Hyundai
86
176,834
Komatsu Forklift FD200-7 FD250-7 Shop Manual SEN06609-04 2026
Type of Machine: Forklift
Type of Manual: Shop Manual, Electric and Hydraulic Diagrams
Model: Komatsu FD200-7 FD250-7 Forklift
Serial Number:
FD200- 2601 and up
FD250- 3601 and up
Part Number: SEN06609-04
Publication Date: 2026
Number of Pages: 342 Pages
10. Outline
Specifications​
Safety items for maintenances​
Standard tightening torque table​
How to use Loctite​
20. Testing and adjusting
Service data​
Replace fuel filter​
TORQFLOW transmission case​
Drive axle and brake​
Adjust accelerator pedal​
Adjust parking brake​
Measure lift and tilt cylinder drift (Lift truck with fork specification)​
Lubrication points​
Cooling system​
Check and replace alternator belt​
Check and replace auto-tensioner​
Hydraulic tank​
Adjust mast​
Air bleeding procedure​
Specified fuels and lubricants​
Lamp display of KOMTRAX terminal​
Brake accumulator​
Work equipment accumulator​
30. Removal and installation
Weight table​
Remove and install units​
Engine​
Torque converter and transmission​
Mast​
Lift cylinder​
Removal and installation of KOMTRAX terminal​
Battery​
Wheel​
40. Disassembly and assembly
Torque converter​
TORQFLOW transmission​
Transmission control valve​
Brake valve​
Steering axle​
Parking brake​
Steering valve​
Hydraulic pump​
Work equipment control valve​
Mast​
Lift cylinder​
Tilt cylinder​
Power steering cylinder​
Side shift cylinder​
Disassemble lift cylinder and tilt cylinder​
50. Maintenance standard
Torque converter​
Differential​
Disc brake​
Steering axle​
Brake valve​
Lift cylinder​
Tilt cylinder​
Mast, fork carriage, and fork​
60. Structure and function
Torque converter​
Automatic transmission​
Steering system​
Steering axle​
Work equipment​
Meter panel​
Electric circuit diagram (1/2)​
Electric circuit diagram (2/2)​
Hydraulic circuit diagram​
70. Yearly inspection criteria
80. Troubleshooting
Check functions of troubleshooting tools and failure codes​
Failure codes table​
Electrical-system failure code record display function (only for interlock controller system)​
Troubleshooting by failure code (only for interlock controller system)​
Checking water pump for water leakage​
