118
6,911
Komatsu Engine SDA12V140-1B-A 10001-UP Parts Catalog
Model: Komatsu SDA12V140-1B-A Engine
Serial Number: 10001-UP
Number of Pages: 232 Pages
SDA12V140-1B-A S N 10001-U
ENGIN
CYLINDER HEA
HEAD COVE
HEAD COVER AND SHIELD PLAT
SHIELD PLAT
AIR INTAKE MANIFOLD AND AFTER COOLER (L.H. BANK
AIR INTAKE MANIFOLD AND AFTER COOLER (R.H. BANK
AFTER COOLER WATER PIPIN
HEATER SWITCH (L.H. BANK
HEATER SWITCH (R.H. BANK
AIR CLEANER MOUNTIN
AIR CLEANER (INNER PARTS
EXHAUST MANIFOL
TURBOCHARGER AND LUBRICATOR (EXCEPT JAPAN
TURBOCHARGER (EXCEPT JAPAN) (INNER PARTS
TURBOCHARGER WATER PIPING (EXCEPT JAPAN
TURBOCHARGER SHIELD COVER (EXCEPT JAPAN
HEAT SHIELD (FOR WA800.900¤ D475A AND HD78
MUFFLER (FOR EXCEPT JAPAN
THERMOSTAT HOUSIN
CYLINDER BLOC
CYLINDER BLOCK COVE
CYLINDER BLOCK BLIND COVE
FRONT COVE
GEAR CAS
BREATHE
IDLER GEA
CAM FOLLOWER COVE
OIL FILLE
OIL PAN AND SUCTION TUBE (QUICK CHARGE SPEC.
OIL PAN AND SUCTION TUBE (QUICK CHARGE SPEC.) (REINFORCED HARNESS
OIL LEVEL GAUGE (QUICK CHARGE SPEC.
OIL LEVEL GAUG
OIL LEVEL GAUGE (QUICK CHARGE SPEC.) (REINFORCED HARNESS
FLYWHEEL HOUSIN
FLYWHEE
ENGINE SUPPORT AND BRACKE
CRANKSHAF
DAMPE
PISTO
CRANK PULLE
ROCKER ARM AND HOUSIN
CAMSHAF
CAMSHAFT AND CAMFOLLOWE
CAM FOLLOWER (FOR D475A
ROCKER ARM AND HOUSING (FOR D475A
TACHOMETER DRIV
OIL PUM
OIL FILTE
OIL ADAPTE
BYPASS FILTER AND PIPIN
OIL COOLE
OIL COOLER (COLD TERRAIN SPEC.
OIL COOLER MOUNTIN
FUEL INJECTION PUMP MOUNTING (FOR ELECTRICAL GOVERNOR
FUEL INJECTION PUMP MOUNTING (FOR ELECTRICAL GOVERNOR) (FOR EC REGULATION
FUEL INJECTION PUMP (PUMP) (L.H.) (1 2) (FOR ELECTRICAL GOVERNOR) (INNER PARTS
FUEL INJECTION PUMP (PUMP) (L.H.) (1 2) (FOR ELECTRICAL GOVERNOR) (FOR EC REGULATION) (INNER PARTS
FUEL INJECTION PUMP (PUMP) (L.H.) (2 2) (FOR ELECTRICAL GOVERNOR) (INNER PARTS
FUEL INJECTION PUMP (PUMP) (L.H.) (2 2) (FOR ELECTRICAL GOVERNOR) (FOR EC REGULATION) (INNER PARTS
FUEL INJECTION PUMP (GOVERNOR) (L.H.) (1 2) (FOR ELECTRICAL GOVERNOR) (INNER PARTS
FUEL INJECTION PUMP (GOVERNOR) (L.H.) (1 2) (FOR ELECTRICAL GOVERNOR) (EC REGULATION) (INNER PARTS
FUEL INJECTION PUMP (GOVERNOR) (L.H.) (2 2) (FOR ELECTRICAL GOVERNOR) (INNER PARTS
FUEL INJECTION PUMP (GOVERNOR) (L.H.) (2 2) (FOR ELECTRICAL GOVERNOR) (EC REGULATION) (INNER PARTS
FUEL INJECTION PUMP (PUMP) (R.H.) (1 2) (FOR ELECTRICAL GOVERNOR) (INNER PARTS
FUEL INJECTION PUMP (PUMP) (R.H.) (1 2) (FOR ELECTRICAL GOVERNOR) (FOR EC REGULATION) (INNER PARTS
FUEL INJECTION PUMP (PUMP) (R.H.) (2 2) (FOR ELECTRICAL GOVERNOR) (INNER PARTS
FUEL INJECTION PUMP (PUMP) (R.H.) (2 2) (FOR ELECTRICAL GOVERNOR) (FOR EC REGULATION ) (INNER PARTS
FUEL INJECTION PUMP (GOVERNOR) (R.H.) (1 2) (FOR ELECTRICAL GOVERNOR) (INNER PARTS
FUEL INJECTION PUMP (GOVERNOR) (R.H.) (1 2) (FOR ELECTRICAL GOVERNOR) (EC REGULATION) (INNER PARTS
FUEL INJECTION PUMP (GOVERNOR) (R.H.) (2 2) (FOR ELECTRICAL GOVERNOR) (INNER PARTS
FUEL INJECTION PUMP (GOVERNOR) (R.H.) (2 2) (FOR ELECTRICAL GOVERNOR) (EC REGULATION) (INNER PARTS
FUEL INJECTION PUMP (COUPLING) (FOR ELECTRICAL GOVERNOR) (INNER PARTS
FUEL INJECTION PUMP (COUPLING) (FOR ELECTRICAL GOVERNOR) (FOR EC REGULATION) (INNER PARTS
FUEL INJECTION PUMP BRACKET (FOR ELECTRICAL GOVERNOR
FUEL INJECTION PUMP PIPING (L.H. BANK) (FOR ELECTRICAL GOVERNOR
FUEL INJECTION PUMP PIPING (R.H. BANK) (FOR ELECTRICAL GOVERNOR
FUEL INJECTION PUMP LUBRICATING (L.H. BANK) (FOR ELECTRICAL GOVERNOR
FUEL INJECTION PUMP LUBRICATING (R.H. BANK) (FOR ELECTRICAL GOVERNOR
FUEL INJECTION PUMP DRIV
FUEL FILTER AND FUEL PIPIN
FUEL PIPING (L.H. BANK
FUEL PIPING (R.H. BANK
WATER SEPARATO
FUEL INJECTION NOZZLE AND SPILL PIP
NOZZLE HOLDER (INNER PARTS
FUEL RETURN (L.H. BANK) (FOR ELECTRICAL GOVERNOR
FUEL RETURN (R.H. BANK) (FOR ELECTRICAL GOVERNOR
FUEL CONTROLLER (FORWARDED INDIVIDUALLY PARTS
FUEL CONTROLLER (FUEL CONTROL RELATED PARTS
WATER PUM
AIR VEN
COOLING FA
TENSION PULLE
CORROSION RESISTO
DUAL CORROSION RESISTO
DUAL WATER PUM
ALTERNATOR MOUNTING (75A
ALTERNATOR MOUNTING (100A
ALTERNATOR (75A) (INNER PARTS
ALTERNATOR (100A) (INNER PARTS
ALTERNATOR DRIV
ALTERNATOR DRIVE (FOR 100A
STARTING MOTOR MOUNTING (
STARTING MOTOR (
STARTING MOTOR (7 (1
STARTING MOTOR (7 (2
STARTING MOTOR (7 (3
ELECTRICAL WIRIN
ELECTRICAL WIRING (FOR EC REGULATION
SAFETY GUARD (INJECTION PUMP DRIVE
CYLINDER HEAD GASKET KI
CYLINDER BLOCK GASKET KI
WATER PUMP GASKET KI
SPARE PART
NAME PLATE AND CAUTION (ENGLISH
NAME PLATE AND CAUTION (JAPANESE-ENGLISH
NAME PLATE (FOR REGULATION OF EPA
CAUTION PLATE (ENGLISH) (NON REGULATION OF EPA
PM-CLINI
PRE CLEANER AND HOOD (AIR INTAKE
EJECTOR PIPIN
CAUTION PLATE (AIR CLEANER) (FOR DOUBLE ELEMENT
EJECTOR PIPING (WITH PRE CLEANER AND HOOD
FUEL CONTROLLE
FUEL CONTROLLER (FOR REGULATOIN OF EPA) (WITH SHEET
COOLING FAN (1
