Komatsu Engine SAA6D140E_3J Parts Catalog
Model: Komatsu SAA6D140E_3J Engine
Number of Pages: 93 Pages
SAA6D140E_3J S N .-UP
ENGINE
CYLINDER HEAD
HEAD COVER
HEAD COVER BOLT
AIR INTAKE MANIFOLD
EXHAUST MANIFOLD
TURBOCHARGER AND OIL PIPING
TURBOCHARGER (KTR110L-585E) (INNER PARTS)
HEAT SHIELD
HEAT SHIELD (1 2) TURBOCHARGER AND EXHAUST MANIFOLD (EXHAUST BRAKE SPEC.)
HEAT SHIELD (2 2) EXHAUST BRAKE
EXHAUST BRAKE
EXHAUST BRAKE (INNER PARTS)
CYLINDER BLOCK
CYLINDER BLOCK COVER AND OIL FILLER
CYLINDER BLOCK COVER AND OIL FILLER (WITH VANDALISM PROTECTION)
FRONT COVER
FRONT COVER MOUNTING AND BREATHER
IDLER GEAR
CAM FOLLOWER COVER
OIL PAN AND SUCTION TUBE
OIL LEVEL GAUGE
FLYWHEEL HOUSING
FLYWHEEL
ENGINE MOUNTING
CRANKSHAFT
VIBRATION DAMPER
PISTON
CRANK PULLEY
CAMSHAFT
ROCKER ARM
CAM FOLLOWER
OIL PUMP
OIL FILTER AND PIPING
OIL COOLER
INJECTION PUMP AND COMMON RAIL MOUNTING
FUEL PUMP SUPPLY AND RETURN PIPING
FUEL INJECTION PUMP (INNER PARTS)
INJECTION PUMP (FEED PUMP) (INNER PARTS)
COMMON RAIL (INNER PARTS)
FUEL INJECTION PUMP BRACKET AND CONNECTION COVER
FUEL PIPING
FUEL SUPPLY PUMP LUBRICATOR
FUEL FILTER (THREAD 1-1 4)
FUEL INJECTION NOZZLE
FUEL RETURN
WATER PUMP
THERMOSTAT AND WATER CONNECTOR
AIR VENT
COOLING FAN
FAN PULLEY AND V-BELT
FAN DRIVE
CORROSION RESISTOR
ALTERNATOR MOUNTING (50A)
ALTERNATOR MOUNTING (75A)
ENGAGE WIRING (1 3) SWITCH AND HEATER
ENGAGE WIRING (2 3) FUEL INJECTOR
ENGAGE WIRING (3 3) SENSOR
GASKET KIT
ENGINE
CYLINDER HEAD
HEAD COVER
HEAD COVER BOLT
AIR INTAKE MANIFOLD
EXHAUST MANIFOLD
HEAT SHIELD
EXHAUST BRAKE
CYLINDER BLOCK
FRONT COVER
IDLER GEAR
CAM FOLLOWER COVER
OIL LEVEL GAUGE
FLYWHEEL HOUSING
FLYWHEEL
ENGINE MOUNTING
CRANKSHAFT
VIBRATION DAMPER
PISTON
CRANK PULLEY
CAMSHAFT
ROCKER ARM
CAM FOLLOWER
OIL PUMP
OIL COOLER
FUEL PIPING
FUEL RETURN
WATER PUMP
AIR VENT
COOLING FAN
FAN DRIVE
CORROSION RESISTOR
GASKET KIT
- KOMATSU Fault Codes
