Martin Welker
104
230,310
Komatsu Excavator PC330-11M0 PC360-11M0 PC375LC-11M0 Shop Manual SMCH360B00-00 ZH
Language: Chinese
Type of Machine: Excavator
Type of Manual: Shop Manual, Electrical Diagram, Hydraulic Schematic
Model: Komatsu PC330-11M0 PC360-11M0 PC375LC-11M0 Excavator
Serial Number:
PC330-11M0 DZBH0001 and up
PC360-11M0 DZBK0001 and up
PC375LC-11M0 DZBM0001 and up
Part Number: SMCH360B00-00
Number of Pages: 2694 Pages
Second Cover
00. Table Of Contents And Foreword
Table Of Contents
List Of Abbreviations
Foreword, Safety, Basic Information
01 Technical Specifications
Table Of Contents
Scope Of Work Diagram
Performance Parameters
Weight Table
Fuel, Coolant And Lubricant Tables
10 Structure And Function
Table Of Contents
Urea Scr System
Starting System
Engine System
Control System
Work Equipment System
Rotary System
Walking System
Chassis And Track Frame
Working Equipment
Driver's Cab And Its Accessories
20. Standard Value Table
Table Of Contents
Engine Standard Value Table
Machine Standard Value Table
Machine Posture And Performance Measurement Steps
Electrical Installation Standard Value Table
30. Inspection And Adjustment
Table Of Contents
Information Related To Inspection And Adjustment
Engine And Cooling System
Drive Train
Pm Diagnosis
40 Troubleshooting
Table Of Contents
Troubleshooting Related Information
Troubleshooting Of Fault Codes (Code Display)
50 Disassembly And Assembly
Table Of Contents
Overview Of Disassembly And Assembly
Drive Train
Chassis And Frame
Working Equipment
60. Maintenance Standards
Table Of Contents
Drive Train
Working Equipment
80 Appendix
Table Of Contents
Air Conditioning System
Components Of Air Conditioning System
Air Conditioning Testing And Troubleshooting Step Instructions
Air Conditioner Circuit Diagram And Connector Pinout
Air Conditioning System Diagram
Air Conditioning Parts Installation Location And Connector Arrangement
Test For Air Leaks (Ventilation Ducts)
Test The Air Conditioner Using The Self-Diagnostic Function
How To Open The Electrical System Abnormality Recording Interface In The Machine Monitor Service Mode
Test Air Outlet (Mode) Conversion
Test External Circulation/Internal Circulation Air Conversion
Test Daylight Sensor
Test The Refrigerant (Dual) Pressure Switch
Test Relay
Air Conditioning Fault Diagnosis Diagram 1
Air Conditioning Fault Diagnosis Diagram 2
Information In The Troubleshooting Table
Fault Code [879aka]
Fault Code [879akb]
Fault Code [879bka]
Fault Code [879bkb]
Fault Code [879cka]
Fault Code [879dkz]
Fault Code [879emc]
Fault Code [879fmc]
Fault Code [879gkx]
A-1 Troubleshooting Of Power System (Air Conditioner Not Working)
A-2 Troubleshooting Of Compressor And Refrigerant Systems (Air Not Cooled)
A-3 Trouble Diagnosis Of Compressor Motor System (No Air Output Or Abnormal Air Volume)
A-4 Troubleshooting Of External Circulation/Internal Circulation Air Conversion
Troubleshooting With Gauge Pressure
Connection To Service Tools
Precautions When Disassembling And Connecting Hoses And Hard Pipes In Air Conditioning Piping
Handling Compressor Oil
90 Loop Diagram
Table Of Contents
Hydraulic Oil Circuit Diagram
Circuit Diagram
Back Cover
次封面
00. 目录和前言
目录
缩写列表
前言、安全、基本信息
01 技术规格
目录
缩写列表
技术规格
工作范围图
性能参数
重量表
燃油、冷却液和润滑剂表
10 结构和功能
目录
缩写列表
尿素SCR系统
起动系统
发动机系统
冷却系统
控制系统
液压系统
工作装置系统
回转系统
行走系统
底盘和履带架
工作装置
司机室及其附属装置
20. 标准值表
目录
缩写列表
发动机标准值表
机器标准值表
机器姿势和性能测量步骤
电气装置标准值表
30. 点检与调整
目录
缩写列表
点检与调整相关信息
发动机和冷却系统
传动系
底盘和履带架
液压系统
司机室及其附属装置
电气系统
Pm诊断
40 故障诊断
目录
缩写列表
故障诊断相关信息
故障代码(代码显示)的故障诊断
50 分解和装配
目录
缩写列表
分解和装配的概述
发动机和冷却系统
传动系
底盘和车架
液压系统
工作装置
司机室及其附属装置
电气系统
60. 维修基准
目录
缩写列表
发动机和冷却系统
传动系
底盘和履带架
液压系统
工作装置
80 附录
目录
缩写列表
空调系统
空调系统的组成部分
空调测试和故障诊断步骤说明
空调电路图和连接器针脚布置
空调系统图
空调零件安装位置和连接器布置
测试漏气(通风道)
使用自诊断功能测试空调
如何打开机器监控器服务模式下的电气系统异常记录界面
测试送风口(模式)转换
测试外循环/内循环空气转换
测试日光传感器
测试制冷剂(双)压力开关
测试继电器
空调故障诊断图1
空调故障诊断图2
故障诊断表中的信息
故障代码[879AKA]
故障代码[879AKB]
故障代码[879BKA]
故障代码[879BKB]
故障代码[879CKA]
故障代码[879DKZ]
故障代码[879EMC]
故障代码[879FMC]
故障代码[879GKX]
A-1电源系统的故障诊断(空调不工作)
A-2压缩机和制冷剂系统的故障诊断(空气未冷却)
A-3压气机马达系统的故障诊断(不出风或风量异常)
A-4外循环/内循环空气转换的故障诊断
用表压进行故障诊断
服务工具的连接
拆开和连接空调管路中的软管和硬管时的注意事项
处理压缩机油
90 回路图
目录
缩写列表
液压油路图
电路图
封底
