Komatsu Hydraulic Excavator PC200LL-8 PC220LL-8 Shop Manual CEBM001505
Type of Manual: Shop Manual
Model: Komatsu PC200LL-8 PC220LL-8 Hydraulic Excavator
Engine 6D107E-1
Serial Number: A87001 and up
Form Number: CEBM001505
Publication Date: 2012
Number of Pages: 1316 Pages
Cover Pc200ll/220ll-8
Contents
00 Foreword
Safety
General
How To Read The Shop Manual
Hoisting Instructions
Handung Electric Equipment And Hydrauuc Components
Push Pull Coupler
Explanation Of Maintenance Standard Terms
Standard Tightening Torque
Electric Wire Code
Conversion Tables
Coating Materials
01 General
Specifications
Weight Table
Fuel, Coolant, And Lubricants
10 Structure, Function And Maintenance Standard
Engine And Cooling System
Power Train
Final Drive
Swing Machinery
Swing Circle
Undercarriage And Frame
Track And Carrier Roller
Track Shoes
Hydrauuc System
Work Equipment
Cab And Its Attachments
Electrical Control System
Monitor System
Sensors
Komtrax Terminal System
20 Standard Value Tables
Standard Service Value Table
Machine Posture
30 Testing And Adjusting
Tools For Testing, Adjusting, And Troubleshooting
Engine Components
Air Conditioner Compressor Belt Tension
Fan Belt
Swing Circle Bearing Clearance
Track Chain Tension
Oil Pressure In Work Equipment, Swing, And Travel Circuits
Control Circuit Basic Pressure
Oil Pressure In Pump Pc Control Circuit
Oil Pressure In Pump Ls Control Circuit
Measuring
Adjusting
Solenoid Valve Output Pressure
Attachment Solenoid Valve Output Pressure
Ppc Valve Output Pressure
Soft Swing Adjustments (If Equipped)
Play Of Work Equipment And Swing Ppc Valves
Hydrauuc Drift Of Work Equipment
Residual Pressure From Hydraulic Circuit
Oil Leakage
Bleeding Air From Each Part
Adjusting Mirrors
Special Functions Of Machine Monitor
Handling Voltage Circuit Of Engine Controller
Preparation For Electrical System Troubleshooting
Procedure For Testing Diodes
Pm Clinic Service
40 Troubleshooting
Electric Wire Code
How To Read Electric Wire Code
Connection Table For Connector Pin Numbers
T-Adapter Table
Failure Codes (Display Codes)
Electrical System (E-Mode)
Hydrauuc And Mechanical System (H-Mode)
50 Disassembly And Assembly
How To Read This Manual
Special Tools List
Sketches Of Special Tools
Connector Repair Procedures
Precautions During Operation
List Of Adhesives
Power Train
Workequipment
60 Air Conditioner
Structure And Function
Troubleshooting
90 Diagrams And Drawings
Hydraulic Diagrams And Drawings
Electrical Diagrams And Drawings
