Momed80
150
35,046
Komatsu Hydraulic Excavator HB205-2 Parts Book ZEN00045-00 2003
Type of Manual: Parts Book
Model: Komatsu HB205-2 Hydraulic Excavator
Serial Number:
HB205-2 Japan Standard Machine 51083 And Up
SAA4D107E-2B 26729328 And Up
Part Number: ZEN00045-00
Publication Date: 2003
Number of Pages: 994 Pages
Lifting Bracket Mounting
Lifting Bracket
Head Cover
Air Intake Manifold
Air Intake Connector
Air Intake Heater
Air Cleaner
Air Transfer Connection
Exhaust Manifold
Turbocharger Oil Piping
Heat Shield
Exhaust Pipe
Komatsu Diesel Oxidation Catalyst (KDOC)
Coolant Piping
Variable Flow Turbocharger
Heater Switch Cover
Exhaust Gas Re-circulation (EGR) Cooler Piping
Exhaust Connection
Cylinder Block Accessory
Cylinder Block Plug
Engine Oil Pan
Engine Oil Pan Drain
Front Gear Cover
Dust Seal
Rocker Arm
Accessory Drive Pulley
Flywheel Housing
Flywheel
Flywheel Mounting
Engine Oil Level Sensor
Vibration Damper
Piston and Connecting Rod
Breather Related Parts
Camshaft
Oil Level Gauge
Rear Gear Housing
Rear Gear Housing Accessory
Cylinder Block Blind Plug
Engine Oil Filler Cap
ENGINE LUBRICATION SYSTEM
Engine Oil Pump
Engine Oil Filter
Engine Oil Cooler
Engine Oil Hose Cover
Engine Oil Level Gauge Bracket
ENGINE FUEL SYSTEM24
Fuel System Related Parts
Fuel Supply Pump
Fuel Filter and Piping
Fuel Injector
Fuel Supply Piping
Fuel Filter Cartridge
Fuel Prefilter
Fuel Drain Piping
Common Rail
Common Rail Cover
ENGINE COOLING SYSTEM
Thermostat
Water Pump Mounting
Cooling Fan
Cooling Fan Belt
Cooling Fan Belt Tensioner
Cooling Fan Drive Pulley
AFA10-001001A 118
Cooling Fan Spacer
Water Outlet Connector
Water Inlet Connector
ENGINE ELECTRICAL SYSTEM
Inner Parts, Alternator (60Amp.)
Alternator Mounting
(60Amp.)
Starting Motor
Inner Parts, Starting Motor (5.5KW)
Starting Motor Mounting
(5.5KW)
Wiring Harness
ENGINE ACCESSORIES AND OTHERS
Engine Controller
Engine Control Module
APH00-001001A 133
Air Compressor Plate
ENGINE MARKS AND PLATES
Caution Plates
Warning Plate
FIELD REPAIR SERVICE PARTS
Repair Service Parts
Spare Parts
ENGINE RELATED PARTS
Engine Related Parts
Komatsu Diesel Oxidation Catalyst (KDOC) Related Parts
Motor-generator
Motor-generator Mounting
Water Piping
Gear Pump (1/2)
Gear Pump (2/2)
Gear Pump Related Parts
Piston Pump (1/12)
Piston Pump (2/12)
Piston Pump (3/12)
Piston Pump (4/12)
Piston Pump (5/12)
Piston Pump (6/12)
Piston Pump (7/12)
Piston Pump (8/12)
Piston Pump (9/12)
Piston Pump (10/12)
Piston Pump (11/12)
Piston Pump (12/12)
Piston Pump Mounting
Oil Filter Mounting
Oil Filter
Motor-generator Piping
Hot Water Piping for Air Conditioner
Engine Mounting
Komatsu Diesel Oxidation Catalyst (KDOC) Cover
Air Cleaner Related Parts
Air Cleaner Related Parts (With Pre-cleaner)
Air Cleaner Duct
Air Cleaner Mounting
Komatsu Closed Crankcase Ventilation (KCCV) Mounting
Komatsu Closed Crankcase Ventilation (KCCV) Piping
Komatsu Closed Crankcase Ventilation (KCCV) Piping (With Pre-cleaner)
Lubrication Piping
COOLING SYSTEM
Aftercooler and Fuel Cooler
Net and Shroud
Hybrid Radiator
Oil Cooler Piping and Condenser
Radiator Seal
Aftercooler and Radiator Piping
Radiator Mounting and Fan Guard
Sub-tank Piping
Related Parts
Hybrid Cooling Piping
Sub-tank
FUEL SYSTEM
Mounting
Remote Drain and Fuel Filter Related Parts
ELECTRICAL SYSTEM
Battery
Electric Wiring Harness
Starting Wiring Harness Clamp
Disconnect Switch
Working Lamp
Main Wiring Harness Clamp (1/3)
Main Wiring Harness Clamp (2/3)
Main Wiring Harness Clamp (3/3)
Engine Wiring Harness
Inverter Capacitor
Power Cable (1/2)
Power Cable (2/2)
Additional Working Lamp
(With Cab Front Full Guard LV1)
(With Cab Front Full Guard LV1, Top Guard LV2)
(With Cab Front Full Guard LV2)
Additional Rear Working Lamp
Beacon Lamp
Horn
Travel Alarm
Rearview Camera
Camera No.1
Camera No.2
HYDRAULIC SYSTEM
Hydraulic Tank
Tank and Strainer
Tank and Strainer (Arm Crane)
Tank and Strainer (1-Additional Actuator Piping, Accumulator)
Tank and Strainer (1-Additional Actuator Piping, Accumulator,Arm Crane)
Tank and Strainer (2-Additional Actuator Piping, Accumulator)
Tank and Strainer (2-Additional Actuator Piping, Accumulator,Arm Crane, Breaker)
Tank and Strainer (Material Handling 1-Additional Actuator Piping Specification,Arm Crane,
Breaker)
Tank and Strainer (Material Handling 2-Additional Actuator Pipingr Specification)
Tank and Strainer (Material Handling 2-Additional Actuator Pipingr Specification,Arm Crane,
Plate and Cap
Plate and Cap (Arm Crane)
Plate and Cap (1-Additional Actuator Piping, Accumulator)
Plate and Cap (1-Additional Actuator Piping, Accumulator,Arm Crane)
Plate and Cap (2-Additional Actuator Piping, Accumulator)
Plate and Cap (2-Additional Actuator Piping, Accumulator,Arm Crane, Breaker)
Plate and Cap (Material Handling 1-Additional Actuator Piping Specification,Arm Crane, Breaker) .H0110-007002B 251
Plate and Cap (Material Handling 2-Additional Actuator Pipingr Specification)
Plate and Cap (Material Handling 2-Additional Actuator Pipingr Specification,Arm Crane, Breaker) H0110-008002B 253
Control Valve
6-Spool (1/17)
6-Spool (2/17)
6-Spool (3/17)
6-Spool (4/17)
6-Spool (5/17)
6-Spool (6/17)
6-Spool (7/17)
6-Spool (8/17)
6-Spool (9/17)
6-Spool (10/17)
6-Spool (11/17)
6-Spool (12/17)
6-Spool (13/17)
6-Spool (14/17)
6-Spool (15/17)
6-Spool (16/17)
6-Spool (17/17)
7-Spool (1/20)
7-Spool (2/20)
7-Spool (2/20) (Material Handling 1-Additional Actuator Piping Specification)
7-Spool (3/20)
7-Spool (3/20) (Material Handling 1-Additional Actuator Piping Specification)
7-Spool (4/20)
7-Spool (5/20)
7-Spool (5/20) (Material Handling 1-Additional Actuator Piping Specification)
7-Spool (6/20)
7-Spool (7/20)
7-Spool (7/20) (Material Handling 1-Additional Actuator Piping Specification)
7-Spool (8/20)
7-Spool (9/20)
7-Spool (10/20)
7-Spool (10/20) (Material Handling 1-Additional Actuator Piping Specification)
7-Spool (11/20)
7-Spool (11/20) (Material Handling 1-Additional Actuator Piping Specification)
7-Spool (12/20)
7-Spool (12/20) (Material Handling 1-Additional Actuator Piping Specification)
7-Spool (13/20)
7-Spool (14/20)
7-Spool (14/20) (Material Handling 1-Additional Actuator Piping Specification)
7-Spool (15/20)
7-Spool (15/20) (Material Handling 1-Additional Actuator Piping Specification)
7-Spool (16/20)
7-Spool (16/20) (Material Handling 1-Additional Actuator Piping Specification)
7-Spool (17/20)
7-Spool (18/20)
7-Spool (19/20)
7-Spool (19/20) (Material Handling 1-Additional Actuator Piping Specification)
7-Spool (20/20)
7-Spool (20/20) (Material Handling 1-Additional Actuator Piping Specification)
8-Spool (1/22)
8-Spool (2/22)
8-Spool (3/22)
8-Spool (4/22)
8-Spool (5/22)
8-Spool (6/22)
8-Spool (7/22)
8-Spool (8/22)
8-Spool (9/22)
8-Spool (10/22)
8-Spool (11/22)
8-Spool (12/22)
8-Spool (13/22)
8-Spool (14/22)
8-Spool (15/22)
8-Spool (16/22)
8-Spool (17/22)
8-Spool (18/22)
8-Spool (19/22)
8-Spool (20/22)
8-Spool (21/22)
8-Spool (22/22)
Connecting Parts (1/4)
Connecting Parts (1/4) (1-Additional Actuator Piping, Accumulator)
Connecting Parts (1/4) (2-Additional Actuator Piping, Accumulator)
Connecting Parts (1/4) (2-Additional Actuator Piping, Accumulator,Arm Crane, Breaker)
Suction Relief Valve
Suction Relief Valve (Material Handling 1-Additional Actuator Piping Specification)
Sensor (1/2)
Suction Relief Valve (1/2)
Suction Relief Valve (1/2) (Material Handling 2-Additional Actuator Pipingr Specification)
Suction Relief Valve (2/2) (Material Handling 2-Additional Actuator Pipingr Specification)
Connecting Parts (1/5)
Connecting Parts (1/5) (Material Handling 1-Additional Actuator Piping Specification)
Connecting Parts (1/5) (Material Handling 2-Additional Actuator Pipingr Specification)
Sensor (2/2)
Connecting Parts (2/5)
Connecting Parts (2/5) (Material Handling 1-Additional Actuator Piping Specification)
Connecting Parts (2/5) (Material Handling 2-Additional Actuator Pipingr Specification)
Slow Return Valve
Slow Return Valve (1/2) (No1)
Connecting Parts (2/4)
Connecting Parts (2/4) (1-Additional Actuator Piping, Accumulator)
Connecting Parts (2/4) (2-Additional Actuator Piping, Accumulator)
Connecting Parts (3/5)
Slow Return Valve (2/2) (No2)
Attachment Plug
Mounting Bracket
Connecting Parts (3/4)
Connecting Parts (3/4) (1-Additional Actuator Piping, Accumulator)
Connecting Parts (3/4) (2-Additional Actuator Piping, Accumulator)
Connecting Parts (3/4) (2-Additional Actuator Piping, Accumulator,Arm Crane, Breaker)
Connecting Parts (4/4)
Connecting Parts (4/4) (1-Additional Actuator Piping, Accumulator)
Connecting Parts (4/4) (2-Additional Actuator Piping, Accumulator)
Connecting Parts (4/4) (2-Additional Actuator Piping, Accumulator,Arm Crane, Breaker)
Connecting Parts (4/5)
Connecting Parts (4/5) (Material Handling 1-Additional Actuator Piping Specification)
Connecting Parts (4/5) (Material Handling 2-Additional Actuator Pipingr Specification)
Connecting Parts (5/5)
Connecting Parts (5/5) (Material Handling 1-Additional Actuator Piping Specification)
Connecting Parts (5/5) (Material Handling 2-Additional Actuator Pipingr Specification)
Mounting Bracket (1-Additional Actuator Piping, Accumulator)
Mounting Bracket (2-Additional Actuator Piping, Accumulator)
Sensor
Attachment Plug (1-Additional Actuator Piping, Accumulator)
Attachment Plug (2-Additional Actuator Piping, Accumulator)
Attachment Plug (2-Additional Actuator Piping, Accumulator,Arm Crane, Breaker)
Hydraulic Pump Related Parts
(Additional Actuator Piping, Accumulator)
Suction Piping
Delivery Piping
Oil Cooler Piping
Return Piping
Drain Piping
Specification)
Boom Piping
Revolving Frame Side
Revolving Frame Side (Arm Crane)
Cylinder Hose
Cylinder Hose (Arm Crane)
Arm and Bucket Piping
(With Arm Hydraulic Drift Prevention Valve)
Relief Valve
(Pressure Regulator Valve, 175kg/cm2)
(Pressure Regulator Valve, 210kg/cm2)
(Pressure Regulator Valve, 250kg/cm2)
(Pressure Regulator Valve, 280kg/cm2)
2-Stage Relief Valve
(Pressure Regulator Valve, 280kg/cm2, 175kg/cm2)
(Pressure Regulator Valve, 280kg/cm2, 210kg/cm2)
(Pressure Regulator Valve, 280kg/cm2, 250kg/cm2)
Attachment Piping
Main Piping, L.H.
Main Piping, L.H. (For Krupp Breaker Kit or Nippon Pneumatic Breaker Kit)
Selector Valve
Main Piping, R.H.
Main Piping, R.H. (Material Handling)
Main Piping, R.H. (For Krupp Breaker Kit or Nippon Pneumatic Breaker Kit)
Return Filter
Return Filter (For Krupp Breaker Kit or Nippon Pneumatic Breaker Kit)
Return Piping (For Krupp Breaker Kit or Nippon Pneumatic Breaker Kit)
Pilot Filter
Pilot Filter (Material Handling)
Attachment Additional Piping
Multi Control Pattern Unit
Selector Valve (2-Way)
Selector Valve (4-Way)
Connecting Parts (2-Way)
Connecting Parts (4-Way)
Hose (4-Way)
Piping (2-Way)
Travel Piping
LS Piping
Solenoid Valve
Inner Parts
Inner Parts, Solenoid Valve (Additional Actuator Piping, Accumulator)
Related Parts (Material Handling)
Related Parts (Additional Actuator Piping, Accumulator)
Solenoid Valve Piping (1-Additional Actuator Piping, Accumulator)
Solenoid Valve Piping (2-Additional Actuator Piping, Accumulator)
Solenoid Valve Piping (Material Handling 2-Additional Actuator Pipingr Specification)
Mounting (1-Additional Actuator Piping, Accumulator)
Mounting (2-Additional Actuator Piping, Accumulator)
Mounting (Material Handling 1-Additional Actuator Piping Specification)
Mounting (Material Handling 2-Additional Actuator Pipingr Specification)
Piping
Piping (Material Handling 1-Additional Actuator Piping Specification)
Solenoid Valve Piping (Material Handling 1-Additional Actuator Piping Specification)
Pressure Switch Block
(Arm Crane)
(Additional Actuator Piping, Accumulator,Arm Crane)
Proportional Pressure Control (PPC) Valve Piping
FRAME AND ITS RELATED PARTS
Revolving Frame
Boom Foot Pin
OPERATOR'S COMPARTMENT AND CONTROL SYSTEM
Operator's Seat
(Rigid Type, Fabric, Tilt)
(Rigid Type, Leather, Tilt)
Seat Belt
Top Guard
(LV2)
Front Guard
(Full Guard LV1)
(Full Guard LV2)
(Full Guard LV2,With Additional Front Working Lamp)
(Half Guard)
Floor Mat
Rain Visor
Sunvisor
Window Washer Tank
Air Conditioner
Compressor
Compressor Mounting
Fire Extinguisher
Cab Body and Window
Front Window
Front Lower Window
Roof Ventilator
Door
Door Lock
Open Lock and Door Catch
Wiper and Room Lamp
Inner Parts, Rubber Antenna
Speaker and Window Washer Hose
Roof Cover, Hanger, Drink Holder and Air Intake
Grip
KOMTRAX Antenna
KOMATSU Mark
Cab In Parts, Monitor and Cover
Cab In Parts, Monitor Cover
Cab In Parts, Washer Hose Mounting
Cab In Parts, Luggage Plate and Cigarette Lighter
Cab In Parts, Monitor Duct
Cab In Parts, Air Duct
Cab In Parts, Air Duct and Fresh Air Filter
Cab In Parts, Partition and Recirculation Air Filter
Cab In Parts, Main Wiring Harness Clamp
Cab In Parts, Rear Cover (1/2)
Cab In Parts, Rear Cover (1/2) (For Power Supply, 12volt)
Cab In Parts, Rear Cover (1/2) (For Power Supply, 12volt,Power Supply, 12volt)
Cab In Parts, Rear Cover (2/2)
Cab In Parts, Rear Cover (2/2) (For Power Supply, 12volt)
Cab In Parts, Rear Cover (2/2) (For Power Supply, 12volt,Power Supply, 12volt)
Floor, Frame
PPC Valve
PPC Valve (1/2)
Floor, Travel Control Lever
Floor, Footrest, L.H.
Floor, Footrest, R.H.
PPC Valve for 2-Attachment
Floor, 2nd Attachment Control
PPC Valve (2/2)
Floor, 1st Attachment Control (1-Additional Actuator Piping, Accumulator)
Floor, 1st Attachment Control (2-Additional Actuator Piping, Accumulator)
Floor, Base
Floor, Base (Mechanical Suspension Type, Fabric, Tilt)
Floor, Wiring Harness
Floor, Battery Cable
Floor, Wiring Harness Clamp and Ground
Floor, Window Washer Hose
Floor, Work Equipment Control Lever, L.H.
PPC Valve for Work Equipment, L.H.
PPC Valve (2/3)
Floor, PPC Valve Mounting for Work Equipment, L.H.
Floor, Console, L.H.
Floor, Radio and Work Equipment Lock Lever
Floor, Armrest, L.H.
Floor, Work Equipment Control Lever, R.H.
PPC Valve for Work Equipment, R.H.
Floor, PPC Valve Mounting for Work Equipment, R.H.
Floor, Console, R.H.
Floor, Console, R.H. (Amber Color Warning Beacon, ISO)
Floor, Armrest, R.H.
Air Conditioner Unit (1/3)
Air Conditioner Unit (2/3)
Air Conditioner Unit (3/3)
Floor, Air Conditioner Mounting and Secondary Engine Stop Switch
Floor, Air Conditioner Piping
Floor, PPC Valve Piping for Travel
Floor, PPC Valve Piping for Work Equipment
Floor, Piping Mounting
Floor, P, T Block
Floor, P, T Block (1-Additional Actuator Piping, Accumulator)
Floor, P, T Block (2-Additional Actuator Piping, Accumulator)
Floor, Seal
Cab In Parts, Pump Controller and Relay
Cab In Parts, Air Conditioner Controller and KOMTRAX Controller
Floor Mounting
Switch
GUARDS AND COVERS
Hood
(With Dust-proof Net, Intake Gas and Exhaust Gas)
Net (With Dust-proof Net, Intake Gas and Exhaust Gas)
Machine Cab Frame
Door L.H.
Frame and Cover
Frame and Cover (With Dust-proof Net, Intake Gas and Exhaust Gas)
Frame and Cover (With Pre-cleaner)
Frame and Cover (With Pre-cleaner,Dust-proof Net, Intake Gas and Exhaust Gas)
Frame
Frame (With Dust-proof Net, Intake Gas and Exhaust Gas)
Frame and Duct
Inner Parts, Pre-cleaner
Inner Parts, Pre-cleaner (With Dust-proof Net, Intake Gas and Exhaust Gas)
Door R.H.
(1/2)
(2/2)
Machine Cab Partition
Lower
Lower (With Control Pattern Change Over Valve)
L.H.
L.H. (With Control Pattern Change Over Valve)
Center and R.H.
Center and R.H. (With Control Pattern Change Over Valve)
Machine Cab Cover
Right Side Case
(With Arm Crane)
Tool Box and Step
Tool Box and Step (With Arm Crane)
Handrail
(With Pre-cleaner)
Rearview Mirror L.H.
Rearview Mirror R.H.
Counterweight
Counterweight Mounting
Under Cover
SWING CIRCLE AND ITS RELATED PARTS
Swing Circle
Swing Machinery and Motor
Electric Swing Motor
Swing Machinery (1/2)
Swing Machinery (2/2)
Motor Drain
Swivel Joint
Connecting Parts
TRAVEL SYSTEM AND ITS RELATED PARTS
Final Drive
Travel Motor and Final Drive
Travel Motor, L.H. (1/2)
Travel Motor, L.H. (2/2)
Final Drive L.H.
Travel Motor, R.H. (1/2)
Travel Motor, R.H. (2/2)
Final Drive R.H.
Cover
UNDERCARRIAGE
Front Idler and Idler Cushion
Front Idler
Front Idler (With Rustproof Spring LV2)
Idler Cushion
Idler Cushion (With Rustproof Spring LV2)
Track Roller
Carrier Roller
Track Shoe Assembly
(Flat Type Shoe, 600mm Width, Grease Sealed Type, 90 Set)
(Oblong Holed Triple Grouser Shoe, 600mm Width, Grease Sealed Type, 90 Set)
(Oblong Holed Triple Grouser Shoe, 700mm Width, Grease Sealed Type, 90 Set)
(Oblong Holed Triple Grouser Shoe, 800mm Width, Grease Sealed Type, 90 Set)
(Road Liner Shoe, 600mm Width, Grease Sealed Type, 90 Set)
(Swamp Shoe, 860mm Width, Grease Sealed Type, 90 Set)
(Triple Grouser Shoe for City Pad, 600mm Width, Grease Sealed Type, 90 Set)
Track Link Assembly
(Supply Only, 90 Set,Grease Sealed Type)
Track Frame
(With Under Cover)
Track Frame Under Cover
Track Roller Guard
(Full Length)
WORK EQUIPMENT
Boom
Boom and Bracket (5700mm)
Boom and Bracket (5700mm Heavy Duty Type)
Boom and Bracket (5700mm, 2-Additional Actuator Piping Demolition Specification)
Top Pin and Bottom Pin
Top Pin and Bottom Pin (With Arm Crane)
Arm Cylinder Piping
Arm Cylinder Piping (5700mm)
Arm Cylinder Piping (5700mm,With Arm Crane)
Arm Cylinder Piping (With Arm Crane)
Bucket Cylinder Piping
Bucket Cylinder Piping (With Arm Crane)
Bucket Cylinder Piping (5700mm,With Arm Crane)
Bucket Cylinder Piping (5700mm,Arm Crane, Breaker)
Additional Piping
Additional Piping (1/2) (5700mm, 2-Additional Actuator Piping Demolition Specification)
Additional Piping (2/2) (5700mm, 2-Additional Actuator Piping Demolition Specification)
Drain Piping (5700mm, 2-Additional Actuator Piping Demolition Specification)
Drain Piping (5700mm, 2-Additional Actuator Piping Demolition Specification,Arm Crane, Breaker)T1110-007008 733
Working Lamp (With Arm Crane)
Working Lamp (5700mm Heavy Duty Type, 1-Attachment)
Working Lamp (5700mm, 2-Additional Actuator Piping Demolition Specification)
Boom Cylinder
Inner Parts, Boom Cylinder, L.H.
Inner Parts, Boom Cylinder, L.H. (With Arm Crane)
Inner Parts, Boom Cylinder, R.H.
Inner Parts, Boom Cylinder, R.H. (With Arm Crane)
Fitting
Fitting (With Arm Crane)
Boom Cylinder Head Pin
Arm Cylinder
Inner Parts, Arm Cylinder
Inner Parts, Arm Cylinder (With Arm Crane)
Shipping Parts
Arm
Arm and Pin (2400mm)
Arm and Pin (2400mm, 1-Attachment)
Arm and Pin (2900mm)
Arm and Pin (2900mm, Heavy Duty Type)
Arm and Pin (2900mm,With Additional Actuator Piping, Accumulator)
Inner Parts, Bucket Cylinder (2400mm)
Inner Parts, Bucket Cylinder (2900mm)
Bucket Link (2400mm)
Bucket Link (2400mm, 1-Attachment)
Bucket Link (2900mm)
Bucket Link (2900mm,With Arm Crane)
Bucket Link (2900mm, Heavy Duty Type)
Bucket Cylinder Hose (2400mm)
Bucket Cylinder Hose (2400mm, 1-Attachment)
Bucket Cylinder Hose (2900mm)
Bucket Cylinder Hose (2900mm, Heavy Duty Type)
Bucket Cylinder Hose (2900mm,With Arm Crane)
Bucket Cylinder Hose (2900mm,With 1-Additional Actuator Piping, Accumulator)
Bucket Cylinder Hose (2900mm, 2-Additional Actuator Piping Demolition Specification)
Additional Piping (2400mm, 1-Attachment)
Additional Piping (2900mm,With 1-Additional Actuator Piping, Accumulator)
Hose and Bracket (2900mm, 2-Additional Actuator Piping Demolition Specification)
Stop Valve (2900mm, 2-Additional Actuator Piping Demolition Specification)
Attachment Piping (2900mm, 2-Additional Actuator Piping Demolition Specification)
O-ring (2900mm, 2-Additional Actuator Piping Demolition Specification)
O-ring (2900mm, 2-Additional Actuator Piping Demolition Specification,Arm Crane, Breaker)
Bucket
(0.80m3, 1150mm Width, Vertical Pin Type, Thrust Adjustment, Side Cutter)
(0.80m3, 1150mm Width, Horizontal Pin Type, Thrust Adjustment, Side Cutter)
(0.80m3, 1170mm Width, PAB Tooth, Side Cutter)
(0.80m3, Heavy Duty Type, 1170mm Width, PAB Tooth, Side Cutter)
(0.80m3, Reinforced Type, 1150mm Width, Horizontal Pin Type, Side Cutter)
(0.90m3, 1200mm Width, Vertical Pin Type, Thrust Adjustment, Side Cutter)
(0.90m3, 1200mm Width, Horizontal Pin Type, Thrust Adjustment, Side Cutter)
(0.90m3, 1325mm Width, PAB Tooth, Thrust Adjustment, Side Cutter)
(1.00m3, 1330mm Width, Vertical Pin Type, Side Cutter)
(1.00m3, 1330mm Width, Horizontal Pin Type, Side Cutter)
(1.00m3, 1455mm Width, PAB Tooth, Side Cutter)
(1.17m3, 1450mm Width, PAB Tooth)
(1.17m3, 1450mm Width, Vertical Pin Type)
(1.17m3, 1450mm Width, Horizontal Pin Type)
Me Bucket
(0.80m3, 1170mm Width, PAB Tooth, Thrust Adjustment, Side Cutter)
(0.80m3, 1170mm Width, Horizontal Pin Type, Thrust Adjustment, Side Cutter)
(0.93m3, 1325mm Width, PAB Tooth, Side Cutter)
(0.93m3, 1325mm Width, PAB Tooth, Thrust Adjustment, Side Cutter)
(0.93m3, 1330mm Width, Horizontal Pin Type, Side Cutter)
(0.93m3, 1330mm Width, Horizontal Pin Type, Thrust Adjustment, Side Cutter)
(1.05m3, 1330mm Width, Horizontal Pin Type, Side Shroud)
(1.05m3, 1340mm Width, PAB Tooth, Side Shroud)
(1.05m3, 1340mm Width, PAB Tooth, Thrust Adjustment, Side Shroud)
(1.05m3, 1395mm Width, Horizontal Pin Type, Thrust Adjustment, Side Shroud)
Trapezoidal Bucket
Ditch Cleaning Bucket
Slope Finishing Bucket
Ripper Bucket
Ripper
(1 Shank)
(3 Shank)
Spacer (1.00m3, 1330mm Width, Vertical Pin Type, Side Cutter)
Spacer (1.00m3, 1330mm Width, Horizontal Pin Type, Side Cutter)
Spacer (1.00m3, 1455mm Width, PAB Tooth, Side Cutter)
Spacer (1.17m3, 1450mm Width, PAB Tooth)
Spacer (1.17m3, 1450mm Width, Vertical Pin Type)
Spacer (1.17m3, 1450mm Width, Horizontal Pin Type)
Spacer
Breaker Adapter
Accumulator Related Parts (For Krupp Breaker Kit)
Accumulator Related Parts (For Nippon Pneumatic Breaker Kit)
Hose and Clamp (For Krupp Breaker Kit)
Hose and Clamp (For Nippon Pneumatic Breaker Kit)
Adapter (For Krupp Breaker Kit)
Adapter (For Okada Breaker Kit or Atlas Breaker Kit)
Adapter (For Furukawa Breaker Kit or Matsuda Breaker Kit)
MARKS AND PLATES
Marks and Plates
Lubrication Chart
Caution Plates, Window Lock
Indicate Structural Standard Plate
(2400mm Arm)
(2900mm Arm)
(2900mm Arm, Heavy Duty Type)
(5700mm Heavy Duty Boom,2900mm Arm, Heavy Duty Type)
(With Material Handling,Arm Crane, Breaker)
(Without Boom,Arm)
Instruction Plate of Guard Wearing
Komatsu Logo
Lifting Capacity Chart
Caution Plates, Battery
(Large Capacity)
Coolant Decal
Fire Prevention Plates
Hydraulic Hose Periodical Exchange Plate
Caution Plates, Blast Site
Seat Belt Wearing Plate
Control Pattern Plates
(Control Pattern Change Over Valve,4-Way)
(Control Pattern Change Over Valve (KOMATSU/ISO))
Caution Plates, Keep Off Working Ranges
FOPS Plate
(With Cab Top Guard LV2)
(With Cab Front Full Guard LV1 or LV2)
(Cab Front Full Guard LV1 or LV2, Top Guard LV2)
ROPS Plate
Plates, Air Cleaner
Caution Plates, Accumulator
Kit)
Caution Plates, Backward
Caution Plates, 24Volt
(Power Supply, 12volt)
(Power Supply, 12volt,For Krupp Breaker Kit or Nippon Pneumatic Breaker Kit)
AUXILIARY PARTS AND TOOL
Tool
OTHER EQUIPMENT
Additional Track Frame Step
SPECIAL PRODUCT AND ITS RELATED PARTS
Arm Crane Unit
Control Valve Related Parts
Control Valve Related Parts (Material Handling 2-Additional Actuator Pipingr Specification)
Drain Piping (1/2)
Drain Piping (1/2) (With Breaker)
Drain Piping (1/2) (Material Handling 2-Additional Actuator Pipingr Specification)
Drain Piping (2/2)
Drain Piping (2/2) (Material Handling 2-Additional Actuator Pipingr Specification)
Arm Lock Valve Piping
Arm Lock Valve Piping (With Breaker)
Bucket Link and Hook
Mark and Plate
Mark and Plate (With Breaker)
Hydraulic Tank Elbow
Solenoid Valve Piping (With Breaker)
Boom Angle Sensor
Spirit Level
Arm Angle Sensor
Boom Anti-drop Valve
Boom Anti-drop Valve Mounting
Boom Anti-drop Valve Piping
Arm Anti-drop Valve
Arm Anti-drop Valve Mounting
Arm Anti-drop Valve Piping
Plate and Case
Plate and Case (With Breaker)
Plate and Case (Material Handling 2-Additional Actuator Pipingr Specification)
Service Kit Parts
KIT 926
