118
6,911
Komatsu Engine SDA12V140E-1D-A 10001-UP Parts Catalog
Model: Komatsu SDA12V140E-1D-A Engine
Serial Number: 10001-UP
Number of Pages: 218 Pages
KOMATSU SDA12V140E-1D-A S N 10001-U
ENGIN
CYLINDER HEA
HEAD COVE
SHIELD PLAT
AIR INTAKE MANIFOLD AND AFTER COOLER (L.H. BANK) (WITH CORROSION RESISTOR
AIR INTAKE MANIFOLD AND AFTER COOLER (L.H. BANK) (WITHOUT CORROSION RESISTOR
AIR INTAKE MANIFOLD AND AFTER COOLER (L.H. BANK) (COLD TERRAIN SPEC.
AIR INTAKE MANIFOLD AND AFTER COOLER (R.H. BANK) (WITH CORROSION RESISTOR
AIR INTAKE MANIFOLD AND AFTER COOLER (R.H. BANK) (WITHOUT CORROSION RESISTOR
AIR INTAKE MANIFOLD AND AFTER COOLER (R.H. BANK) (COLD TERRAIN SPEC.
AFTER COOLER WATER PIPING (WITH CORROSION RESISTOR
AFTER COOLER WATER PIPING (WITHOUT CORROSION RESISTOR
AFTER COOLER WATER PIPING (COLD TERRAIN SPEC.
HEATER SWITCH (L.H. BANK
HEATER SWITCH (R.H. BANK
AIR CLEANER MOUNTIN
AIR CLEANER (INNER PARTS
EXHAUST MANIFOL
EXHAUST MANIFOLD (WITH EXHAUST TEMPERATURE SENSOR
TURBOCHARGER AND LUBRICATOR (EXCEPT JAPAN
TURBOCHARGER (EXCEPT JAPAN) (INNER PARTS
TURBOCHARGER WATER PIPING (EXCEPT JAPAN
TURBOCHARGER SHIELD COVER (EXCEPT JAPAN
HEAT SHIELD (FOR WA800.900¤ D475A AND HD78
MUFFLER (EXCEPT JAPAN
MUFFLER PIPING (EXCEPT JAPAN
THERMOSTAT HOUSIN
CYLINDER BLOC
CYLINDER BLOCK BLIND COVE
FRONT COVE
GEAR CASE (WITH BLOWBY SENSOR
GEAR CASE (WITHOUT BLOWBY SENSOR
BREATHER AND FRONT SEAL (WITH BLOWBY SENSOR
BREATHER AND FRONT SEAL (WITHOUT BLOWBY SENSOR
IDLER GEA
CAMFOLLOWER COVE
OIL FILLE
OIL FILLER (PRELUBRICATION SPEC.
OIL PAN AND SUCTION TUBE (QUICK CHARGE SPEC.
OIL PAN AND SUCTION TUBE (WITH OIL LEVEL SENSOR
OIL PAN AND SUCTION TUBE (PRELUBRICATION SPEC.) (WITH OIL LEVEL SENSOR
OIL PAN AND SUCTION TUBE (PRELUBRICATION AND QUICK CHARGE SPEC.
OIL PAN AND SUCTION TUBE (COLD TERRAIN SPEC.
OIL LEVEL GAUGE (QUICK CHARGE SPEC.
OIL LEVEL GAUG
OIL LEVEL GAUGE (WITH OIL LEVEL SENSOR
OIL LEVEL GAUGE (PRELUBRICATION SPEC.) (WITH OIL LEVEL SENSOR
OIL LEVEL GAUGE (PRELUBRICATION AND QUICK CHARGE SPEC.
OIL LEVEL GAUGE (COLD TERRAIN SPEC.
OIL PAN HEATER (COLD TERRAIN SPEC.
FLYWHEEL HOUSING (REINFORCED HARNESS
FLYWHEE
ENGINE SUPPORT AND BRACKE
CRANKSHAF
DAMPE
PISTO
CRANK PULLEY (ADAPTER TYPE
CAMSHAF
CAMFOLLOWER (FOR D475A
ROCKER ARM AND HOUSING (FOR D475A
OIL PUM
OIL FILTER (FOR VHMS
OIL FILTE
OIL ADAPTER (FOR VHMS
OIL ADAPTE
OIL COOLE
OIL COOLER (COLD TERRAIN SPEC.
OIL COOLER MOUNTIN
FUEL INJECTION PUMP MOUNTING (FOR REGULATION OF EPA
FUEL INJECTION PUMP MOUNTING (FOR REGULATION OF EPA AND EC
FUEL INJECTION PUMP (PUMP) (L.H.) (1 2) (FOR REGULATION OF EPA) (INNER PARTS
FUEL INJECTION PUMP (PUMP) (L.H.) (1 2) (FOR REGULATION OF EPA AND EC) (INNER PARTS
FUEL INJECTION PUMP (PUMP) (L.H.) (2 2) (FOR REGULATION OF EPA) (INNER PARTS
FUEL INJECTION PUMP (PUMP) (L.H.) (2 2) (FOR REGULATION OF EPA AND EC) (INNER PARTS
FUEL INJECTION PUMP (GOVERNOR) (L.H.) (1 2) (FOR REGULATION OF EPA) (INNER PARTS
FUEL INJECTION PUMP (GOV.) (L.H.) (1 2) (FOR REGULATION OF EPA AND EC) (INNER PARTS
FUEL INJECTION PUMP (GOVERNOR) (L.H.) (2 2) (FOR REGULATION OF EPA) (INNER PARTS
FUEL INJECTION PUMP (GOV.) (L.H.) (2 2) (FOR REGULATION OF EPA AND EC) (INNER PARTS
FUEL INJECTION PUMP (PUMP) (R.H.) (1 2) (FOR REGULATION OF EPA) (INNER PARTS
FUEL INJECTION PUMP (PUMP) (R.H.) (1 2) (FOR REGULATION OF EPA AND EC) (INNER PARTS
FUEL INJECTION PUMP (PUMP) (R.H.) (2 2) (FOR REGULATION OF EPA) (INNER PARTS
FUEL INJECTION PUMP (PUMP) (R.H.) (2 2) (FOR REGULATION OF EPAAN D EC) (INNER PARTS
FUEL INJECTION PUMP (GOVERNOR) (R.H.) (1 2) (FOR REGULATION OF EPA) (INNER PARTS
FUEL INJECTION PUMP (GOV.) (R.H.) (1 2) (FOR REGULATION OF EPA AND EC) (INNER PARTS
FUEL INJECTION PUMP (GOVERNOR) (R.H.) (2 2) (FOR REGULATION OF EPA) (INNER PARTS
FUEL INJECTION PUMP (GOV.) (R.H.) (2 2) (FOR REGULATION OF EPA AND EC) (INNER PARTS
FUEL INJECTION PUMP (COUPLING) (FOR REGULATION OFEPA) (INNER PARTS
FUEL INJECTION PUMP (COUPLING) (FOR REGULATION OF EPA AND EC) (INNER PARTS
FUEL INJECTION PUMP BRACKE
FUEL INJECTION PUMP BRACKET (PRELUBRICATION SPEC.
FUEL INJECTION PUMP PIPING (L.H. BANK) (FOR ELECTRICAL GOVERNOR
FUEL INJECTION PUMP PIPING (R.H. BANK) (FOR ELECTRICAL GOVERNOR
FUEL INJECTION PUMP LUBRICATING (L.H. BANK) (FOR ELECTRICAL GOVERNOR
FUEL INJECTION PUMP LUBRICATING (R.H. BANK) (FOR ELECTRICAL GOVERNOR
FUEL INJECTION PUMP DRIVE (FOR REGULATION OF EPA
FUEL FILTER AND FUEL PIPIN
FUEL PIPING (L.H. BANK
FUEL PIPING (R.H. BANK
WATER SEPARATO
WATER SEPARATOR (WITHOUT WATER SEPARATOR
FUEL INJECTION NOZZLE AND SPILL PIP
NOZZLE HOLDER (INNER PARTS
FUEL RETURN (L.H. BANK
FUEL RETURN (R.H. BANK
FUEL CONTROLLER (FOR REGULATION OF EPA) (WITH SHEET
WATER PUM
AIR VEN
CORROSION RESISTO
DUAL CORROSION RESISTO
DUAL WATER PUM
ALTERNATOR MOUNTING (100A
ALTERNATOR (100A) (INNER PARTS
ALTERNATOR DRIVE (100A
STARTING MOTOR MOUNTING (
STARTING MOTOR (
STARTING MOTOR (7 (1
WIRING HARNESS (L.H. BANK
WIRING HARNESS (L.H. BANK) (FOR VHMS LESS
WIRING HARNESS (R.H. BANK
WIRING HARNESS (R.H. BANK) (FOR VHMS LESS
SAFETY GUARD (INJECTION PUMP DRIVE
CYLINDER HEAD GASKET KI
CYLINDER BLOCK GASKET KI
WATER PUMP GASKET KI
PRELUBE OIL PUMP RELATED PART
PRELUBE OIL PUMP AND QUICK CHARGE SYSTEM RELATED PART
PRELUBE OIL PUMP AND OIL LEVEL SENSOR SYSTEM RELATED PART
NAME PLATE AND CAUTION (JAPANESE-ENGLISH
CAUTION PLATE (ENGLISH) (NON REGULATION OF EPA
PM-CLINI
CAUTION PLATE (AIR CLEANER) (FOR DOUBLE ELEMENT
FUEL CONTROLLE
FUEL CONTROLLER (FOR REGULATOIN OF EPA) (WITH SHEET
PRE CLEANER AND HOOD (AIR INTAKE
MUFFLER PIPE AND CA
COOLING FA
SPARE PART
PRE LUBRICATING OIL PUM
