Komatsu Hydraulic Excavator PC200-10M0 CE Parts Book YEPB203100-00 2024
Type of Manual: Parts Book
Model: Komatsu PC200-10M0 CE Hydraulic Excavator
Serial Number: DBCR0001 And Up
Part Number: YEPB203100-00
Publication Date: 2024
Number of Pages: 551 Pages
Lifting Bracket Mounting
Lifting Bracket
Head Cover
Exhaust Muffler and Mounting Bracket
Breather and Hose
Air Intake Manifold
Air Intake Connector
Air Transfer Connection
Exhaust Manifold
Turbocharger
Turbocharger Exhaust Gas Connector
Turbocharger Water Piping
Turbocharger Oil Piping
Heat Shield
Engine Oil Pan
Engine Oil Pan Drain
Front Gear Cover
Dust Seal
Rocker Arm
Accessory Drive Pulley
Flywheel Housing
Flywheel
Flywheel Mounting
Engine Oil Level Sensor
Vibration Damper
Piston and Connecting Rod
Cabin Heater Plug
Oil Level Gauge
Rear Gear Housing
Engine Oil Filler Cap
Cylinder Block Related Parts
ENGINE LUBRICATION SYSTEM
Engine Oil Pump
Engine Oil Filter
Engine Oil Cooler
ENGINE FUEL SYSTEM
Fuel System Cover
Fuel System Related Parts
Fuel Supply Pump
Fuel Filter Piping
Fuel Injector
Fuel Piping
Fuel Filter Cartridge
ENGINE COOLING SYSTEM
Thermostat
Water Pump Mounting
Cooling Fan
Cooling Fan Belt
Cooling Fan Belt Tensioner
Cooling Fan Drive Pulley
Cooling Fan Spacer
Water Outlet Connector
Water Inlet Connector
Coolant Ventilator
Plug
ENGINE ELECTRICAL SYSTEM
Inner Parts, Alternator
Alternator Mounting
Starting Motor
Inner Parts, Starting Motor
Starting Motor Mounting
Wiring Harness
Cap
Bracket
ENGINE ACCESSORIES AND OTHERS
Engine Controller
Engine Controller Related Parts
Parts Performance
Camshaft and Common Rail
ENGINE MARKS AND PLATES
Caution Plates
FIELD REPAIR SERVICE PARTS
Repair Service Parts
ENGINE RELATED PARTS
Engine Assembly and Exhaust Muffler
Engine Assembly (Biodiesel Fuel B20)
Engine Assembly (With Additional Fuel Prefilter,Biodiesel Fuel B30)
Exhaust Muffler and Heat Cover
Engine Assembly
(With Muffler,Additional Fuel Prefilter,Biodiesel Fuel B30)
(With Muffler,Biodiesel Fuel B20)
Damper
Connecting Parts, Breather and Drain Port
Piston Pump (1/7)
Piston Pump (2/7)
Piston Pump (3/7)
Piston Pump (4/7)
Piston Pump (5/7)
Piston Pump (6/7)
Piston Pump (7/7)
Engine Mounting
Engine Related Parts
Inner Parts, Air Cleaner
Inner Parts, Air Cleaner (With Pre-cleaner)
Air Cleaner Related Parts
Air Cleaner Related Parts (With Pre-cleaner)
Coolant Filter
Water Filter Head
Hose
COOLING SYSTEM
Aftercooler
Condenser
Radiator Seal
Aftercooler Piping and Radiator Core Piping
Radiator Mounting and Fan Guard
Aftercooler Piping
Shroud
FUEL SYSTEM
(For Biodiesel Fuel B20)
(With Refueling Pump)
Fuel Supply Piping
Fuel Piping (For Biodiesel Fuel B20)
Fuel Piping (With Additional Fuel Prefilter,Biodiesel Fuel B30)
Inner Parts, Fuel Prefilter
Fuel Prefilter Related Parts (For Biodiesel Fuel B20)
Fuel Prefilter Related Parts (With Additional Fuel Prefilter,Biodiesel Fuel B30)
Inner Parts, Water Separator
Water Separator Mounting
Remote Drain
Fuel Filter Bracket
Clip (For Biodiesel Fuel B20)
Clip (With Additional Fuel Prefilter,Biodiesel Fuel B30)
ELECTRICAL SYSTEM
Battery
Electric Wiring Harness
Starting Wiring Harness
Wiring Harness Mounting (1/2)
Wiring Harness Mounting (2/2)
Engine Wiring Harness
Working Lamp, Front
Additional Working Lamp
Additional Rear Working Lamp
Beacon Lamp
Horn
Travel Alarm
Rearview Camera Less
Rearview Camera
HYDRAULIC SYSTEM
Hydraulic Tank
Tank
Tank (With 1-Additional Actuator Piping, Accumulator)
Breather
Bypass Valve
Related Parts
Control Valve
6-Spool (1/18)
6-Spool (2/18)
6-Spool (3/18)
6-Spool (4/18)
6-Spool (5/18)
6-Spool (6/18)
6-Spool (7/18)
6-Spool (8/18)
6-Spool (9/18)
6-Spool (10/18)
6-Spool (11/18)
6-Spool (12/18)
6-Spool (13/18)
6-Spool (14/18)
6-Spool (15/18)
6-Spool (16/18)
6-Spool (17/18)
6-Spool (18/18)
7-Spool (1/21)
7-Spool (2/21)
7-Spool (3/21)
7-Spool (4/21)
7-Spool (5/21)
7-Spool (6/21)
7-Spool (7/21)
7-Spool (8/21)
7-Spool (9/21)
7-Spool (10/21)
7-Spool (11/21)
7-Spool (12/21)
7-Spool (13/21)
7-Spool (14/21)
7-Spool (15/21)
7-Spool (16/21)
7-Spool (17/21)
7-Spool (18/21)
7-Spool (19/21)
7-Spool (20/21)
7-Spool (21/21)
Mounting Bracket
Connecting Parts (1/3)
Connecting Parts (2/4) (With 1-Additional Actuator Piping, Accumulator)
Connecting Parts (2/3)
Connecting Parts (3/3)
Connecting Parts (4/4) (With 1-Additional Actuator Piping, Accumulator)
Hydraulic Pump Related Parts
Suction Piping
Delivery Piping
Oil Cooler Piping
Return Piping
Drain Piping
Boom Piping
Arm and Bucket Piping
Attachment Piping
Main Piping, L.H.
Selector Valve
Main Piping, R.H.
Return Piping (1/2)
Return Piping (2/2)
Pilot Filter
Travel Piping
Swing Piping
LS Piping
Solenoid Valve
Related Parts (With 1-Additional Actuator Piping, Accumulator)
Piping
Piping (With 1-Additional Actuator Piping, Accumulator)
Mounting
Mounting (With 1-Additional Actuator Piping, Accumulator)
Pressure Switch Block
Block
Proportional Pressure Control (PPC) Main Piping
FRAME AND ITS RELATED PARTS
Revolving Frame
Boom Foot Pin
OPERATOR'S COMPARTMENT AND CONTROL SYSTEM
Operator's Seat
(1/2)
(2/2)
Seat Belt
(50mm, 2-Point Type, Rigid Type Operator's Seat)
(78mm, 2-Point Type, Rigid Type Operator's Seat)
Floor Mat
Sunvisor
Parts For Less Window Washer Tank
Air Conditioner
Compressor
Compressor Mounting
Air Conditioner Piping Mounting (1/2)
Air Conditioner Piping Mounting (2/2)
V-Belt
Cab Body and Window
Front Window
Front Lower Window
Roof Ventilator
Door
Door Lock
Open Lock and Door Catch
Wiper and Room Lamp
Inner Parts, Rubber Antenna
Speaker and Window Washer
Roof Cover, Hanger, Drink Holder and Air Intake
Roof Cover, Hanger, Drink Holder and Air Intake (For North America and Latin America)
Grip
Gateway Function Controller Antenna (Gateway Function Controller, GPRS)
Gateway Function Controller Antenna (Gateway Function Controller, IRIDIUM)
Gateway Function Controller Antenna (Gateway Function Controller, North America and Latin
America)
KOMATSU Mark
Plate
Cab In Parts, Console Cover, Front, R.H.
Cab In Parts, Console Cover, Front, R.H. (With Monitor Guard)
Cab In Parts, Monitor Cover
Cab In Parts, Monitor Cover (With Monitor Guard)
Cab In Parts, Washer Hose Mounting
Cab In Parts, Luggage Plate and Cigarette Lighter
Cab In Parts, Air Duct
Cab In Parts, Air Duct and Fresh Air Filter
Cab In Parts, Partition and Recirculation Air Filter
Cab In Parts, Pump Controller and Relay
Cab In Parts, Air Conditioner Controller
Cab In Parts, Main Wiring Harness Clamp
Cab In Parts, Rear Cover, With 12V Converter
Controller and Monitor (Gateway Function Controller, GPRS)
Controller and Monitor (Gateway Function Controller, IRIDIUM)
Controller and Monitor (Gateway Function Controller, North America and Latin America)
Floor, Frame
PPC Valve (1/3) (For Travel)
Floor, Travel Control Lever
Floor, Footrest, L.H.
Floor, Footrest, R.H.
PPC Valve (2/4) (For Attachment)
Floor, 1st Attachment Control
Floor, Base
Floor, Wiring Harness
Floor, Wiring Harness Clamp and Ground
Floor, Window Washer Hose
Floor, Work Equipment Control Lever, L.H.
PPC Valve (2/3) (For Work Equipment L.H.)
Floor, PPC Valve Mounting for Work Equipment, L.H.
Floor, Console, L.H.
Floor, PPC Lock Lever and Radio
Floor, PPC Lock Lever and Radio (With AM-FM Radio for North America,Latin America)
Floor, Armrest, L.H.
Floor, Work Equipment Control Lever, R.H.
PPC Valve (3/3) (For Work Equipment R.H.)
Floor, PPC Valve Mounting for Work Equipment, R.H.
Floor, Console, R.H.
Floor, Armrest, R.H.
Floor, Console, R.H. (With Amber Color Warning Beacon)
Air Conditioner Unit (1/3)
Air Conditioner Unit (2/3)
Air Conditioner Unit (3/3)
Floor, Air Conditioner Mounting
Floor, Air Conditioner Piping
Floor, PPC Valve Piping for Travel
Floor, PPC Valve Piping for Work Equipment
Floor, Piping Mounting
Floor, P, T Block
Floor, P, T Block (With 1-Additional Actuator Piping, Accumulator)
Floor, Seal
Floor Mounting
Switch
GUARDS AND COVERS
Engine Hood
Frame
Door L.H.
Door R.H.
Partition
(1/4)
(1/4) (With Pre-cleaner)
(2/4)
(3/4)
(4/4)
Partition Cover
(With Pre-cleaner)
Upper Cover
Right Side Case
Floor Cover
Handrail
Rearview Mirror L.H.
Rearview Mirror R.H.
Rear Under View Mirror
Without Rearview Mirror
Counterweight
Counterweight Mounting
Under Cover
(1/2) (With Pre-cleaner)
(1/2) (With Refueling Pump)
(2/2) (With Battery Case Under Cover)
(2/2) (With Refueling Pump)
SWING CIRCLE AND ITS RELATED PARTS
Swing Circle
Swing Machinery and Motor
Inner Parts, Swing Motor (1/3)
Inner Parts, Swing Motor (2/3)
Inner Parts, Swing Motor (3/3)
Mounting (Oil Resistance)
Swivel Joint
Inner Parts, Swivel Joint
Connecting Parts
TRAVEL SYSTEM AND ITS RELATED PARTS
Travel Motor and Final Drive
Travel Motor, L.H. (1/2)
Travel Motor, L.H. (2/2)
Final Drive L.H.
Travel Motor, R.H. (1/2)
Travel Motor, R.H. (2/2)
Final Drive R.H.
Cover
UNDERCARRIAGE
Front Idler and Idler Cushion
Front Idler
Idler Cushion (For Link, 6 Type)
Idler Cushion (For Link, 7 Type)
Track Roller
Carrier Roller
Track Shoe Assembly
(Oblong Holed Triple Grouser Shoe, 700mm Width, Grease Sealed Type, 90 Set )
(Triple Grouser Shoe, 600mm Width, Grease Sealed Type)
(Triple Grouser Shoe, 700mm Width, Grease Sealed Type,Link, 7 Type)
(Triple Grouser Shoe, 790mm Width, Grease Sealed Type)
(Triple Grouser Shoe, 800mm Width, Grease Sealed Type)
Track Frame
Track Frame Under Cover
(Plug For Under Cover Less)
(Under Cover, Track Frame)
Track Roller Guard
(For Link, 6 Type)
(For Link, 7 Type)
WORK EQUIPMENT
Boom
Boom and Bushing
Top Pin and Bottom Pin
Arm Cylinder Piping
Bucket Cylinder Piping
Lubrication Piping
Additional Piping
Attachment Plug (With 1-Additional Actuator Piping, Accumulator)
Working Lamp
Boom Cylinder
Inner Parts, Boom Cylinder, L.H.
Inner Parts, Boom Cylinder, R.H.
Fitting
Boom Cylinder Head Pin
Arm Cylinder
Inner Parts, Arm Cylinder
Arm
Arm and Pin
Arm and Pin (With 1-Additional Actuator Piping, Accumulator)
Arm and Pin (With Arm Protector)
Inner Parts, Bucket Cylinder
Bucket Link
Bucket Cylinder Hose
Bucket Cylinder Hose (With 1-Additional Actuator Piping, Accumulator)
Shipping Parts
Bucket
(1.00m3, 1085mm Width, Horizontal Pin Type, Thrust Adjustment, Side Shroud)
(1.00m3, 1190mm Width, Horizontal Pin Type, Side Cutter, Bottom Wear Plate, Lifting Hook)
MARKS AND PLATES
Marks and Plates
Lubrication Chart
(With Additional Pre-Filter)
Caution Plates, Window Lock
Komatsu Logo
Caution Plate
(English)
(Thai)
Caution Plate, Lifting Capacity, STD
Caution Plate, Refuel
Caution Plates, Battery
Coolant Decal
Caution Plates, Blast Site
Caution Plates, Blast Site, GPRS 4G
Seat Belt Wearing Plate
Caution Plates, Keep Off Working Ranges
ROPS Plate
Plates, Air Cleaner
Caution Plates, Accumulator
Caution Plates, Backward
AUXILIARY PARTS AND TOOL
Spare Parts
Tool
OTHER EQUIPMENT
Preventive Maintenance Service Connectors
Nipple
Valve Assembly
Sensor
Tee
Nipple (2/2)
Refueling Pump
Vandalism Protection Guard
Service Kit Parts
KIT 514
Lifting Bracket
Head Cover
Breather and Hose
Air Intake Manifold
Exhaust Manifold
Turbocharger
Heat Shield
Engine Oil Pan
Front Gear Cover
Dust Seal
Rocker Arm
Flywheel Housing
Flywheel
Flywheel Mounting
Vibration Damper
Cabin Heater Plug
Oil Level Gauge
Rear Gear Housing
Engine Oil Pump
Engine Oil Filter
Engine Oil Cooler
ENGINE FUEL SYSTEM
Fuel System Cover
Fuel Supply Pump
Fuel Filter Piping
Fuel Injector
Fuel Piping
Thermostat
Water Pump Mounting
Cooling Fan
Cooling Fan Belt
Cooling Fan Spacer
Coolant Ventilator
Plug
Alternator Mounting
Starting Motor
Wiring Harness
Cap
Bracket
Engine Controller
Parts Performance
Caution Plates
Engine Assembly
Damper
Piston Pump (1/7)
Piston Pump (2/7)
Piston Pump (3/7)
Piston Pump (4/7)
Piston Pump (5/7)
Piston Pump (6/7)
Piston Pump (7/7)
Engine Mounting
Coolant Filter
Water Filter Head
Hose
COOLING SYSTEM
Aftercooler
Condenser
Radiator Seal
Aftercooler Piping
Shroud
FUEL SYSTEM
Fuel Supply Piping
Remote Drain
Fuel Filter Bracket
ELECTRICAL SYSTEM
Battery
Working Lamp, Front
Beacon Lamp
Horn
Travel Alarm
Rearview Camera
HYDRAULIC SYSTEM
Hydraulic Tank
Tank
Breather
Bypass Valve
Related Parts
Control Valve
6-Spool (1/18)
6-Spool (2/18)
6-Spool (3/18)
6-Spool (4/18)
6-Spool (5/18)
6-Spool (6/18)
6-Spool (7/18)
6-Spool (8/18)
6-Spool (9/18)
6-Spool (10/18)
6-Spool (11/18)
6-Spool (12/18)
6-Spool (13/18)
6-Spool (14/18)
6-Spool (15/18)
6-Spool (16/18)
6-Spool (17/18)
6-Spool (18/18)
7-Spool (1/21)
7-Spool (2/21)
7-Spool (3/21)
7-Spool (4/21)
7-Spool (5/21)
7-Spool (6/21)
7-Spool (7/21)
7-Spool (8/21)
7-Spool (9/21)
7-Spool (10/21)
7-Spool (11/21)
7-Spool (12/21)
7-Spool (13/21)
7-Spool (14/21)
7-Spool (15/21)
7-Spool (16/21)
7-Spool (17/21)
7-Spool (18/21)
7-Spool (19/21)
7-Spool (20/21)
7-Spool (21/21)
Mounting Bracket
Suction Piping
Delivery Piping
Oil Cooler Piping
Return Piping
Drain Piping
Boom Piping
Attachment Piping
Main Piping, L.H.
Selector Valve
Main Piping, R.H.
Return Piping (1/2)
Return Piping (2/2)
Pilot Filter
Travel Piping
Swing Piping
LS Piping
Solenoid Valve
Piping
Mounting
Block
Revolving Frame
Boom Foot Pin
Operator's Seat
(1/2)
(2/2)
Seat Belt
Floor Mat
Sunvisor
Air Conditioner
Compressor
Compressor Mounting
V-Belt
Cab Body and Window
Front Window
Front Lower Window
Roof Ventilator
Door
Door Lock
Wiper and Room Lamp
Grip
America)
KOMATSU Mark
Plate
Floor, Frame
Floor, Base
Floor, P, T Block
Floor, Seal
Floor Mounting
Switch
GUARDS AND COVERS
Engine Hood
Frame
Door L.H.
Door R.H.
Partition
(1/4)
(2/4)
(3/4)
(4/4)
Partition Cover
(With Pre-cleaner)
Upper Cover
Right Side Case
Floor Cover
Handrail
Counterweight
Under Cover
Swing Circle
Swivel Joint
Connecting Parts
Final Drive L.H.
Final Drive R.H.
Cover
UNDERCARRIAGE
Front Idler
Track Roller
Carrier Roller
Track Shoe Assembly
Track Frame
Track Roller Guard
(For Link, 6 Type)
(For Link, 7 Type)
WORK EQUIPMENT
Boom
Boom and Bushing
Arm Cylinder Piping
Lubrication Piping
Additional Piping
Working Lamp
Boom Cylinder
Fitting
Arm Cylinder
Arm
Arm and Pin
Bucket Link
Shipping Parts
Bucket
MARKS AND PLATES
Marks and Plates
Lubrication Chart
Komatsu Logo
Caution Plate
(English)
(Thai)
Coolant Decal
ROPS Plate
Plates, Air Cleaner
Spare Parts
Tool
OTHER EQUIPMENT
Nipple
Valve Assembly
Sensor
Tee
Nipple (2/2)
Refueling Pump
Service Kit Parts
KIT 514
- KOMATSU Fault Codes
