BigBoss1
106
307,254
Komatsu Excavator PC58SF-1 SN 1001-UP Parts Catalog
Type of Machine: Excavator
Model: Komatsu PC58SF-1 Excavator
Serial Number: 1001-UP
Number of Pages: 321 Pages
KOMATSU PC58SF-1 S N 1001-UP
ENGINE RELATED PARTS
ENGINE MOUNT (1 2)
ENGINE MOUNT (2 2)
ENGINE MOUNT (2 2) (UPPER MUFFLER)
POWER TAKE OFF
COOLER COMPRESSOR
COOLING SYSTEM
RADIATOR AND OIL COOLER
COOLING (SUB TANK)
CONDENSER (MOUNTING)
CONDENSER (PIPING)
FUEL TANK AND RELATED PARTS
FUEL TANK (TANK)
FUEL TANK (FUEL LINE)
ELECTRICAL SYSTEM
BATTERY AND MOUNTING
BATRERY AND MOUNTING (LARGE CAPACITY)
ELECTRICAL (MAIN HARNESS) (CANOPY AND CAB) (1 3)
ELECTRICAL (MAIN HARNESS) (CANOPY AND CAB) (2 3)(#1001-1018)
ELECTRICAL (MAIN HARNESS) (CANOPY AND CAB) (2 3)(#1019-)
ELECTRICAL (MAIN HARNESS) (CANOPY AND CAB) (3 3)(#1001-1072)
ELECTRICAL (MAIN HARNESS) (CANOPY AND CAB) (3 3)(#1073-)
HYDRAULIC SYSTEM
HYDRAULIC TANK
MAIN VALVE (MOUNT AND ELBOW)
MAIN VALVE (BRACKET)
MAIN PUMP (MOUNT AND ELBOW)
SUCTION LINE
DELIVERY LINE
RERURN LINE
DRAIN LINE
ACTUATOR LINE (1ST BOOM)
ACTUATOR LINE (2ND BOOM¤BUCKET¤ ARM AND OFFSET)
ACTUATOR LINE (BLADE¤SWING AND TRAVEL)
ACTUATOR LINE (PLATE AND CUSHION)
ACTUATOR LINE (MOUNT)
ACTUATOR LINE (SWING SUCTION LINE)
E.P.C. MAIN LINE (PUMP LINE)
E.P.C. MAIN LINE (BRACKET)
E.P.C. MAIN LINE (EPC MAIN LINE)
MAIN REVOLVING FRAME AND RELATED PARTS
REVOLVING FRAME
BOOM FOOT PIN
LUBRICATING LINE
OPERATOR'S COMPARTMENT AND CONTROL SYSTEM
OPERATOR'S SEAT(#1001-1300)
OPERATOR'S SEAT (RECLINING)(#1301-)
SEAT BELT (50MM WIDE)
OPERATOR'S CAB (CAB)
OPERATOR'S CAB (RAIL)
OPERATOR'S CAB (BRACKET)
OPERATOR'S CAB (DOOR 1 2)
OPERATOR'S CAB (DOOR 2 2)
OPERATOR'S CAB (PULL UP)
OPERATOR'S CAB (LAMP)
OPERATOR'S CAB (MOUNT)
HEAD GUARD
FLOOR MAT
WINDOW WASHER
CANOPY
HEATER (HOSE)
CAR COOLER (PIPING AND MOUNT)
RADIO
RADIO(#1301-)
RADIO (FM AM)(#1301-)
ASHTRAY
FLOOR FRAME (FLOOR FRAME) (FOR CAB)
FLOOR FRAME (FLOOR FRAME) (FOR CANOPY)
FLOOR FRAME (BASE)
FLOOR FRAME (TRAVEL CONTROL)
FLOOR FRAME (OFFSET CONTROL)
FLOOR FRAME (BLADE CONTROL)
FLOOR FRAME (LEVER L.H.)
FLOOR FRAME (COVER L.H.) (CANOPY)
FLOOR FRAME (COVER L.H.) (CAB)
FLOOR FRAME (LEVER R.H.)
FLOOR FRAME (PANEL)
FLOOR FRAME (MONITOR SYSTEM)
FLOOR FRAME (WIRING)(#1001-1018)
FLOOR FRAME (WIRING)(#1019-)
FLOOR FRAME (ELECTRICAL PARTS)
FLOOR FRAME (TRAVEL SPEED PEDAL)
FLOOR FRAME (ATTACHMENT CONTROL) (COVER)
FLOOR FRAME (HEATER) (COVER) (CANOPY)
FLOOR FRAME (HEATER) (CAB)
FLOOR FRAME (DECEL MOTOR)
FLOOR FRAME (BRACKET)
HARNESS KIT
FLOOR MOUNT (FLOOR MOUNT) (CANOPY)
FLOOR MOUNT (FLOOR MOUNT) (CAB)
FLOOR MOUNT (MOUNT PARTS)
FLOOR COVER (CANOPY)
FLOOR COVER (CAB)
MULTI SWITCH
HAND RAIL
GUARD
HOOD (COVER)
HOOD (COVER) (UPPER MUFFLER)
HOOD (HOOD)
LEFT SIDE COVER (CANOPY)
LEFT SIDE COVER (CAB)
RIGHT SIDE COVER
FRONT COVER (TANK COVER¤ 1 2)(#1001-1300)
FRONT COVER (TANK COVER¤ 1 2)(#1301-)
FRONT COVER (TANK COVER¤ 2 2)
FRONT COVER (FRONT COVER) (CANOPY)
FRONT COVER (FRONT COVER) (CAB)
FRONT COVER (FRONT COVER) (CAB) (UPPER MUFFLER)
REAR VIEW MIRROR (FOR CANOPY)
REAR VIEW MIRROR (FOR CAB)
COUNTER WEIGNT
COUNTER WEIGNT (UPPER MUFFLER)
UNDER COVER (1 2)
UNDER COVER (2 2)
SWING CIRCLE AND RELATED PARTS
SWING CIRCLE
SWING MACHINERY AND MOTOR (SWING MACHINERY)
SWIVEL JOINT (MOUNT AND ELBOW)(#1001-1018)
SWIVEL JOINT (MOUNT AND ELBOW)(#1019-)
TRAVEL AND LOWER PIPING
LOWER HYDRAULIC LINE (TRAVEL MOTOR LINE)
LOWER HYDRAULIC LINE (BLADE CYLINDER LINE)
FINAL DRIVE
SPROCKET
UNDER CARRIAGE
FRONT IDLER
IDLER CUSHION
TRACK ROLLER
CARRIER ROLLER
RUBBER SHOE
TRACK SHOE (FOR CITY PAD)
TRACK SHOE (ROAD LINEAR)(#1001-1300)
TRACK SHOE (STRENGTH ROAD LINEAR)(#1301-)
TRACK FRAME
TRACK FRAME COVER
TRACK GUARD (FOR RUBBER SHOE)
TRACK GUARD (FOR STEEL SHOE)
WORK EQUIPMENT
BOOM (1ST¤ 2ND BOOM¤ 3RD BRACKET AND SUB LINK)
BOOM (PIN)
BOOM (HYDRAULIC LINE)
BOOM (WORK LAMP AND COVER)
BOOM (SAFETY EQUIPMENT)
BOOM (SAFETY EQUIPMENT) (2ND BOOM)
BOOM CYLINDER
ARM CYLINDER
OFFSET CYLINDER
ARM (ARM AND PIN)
ARM (ARM AND PIN) (MULTIPLE CHANGE)
ARM (SAFETY EQUIPMENT)
ARM (SAFETY EQUIPMENT) (MULTIPLE CHANGE)
BUCKET CYLINDER
BUCKET CYLINDER (MULTIPLE CHANGE)
BUCKET LINK
BUCKET LINK (MULTIPLE CHANGE) (FOR KKU COUPLER)
BUCKET LINK (MULTIPLE CHANGE) (FOR KHY COUOLER)
BUCKET PIN
BUCKET PIN (FOR WIDTH 370MM BUCKET)
BUCKET PIN (MULTIPLE CHANGE) (KOMATSU BUCKET) (FOR KHY COUPLER)
BUCKET PIN (MULTIPLE CHANGE) (KOMATSU BUCKET) (FOR KKU COUPLER)
BUCKET PIN (MULTIPLE CHANGE) (KOMATU 370MM WIDTH BUCKET) (FOR KHY COUPLER)
BUCKET PIN (MULTIPLE CHANGE) (H TYPE BUCKET) (FOR KHY COUPLER)
BUCKET PIN (MULTIPLE CHANGE) (Y TYPE BUCKET) (FOR KHY COUPLER)
BUCKET PIN (MULTIPLE CHANGE) (KU TYPE BUCKET) (FOR KKU COUPLER)
BUCKET PIN (MULTIPLE CHANGE) (KOMATU 370MM WIDTH BUCKET) (FOR KKU COUPLER)
BUCKET PIN(#1301-)
BUCKET PIN (MULTIPLE CHANGE) (FOR KHY COUPLER) (GATA CHOSEI NASHI)(#1301-)
BUCKET¤ 0.20M3 (MINI 0
BUCKET¤ 0.14M3 (MINI 0
BUCKET¤ 0.12M3 (MINI 0
BUCKET¤ 0.05M3 (MINI 0.08M3) WIDTH 370MM (VERTICAL PIN TYPE)
BUCKET¤ 0.20M3 (MINI 0 (1)
BUCKET¤ 0.14M3 (MINI 0 (1)
BUCKET¤ 0.12M3 (MINI 0 (1)
BLADE
BLADE CYLINDER
ADAPTER (MULTIPLE CHANGE) (KHY COUPLER)
ADAPTER (MULTIPLE CHANGE) (KKU COUPLER)
MARKS AND PLATES
MARKS AND PLATES(#1001-1018)
MARKS AND PLATES(#1019-1300)
MARKS AND PLATES (1 2)(#1301-)
MARKS AND PLATES (2 2)(#1301-)
MARKS AND PLATES (FOR CAB)
ACCESSORY
GENERAL TOOLS
GENERAL TOOLS (WRENCH SET)
SERVICE KIT AND COMPONENT PARTS
MAIN PUMP (1 6)
MAIN PUMP (2 6)
MAIN PUMP (3 6)
MAIN PUMP (4 6)
MAIN PUMP (5 6)
MAIN PUMP (6 6)
1ST BOOM CYLINDER (INNER PARTS)
2ND BOOM CYLINDER (INNER PARTS)
ARM CYLINDER (INNER PARTS)
BOOM OFFSET CYLINDER (INNER PARTS)
BUCKET CYLINDER (INNER PARTS)
BUCKET CYLINDER (INNER PARTS) (MULTIPLE CHANGE)
BLADE CYLINDER (INNER PARTS)
SWIVEL JOINT (SWIVEL JOINT) (INNER PARTS)(#1001-1018)
SWIVEL JOINT (SWIVEL JOINT) (INNER PARTS)(#1019-)
SWING MOTOR (1 2)
SWING MOTOR (2 2)
FINAL DRIVE (TRAVEL MOTOR 1 3) (HYDRAULIC MOTOR 1 2)
FINAL DRIVE (TRAVEL MOTOR 2 3) (HYDRAULIC MOTOR 2 2)
FINAL DRIVE (TRAVEL MOTOR 3 3) (FINAL DRIVE)
MAIN VALVE (1 17)
MAIN VALVE (2 17)
MAIN VALVE (3 17)
MAIN VALVE (4 17)
MAIN VALVE (5 17)
MAIN VALVE (6 17)
MAIN VALVE (7 17)
MAIN VALVE (8 17)
MAIN VALVE (9 17)
MAIN VALVE (10 17)
MAIN VALVE (11 17)
MAIN VALVE (12 17)
MAIN VALVE (13 17)
MAIN VALVE (14 17)
MAIN VALVE (15 17)
MAIN VALVE (16 17)
MAIN VALVE (17 17)
ELECTRIC LEVER
PARTS BOOKS
ELEMENT AND V-BELT
PERIODICAL REPLACEMENT CRITICAL PARTS (1 3) (FUEL HOSE)
PERIODICAL REPLACEMENT CRITICAL PARTS (2 3) (HYDRAULIC HOSE)
PERIODICAL REPLACEMENT CRITICAL PARTS (3 3) (SEAT BELT)
WORK EQUIPMENT HOSE
LAMP AND FUSE
GLASS AND REAR VIEW MIRROR
TRACK SHOE
BUCKET (VERTICAL PIN TYPE¤ WITH ADJUSTER)
BUCKET (VERTICAL PIN TYPE¤ WITHOUT ADJUSTER)
BUCKET PIN (1)
BUCKET PIN (FOR WIDTH 370MM BUCKET) (1)
BUCKET PIN (MULTIPLE CHANGE) (KOMATSU BUCKET) (FOR KHY COUPLER) (1)
BUCKET PIN (MULTIPLE CHANGE) (KOMATSU BUCKET) (FOR KKU COUPLER) (1)
BUCKET PIN (MULTIPLE CHANGE) (KOMATU 370MM WIDTH BUCKET) (FOR KHY COUPLER) (1)
BUCKET PIN (MULTIPLE CHANGE) (H TYPE BUCKET) (FOR KHY COUPLER) (1)
BUCKET PIN (MULTIPLE CHANGE) (Y TYPE BUCKET) (FOR KHY COUPLER) (1)
BUCKET PIN (MULTIPLE CHANGE) (KU TYPE BUCKET) (FOR KKU COUPLER) (1)
BUCKET PIN (MULTIPLE CHANGE) (KOMATU 370MM WIDTH BUCKET) (FOR KKU COUPLER) (1)
BLADE (1)
MARKS AND PLATES(#1001-1018) (1)
MARKS AND PLATES(#1019-)
MARKS AND PLATES (FOR CAB) (1)
