Hyundai
86
176,834
Komatsu Forklift FB25-12 SN 100001-UP Parts Catalog
Type of Machine: Forklift
Model: Komatsu FB25-12 Forklift
Serial Number: 100001-UP
Number of Pages: 488 Pages
TOOL (FOR DOUBLE TIRE)
ACCESSORY AND TOOL
TOOL (FOR DOUBLE TIRE) 2
TOOL (FOR SINGLE TIRE)
ATT PIPING-FFV MAST
3-SPOOL CONTROL VALVE FFV MAST PIPING (1_2)
3-SPOOL CONTROL VALVE FFV MAST PIPING (2_2)
ATT PIPING-FV MAST
3-SPOOL CONTROL VALVE FV MAST PIPING (FOR SIDE SHIFTER INTEGRAL TYPE)
ATT PIPING-TFV MAST
3-SPOOL CONTROL VALVE TFV MAST PIPING (INTEGRAL TYPE) (1_2)
3-SPOOL CONTROL VALVE TFV MAST PIPING (INTEGRAL TYPE) (4.0M-4.7M) (2_2)
3-SPOOL CONTROL VALVE TFV MAST PIPING (INTEGRAL TYPE) (5.0M-6.0M) (2_2)
AXLE AND BRAKE SYSTEM
DRIVE AXLE (CASE)
DRIVE AXLE (GEAR)
DRIVE AXLE (HUB) (FOR DOUBLE TIRE_WIDE TREAD)
DRIVE AXLE (HUB) (FOR SINGLE TIRE)
DRIVE AXLE (MOUNTING PARTS)
DRIVE AXLE (SUPPORT AND BRAKE)
DRIVE AXLE (SUPPORT AND BRAKE) (FOR DOUBLE TIRE_WIDE TREAD)(#101963-)
PARKING BRAKE LEVER
STEERING AXLE (AXLE)
STEERING AXLE (AXLE) (FISHERY_COLD_DUST-PROOF SPEC.)
STEERING AXLE (HUB)
STEERING AXLE (HUB) (FISHERY_COLD_DUST-PROOF SPEC.)
STEERING AXLE (PIPING-STEERING VALVE TO STEERING CYLINDER)
STEERING AXLE (POWER CYLINDER INNER PARTS)(#100001-101779)
STEERING AXLE (POWER CYLINDER INNER PARTS)(#101780-)
STEERING AXLE (STEERING CYLINDER)
STEERING AXLE (STEERING CYLINDER) (FISHERY_COLD_DUST-PROOF SPEC.)
WHEEL BRAKE (INNER PARTS)
WHEEL BRAKE (INNER PARTS) (FOR DOUBLE TIRE_WIDE TREAD)(#101963-)
ELECTRICAL SYSTEM
BACK BUZZER
BACK BUZZER (WITH FORWARD AND REVERSE TRAVEL CHIME)
BACK BUZZER (WITH VOLUME ADJUST AND FORWARD TRAVEL CHIME)
BACK BUZZER (WITH VOLUME ADJUST)
BATTERY (FOR TURKISH AND RUSSIAN)
BATTERY (WITH COLLECTIVE SUPPLEMENTARY WATER DEVICE) (FOR TURKISH AND RUSSIAN)
BATTERY CASE
BEACON LAMP
BEACON LAMP (FOR ADDITIONAL OPTION SYSTEM)
BEACON LAMP (FOR LED AND ADDITIONAL OPTION SYSTEM)
BEACON LAMP (FOR LED)
CHARGER (INNER PARTS) (STATIONAL TYPE) (72V 330AH-450AH)
CHARGER (INNER PARTS) (STATIONAL TYPE) (72V 440AH-560AH)
CHARGER UNIT (CHARGER AND TRANS LESS PARTS)
CHARGER UNIT (CHARGER AND TRANS LESS PARTS) (FOR REAR COMBINATION LAMP ON HEAD GUARD)
CHARGER UNIT (CHARGER-STATIONAL TYPE) (AC _ 3 PHASE _ 200V)
CHARGER UNIT (CHARGER-STATIONAL TYPE) (AC _ 3 PHASE _ 200V) 1
CHARGER UNIT (CHARGER-STATIONAL TYPE) (AC _ 3 PHASE _ 400V) (72V 330-450AH)
CHARGER UNIT (CHARGER-STATIONAL TYPE) (AC _ 3 PHASE _ 400V) (72V 440-560AH)
CONTACTOR (INNER PARTS)
CONTACTOR (INNER PARTS) (WITH KOMTRAX)
FORWARD TRAVEL ALARM
FORWARD TRAVEL CHIME (FOR BACK BUZZER WITH VOLUME ADJUST OR VOICE ALARM)
FRONT WORKING LAMP (ON FENDER)
FRONT WORKING LAMP (ON FENDER) (FOR LED)
KOMTRAX (ANTENNA)
KOMTRAX (ANTENNA) (3G)
KOMTRAX (CONTROLLER)
KOMTRAX (CONTROLLER) (3G)
MAIN CONTROLLER (BATTERY CABLE) (FOR TURKISH AND RUSSIAN)
MAIN CONTROLLER (BATTERY CABLE)(#100001-102177)
MAIN CONTROLLER (BATTERY CABLE)(#10217
MAIN CONTROLLER (CONVERTER AND HEAT SINK)
MAIN CONTROLLER (CONVERTER AND HEAT SINK) (FOR LED HEAD LAMP)
MAIN CONTROLLER (COVER)
MAIN CONTROLLER (FAN AND INVERTER CABLE)
MAIN CONTROLLER (INVERTER AND CONTACTOR)
MAIN CONTROLLER (INVERTER AND CONTACTOR) (WITH KOMTRAX)
MASTER CONTROLLER
PUMP MOTOR
REAR WORKING LAMP
REAR WORKING LAMP (FOR ADDITIONAL OPTION SYSTEM)
REAR WORKING LAMP (FOR LED ADDITIONAL OPTION SYSTEM)
REAR WORKING LAMP (FOR LED)
TRACTION MOTOR
WIRING HARNESS (FAN)
WIRING HARNESS (MAIN WIRING HARNESS) (FOR FORWARD AND REVERSE SWITCH L.H.)(#100001-101220)
WIRING HARNESS (MAIN WIRING HARNESS) (FOR FORWARD AND REVERSE SWITCH L.H.)(#101221-102313)
WIRING HARNESS (MAIN WIRING HARNESS) (FOR FORWARD AND REVERSE SWITCH L.H.)(#102314-)
WIRING HARNESS (MOUNTING PARTS) (1_2)
WIRING HARNESS (MOUNTING PARTS) (2_2)
WIRING HARNESS (MOUNTING PARTS) (2_2) (FOR LED HEAD LAMP)
WIRING HARNESS (TRACTION MOTOR CABLE AND PUMP MOTOR CABLE)
WIRING HARNESS FOR OPTIONAL SYSTEM (CONVERTER)
WIRING HARNESS FOR OPTIONAL SYSTEM (WIRING HARNESS)
WIRING HARNESS FOR OPTIONAL SYSTEM (WIRING HARNESS) (FOR SEAT BELT INTERLOCK)
FORK POSITIONER-FV MAST
FORK POSITIONER (FV MAST) (FMH254) (SIMULTANEOUS STROKE HOOK_HOOK TYPE) (CYLINDER AND PIPING)
FORK POSITIONER (FV MAST) (FMH254) (SIMULTANEOUS STROKE HOOK_HOOK TYPE) (CYLINDER INNER PARTS)
FORK POSITIONER (FV MAST) (FMH254) (SIMULTANEOUS STROKE HOOK_HOOK TYPE) (FRAME AND ROLLER)
FORK_HOLDER (FOR ATTACHMENT)
FORK (FORK POSITIONER) (HOOK TYPE)
FORK (FORK POSITIONER) (INDEPENDENT STROKE SHAFT TYPE)
FRAME RELATED PARTS
FRAME
GUARD
BATTERY HOOD (1_2)(#100001-101867)
BATTERY HOOD (1_2)(#10186
BATTERY HOOD (2_2) (FOR AUSTRALIA)
BATTERY HOOD (2_2) (FOR TURKISH AND RUSSIAN)
BATTERY HOOD (2_2)(#100001-102054)
BATTERY HOOD (2_2)(#102055-)
BATTERY HOOD (HARNESS) (FOR SEAT BELT INTERLOCK)
CENTER AND SIDE VIEW MIRROR
CENTER VIEW MIRROR
COUNTERWEIGHT (FOR REAR COMBINATION LAMP ON HEAD GUARD)
COUNTERWEIGHT AND REAR COMBINATION LAMP
COUNTERWEIGHT AND REAR COMBINATION LAMP (FOR LED)
FENDER (FOR DOUBLE TIRE)(#100001-102445)
FENDER (FOR DOUBLE TIRE)(#102446-)
FENDER (FOR WIDE TREAD)(#100001-102445)
FENDER (FOR WIDE TREAD)(#102446-)
SIDE COVER (BATTERY)
SIDE COVER (FRAME)
SIDE VIEW MIRROR
STEP (1_2)(#100001-102202)
STEP (1_2)(#102203-)
STEP (2_2)
HYDRAULIC SYSTEM
BRAKE PIPING
HYDRAULIC PUMP
HYDRAULIC PUMP (INNER PARTS)
HYDRAULIC TANK
HYDRAULIC TANK (WITH LIFT CYLINDER RETURN PIPING)
MARKS AND PLATES
MARK AND PLATES (ENGLISH)
MARK AND PLATES (RUSSIAN)
MARK AND PLATES (TURKISH)
NAME PLATE (SIDE SHIFTER)
MISCELLANEOUS
ACCESSORY
OPERATOR'S COMPARTMENT AND CONTROL SYSTEM
BRAKE MASTER CYLINDER (INNER PARTS)
CANVAS CAB
COMBINATION SWITCH (INNER PARTS) (FOR FORWARD AND REVERSE SWITCH L.H.)
CONTROL VALVE (INNER PARTS) (COVER AND STUD BOLT)
CONTROL VALVE (INNER PARTS) (FOR 3-SPOOL CONTROL VALVE)
CONTROL VALVE (INNER PARTS) (FOR 3-SPOOL CONTROL VALVE) (WITH PORT RELIEF VALVE-0N 3RD VALVE)
CONTROL VALVE (INNER PARTS) (FOR 4-SPOOL CONTROL VALVE)
CONTROL VALVE (INNER PARTS) (LIFT SPOOL AND TILT SPOOL)
CONTROL VALVE (INNER PARTS)(FOR 4-SPOOL CONTROL VALVE)(WITH PORT RELIEF VALVE-0N 3RD AND 4TH VALVES)
FLOOR MAT
FLOOR PLATE AND ACCELERATOR PEDAL
FRONT WINDOW
FRONT WINDOW (RELATED PARTS)
GUARD UNIT (2-SPOOL CONTROL VALVE CONNECTING PARTS)
GUARD UNIT (2-SPOOL CONTROL VALVE LEVER)
GUARD UNIT (2-SPOOL CONTROL VALVE)
GUARD UNIT (3-SPOOL CONTROL VALVE CONNECTING PARTS)
GUARD UNIT (3-SPOOL CONTROL VALVE LEVER)
GUARD UNIT (3-SPOOL CONTROL VALVE)
GUARD UNIT (4-SPOOL CONTROL VALVE CONNECTING PARTS)
GUARD UNIT (4-SPOOL CONTROL VALVE LEVER)
GUARD UNIT (4-SPOOL CONTROL VALVE)
GUARD UNIT (ACTUATOR PIPING)
GUARD UNIT (BRACKET) (REAR COMBINATION LAMP ON HEAD GUARD)
GUARD UNIT (BRACKET)(FOR LED)
GUARD UNIT (BRAKE MASTER CYLINDER)
GUARD UNIT (BRAKE PEDAL)
GUARD UNIT (CONTROL LEVER COVER) (FOR 2-SPOOL CONTROL VALVE)
GUARD UNIT (CONTROL LEVER COVER) (FOR 3-SPOOL CONTROL VALVE)
GUARD UNIT (CONTROL LEVER COVER) (FOR 4-SPOOL CONTROL VALVE)
GUARD UNIT (DASHBOARD COVER)
GUARD UNIT (DASHBOARD PIPING) (FOR 3-SPOOL CONTROL VALVE)
GUARD UNIT (DASHBOARD PIPING) (FOR 4-SPOOL CONTROL VALVE)
GUARD UNIT (DASHBOARD)
GUARD UNIT (HALOGEN HEAD LAMP)
GUARD UNIT (HEAD GUARD)
GUARD UNIT (HORN)
GUARD UNIT (LED HEAD LAMP)
GUARD UNIT (MONITOR)
GUARD UNIT (MOUNTING PARTS)
GUARD UNIT (REAR COMBINATION LAMP ON HEAD GUARD)
GUARD UNIT (RETURN PIPING)
GUARD UNIT (STEERING COLUMN AND STEERING VALVE) (FOR FORWARD AND REVERSE SWITCH L.H. AND ID KEY)
GUARD UNIT (STEERING COLUMN AND STEERING VALVE) (FOR FORWARD AND REVERSE SWITCH L.H.)
GUARD UNIT (STEERING COLUMN COVER AND KEY SWITCH)
GUARD UNIT (STEERING COLUMN COVER AND KEY SWITCH) (EU SPEC.)
GUARD UNIT (STEERING COLUMN COVER AND KEY SWITCH) (FOR ID KEY.)(#100001-100449)
GUARD UNIT (STEERING COLUMN COVER AND KEY SWITCH) (FOR ID KEY.)(#100550-)
GUARD UNIT (STEERING COLUMN COVER AND KEY SWITCH)(#100001-100549)
GUARD UNIT (STEERING WHEEL)
HEAD GUARD COVER
OPERATOR'S SEAT (FOR SEAT BELT INTERLOCK)
OPERATOR'S SEAT (FOR SEAT HEATER)(#100001-101699)
OPERATOR'S SEAT (FOR SEAT HEATER)(#101700-)
OPERATOR'S SEAT (FOR TURKISH AND RUSSIAN)(#100001-102132)
OPERATOR'S SEAT (FOR TURKISH AND RUSSIAN)(#102133-)
OPERATOR'S SEAT (INNER PARTS) (FOR SEAT BELT INTERLOCK)
OPERATOR'S SEAT (INNER PARTS) (FOR TURKISH AND RUSSIAN)
OPERATOR'S SEAT (INNER PARTS)(#100001-101699)
OPERATOR'S SEAT (INNER PARTS)(#101700-)
OPERATOR'S SEAT(#100001-101699)
OPERATOR'S SEAT(#101700-)
STEERING VALVE (INNER PARTS)
SIDE SHIFTER-FFV MAST
SIDE SHIFTER (FFV MAST) (FSA253) (INTEGRAL TYPE) (CYLINDER INNER PARTS)
SIDE SHIFTER (FFV MAST) (FSA253) (INTEGRAL TYPE) (FRAME)
SIDE SHIFTER (FFV MAST) (FSA253) (INTEGRAL TYPE) (ROLLER)
SIDE SHIFTER-FV MAST
SIDE SHIFTER (FV MAST) (FSA253) (INTEGRAL TYPE) (CYLINDER INNER PARTS)
SIDE SHIFTER (FV MAST) (FSA253) (INTEGRAL TYPE) (FRAME)
SIDE SHIFTER (FV MAST) (FSA253) (INTEGRAL TYPE) (FRAME) (FOR 4-SPOOL CONTROL VALVE)
SIDE SHIFTER (FV MAST) (FSA253) (INTEGRAL TYPE) (ROLLER)
SIDE SHIFTER (FV MAST) (FSA253) (INTEGRAL TYPE) (ROLLER) (HIGH=1334MM)
SIDE SHIFTER (FV MAST) (FSH254) (ROLLER TYPE) (CYLINDER INNER PARTS)
SIDE SHIFTER (FV MAST) (FSH254) (ROLLER TYPE) (FRAME)
SIDE SHIFTER (FV MAST) (FSH254) (ROLLER TYPE) (PIPING)
SIDE SHIFTER (FV MAST) (FSH254) (ROLLER TYPE) (ROLLER)
SIDE SHIFTER-TFV MAST
SIDE SHIFTER (TFV MAST) (FSA253) (INTEGRAL TYPE) (CYLINDER INNER PARTS)
SIDE SHIFTER (TFV MAST) (FSA253) (INTEGRAL TYPE) (FRAME)
SIDE SHIFTER (TFV MAST) (FSA253) (INTEGRAL TYPE) (ROLLER)
WHEEL RELATED PARTS
FRONT WHEEL (23X9-10) (ELASTIC CUSHION) (RIB-LUG)
FRONT WHEEL (23X9-10-16PR) (RIB-LUG)
FRONT WHEEL (23X9-10-16PR) (SNOW)
FRONT WHEEL (DOUBLE TIRE) (6.50-10-10PR) (RIB-LUG)
FRONT WHEEL (DOUBLE TIRE) (6.50-10-10PR) (SNOW)
FRONT WHEEL (DOUBLE TIRE) (6.50-10_5.00) (ELASTIC CUSHION) (RIB-LUG)
FRONT WHEEL (WIDE TREAD) (23X9-10) (ELASTIC CUSHION) (RIB-LUG)
FRONT WHEEL (WIDE TREAD) (23X9-10-16PR) (RIB-LUG)
FRONT WHEEL HUB NUT (FOR DOUBLE TIRE)
FRONT WHEEL HUB NUT (FOR SINGLE TIRE)
FRONT WHEEL HUB NUT (FOR SINGLE WIDE TREAD TIRE)
REAR WHEEL (18X7-8) (ELASTIC CUSHION) (RIB-LUG)
REAR WHEEL (18X7-8) (SNOW)
REAR WHEEL (18X7-8-16PR) (RIB-LUG)
WORK EQUIPMENT
FFV MAST (FORK CARRIAGE AND BACK REST)
FFV MAST (LIFT CYLINDER INNER PARTS) (FRONT) (3.0-4.0M)
FFV MAST (LIFT CYLINDER INNER PARTS) (REAR) (L.H.) (3.0-4.0M)
FFV MAST (LIFT CYLINDER INNER PARTS) (REAR) (R.H.) (3.0-4.0M)
FFV MAST (LIFT PIPING)
FFV MAST (MAST AND LIFT CYLINDER)
FFV MAST (MAST ATTACHING PARTS)
FFV MAST (MOUNTING PARTS)
FFV MAST (TILT CYLINDER PIN)
FORK (L=1150MM_1370MM_1520MM_1670MM_1820MM_2000MM_2200MM)
FORK (L=2120MM)
FORK (L=920MM_1070MM_1220MM)
FV MAST (FORK CARRIAGE AND BACK REST) (FOR HIGH BACKREST)
FV MAST (LIFT CYLINDER INNER PARTS) (3.0-3.5M)
FV MAST (LIFT CYLINDER INNER PARTS) (4.0-5.0M)
FV MAST (LIFT SENSOR BRACKET)
FV MAST (LIFT SENSOR)
FV MAST (RETURN LINE)
TFV MAST (FORK CARRIAGE AND BACK REST)
TFV MAST (LIFT CYLINDER INNER PARTS) (FRONT)
TFV MAST (LIFT CYLINDER INNER PARTS) (REAR)
TFV MAST (LIFT PIPING)
TFV MAST (MAST AND LIFT CYLINDER)
TFV MAST (MAST ATTACHING PARTS_1_2)
TFV MAST (MAST ATTACHING PARTS_2_2)
TFV MAST (MAST SENSOR)
TFV MAST (MOUNTING PARTS)
TFV MAST (SENSOR BRACKET) (FOR SEAT BELT INTERLOCK)
TFV MAST (TILT CYLINDER PIN)
TILT CYLINDER
TILT CYLINDER (INNER PARTS) (WITH BOOT)(#100001-101956)
TILT CYLINDER (INNER PARTS) (WITH BOOT)(#101957-)
TILT CYLINDER (INNER PARTS)(#100001-101956)
TILT CYLINDER (INNER PARTS)(#101957-)
TILT CYLINDER (WITH BOOT)
TILT CYLINDER SPACER
TILT INDICATOR
