Momed80
150
35,046
Komatsu Hydraulic Excavator PC4000-11 Parts Book 2025
Type of Manual: Parts Book
Model: Komatsu PC4000-11-08289-FS Hydraulic Excavator
Serial Number: 08289
Publication Date: 2025
Number of Pages: 853 Pages
General View – Shovel Bullclam Attachment
General View – Superstructure
General View – Undercarriage
General View – Equipment Shovel Bullclam
Machine – Maintenance Parts
Superstructure
Pin – Boom Counterweight
Rails And Platforms
Emergency Ladder – Cab
Hydraulic Cylinder With Accumulator
Hydraulic Cylinder
Engine Housing Covering
Emergency Ladder – Machine Covering
Hydraulic Cylinder
Hydraulic Cylinder
Power Frame – Gratings
Ladder Stopper / Way Up
Winch Installation
Slew Ring Arrangement
Slew Ring Protection
Slew Gear Arrangement
Hydraulic Motor
Slew Brake Valve
Power Frame Arrangement
Drive Assembly – Mounting
Engine Mounting
Engine Mounting
Drive Assembly
Cold Starting System – Engine
Lines For Feed Pump – Engine Oil
Pump Mounting
Pump Distributor Gear
Radiator – Fan Drive – Fan Motor
Hydraulic Motor
Coolant Water Lines
Engine Air Intake
Air Cleaner
Exhaust System – Def Tank
Fuel Cooler
Fuel Cooler
Fuel Lines
Main Oil Tank – Mounting
Main Oil Tank
Return Oil Filter
Aeration Filter
Pressure Relief Valve – Pre-Controlled
Leakage Oil Filter
Suction Tank
Transfusing Pump – Mounting
Gear Pump Unit
Main Pumps Suction Lines
Oil Cooler System
Oil Cooler Fan Drive
Hydraulic Motor
Oil Cooler Hose Assembly
Lines – Fan Motors – Fan Pump (Oil Cooler)
Lines – Fan Motors – Fan Pump (Radiator)
Hydraulic Lines – Fuel Cooler
Return Oil Pipe – Main Pump
Pressure Lines – Main Pumps
Pressure Lines – Gear Oil And Pilot Oil Pump
Control And Filter Plate
Hydraulic Filter
Hydraulic Filter
Hydraulic Filter
Pressure Accumulator
Valve Cartridge Block
Valve – Pilot Oil Block – Drive
Valve – Travelling Gear
Valve – Slew Gear
Valve – Ladder 60 Bar
Valve – Refueling 45 Bar
Control And Filter Plate Piping
Tank Lines – Control And Filter Plate
Remote Control Arrangement
Control Plate
Control Unit – Mounting Fs
Control Block
Control Block
Control Block
Control Block
Valve Control Block (Bbe)
Anti-Cavitation Valve
Bleed-Off Valve – Pre-Controlled
Pressure Lines – Control Blocks – Rotary Joint
Hydraulic Lines – Rotary Joint
Pressure Lines – Control Blocks – Manifold
Manifold Valve Piping (Fs)
Throttle Check Valve
Return Lines – Manifold Fs
Return Lines – Control Block – Tank
Pressure Lines – Slew Gear
Lines – Slew Gear
Hoses Assembly – Manifold – Boom
Float Position
Countersunk Valve
Preliminary Catalogue – Do Not Order
Operator's Cab
Cab Support
Operator's Cab Arrangement
Operator's Cab Part 1
Operator's Cab Part 2
Operator's Cab – Glazing Front Window Glued
Windscreen Washing Assembly
Ventilation System Arrangement
Ventilation System
Operator's Cab – Insulation
Co-Driver Seat
Komvision Camera System
Komvision Camera System – Cab
Komvision Camera System – Cab Support Assembly
Komvision Camera – Fuel Tank Ladder
Komvision Camera System – Engine Housing Counterweight
Komvision Camera System – Oil Tank Oil Cooler
Provision
Cabin – Operation Elements – Location 20
Operator's Seat
Cabin – Electric Harnesses
Air Conditioning System – Heater
Cab Heater Arrangement
Electric Heater (Collectorless)
Mounting – Additional Heating System
Water Heating
Air Conditioning Arrangement
Air Conditioning Unit
Air Condition Compressor Drive
Air Condition Arrangement – Cabin
Compressor Mounting – Additional Air Condition
E-Parts – Auxiliary Air Conditioner
Lighting Equipment – Machine House And Counterweight
Lighting Equipment – Stage
Additional Lighting Equipment
Batteries With Cables
Electric – Cab Support
Horn And Illumination
Switch Framing – Cab Support – Location 11
Controller – Cab Support – Location 14
Cables – Oil Tank And Switch – Transfusing Pump
Cables – Tank Sensor
Electric Parts – Ladder
Electric Parts – Air Intake
Electric Parts – Exhaust System
Electric Parts – Movement Signal / Motor Switch Off / Warning System Assembly
Cables – Pump Distributor Gear
Cables – Control Blocks – Hp Filter
Cables – Control And Filter Plate
Cables – Engine And Transmitter
Data Transfer – Orb Command Gps
Data Transfer – Iridium And Gps
Lubrication And Refueling Equipment
Refueling Equipment
Hydraulic Cylinder
Electric Parts – Refueling
Lube Pump Station Arrangement
Pressure Filter
Lube Pump Station – Filling Connection
Lube Pump
Lube Distributor – Slew Ring
Metering Valve
Electric Parts – Lube System
Gear Greasing By Pinion
Metering Valve
Boom – Central Lubrication (Fs)
Metering Valve
Metering Valve
Stick – Central Lubrication
Metering Valve
Metering Valve
Central Lubrication – Bullclam Standard (Br4000)
Metering Valve
Temperature Conditioning
Cables – Temperature Conditioning
Switch Framing – Location 12
Temperature Conditioning – Water And Hydraulic Oil
Water Heating
Switch Box
Heater 3.5 Kw
Water Heating
Undercarriage
Track Group – Idler Side Rh + Lh
Hydraulic Tensioner
Bottom Roller
Top Roller
Track Group Drive Sprocket Side Rh And Lh
Travelling Gear
Hydraulic Motor
Drive Sprocket
Protecting Cage
Drive Motor Protection
Track Group 1200 Mm
Rotary Joint
Pressure Lines – Drive Motor – Rotary Joint
Drive Motor Brake Valve – Leakage Lines
Travelling Gear Brake Valve
Piping – Brake
Track Adjusting
Valve Block – Hydraulic Track Adjusting
Bullclam Bucket Equipment
Bullclam Bucket Boom 7.15 M
Ladder – Bullclam Bucket Boom 7.15 M
Connector – Boom Cylinder
Boom Cylinder
Rod Protection – Boom Cylinder
Bullclam Bucket Stick 4.9 M
Piping – Stick Cylinder (Fs)
Stick Cylinder
Rod Protection – Stick Cylinder
Bucket Cylinder
Pin Sealing – Bullclam Bucket
Bullclam Bucket 22 M³
Connector – Clam Cylinder Rh And Lh
Clam Cylinder
Tools And Accessories
O-Ring Kit
Electro Kit – Deutsch
Union Set
* Variations From Page
