Momed80
150
35,046
Komatsu Hydraulic Excavator PC130F-7 Parts Book LEPBP13710 2018
Type of Manual: Parts Book
Model: Komatsu PC130F-7 Hydraulic Excavator
Serial Number: J10001-UP
Part Number: LEPBP13710
Publication Date: 2018
Number of Pages: 585 Pages
ENGINE
Head Cover
Rear Hanger
Head Cover
Head Cover Accessory
Air Intake Manifold
Air Intake Connector
Exhaust Manifold
Turbocharger
Heat Shield
Muffler
Exhaust Connection
Front Cover (For 25A Alternator)
Front Cover (For 35A Alternator)
Idler Gear
Blind Plug (Oil Filler Upper Spec.)
Oil Pan and Suction Tube
Oil Level Gauge
Flywheel Housing
Flywheel
Piston
Piston
Crank Pulley (Non Hardening)
Camshaft and Gear
Tappet
Rocker Arm
Coupling (Power Take Off)
Tachometer Drive Cover
Cover (Seal)
Oil Pump
Turbocharger Lubricating Oil Piping
Oil Filter
Oil Pressure Switch
Fuel Injection Pump
Fuel Injection Pump (Pump) (1/3) (Inner Parts)
Fuel Injection Pump (Pump) (2/3) (Inner Parts)
Fuel Injection Pump (Pump) (3/3) (Inner Parts)
Fuel Injection Pump (Governor) (1/2) (Inner Parts)
Fuel Injection Pump (Governor) (2/2) (Inner Parts)
Fuel Injection Pump (Feed Pump) (Inner Parts)
Fuel Injection Pump Mounting
Fuel Injection Piping
Fuel Injection Pump Lubricator
Fuel Control (Boost Compensate)
Injection Nozzle
Nozzle Holder (Inner Parts)
Fuel Return (Center Return Spec.)
Solenoid
Water Pump Pulley (With Non Hardening Pulley)
Cooling Fan
Fan Spacer
Fan Spacer Mounting
Water Connector (Outlet)
Cooling Fan Bolt
Fan Belt (For 35A Alternator)
Fan Belt (For 25A Alternator)
Alternator (For 35A Alternator)
Alternator (For 60A Alternator)
Alternator (For 25A Alternator)
Alternator (Inner Parts)
Alternator Mounting
Starting Motor Mounting
Starting Motor (Inner Parts)
Accessory Bracket (For Compressor)
Cylinder Block Gasket Kit
Cylinder Head Gasket Kit
Tamper Proof Kit
Water Piping Bracket
Engine Name Plate and Regulation Plate
Spare Parts
ENGINE RELATED PARTS
Main Pump Mounting
Engine Bracket and Mounting
Engine Mount
Engine Mount Bracket
Remote Filter Mount
Air Cleaner and Duct
Fuel Control
Corrosion Resistor
Air Cleaner
COOLING SYSTEM
Cooling (Radiator Core and Frame)
Cooling (Oil Cooler)
Cooling (Net and Shroud)
Cooling (After Cooler)
Cooling (After Cooler and Condenser)
Cooling (Radiator Piping)
Cooling (After Cooler Piping)
Fan Guard
FUEL TANK AND RELATED PARTS
Fuel Line (Arrange Spec)
Fuel Line (Water Separator)
Fuel Line (Fuel Filter)
Fuel Line (Additional Fuel Filter)
ELECTRICAL SYSTEM
Battery
Wiring (Starting Harness)
Wiring (Main Harness)
Wiring (Battery Harness and Ground)
Horn
HYDRAULIC SYSTEM
Hydraulic Tank
Main Valve (Connecting Parts)
Main Pump (Connecting Parts)
Suction Line
Delivery Line
Oil Cooler Line
Return Line
Drain Line
Boom Line
Arm and Bucket Line
Attachment Line
Travel Line
Swing Line
LS Line
Solenoid Valve
Pressure Switch
PPC Main Line
MAIN FRAME AND RELATED PARTS
Revolving Frame
Boom Foot Pin
OPERATOR'S COMPARTMENT AND CONTROL SYSTEM
Operator Seat
Seat Belt
Seat Rear Cover
Cabin Guard
Floor Mat
Window Washer
Air Conditioner
Floor Frame (Operator's Cab)
GUARD
Hood
Frame
Door L.H
Door R.H
Partition
Upper Cover
Tool Case
Valve Upper Cover
Hand Rail
Rear View Mirror L.H
Rear View Mirror R.H
Counter Weight
Counter Weight Mounting
Under Cover
SWING CIRCLE AND RELATED PARTS
Swing Circle
Swing Machinery
Swing Motor
Swivel Joint
TRAVEL AND LOWER PIPING
Travel Piping
Final Drive
Travel Motor
UNDERCARRIAGE
Front Idler
Idler Cushion
Track Roller
Track Roller Upper
Track Shoe
Track Frame
Track Frame Under Cover
Center Roller Guard
WORK EQUIPMENT
Boom
Boom Cylinder
Boom Cylinder Top Pin
Arm Cylinder
Arm
Bucket Cylinder
Bucket Link
Side Cutter
Bucket
Fix Grapple
Shear Head
Hitch
Skidder
Rotator Mounting
MARK AND PLATES
Mark and Plates
Plate (Logging Spec)
Plate (Window)
Logo (Counter Weight)
Coolant Decal
Logo (Arm Side)
Plate (Air Cleaner Double Element)
ACCESSORY
Spare Parts
Cap and Overall
Tool
OTHER EQUIPMENT
Additional Sheet
SERVICE KIT
Swing Machinery (Inner Parts)
Shoe Bolt and Nut Service Kit
Track Link Assembly
Rubber Antenna
Main Pump (1/8 – 8/8)
Boom Cylinder (Inner Parts)
Arm Cylinder (Inner Parts)
Bucket Cylinder (Inner Parts)
Swivel Joint (Inner Parts)
Swing Motor
Travel Motor
Main Valve
PPC Valve
Pilot Valve
Solenoid Valve
Compressor Assembly (Air Conditioner)
Cooling Unit Assembly (Air Conditioner)
QC-9 PC130F-7
