704,032
Komatsu Forklift FG35Z-4 to FG45S-4, FD33S-4 to FD45S-4 Shop Manual SM030
Type of Machine: Forklift
Type of Manual: Shop Manual
Model: FG35Z-4 FG40Z-4 FD35Z-4 FD40Z-4 FG35-4 FG40-4 FG45-4 FD35-4 FD40-4 FD45-4 FG33S-4 FG35S-4 FG40S-4 FG45S-4 FD33S-4 FD35S-4 FD40S-4 FD45S-4
Part Number: SM030 FG35/45.4-BE5
Number of Pages: 770 Pages
FOREWORD
GENERAL DISASSEMBLY AND ASSEMBLY
DESCRIPTION OF THE SYMBOLS
GENERAL AND SPECIFICATIONS
GENERAL VIEW
SPECIFICATIONS
ENGINE PERFORMANCE CURVE
WEIGHT TABLE
INSPECTION AND MAINTENANCE
TURBOCHARGER (S6D95L)
CYLINDER HEAD
VALVE AND VALVE GUIDE
ROCKER ARM SHAFT, PUSH ROD AND TAPPET
CYLINDER BLOCK
PISTON, PISTON RING AND PISTON PIN
CONNECTING ROD
TIMING GEAR
CAMSHAFT
FLYWHEEL AND FLYWHEEL HOUSING
OIL PUMP
REGULATOR VALVE
WATER PUMP AND THERMOSTAT
CYLINDER HEAD SECTION
CYLINDER BLOCK SECTION
INTAKE AND EXHAUST SYSTEM
LUBRICATION SYSTEM
FUEL SYSTEM
COOLING SYSTEM
ELECTRICAL SYSTEM
TESTING AND ADJUSTING DATA
FUEL INJECTION PUMP CALIBRATION DATA
STANDARD VOLUME OF FUEL INJECTION
ADJUSTMENT OF GOVERNOR
METHOD OF USING TROUBLESHOOTING CHART
POINTS TO REMEMBER WHEN TROUBLESHOOTING
STARTING PERFORMANCE IS POOR
ENGINE DOES NOT START
ENGINE DOES NOT PICK UP SMOOTHLY (FOLLOW-UP IS POOR)
ENGINE STOPS DURING OPERATIONS
ENGINE DOES NOT ROTATE SMOOTHLY
ENGINE LACKS OUTPUT (NO POWER)
EXHAUST GAS IS BLACK (INCOMPLETE COMBUSTION)
OIL CONSUMPTION IS EXCESSIVE (OR EXHAUST GAS IS BLUE)
OIL BECOMES CONTAMINATED QUICKLY
FUEL CONSUMPTION IS EXCESSIVE
OIL IS IN COOLING WATER, OR WATER SPURTS BACK, OR WATER LEVEL GOES DOWN
OIL PRESSURE LAMP LIGHTS UP (DROP IN OIL PRESSURE)
OIL LEVEL RISES
WATER TEMPERATURE BECOMES TOO HIGHT (OVERHEATING)
ABNORMAL NOISE IS MADE
VIBRATION IS EXCESSIVE
GENERAL
GENERAL STRUCTURE
ELECTRICAL SYSTEM
ENGINE BODY
FUEL SYSTEM
LUBRICATION SYSTEM
COOLING SYSTEM
PERFORMANCE TEST
CONVERSION TABLE
POWER TRAIN
STEERING SYSTEM
BRAKE SYSTEM
HYDRAULIC SYSTEM
MAST
ELECTRICAL
REMOVAL AND INSTALLATION OF UNITS
SERVICE INFORMATION
TROUBLESHOOTING
MAINTENANCE STANDARD
CRANKSHAFT
STRUCTURE AND FUNCTION
