118
6,911
Komatsu Engine SDA6D140E-3H-9 110003-UP Parts Catalog
Model: Komatsu SDA6D140E-3H-9 Engine
Serial Number: 110003-UP
Number of Pages: 169 Pages
SDA6D140E-3H-9 S N 110003-U
ENGIN
CYLINDER HEA
HEAD COVE
HEAD COVER BOL
AIR INTAKE MANIFOL
AFTER COOLER WATER PIPIN
AIR CLEANE
AIR CLEANER (POOR FUEL ARRANGEMENT SPEC.
AIR CLEANER (LANDFILL SPEC.
AIR CLEANER (INNER PARTS
AIR CLEANER (INNER PARTS) (POOR FUEL ARRANGEMENT SPEC.
AIR CLEANER (INNER PARTS) (LANDFILL SPEC.
EXHAUST MANIFOL
EXHAUST MANIFOLD (LANDFILL SPEC
TURBOCHARGER AND OIL PIPIN
TURBOCHARGER AND OIL PIPING (REGULATION OF EPA AND EU 2ND
TURBOCHARGER (KTR110L-585E) (INNER PARTS
TURBOCHARGER (KTR110L-585E) (REGULATION OF EPA AND EU 2ND) (INNER PARTS
HEAT SHIEL
HEAT SHIELD (LAND FILL SPEC.
MUFFLER CONNECTIO
MUFFLER CONNECTION (LANDFILL SPEC
CYLINDER BLOC
CYLINDER BLOCK COVER AND OIL FILLE
CYLINDER BLOCK COVER AND OIL FILLER (WITH HEATER
FRONT COVER (FRONT POWER TAKE OFF SPEC.) (WITH SLEEVE
FRONT COVER MOUNTING AND BREATHE
IDLER GEA
CAMFOLLOWER COVE
OIL PAN AND SUCTION TUB
OIL PAN AND SUCTION TUBE (WITH HEATER
OIL LEVEL GAUG
OIL LEVEL GAUGE (WITH HEATER
FLYWHEEL HOUSIN
FLYWHEE
ENGINE SUPPOR
CRANKSHAF
VIBRATION DAMPE
PISTO
FLANG
CAMSHAF
ROCKER AR
CAMFOLLOWE
FRONT POWER TAKE OFF (SANDY AND DUSTY SPEC.
FRONT POWER TAKE OFF (NON DRIVE SPEC.
OIL PUM
OIL FILTER AND PIPIN
OIL COOLE
FUEL SUPPLY PUMP AND COMMON RAIL MOUNTIN
FUEL SUPPLY PUMP AND COMMON RAIL MOUNTING (LOW-VISCOSITY FUEL SPEC.) (REGULATION OF EPA AND EU 2ND
FUEL PUMP SUPPLY AND RETURN PIPIN
FUEL PUMP SUPPLY AND RETURN PIPING (LOW-VISCOSITY FUEL SPEC.) (REGULATION OF EPA AND EU 2ND
FUEL SUPPLY PUMP (PUMP) (INNER PARTS
FUEL SUPPLY PUMP (PUMP) (LOW-VISCOSITY FUEL SPEC.) (REGULATION OF EPA AND EU 2ND) (INNER PARTS
FUEL SUPPLY PUMP (FEED PUMP) (INNER PARTS
FUEL SUPPLY PUMP (FEED PUMP) (LOW-VISCOSITY FUEL SPEC.) (REGULATION OF EPA AND EU 2ND) (INNER PARTS
COMMON RAIL (INNER PARTS
COMMON RAIL (LOW-VISCOSITY FUEL SPEC.) (REGULATION OF EPA AND EU 2ND) (INNER PARTS
FUEL SUPPLY PUMP BRACKET AND CONNECTION COVE
FUEL PIPIN
FUEL SUPPLY PUMP LUBRICATO
FUEL FILTER (THREAD 1-1 4
FUEL FILTER (POOR FUEL ARRANGEMENT SPEC.) (THREAD 1-1 4
FUEL FILTER (THREAD 1-5 8
FUEL FILTER (EXTREMELY BAD FUEL GROUND SPEC.) (THREAD 1-5 8
FUEL FILTER CARTRIDGE (SERVICE ONLY
WATER SEPARATO
PRE FILTER MOUNTING (POOR FUEL ARRANGEMENT SPEC.) (THREAD 1-1 4
FUEL INJECTO
FUEL RETUR
FUEL CONTRO
WATER PUM
WATER PUMP (LANDFILL SPEC
THERMOSTAT AND AIR VEN
THERMOSTAT AND AIR VENT (LANDFILL SPEC
CORROSION RESISTO
WATER LINE PLUG (WITHOUT CORROSION RESISTOR
DUAL WATER PUM
DUAL WATER PUMP MOUNTIN
ALTERNATOR MOUNTING (75A
ALTERNATOR MOUNTING (75A) (EXCEPT JAPAN
ALTERNATOR MOUNTING (90A) (WITH HARDENING PULLEY
ALTERNATOR MOUNTING (90A) (SANDY AND DUSTY SPEC
ALTERNATOR (75A) (INNER PARTS
ALTERNATOR (75A) (INNER PARTS) (EXCEPT JAPAN
ALTERNATOR (90A) (SANDY AND DUSTY SPEC.) (INNER PARTS
ALTERNATOR (75A) (INNER PARTS) (HARDENING PULLEY
STARTING MOTOR MOUNTING (11KW
WIRING (1 3) SWITCH AND HEATE
WIRING (1 3) SWITCH AND HEATER (EXCEPT JAPAN
WIRING (2 3) FUEL INJECTO
WIRING (2 3) FUEL INJECTOR (EXCEPT JAPAN
WIRING (3 3) SENSO
WIRING (3 3) SENSOR (EXCEPT JAPAN
CYLINDER HEAD GASKET KI
CYLINDER BLOCK GASKET KI
WATER PUMP GASKET KI
NAME PLATE AND CAUTION PLATE (JAPANESE-ENGLISH
NAME PLATE AND CAUTION PLATE (JAPANESE-ENGLISH) (REGULATION OF EPA AND EU
NAME PLATE AND CAUTION PLATE (ENGLISH) (REGULATION OF EPA
PM-CLINI
MUFFLER MOUN
EXHAUST PIP
COOLING FAN (SUCTION
SPARE PART
