Komatsu Hydraulic Excavator PC4000-11 Parts Book 2024
Type of Manual: Parts Book
Model: Komatsu PC4000-11-08275-FS Hydraulic Excavator
Serial Number: 08275-08275
Publication Date: 2024
Number of Pages: 844 Pages
General View
General View – Shovel Bullclam Attachment
General View – Superstructure
General View – Undercarriage
General View – Equipment Shovel Bullclam
Machine – Maintenance Parts
Superstructure
Pin – Boom Counterweight
Rails And Platforms
Emergency Ladder – Cab
Hydraulic Cylinder With Accumulator
Hydraulic Cylinder
Engine Housing Covering
Emergency Ladder – Machine Covering
Hydraulic Cylinder
Hydraulic Cylinder
Power Frame – Gratings
Ladder Stopper / Way Up
Winch Installation
Slew Ring Arrangement
Slew Ring Protection
Slew Gear Arrangement
Hydraulic Motor
Slew Brake Valve
Power Frame Arrangement
Drive Assembly – Mounting
Engine Mounting
Engine Mounting
Drive Assembly
Cold Starting System – Cu Engine
Lines For Feed Pump – Engine Oil
Pump Mounting
Pump Distributor Gear
Radiator Arrangement
Radiator – Fan Drive – Fan Motor
Hydraulic Motor
Coolant Water Lines
Engine Air Intake
Air Cleaner
Exhaust System – Def Tank
Def Tank
Fuel Cooler
Fuel Cooler
Fuel Lines
Hydraulic
Main Oil Tank – Mounting
Main Oil Tank
Return Oil Filter
Aeration Filter
Pressure Relief Valve – Pre-Controlled
Leakage Oil Filter
Suction Tank
Transfusing Pump – Mounting
Gear Pump Unit
Main Pumps Suction Lines
Oil Cooler System
Oil Cooler Fan Drive
Hydraulic Motor
Oil Cooler Hose Assembly
Lines – Fan Motors – Fan Pump (Oil Cooler)
Lines – Fan Motors – Fan Pump (Radiator)
Hydraulic Lines – Fuel Cooler
Return Oil Pipe – Main Pump
Pressure Lines – Main Pumps
Pressure Lines – Gear Oil And Pilot Oil Pump
Control And Filter Plate
Hydraulic Filter
Hydraulic Filter
Hydraulic Filter
Pressure Accumulator
Valve Cartridge Block
Base Plate
Valve – Pilot Oil Block Drive
Valve – Travelling Gear
Valve – Slew Gear
Valve – Ladder 60 Bar
Valve – Refueling 45 Bar
Control And Filter Plate Piping
Tank Lines – Control And Filter Plate
Remote Control Arrangement
Control Plate
Control Unit – Mounting Fs
Control Block
Control Block
Control Block
Control Block
Valve Control Block (Bbe)
Anti-Cavitation Valve
Bleed-Off Valve – Pre-Controlled
Pressure Lines – Control Blocks – Rotary Joint
Hydraulic Lines – Rotary Joint
Pressure Lines – Control Blocks – Manifold
Manifold Valve Piping (Fs)
Throttle Check Valve
Return Lines – Manifold Fs
Return Lines – Control Block – Tank
Pressure Lines – Slew Gear
Lines – Slew Gear
Hoses Assembly – Manifold – Boom
Float Position
Countersunk Valve
Operator's Cab
Cab Support
Operator's Cab Arrangement
Operator's Cab Part 1
Operator's Cab Part 2
Operator's Cab – Glazing Front Window Glued
Windscreen Washing Assembly
Ventilation System Arrangement
Ventilation System
Operator's Cab – Insulation
Co-Driver Seat
Komvision Camera System
Komvision Camera System – Cab
Komvision Camera System – Cab Support Assembly
Komvision Camera – Fuel Tank Ladder
Komvision Camera System – Engine Housing Counterweight
Komvision Camera System – Oil Tank Oil Cooler
Cabin – Operation Elements – Location 20
Manipulator
Rod Protection – Boom Cylinder
Bullclam Bucket Stick 4.9 M
Piping – Stick Cylinder (Fs)
Stick Cylinder
Rod Protection – Stick Cylinder
Bucket Cylinder
Pin Sealing – Bullclam Bucket
Bullclam Bucket 22 M³
Connector – Clam Cylinder Rh And Lh
Clam Cylinder
Wear And Tear Parts – Bullclam Bucket Wall 22 + 24 St
Wear And Tear Parts – Bucket Clam 22.0 M³
Bullclam Bucket 28 Cbm
Clam Cylinder
Wear And Tear Parts – Bucket Clam 29.0 Wp2
Tools And Accessories
O-Ring Kit
Electro Kit – Deutsch
* Variations From Page
General View
Superstructure
Rails And Platforms
Hydraulic Cylinder
Hydraulic Cylinder
Hydraulic Cylinder
Winch Installation
Hydraulic Motor
Slew Brake Valve
Engine Mounting
Engine Mounting
Drive Assembly
Pump Mounting
Hydraulic Motor
Coolant Water Lines
Engine Air Intake
Air Cleaner
Def Tank
Fuel Cooler
Fuel Cooler
Fuel Lines
Hydraulic
Main Oil Tank
Return Oil Filter
Aeration Filter
Leakage Oil Filter
Suction Tank
Gear Pump Unit
Oil Cooler System
Hydraulic Motor
Hydraulic Filter
Hydraulic Filter
Hydraulic Filter
Base Plate
Valve – Slew Gear
Control Plate
Control Block
Control Block
Control Block
Control Block
Lines – Slew Gear
Float Position
Countersunk Valve
Operator's Cab
Cab Support
Ventilation System
Co-Driver Seat
Manipulator
Stick Cylinder
Bucket Cylinder
Clam Cylinder
Clam Cylinder
O-Ring Kit
- KOMATSU Fault Codes
