Komatsu Hydraulic Excavator MX352 MX502 Shop Manual SEBD035400
Type of Manual: Shop Manual
Model: Komatsu MX352 MX502 Hydraulic Excavator
Form Number: SEBD035400
Serial Number:
6Y6089 and up
6Y7038 and up
Publication Date: 2003
Number of Pages: 491 Pages
Safety
Safety Notice
Foreword
General
How To Read The Shop Manual
Hoisting Instructions
Method Of Disassembling, Connecting Push-Pull Type Coupler
Coating Materials
Standard Tightening Torque
Electric Wire Code
Conversion Table
Units
01 General
Specification Dimension Drawing
Working Range Drawing
Specifications
Weight Table
Lubricants, Fuel And Coolant Specifications
10 Structure, Function And Maintenance Standard
Pto
Power Train
Swing Circle
Swing Machinery
Track Frame
Idler Cushion
Idler
Track Roller
Carrier Roller
Sprocket
Track Shoe
Hydraulic Components Layout Drawing
Hydraulic Tank
Center Swivel Joint
Travel Motor
Hydraulic Cylinder
Solenoid Valve
Multi-Control Valve
Control Valve
Clss
Operation For Each Function And Valve
Swing Motor
Ppc Valve
Work Equipment
Dimensions Of Each Part Of Work Equipment
Floor
Air Conditioner
Engine Control
Electric Control System
Component Parts Of System
Monitor System
Monitor Panel
Sensors
20 Testing And Adjusting
Standard Value Table For Engine Related Parts
Standard Value Table For Chassis Related Parts
Troubleshooting
30 Disassembly And Assembly
How To Read This Manual
Precautions When Performing Operation
Special Tool List
Sketches Of Special Tools
Removal And Installation Of Radiator And Hydraulic Oil Cooler
Removal And Installation Of Engine And Hydraulic Pump
Removal And Installation Of Track Shoe
Disassembly And Assembly Of Idler
Disassembly And Assembly Of Recoil Spring
Disassembly And Assembly Of Track Roller
Disassembly And Assembly Of Carrier Roller
Removal And Installation Of Center Swivel Joint
Disassembly And Assembly Of Center Swivel Joint
Removal And Installation Of Floor Frame Assembly
Removal And Installation Of Swing Motor And Swing Machinery
Disassembly And Assembly Of Swing Motor And Swing Machinery
Removal And Installation Of Work Equipment
Removal And Installation Of Revolving Frame
Removal And Installation Of Swing Circle
Disassembly And Assembly Of Control Valve
Disassembly And Assembly Of Hydraulic Cylinder Assembly
Removal And Installation Of Air Conditioner Unit
90 Others
Hydraulic Circuit Diagram Mx352
Hydraulic Circuit Diagram Mx502
Hydraulic Circuit Diagram (Additional Attachment Circuit) Mxso2
Electrical Circuit Diagram Mx352 (1/2)
Electrical Circuit Diagram Mx352 (2/2)
Electrical Circuit Diagram Mx502 (1/2)
Serial Number:
6Y6089 and up
6Y7038 and up
Safety
Safety Notice
Foreword
General
Coating Materials
Electric Wire Code
Conversion Table
Units
01 General
Specifications
Weight Table
Pto
Power Train
Swing Circle
Swing Machinery
Track Frame
Idler Cushion
Idler
Track Roller
Carrier Roller
Sprocket
Track Shoe
Hydraulic Tank
Center Swivel Joint
Travel Motor
Hydraulic Cylinder
Solenoid Valve
Multi-Control Valve
Control Valve
Clss
Swing Motor
Ppc Valve
Work Equipment
Floor
Air Conditioner
Engine Control
Monitor System
Monitor Panel
Sensors
Troubleshooting
Special Tool List
90 Others
- KOMATSU Fault Codes
