Komatsu Engine SAA6D140E-5H-01 530001-UP Parts Catalog
Model: Komatsu SAA6D140E-5H-01 Engine
Serial Number: 530001-UP
Number of Pages: 237 Pages
SAA6D140E-5H-01 S N 530001-U
ENGIN
CYLINDER HEA
CYLINDER HEAD COVE
HEAD COVER MOUNTING BOL
AIR INTAKE MANIFOLD AND CONNECTIO
AIR INTAKE MANIFOLD AND CONNECTION (AIR CONDITIONER SPEC.
AIR INTAKE MANIFOLD AND CONNECTION (LANDFILL SPEC.
EXHAUST MANIFOL
TURBOCHARGER MOUNTING AND LUBRICATO
TURBOCHARGER MOUNTING AND LUBRICATOR (LANDFILL SPEC.
TURBOCHARGER WATER PIPIN
TURBOCHARGER WATER PIPING (LANDFILL SPEC.
TURBOCHARGER (KTR110M-532AW) (INNER PARTS
TURBOCHARGER (LANDFILL SPEC.) (KTR110M-532AW) (INNER PARTS
EXHAUST GAS RECIRCULATION VALVE (1 7) (EGR COOLER AND VALVE MOUNTING
EXHAUST GAS RECIRCULATION VALVE (1 6) (EGR COOLER AND VALVE MOUNTING
EXHAUST GAS RECIRCULATION VALVE (1 7) (EGR COOLER AND VALVE MOUNTING) (AIR CONDITIONER SPEC.
EXHAUST GAS RECIRCULATION VALVE (1 6) (EGR COOLER AND VALVE MOUNTING) (AIR CONDITIONER SPEC.
EXHAUST GAS RECIRCULATION VALVE (1 6) (EGR COOLER AND VALVE MOUNTING) (LANDFILL SPEC.
EXHAUST GAS RECIRCULATION VALVE (2 7) (EGR COOLER WATER PIPING
EXHAUST GAS RECIRCULATION VALVE (2 6) (EGR COOLER WATER PIPING
EXHAUST GAS RECIRCULATION VALVE (2 7) (EGR COOLER WATER PIPING) (AIR CONDITIONER SPEC.
EXHAUST GAS RECIRCULATION VALVE (2 6) (EGR COOLER WATER PIPING) (AIR CONDITIONER SPEC.
EXHAUST GAS RECIRCULATION VALVE (2 6) (EGR COOLER WATER PIPING) (LANDFILL SPEC.
EXHAUST GAS RECIRCULATION VALVE (3 7) (EGR COOLER AIR VENT AND BYPASS VALVE PIPING
EXHAUST GAS RECIRCULATION VALVE (3 6) (EGR COOLER AIR VENT AND BYPASS VALVE PIPING
EXHAUST GAS RECIRCULATION VALVE (3 7) (AIR VENT AND BYPASS VALVE PIPING) (AIR CONDITIONER SPEC.
EXHAUST GAS RECIRCULATION VALVE (3 6) (AIR VENT AND BYPASS VALVE PIPING) (AIR CONDITIONER SPEC.
EXHAUST GAS RECIRCULATION VALVE (3 6) (EGR COOLER AIR VENT AND BYPASS VALVE PIPING) (LANDFILL SPEC.
EXHAUST GAS RECIRCULATION VALVE (4 7) (EGR OIL PUMP LUBRICATOR
EXHAUST GAS RECIRCULATION VALVE (4 6) (EGR OIL PUMP LUBRICATOR
EXHAUST GAS RECIRCULATION VALVE (4 7) (EGR OIL PUMP LUBRICATOR) (AIR CONDITIONER SPEC.
EXHAUST GAS RECIRCULATION VALVE (4 6) (EGR OIL PUMP LUBRICATOR) (AIR CONDITIONER SPEC.
EXHAUST GAS RECIRCULATION VALVE (4 6) (EGR OIL PUMP LUBRICATOR) (LANDFILL SPEC.
EXHAUST GAS RECIRCULATION VALVE (5 7) (EGR VALVE OIL RETURN PIPING
EXHAUST GAS RECIRCULATION VALVE (5 6) (EGR VALVE OIL RETURN PIPING
EXHAUST GAS RECIRCULATION VALVE (5 7) (EGR VALVE OIL RETURN PIPING) (AIR CONDITIONER SPEC.
EXHAUST GAS RECIRCULATION VALVE (5 6) (EGR VALVE OIL RETURN PIPING) (AIR CONDITIONER SPEC.
EXHAUST GAS RECIRCULATION VALVE (5 6) (EGR VALVE OIL RETURN PIPING) (LANDFILL SPEC.
EXHAUST GAS RECIRCULATION VALVE (6 7) (ENGINE FRONT HANGER
EXHAUST GAS RECIRCULATION VALVE (6 6) (ENGINE FRONT HANGER
EXHAUST GAS RECIRCULATION VALVE (6 7) (ENGINE FRONT HANGER) (AIR CONDITIONER SPEC.
EXHAUST GAS RECIRCULATION VALVE (6 6) (ENGINE FRONT HANGER) (AIR CONDITIONER SPEC.
EXHAUST GAS RECIRCULATION VALVE (6 6) (ENGINE FRONT HANGER) (LANDFILL SPEC.
EXHAUST GAS RECIRCULATION VALVE (7 7) (EGR SENSOR GROUP
EXHAUST GAS RECIRCULATION VALVE (7 7) (EGR SENSOR GROUP) (AIR CONDITIONER SPEC.
EXHAUST GAS RECIRCULATION OIL PUMP (LANDFILL SPEC.) (INNER PARTS
EXHAUST GAS RECIRCULATION OIL PUMP (INNER PARTS
EXHAUST GAS RECIRCULATION OIL PUMP (AIR CONDITIONER SPEC.) (INNER PARTS
HEAT SHIEL
HEAT SHIELD (FOR 90A ALTERNATOR
HEAT SHIELD (1 3) (LANDFILL SPEC.
HEAT SHIELD (2 3) (LANDFILL SPEC.
HEAT SHIELD (3 3) (LANDFILL SPEC.
EXHAUST CONNECTIO
EXHAUST CONNECTION (LANDFILL SPEC.
CYLINDER BLOC
CYLINDER BLOCK ACCESSOR
CYLINDER BLOCK ACCESSORY (OIL SENSOR AND WITH COOLANT HEATER
FRONT COVER (WITH SLEEVE
FRONT COVER ACCESSORY AND BREATHE
IDLER GEA
CAMFOLLOWER COVE
OIL PAN AND SUCTION TUB
OIL PAN AND SUCTION TUBE (COLD TERRAIN (A) SPEC.) (COOLANT HEATER SPEC.
FLYWHEEL HOUSIN
FLYWHEE
ENGINE SUPPOR
CRANKSHAF
VIBRATION DAMPE
PISTON AND CONNECTING RO
DAMPER FLANG
CAMSHAF
CAMFOLLOWER AND PUSH RO
ROCKER AR
FRONT POWER TAKE OFF (HARDENING PULLEY
FRONT POWER TAKE OFF (NON DRIVE SPEC.
LUBRICATING OIL PUM
OIL FILTE
OIL COOLE
FUEL SUPPLY PUMP AND COMMON RAIL MOUNTIN
COMMON RAIL (INNER PARTS
FUEL SUPPLY PUMP (PUMP) (INNER PARTS
FUEL SUPPLY PUMP (FEED PUMP) (INNER PARTS
FUEL SUPPLY PUMP BRACKET AND PIPIN
FUEL SUPPLY TUBE JOINT SUPPOR
FUEL SUPPLY PUMP LUBRICATO
FUEL FILTER (THREAD 1-5 8
FUEL FILTER CARTRIDGE (SERVICE ONLY
PRE FILTER (THREAD 1-1 4
PRE FILTER (SERVICE ONLY
FUEL INJECTOR AND SPILL TUB
FUEL RETUR
FUEL INJECTION CONTROLLE
THERMOSTAT AND AIR VEN
THERMOSTAT AND AIR VENT (LANDFILL SPEC.
WATER PUM
WATER PUMP (LANDFILL SPEC.
CORROSION RESISTOR (EXCEPT JAPAN
WATER LINE PLUG (WITHOUT CORROSION RESISTOR
ALTERNATOR MOUNTING (FOR 75A ALTERNATOR
ALTERNATOR MOUNTING (FOR 90A ALTERNATOR
ALTERNATOR MOUNTING (FOR 90A ALTERNATOR) (LANDFILL SPEC.) (FOR EU SAFETY REGULATION
ALTERNATOR (FOR 75A ALTERNATOR) (INNER PARTS
ALTERNATOR (FOR 90A ALTERNATOR) (INNER PARTS
ALTERNATOR (FOR 90A ALTERNATOR) (LANDFILL SPEC.) (FOR EU SAFETY REGULATION) (INNER PARTS
STARTING MOTOR MOUNTING (11KW
WIRING HARNESS (1 4) (FOR 75A ALTERNATOR
WIRING HARNESS (1 4) (FOR 90A ALTERNATOR
WIRING HARNESS (1 4) (FOR 75A ALTERNATOR) (FOR ROT PREVENTION HARNESS
WIRING HARNESS (1 4) (FOR 90A ALTERNATOR) (FOR ROT PREVENTION HARNESS
WIRING HARNESS (2 4) (FOR 75A ALTERNATOR
WIRING HARNESS (2 4) (FOR 90A ALTERNATOR
WIRING HARNESS (2 4) (FOR 75A ALTERNATOR) (FOR ROT PREVENTION HARNESS
WIRING HARNESS (2 4) (FOR 90A ALTERNATOR) (FOR ROT PREVENTION HARNESS
WIRING HARNESS (3 4) (FOR 75A ALTERNATOR
WIRING HARNESS (3 4) (FOR 90A ALTERNATOR
WIRING HARNESS (3 4) (FOR 75A ALTERNATOR) (FOR ROT PREVENTION HARNESS
WIRING HARNESS (3 4) (FOR 90A ALTERNATOR) (FOR ROT PREVENTION HARNESS
WIRING HARNESS (4 4) (FOR 75A ALTERNATOR
WIRING HARNESS (4 4) (FOR 90A ALTERNATOR
WIRING HARNESS (4 4) (FOR 75A ALTERNATOR) (FOR ROT PREVENTION HARNESS
WIRING HARNESS (4 4) (FOR 90A ALTERNATOR) (FOR ROT PREVENTION HARNESS
NAME PLATE AND CAUTION PLATE (JAPANESE-ENGLISH
NAME PLATE AND CAUTION PLATE (ENGLISH) (REGULATION OF EPA AND EU
SENSOR (EXHAUST TEMPERATURE¤ OIL PRESSURE¤ AIR PRESSURE) (FOR PM-CLINIC
MUFFLER MOUN
MUFFLER MOUNT (LANDFILL SPEC.
COOLING FAN AND AIR CLEANE
COOLING FAN AND AIR CLEANER (LANDFILL SPEC.
ENGIN
CYLINDER HEA
CYLINDER HEAD COVE
EXHAUST MANIFOL
HEAT SHIEL
EXHAUST CONNECTIO
CYLINDER BLOC
IDLER GEA
CAMFOLLOWER COVE
FLYWHEEL HOUSIN
FLYWHEE
ENGINE SUPPOR
CRANKSHAF
VIBRATION DAMPE
DAMPER FLANG
CAMSHAF
ROCKER AR
LUBRICATING OIL PUM
OIL FILTE
OIL COOLE
FUEL RETUR
WATER PUM
MUFFLER MOUN
- KOMATSU Fault Codes
