Komatsu Hydraulic Excavator PC200-10M0 Shop Manual SEN06867-03
Type of Manual: Shop Manual
Model: Komatsu PC200-10M0 Hydraulic Excavator
Serial Number: 700001 and up
Form Number: SEN06867-03
Publication Date: 12.2021
Number of Pages: 2218 Pages
00 Index And Foreword
Index
Abbreviation List
Foreword, Safety, Basic Information
01 Specification
Contents
Abbreviation List
Specifications
10 Structure And Function
Contents
Abbreviation List
Boot-Up System
Engine System
Control System
Hydrauuc System
Work Equipment System
Swing System
Travel System
Function Of Swing Circle
Undercarriage And Frame
Work Equipment
Cab Related Parts
20 Standard Value Table
Contents
Standard Value Table For Engine
30 Testing And Adjusting
Contents
Related Information On Testing And Adjusting
Engine And Cooling System
Power Train
Cabrelatedparts
Pm-Clinic
40 Troubleshooting
Contents
Related Information To Troubleshoot
Troubleshooting By Failure Code (Display Of Code)
Troubleshooting Of Electrical System (E-Mode)
Troubleshooting For Hydraulic And Mechanical Systems (H Mode)
Troubleshooting Of Engine (S-Mode)
50 Disassembly And Assembly
Contents
Abbreviation List
Related Information On Disassembly And Assembly
Preparation
Power Train
Work Equipment
Cab Related Parts
60 Maintenance Standard
Contents
Abbreviation List
B(Planation Of Terms For Maintenance Standard
Power Train
Work Equipment
80 Others
Contents
Abbreviation
Air Conditioner System
System Diagram Of Air Conditioner
Component Parts Of Air Conditioner System
Circuit Diagram And Arrangement Of Connector Pins Of Air Conditioner
Installation Locations Of Air Conditioner Parts And Arrangement Of Connectors
Test Air Leakage (Duct Connection)
Test Air Conditioner By Self-Diagnosis Function
Test Vent (Mode) Changeover
Test Fresh/Recirc Air Changeover
Test Sunlight Sensor
Test Dual Pressure Switch
Test Relay
Simple Check Of Refrigerant Volume Through Sight Glass
Procedure For Trouble Shooting Of Air Conditioner
Information Described In Troubleshooting Table
Failure Code [879aka]
Failure Code [879akb]
Failure Code [879bka]
Failure Code [879bkb]
Failure Code [879cka]
Failure Code [879ckb]
Failure Code [87odkz]
Failure Code [879emc]
Failure Code [879fmc]
Failure Code [879g1œ]
Air Conditioner Does Not Operate
Defective Cooling
Heater Does Not Operate
Cool Air Does Not Come Out
No Air Comes Out Or Air Flow Is Abnormal
Fresh/Recirc Air Changeover Not Possible
Connect Service Tool
Precautions For Disconnection And Connection Of Air Conditioner Piping
Handle Compressor Oil
Replace Desiccant
90 Circuit Diagrams
Contents
Abbreviation List
How To Read The Codes For Electric Cable
Hydrauuc Circuit Diagram
Electrical Circuit Diagram
Index
