Head
EI£CTRICAL SYSTEM
Battery
Mounting Parts
Blowby Sensor
Vehicle Lamp
Headlamp
Boom
(LED Lamp)
Beacon Lamp
Rear
Horn
Travel Alarm
KomVision Camera
Center
Rear
Rearview Camera
(1-Camera)
L.H. (2-Camera)
R.H. (2-Camera)
HYDRAULIC SYSTEM
Hydraulic Tank
Tank (With Catwalk)
Tank
Breather
Bypass Valve
Bypass Valve
Cover
Control Valve
Pilot Filter
Solenoid Valve
Related Parts
Bracket
Revolving Frame
(For KomVision)
Boom Foot Pin
Operator's Seat
Seat Belt
Top Guard
(With Catwalk)
Front Guard
(Full Guard LV1)
(Full Guard LV2)
(Half Guard)
Floor Mat
Rain Visor
Roller Shades
Front
Sunvisor
(Ceiling Window)
Window Washer
Receiver Tank
Cooler Piping
Heater Piping Clamp
Cab Body and Window
Cab Body and Window
Cab Body and Window
Cab Body and Window
Cab Body and Window
Cab Body and Window
Front Window
Front Lower Window
Front Lower Window
Roof Ventilator
Door
Door
Door
Door
Door Lock
Wiper and Room Lamp
Wiper and Room Lamp
Wiper and Room Lamp
Wiper and Room Lamp
Wiper and Room Lamp
KOMATSU Mark
Controller)
Controller)
Russia)
Floor, Frame
Floor, Frame
Floor, Frame
PPC Valve (114)
PPC Valve (113)
PPC Valve (114)
PPC Valve (114)
PPC Valve (113)
PPC Valve (214)
PPC Valve (214)
PPC Valve (214)
Floor, P, T Block
Floor, Seal
Floor Mounting
GUARDS AND COVERS
Engine Hood
Frame
Side Cover L.H.
Side Cover RH.
Frame
Frame
Cover and Sheet
Cover and Sheet
Machine Cab Frame
Right Side Case
Handrail
(With Catwalk)
Rearview Mirror RH.
Rearview Mirror
Counterweight
Under Cover
(Refueling Pump)
Suing Circle
Swivel Joint
Related Parts
UNDERCARRIAGE
Cushion
Track Roller
Carrier Roller
Track Shoe Assembly
Track Link Assembly
Track Frame
Frame
Track Roller Guard
(Full Length)
WORK EQUIPMENT
Boom
Blind Parts (112)
Blind Parts
Clamp
Blind Parts (212)
Boom Cylinder
Arm Cylinder
- KOMATSU Fault Codes
