Momed80
150
35,046
Komatsu Hydraulic Excavator PC200-11 Parts Book ZEN00043-00 2023
Type of Manual: Parts Book
Model: Komatsu Hydraulic Excavator
PC200-11 508310 and up
SAA6D107E-3C 26756739 and up
Part Number: ZEN00043-00
Publication Date: 2023
Number of Pages: 1219 Pages
Cylinder Head Cover
Lifting Bracket Mounting
Lifting Bracket
Air Intake Port Cover
Air Intake Connector
Exhaust Manifold Mounting
Exhaust Manifold
Variable Geometry Turbocharger (VGT) Oil Piping
Heat Shield
Coolant Piping Related Parts
Coolant Adapter
Variable Geometry Turbocharger (VGT) Related Parts
Hydraulic Pump Piping
Filter Remote Related Parts
Engine Oil Pan
Engine Oil Pan Drain
Front Gear Cover
Dust Seal
Rocker Arm
Tappet
Flywheel Housing
Flywheel
Flywheel Mounting
Engine Oil Level Sensor
Vibration Damper
Damper
Piston and Connecting Rod
Breather Related Parts
Oil Level Gauge
Rear Gear Housing
Plug
Coolant Heater Related Parts
Parts Performance
Camshaft (For Regulation Tier4 Final)
Camshaft (For Stage5, Regulation Tier4 Final Step2)
ENGINE LUBRICATION SYSTEM
Lubrication Oil Pump
Engine Oil Filter and Piping
Engine Oil Cooler
Engine Coolant Vent
ENGINE FUEL SYSTEM
Fuel System Cover
Fuel System Related Parts
Fuel Supply Pump
Fuel Filter Piping
Fuel Piping
Fuel Filter Cartridge
Fuel Drain Piping
Injector (For Regulation Tier4 Final)
Injector (For Stage5, Regulation Tier4 Final Step2)
ENGINE COOLING SYSTEM
Thermostat
Water Pump Mounting
Cooling Fan Belt
(For 90Amp. Alternator)
(For 60Amp. Alternator)
Cooling Fan Belt Tensioner
Cooling Fan Drive Pulley
Water Outlet Connector
Water Inlet Connector
ENGINE ELECTRICAL SYSTEM
Inner Parts, Alternator (60Amp.)
Inner Parts, Alternator (90Amp.)
Mounting (90Amp.)
Mounting (60Amp.)
Starting Motor
Inner Parts, Starting Motor (4.5KW)
Inner Parts, Starting Motor (5.5KW)
Starting Motor Mounting
(5.5KW)
(4.5KW)
Wiring Harness
Electrical Parts
Bolt
Wiring Harness Cover
Wiring Harness Clip
ENGINE ACCESSORIES AND OTHERS
Engine Controller
Connector (For Regulation Tier4 Final,Stage5, Regulation Tier4 Final Step2)
Common Rail (For Regulation Tier4 Final,Stage5, Regulation Tier4 Final Step2)
Engine Control Module
FIELD REPAIR SERVICE PARTS
Repair Service Parts
ENGINE RELATED PARTS
Engine Mounting
Air Cleaner
Inner Parts, Air Cleaner
Air Cleaner Mounting
Air Cleaner Mounting (Dust-proof Specification)
Air Cleaner Mounting (With Pre-cleaner)
Komatsu Closed Crankcase Ventilation (KCCV) Piping
Exhaust Pipe
Bracket
SCR Assembly
Komatsu Diesel Particulate Filter (KDPF)
Komatsu Diesel Particulate Filter (KDPF) Mounting
DEF Mixing Tube
Guard
Guard (Dust-proof Specification)
Sensor and Mounting
Drain Piping
Tube and Bracket
Tube and Bracket (Dust-proof Specification)
COOLING SYSTEM
Aftercooler and Shroud
Fuel Cooler and Condenser
Aftercooler and Radiator Piping
Fan Guard
Oil Cooler Piping
Cover
Sensor
Reservoir Tank
Fan Clutch
FUEL SYSTEM
Piping
Bracket and Clip
Inner Parts, Fuel Prefilter
Fuel Prefilter Mounting
Remote Drain
DEF Tank
DEF Tank Frame
Supply Module Mounting
Tank and sensor
Suction Tube
DEF Piping
Dosing Module Coolant Hose
DEF Tank Coolant Piping
DEF Pressure Hose
ELECTRICAL SYSTEM
Battery
(Large Capacity)
Electric Wiring Harness
Starting Wiring Harness Clamp
Main Wiring Harness Clamp (1/4)
Main Wiring Harness Clamp (2/4)
Main Wiring Harness Clamp (3/4)
Main Wiring Harness Clamp (3/4) (LED Lamp)
Main Wiring Harness Clamp (4/4)
Engine Wiring Harness (1/2) (4.5KW Starting Motor)
Engine Wiring Harness (1/2) (4.5KW Starting Motor,90Amp. Alternator)
Engine Wiring Harness (1/2) (5.5KW Starting Motor)
Engine Wiring Harness (2/2)
Engine Wiring Harness (2/2) (Roller Shades, Rear)
Working Lamp
Working Lamp (LED Lamp)
Additional Working Lamp
(Cab Front Full Guard LV1)
(Cab Front Full Guard LV1, Top Guard LV2)
(Cab Front Full Guard LV2)
(Cab Front Full Guard LV2, Pin Type)
(LED Lamp)
(LED Lamp,Cab Front Full Guard LV2)
(LED Lamp,Cab Front Full Guard LV2, Pin Type)
Additional Rear Working Lamp
(LED Lamp,Roller Shades, Rear)
(For Additional Counterweight)
Beacon Lamp
(Amber Color Warning Beacon, ISO)
(Green Color Warning Beacon, Human Detection Warning System)
(1/2) (Amber Color Warning Beacon, ISO,Green Color Warning Beacon, Human Detection
Warning System)
(2/2) (Amber Color Warning Beacon, ISO,Green Color Warning Beacon, Human Detection
Horn
Travel Alarm
KomVision Camera
Center
Center (For Additional Counterweight)
L.H.
R.H.
HYDRAULIC SYSTEM
Hydraulic Tank
Tank
Tank (Arm Crane)
Tank (Arm Crane, Breaker)
Tank (1-Additional Actuator Piping, Tool Control)
Tank (1-Additional Actuator Piping, Accumulator)
Breather
Breather (Arm Crane)
Breather (Arm Crane, Breaker)
Breather (1-Additional Actuator Piping, Tool Control)
Breather (1-Additional Actuator Piping, Accumulator)
Block (1-Additional Actuator Piping, Tool Control)
Control Valve
6-Spool (1/18)
6-Spool (2/18)
6-Spool (2/18) (Arm Crane)
6-Spool (3/18)
6-Spool (3/18) (Arm Crane)
6-Spool (4/18)
6-Spool (4/18) (Arm Crane)
6-Spool (5/18)
6-Spool (5/18) (Arm Crane)
6-Spool (6/18)
6-Spool (6/18) (Arm Crane)
6-Spool (7/18)
6-Spool (8/18)
6-Spool (9/18)
6-Spool (10/18)
6-Spool (10/18) (Arm Crane)
6-Spool (11/18)
6-Spool (12/18)
6-Spool (12/18) (Arm Crane)
6-Spool (13/18)
6-Spool (14/18)
6-Spool (14/18) (Arm Crane)
6-Spool (15/18)
6-Spool (15/18) (Arm Crane)
6-Spool (16/18)
6-Spool (16/18) (Arm Crane)
6-Spool (17/18)
6-Spool (17/18) (Arm Crane)
6-Spool (18/18)
6-Spool (18/18) (Arm Crane)
7-Spool (1/21)
7-Spool (2/21)
7-Spool (2/21) (Arm Crane, Breaker)
7-Spool (3/21)
7-Spool (3/21) (Arm Crane, Breaker)
7-Spool (4/21)
7-Spool (4/21) (Arm Crane, Breaker)
7-Spool (5/21)
7-Spool (5/21) (Arm Crane, Breaker)
7-Spool (6/21)
7-Spool (6/21) (Arm Crane, Breaker)
7-Spool (7/21)
7-Spool (8/21)
7-Spool (9/21)
7-Spool (10/21)
7-Spool (10/21) (Arm Crane, Breaker)
7-Spool (10/21) (1-Additional Actuator Piping, Tool Control)
7-Spool (11/21)
7-Spool (12/21)
7-Spool (12/21) (Arm Crane, Breaker)
7-Spool (12/21) (1-Additional Actuator Piping, Tool Control)
7-Spool (13/21)
7-Spool (14/21)
7-Spool (14/21) (Arm Crane, Breaker)
7-Spool (14/21) (1-Additional Actuator Piping, Tool Control)
7-Spool (15/21)
7-Spool (15/21) (Arm Crane, Breaker)
7-Spool (15/21) (1-Additional Actuator Piping, Tool Control)
7-Spool (16/21)
7-Spool (17/21)
7-Spool (17/21) (Arm Crane, Breaker)
7-Spool (18/21)
7-Spool (19/21)
7-Spool (20/21)
7-Spool (20/21) (1-Additional Actuator Piping, Tool Control)
7-Spool (21/21)
7-Spool (21/21) (Arm Crane, Breaker)
7-Spool (21/21) (1-Additional Actuator Piping, Tool Control)
8-Spool (1/23)
8-Spool (2/23)
8-Spool (3/23)
8-Spool (4/23)
8-Spool (5/23)
8-Spool (6/23)
8-Spool (7/23)
8-Spool (8/23)
8-Spool (9/23)
8-Spool (10/23)
8-Spool (11/23)
8-Spool (12/23)
8-Spool (13/23)
8-Spool (14/23)
8-Spool (15/23)
8-Spool (16/23)
8-Spool (17/23)
8-Spool (18/23)
8-Spool (19/23)
8-Spool (20/23)
8-Spool (21/23)
8-Spool (22/23)
8-Spool (23/23)
Connecting Parts (1/2)
Connecting Parts (1/2) (Arm Crane)
Connecting Parts (1/2) (2-Additional Actuator Piping, Accumulator)
Slow Return Valve
Connecting Parts (2/2)
Connecting Parts (2/2) (1-Service Valve)
Connecting Parts (2/2) (1-Additional Actuator Piping, Tool Control)
Connecting Parts (2/2) (1-Additional Actuator Piping, Accumulator)
Connecting Parts (2/2) (2-Additional Actuator Piping, Accumulator)
Valve Bracket and Sensor
Valve Bracket and Sensor (Arm Crane)
Valve Bracket and Sensor (Arm Crane, Breaker)
Valve Bracket and Sensor (1-Service Valve)
Valve Bracket and Sensor (1-Additional Actuator Piping, Tool Control)
Valve Bracket and Sensor (1-Additional Actuator Piping, Accumulator)
Valve Bracket and Sensor (2-Additional Actuator Piping, Accumulator)
Piston Pump (1/12)
Piston Pump (2/12)
Piston Pump (3/12)
Piston Pump (4/12)
Piston Pump (5/12)
Piston Pump (6/12)
Piston Pump (7/12)
Piston Pump (8/12)
Piston Pump (9/12)
Piston Pump (10/12)
Piston Pump (11/12)
Piston Pump (12/12)
Hydraulic Pump Related Parts
Suction Piping
Delivery Piping
Return Piping
Boom Piping
(Arm Crane)
Arm and Bucket Piping
Attachment Piping
Piping, L.H. (1-Additional Actuator Piping, Tool Control)
Piping, L.H. (1-Additional Actuator Piping, Accumulator)
Piping, L.H. (1-Additional Actuator Piping, Accumulator,Nippon Pneumatic Breaker Kit)
Selector Valve
Piping, R.H. (1-Additional Actuator Piping, Tool Control)
Pilot Filter
Return Piping (1/2) (1-Additional Actuator Piping, Tool Control)
Return Piping (2/2) (1-Additional Actuator Piping, Tool Control)
Wiring Harness (1-Additional Actuator Piping, Tool Control)
Piping, R.H. (1-Additional Actuator Piping, Accumulator)
Piping, R.H. (1-Additional Actuator Piping, Accumulator,Nippon Pneumatic Breaker Kit)
Multi Control Pattern Unit
Selector Valve (Control Pattern Change Over Valve)
Selector Valve (2-Way)
Connecting Parts (Control Pattern Change Over Valve)
Connecting Parts (2-Way)
Piping (Control Pattern Change Over Valve)
Piping (2-Way)
Travel Piping
Swing Piping
LS Piping
Solenoid Valve
Related Parts
Related Parts (1-Additional Actuator Piping)
Piping (1-Service Valve)
Piping (1/2) (1-Additional Actuator Piping, Accumulator)
Piping (1/2) (2-Additional Actuator Piping, Accumulator)
Mounting
Mounting (1-Service Valve)
Mounting (1-Additional Actuator Piping, Tool Control)
Mounting (1-Additional Actuator Piping, Accumulator)
Mounting (2-Additional Actuator Piping, Accumulator)
Piping (2/2) (1-Additional Actuator Piping, Accumulator)
Piping (2/2) (2-Additional Actuator Piping, Accumulator)
Pressure Switch Block
Block
Bracket (Arm Crane)
Proportional Pressure Control (PPC) Main Piping
FRAME AND ITS RELATED PARTS
Revolving Frame
Boom Foot Pin
OPERATOR'S COMPARTMENT AND CONTROL SYSTEM
Operator's Seat
(Rigid Type, Leather, Tilt)
(Rigid Type, Fabric, Tilt)
Seat Belt
Top Guard
Front Guard
(Half Guard)
(Full Guard LV1)
(Full Guard LV2)
Floor Mat
Rain Visor
Roller Shades
Front
Front (With Sunvisor)
Front (Roller Shades, Rear,With Sunvisor)
Sunvisor
Upper
Rear
Window Washer
Air Conditioner
Compressor
Compressor Mounting
Cooler Piping
Heater Piping
V-Belt
Air Conditioner Condenser Unit (Dust-proof Specification)
High-efficiency Air Conditioner Recirculation Air Filter
Fire Extinguisher
Cab Body and Window
Cab Body and Window (Roller Shades, Front)
Cab Body and Window (For Gateway Function Controller)
Front Window
Front Window (Roller Shades, Front)
Front Window (For Roller Shades, Front)
Front Lower Window
Roof Ventilator
Door
Open Lock and Door Catch
Wiper and Room Lamp
Inner Parts, Rubber Antenna
Speaker and Window Washer Hose
Speaker and Window Washer Hose (For Gateway Function Controller)
Roof Cover, Hanger, Drink Holder and Air Intake
Roof Cover, Hanger, Drink Holder and Air Intake (For Roller Shades, Front)
Grip
KOMTRAX Antenna
KOMTRAX Antenna (For KOMTRAX, 4G)
Gateway Function Controller Antenna
KOMATSU Mark
Cab In Parts, Console Cover, Front, R.H.
Cab In Parts, Monitor Cover
Cab In Parts, Washer Hose Mounting
Cab In Parts, Luggage Plate and Cigarette Lighter
Cab In Parts, Luggage Plate and Cigarette Lighter (For KOMTRAX, 3G, Except North America)
Cab In Parts, Air Duct
Cab In Parts, Air Duct and Fresh Air Filter
Cab In Parts, Air Duct and Fresh Air Filter (For KOMTRAX, 3G, Except North America)
Cab In Parts, Partition and Recirculation Air Filter
Cab In Parts, Partition and Recirculation Air Filter (For KOMTRAX, 3G, Except North America)
Cab In Parts, Pump Controller and Relay
Cab In Parts, Pump Controller and Relay (For KOMTRAX, 4G)
Cab In Parts, Pump Controller and Relay (Roller Shades, Rear)
Cab In Parts, Pump Controller and Relay (Dust-proof Specification)
Cab In Parts, Pump Controller and Relay (High Speed Cooling Fan)
Cab In Parts, Air Conditioner Controller
Cab In Parts, Air Conditioner Controller (For KOMTRAX, 4G)
Cab In Parts, Air Conditioner Controller (For Gateway Function Controller)
Cab In Parts, Main Wiring Harness Clamp
Cab In Parts, Main Wiring Harness Clamp (AM-FM Radio, Bluetooth®)
Cab In Parts, Main Wiring Harness Clamp (For Gateway Function Controller)
Cab In Parts, Rear Cover
Cab In Parts, Rear Cover (Power Supply, 12volt)
Cab In Parts, Cab Mounting
Cab In Parts, Rear Cover, With 12V Converter
Cab In Parts, Rear Cover, With 12V Converter (For KOMTRAX, 3G, Except North America)
Cab In Parts, KomVision Cover
Cab In Parts, Monitor and Controller
Cab In Parts, Monitor and Controller (For KOMTRAX, 4G)
Cab In Parts, Monitor and Controller (For Gateway Function Controller)
Cab In Parts, Monitor and Controller (For KomVision, Human Detection Warning System)
Cab In Parts, Monitor and Controller (Roller Shades, Rear,For KomVision, Human Detection
Floor, Frame
PPC Valve
PPC Valve (1/3) (For Travel)
Floor, Travel Control Lever
PPC Valve (2/5)
Floor, 2nd Attachment Control
Floor, Footrest, L.H.
Floor, Footrest, R.H.
PPC Valve (2/4)
Floor, 1st Attachment Control
Floor, Base
Floor, Base (Operator's Seat, Rigid Type, Fabric, Tilt)
Floor, Base (Operator's Seat, Mechanical Suspension Type, Fabric, Tilt)
Floor, Wiring Harness
Floor, Wiring Harness (For KOMTRAX, 4G)
Floor, Wiring Harness (Dust-proof Specification)
Floor, Wiring Harness (For Gateway Function Controller)
Floor, Wiring Harness (For KOMTRAX, 3G, Except North America)
Floor, Wiring Harness (Roller Shades, Rear,For Gateway Function Controller)
Floor, Battery Cable
Floor, KomVision Harness
Floor, Wiring Harness Clamp and Ground
Floor, Wiring Harness Clamp and Ground (For KOMTRAX, 3G, Except North America)
Floor, Window Washer Hose
Floor, Work Equipment Control Lever, L.H.
PPC Valve for Work Equipment, L.H.
PPC Valve (2/3) (L.H.)
PPC Valve (2/3)
Floor, PPC Valve Mounting for Work Equipment, L.H.
Floor, Console, L.H.
Floor, Radio and Work Equipment Lock Lever
Floor, Radio and Work Equipment Lock Lever (AM-FM Radio, Bluetooth®)
Floor, Radio and Work Equipment Lock Lever (AM-FM Radio, Bluetooth®,KOMTRAX, 4G)
Floor, Radio and Work Equipment Lock Lever (AM-FM Radio, Bluetooth®,For KOMTRAX, 4G)
Floor, Radio and Work Equipment Lock Lever (AM-FM Radio, Bluetooth®,Roller Shades, Rear)
Floor, Armrest, L.H.
Floor, Work Equipment Control Lever, R.H.
PPC Valve for Work Equipment, R.H.
PPC Valve (3/3) (R.H.)
Floor, PPC Valve Mounting for Work Equipment, R.H.
Floor, Console, R.H.
Floor, Console, R.H. (Master Key)
Floor, Console, R.H. (Roller Shades, Rear)
Floor, Console, R.H. (High Speed Cooling Fan)
Floor, Console, R.H. (Master Key,Roller Shades, Rear)
Floor, Console, R.H. (Amber Color Warning Beacon, ISO)
Floor, Console, R.H. (Amber Color Warning Beacon, ISO,Roller Shades, Rear)
Floor, Armrest, R.H.
Air Conditioner Unit (1/3)
Air Conditioner Unit (2/3)
Air Conditioner Unit (3/3)
Floor, Air Conditioner Mounting and Secondary Engine Stop Switch
Floor, Air Conditioner Piping
Floor, Air Conditioner Piping (Dust-proof Specification)
Floor, PPC Valve Piping for Travel
Floor, PPC Valve Piping for Work Equipment
Floor, Piping Mounting
Floor, P, T Block
Floor, P, T Block (1-Additional Actuator Piping, Accumulator)
Floor, P, T Block (2-Additional Actuator Piping, Accumulator)
Floor, P, T Block (With 2-Additional Actuator Piping, Accumulator)
Floor, P, T Block (1-Additional Actuator Piping, Accumulator,For KOMTRAX, 3G, Except North
America)
Floor, P, T Block (2-Additional Actuator Piping, Accumulator,For KOMTRAX, 3G, Except North
Floor, Seal
Door Lock
PPC Valve for 1-Attachment
Floor Mounting
Switch
GUARDS AND COVERS
Engine Hood
(Dust-proof Net, Intake Gas and Exhaust Gas)
(Dust-proof Net, Intake Gas and Exhaust Gas,With Additional Rear Working Lamp)
Net
Net (Dust-proof Net, Intake Gas and Exhaust Gas)
Net (Dust-proof Net, Intake Gas and Exhaust Gas,With Additional Rear Working Lamp)
Frame
Side Cover L.H.
Door (With Pre-cleaner)
Door (Dust-proof Specification)
Frame (Dust-proof Specification)
Frame (Additional Rear Working Lamp)
Cover and Duct
Cover and Duct (With Pre-cleaner)
Inner Parts, Pre-cleaner
Side Cover R.H.
Partition
Air Cleaner Side
Air Cleaner Side (Control Pattern Change Over Valve)
Engine Side
Engine Side (Control Pattern Change Over Valve)
Upper Cover
Net (Dust-proof Specification)
Right Side Case
DEF Tank Cover
Handrail
(With Pre-cleaner)
Rearview Mirror L.H.
Rearview Mirror R.H.
Counterweight
Counterweight Mounting
Under Cover
SWING CIRCLE AND ITS RELATED PARTS
Swing Circle
Swing Machinery and Motor
(Supply Only)
Inner Parts, Swing Motor (1/3)
Inner Parts, Swing Motor (2/3)
Inner Parts, Swing Motor (3/3)
Swivel Joint
Inner Parts
Connecting Parts
TRAVEL SYSTEM AND ITS RELATED PARTS
Travel Motor and Final Drive
Travel Motor, L.H. (1/2)
Travel Motor, L.H. (2/2)
Final Drive L.H.
Travel Motor, R.H. (1/2)
Travel Motor, R.H. (2/2)
Final Drive R.H.
UNDERCARRIAGE
Front Idler and Idler Cushion
Front Idler
Idler Cushion
Track Roller
Carrier Roller
Track Shoe Assembly
(Swamp Shoe, 860mm Width, Grease Sealed Type, 90 Set)
(Flat Type Shoe, 600mm Width, Grease Sealed Type, 90 Set)
(Road Liner Shoe, 600mm Width, Grease Sealed Type, 90 Set)
(Oblong Holed Triple Grouser Shoe, 600mm Width, Grease Sealed Type, 90 Set)
(Oblong Holed Triple Grouser Shoe, 700mm Width, Grease Sealed Type, 90 Set)
(Oblong Holed Triple Grouser Shoe, 800mm Width, Grease Sealed Type, 90 Set)
(Triple Grouser Shoe for City Pad, 600mm Width, Grease Sealed Type, 90 Set)
(Round Holed Double Grouser Shoe, 600mm Width, Grease Sealed Type, 90 Set)
Track Link Assembly
(Supply Only, 90 Set,Grease Sealed Type)
Track Frame
(Full Length Track Roller Guard or Under Cover)
Track Frame Under Cover
Track Roller Guard
(Full Length)
WORK EQUIPMENT
Boom
Boom and Bushing (5700mm Heavy Duty Type)
Boom and Bushing (5700mm Heavy Duty Type,Tie-off)
Top Pin and Bottom Pin
Top Pin and Bottom Pin (For Arm Crane)
Arm Cylinder Piping
Arm Cylinder Piping (For Arm Crane)
Bucket Cylinder Piping
Bucket Cylinder Piping (For Arm Crane)
Lubrication Piping
Attachment Plug
Attachment Piping (For Arm Crane, Breaker)
Attachment Piping (5700mm Heavy Duty Type, 1-Attachment)
Boom Cylinder
Inner Parts, Boom Cylinder, L.H.
Inner Parts, Boom Cylinder, L.H. (Arm Crane)
Inner Parts, Boom Cylinder, R.H.
Inner Parts, Boom Cylinder, R.H. (Arm Crane)
Fitting
Boom Cylinder Head Pin
Arm Cylinder
Inner Parts, Arm Cylinder
Inner Parts, Arm Cylinder (Arm Crane)
Shipping Parts
Arm
Arm and Pin (2900mm)
Arm and Pin (2900mm, 1-Attachment)
Arm and Pin (2900mm, Heavy Duty Type)
Inner Parts, Bucket Cylinder
Bucket Link
Bucket Link (2900mm)
Bucket Link (For Arm Crane)
Bucket Link (2900mm, Heavy Duty Type)
Bucket Cylinder Hose
Bucket Cylinder Hose (For Arm Crane)
Bucket Cylinder Hose (For Arm Crane, Breaker)
Bucket Cylinder Hose (2900mm, Heavy Duty Type, 1-Attachment)
Additional Piping
Bucket
(0.50m3, 750mm Width, Vertical Pin Type, Side Cutter)
(0.50m3, 875mm Width, PAB Tooth, Side Cutter)
(0.50m3, 875mm Width, Horizontal Pin Type, Side Cutter)
(0.60m3, 970mm Width, Vertical Pin Type, Side Cutter)
(0.80m3, 1150mm Width, Vertical Pin Type, Thrust Adjustment, Side Cutter)
(0.80m3, 1150mm Width, Horizontal Pin Type, Thrust Adjustment, Side Cutter)
(0.80m3, 1170mm Width, PAB Tooth, Side Cutter)
(0.80m3, Heavy Duty Type, 1170mm Width, PAB Tooth, Side Cutter)
(0.80m3, Reinforced Type, 1150mm Width, Horizontal Pin Type, Side Cutter)
(0.90m3, 1200mm Width, Vertical Pin Type, Thrust Adjustment, Side Cutter)
(0.90m3, 1200mm Width, Horizontal Pin Type, Thrust Adjustment, Side Cutter)
(0.90m3, 1325mm Width, PAB Tooth, Thrust Adjustment, Side Cutter)
(1.00m3, 1330mm Width, Vertical Pin Type, Side Cutter)
(1.00m3, 1330mm Width, Horizontal Pin Type, Side Cutter)
(1.00m3, 1455mm Width, PAB Tooth, Side Cutter)
(1.17m3, 1450mm Width, PAB Tooth)
(1.17m3, 1450mm Width, Vertical Pin Type)
(1.17m3, 1450mm Width, Horizontal Pin Type)
Me Bucket
(0.80m3, 1170mm Width, PAB Tooth, Thrust Adjustment, Side Cutter)
(0.80m3, 1170mm Width, Vertical Pin Type, Thrust Adjustment, Side Cutter)
(0.80m3, 1170mm Width, Horizontal Pin Type, Thrust Adjustment, Side Cutter)
(0.93m3, 1325mm Width, PAB Tooth, Side Cutter)
(0.93m3, 1325mm Width, PAB Tooth, Thrust Adjustment, Side Cutter)
(0.93m3, 1330mm Width, Horizontal Pin Type, Side Cutter)
(0.93m3, 1330mm Width, Horizontal Pin Type, Thrust Adjustment, Side Cutter)
(1.05m3, 1340mm Width, PAB Tooth, Side Shroud)
(1.05m3, 1340mm Width, PAB Tooth, Thrust Adjustment, Side Shroud)
(1.05m3, 1395mm Width, Horizontal Pin Type, Side Cutter)
(1.05m3, 1395mm Width, Horizontal Pin Type, Thrust Adjustment, Side Shroud)
Spacer
Spacer (0.60m3, 970mm Width, Vertical Pin Type, Side Cutter)
Spacer (1.00m3, 1330mm Width, Vertical Pin Type, Side Cutter)
Spacer (1.00m3, 1330mm Width, Horizontal Pin Type, Side Cutter)
Spacer (1.00m3, 1455mm Width, PAB Tooth, Side Cutter)
Spacer (1.17m3, 1450mm Width, PAB Tooth)
Spacer (1.17m3, 1450mm Width, Vertical Pin Type)
Spacer (1.17m3, 1450mm Width, Horizontal Pin Type)
Breaker Adapter
Adapter
Adapter (Okada Breaker Kit)
Accumulator Related Parts (Nippon Pneumatic Breaker Kit)
MARKS AND PLATES
Marks and Name Plates
(KomVision, Human Detection Warning System)
(KomVision, Human Detection Warning System,Roller Shades, Rear)
Lubrication Chart
Caution Plates, Window Lock
Indicate Structural Standard Plate
(Without Boom,Arm)
(2900mm Arm)
(2900mm Arm, Heavy Duty Type)
Instruction Plate of Guard Wearing
Komatsu Logo
(Without Boom)
Lifting Capacity Chart
Caution Plates, Battery
Coolant Decal
Fire Prevention Plates
Hydraulic Hose Periodical Exchange Plate
Caution Plates, Blast Site
Seat Belt Wearing Plate
Control Pattern Plates
(Control Pattern Change Over Valve (KOMATSU/ISO))
Plate, Tie-off
Caution Plates, Keep Off Working Ranges
FOPS Plate
(Cab Top Guard LV2)
(Cab Front Full Guard LV1 or LV2)
(Cab Front Full Guard LV1 or LV2, Top Guard LV2)
ROPS Plate
Rivet
Plates, Air Cleaner
Caution Plates, Accumulator
Caution Plates, Backward
Caution Plates, 24Volt
(With Power Supply, 12volt)
(Nippon Pneumatic Breaker Kit,With Power Supply, 12volt)
Rated Load Table
AUXILIARY PARTS AND TOOL
Tool
(Large Capacity Maintenance-free Battery)
OTHER EQUIPMENT
Additional Track Frame Step
SPECIAL PRODUCT AND ITS RELATED PARTS
Arm Crane Unit
Control Valve Related Parts
Arm Lock Valve Piping
Bucket Link and Hook
Decal
Decal (Breaker)
Hydraulic Tank Elbow
Hydraulic Tank Elbow (Breaker,1-Additional Actuator Piping, Tool Control)
Solenoid Valve (Breaker)
Solenoid Valve (Breaker,1-Additional Actuator Piping, Tool Control)
Potentio Sensor
Level
Angle Sensor
Angle Sensor (For Arm Crane, Breaker)
Boom Anti-drop Valve
Boom Anti-drop Valve Mounting
Boom Anti-drop Valve Piping
Arm Anti-drop Valve
Arm Anti-drop Valve Mounting
Arm Anti-drop Valve Piping
Plate and Case
Service Kit Parts
