Komatsu Engine SAA6D140E-5G 535912-UP Parts Catalog
Model: Komatsu SAA6D140E-5G (For D155AX-6) Engine
Serial Number: 535912-UP
Number of Pages: 343 Pages
Cylinder Head Cover
Head Cover Mounting Bolt
Air Intake Manifold
Air Intake Manifold Landfill Specification
Air Intake Manifold (Landfill Specification)
Exhaust Manifold
Turbocharger
Turbocharger Mounting Parts
Turbocharger Inner Parts
Turbocharger Lubrication Piping
Turbocharger Water Piping
Turbocharger Landfill Specification
Turbocharger Mounting Parts (Landfill Specification)
Turbocharger Inner Parts (1)
Turbocharger Lubrication Piping (Landfill Specification)
Turbocharger Water Piping (Landfill Specification)
Exhaust Gas Re-circulation (EGR) Valve EGR Valve and Cooler Mounting
Exhaust Gas Re-circulation (EGR) Valve EGR Cooler Piping and Air Vent
Exhaust Gas Re-circulation (EGR) Valve EGR By-Pass Valve Piping
Exhaust Gas Re-circulation (EGR) Valve Inner Parts EGR Oil Pump
Exhaust Gas Re-circulation (EGR) Valve EGR Oil Pump Lubricator
Exhaust Gas Re-circulation (EGR) Valve Return Piping
Exhaust Gas Re-circulation (EGR) Valve Front Hanger
Exhaust Gas Re-circulation (EGR) Valve Landfill Specification
Exhaust Gas Re-circulation (EGR) Valve EGR Valve and Cooler Mounting (Landfill Specification)
Exhaust Gas Re-circulation (EGR) Valve EGR Cooler Piping and Air Vent (Landfill Specification)
Exhaust Gas Re-circulation (EGR) Valve EGR By-Pass Valve Piping (Landfill Specification)
Exhaust Gas Re-circulation (EGR) Valve Inner Parts EGR Oil Pump (1)
Exhaust Gas Re-circulation (EGR) Valve EGR Valve Lubricating Oil Piping (Landfill Specification)
Exhaust Gas Re-circulation (EGR) Valve Return Piping (Landfill Specification)
Exhaust Gas Re-circulation (EGR) Valve Front Hanger (Landfill Specification)
Heat Shield
Heat Shield For 90Amp. Alternator
Heat Shield (For 90Amp. Alternator)
Heat Shield Landfill Specification
Heat Shield (1 3) (Landfill Specification)
Heat Shield (2 3) (Landfill Specification)
Heat Shield (3 3) (Landfill Specification)
Exhaust Muffler
Exhaust Muffler Landfill Specification
Exhaust Muffler (Landfill Specification)
Cylinder Block Accessory
Cylinder Block Accessory With Coolant Heater
Cylinder Block Accessory (With Coolant Heater)
Front Cover
Front Cover Accessory
Front Cover Accessory For Slag Handling
Front Cover Accessory (For Slag Handling)
Idle Gears
Cam Follower Cover
Engine Oil Filler
Engine Oil Pan
Engine Oil Pan With Coolant Heater
Engine Oil Pan (With Coolant Heater)
Flywheel Housing
Flywheel
Engine Mounting
Vibration Damper
Piston and Connecting Rod
Damper Flange
Camshaft
Camshaft Related Parts
Camshaft Related Parts Cam Follower
Front PTO (Power Take Off) With Hardened Pulley
Front PTO (Power Take Off) (With Hardened Pulley)
Front PTO (Power Take Off) Non Drive Type
Front PTO (Power Take Off) (Non Drive Type)
ENGINE LUBRICATION SYSTEM
Lubrication Oil Pump
ENGINE FUEL SYSTEM
Fuel Supply Pump
Fuel Supply Pump Drive Gear
Fuel Supply Pump Inner Parts Pump(#535751-535911)
Fuel Supply Pump Inner Parts Feed Pump
Fuel Supply Pump Common Rail
Fuel Supply Pump Fuel Piping
Fuel Supply Pump Bracket and Piping
Fuel Supply Pump Bracket and Piping Bracket
Fuel Supply Pump Bracket and Piping Cover
Fuel Supply Pump Lubricator
Fuel Filter (#535751-535909)
Fuel Filter For Bad Fuel and Poor Fuel Specification Water+Dust Turkey
Fuel Filter (For Bad Fuel and Poor Fuel Specification Water+Dust Turkey)
Fuel Filter (1)
Fuel Injection Controller
Fuel Injection Controller For Slag Handling
Fuel Injection Controller (For Slag Handling)
Fuel Prefilter
Fuel Injection Nozzle
Fuel Return
ENGINE COOLING SYSTEM
Water Pump Air Vent and Thermostat
Water Pump Inner Parts
Water Pump For Air Conditioner
Water Pump Air Vent and Thermostat (For Air Conditioner)
Water Pump Inner Parts (1)
Water Pump Landfill Specification
Water Pump Air Vent and Thermostat (Landfill Specification)
Water Pump Inner Parts (Landfill Specification)
Cooling Fan
Corrosion Resistor
Corrosion Resistor (1)
Coolant Filter With Coolant Filter
Coolant Filter (With Coolant Filter)
ENGINE ELECTRICAL SYSTEM
Alternator 75Amp.
Alternator Inner Parts (75Amp.)
Alternator Mounting Parts (75Amp.)
Alternator 75Amp.For EU Safety Regulation
Alternator Inner Parts (75Amp. For EU Safety Regulation)
Alternator Mounting Parts (75Amp. For EU Safety Regulation)
Alternator 50Amp.60Amp.
Alternator Inner Parts (50Amp. 60Amp.)
Alternator Mounting Parts (50Amp. 60Amp.)
Alternator 60Amp.For EU Safety Regulation
Alternator Inner Parts (60Amp. For EU Safety Regulation)
Alternator Mounting Parts (60Amp. For EU Safety Regulation)
Alternator 75Amp.Sandy and Dusty Terrain Spec.
Alternator Inner Parts (75Amp. Sandy and Dusty Terrain Spec.)
Alternator Mounting Parts (75Amp. Sandy and Dusty Terrain Spec.)
Alternator 75Amp. (1)
Alternator 50Amp.Sandy and Dusty Terrain Spec.
Alternator Inner Parts (50Amp. Sandy and Dusty Terrain Spec.)
Alternator Mounting Parts (50Amp. Sandy and Dusty Terrain Spec.)
Alternator 50Amp.60Amp.For Sandy and Dusty Terrain ArrangementEU Safety Regulation
Alternator Inner Parts (50Amp. 60Amp. For Sandy and Dusty Terrain Arrangement EU Safety Regulation)
Alternator Mounting Parts (50Amp. 60Amp. For Sandy and Dusty Terrain Arrangement EU Safety Regulation)
Alternator 90Amp.Landfill Specification
Alternator Inner Parts (90Amp. Landfill Specification)
Alternator Inner Parts Alternator (90Amp. Landfill Specification)
Alternator Mounting Parts (90Amp. Landfill Specification)
Alternator 90Amp.
Alternator Inner Parts (90Amp.)
Alternator Mounting Parts (90Amp.)
Starting Motor 11KW
Starting Motor Inner Parts (11KW)
Starting Motor Inner Parts Starting Motor (11KW)
Starting Motor Mounting Parts (11KW)
Wiring Harness
Wiring Harness (1 4)
Wiring Harness (2 4)(#535751-542518)
Wiring Harness (3 4)
Wiring Harness (4 4)
Wiring Harness For 90Amp. Alternator
Wiring Harness (1 4) (For 90Amp. Alternator)
Wiring Harness (2 4) (For 90Amp. Alternator)(#535751-542518)
Wiring Harness (3 4) (For 90Amp. Alternator)
Wiring Harness (4 4) (For 90Amp. Alternator)
Wiring Harness 75Amp.For Slag Handling
Wiring Harness (1 4) (75Amp. For Slag Handling)
Wiring Harness (2 4) (75Amp. For Slag Handling)(#535751-542518)
Wiring Harness (3 4) (75Amp. For Slag Handling)
Wiring Harness (4 4) (75Amp. For Slag Handling)
ENGINE MARKS AND PLATES
Name Plate and Caution Plate Japanese-English
Name Plate and Caution Plate (Japanese-English)(#535751-536514)
Name Plate and Caution Plate For EU Exhaust Emissions 3rd RegulationsNorth America EPA 3rd Regulations
Name Plate and Caution Plate (For EU Exhaust Emissions 3rd Regulations North America EPA 3rd Regulations)
Name Plate and Caution Plate For EU Safety RegulationEU Exhaust Emissions 3rd RegulationsNorth America EPA 3rd Regulations
Name Plate and Caution Plate (For EU Safety Regulation EU Exhaust Emissions 3rd Regulations North America EPA 3rd Regulations
Name Plate and Caution Plate For EU Exhaust Emissions 3rd RegulationsNorth America EPA Interim 4th RegulationsKorea EX-Gas Re
Name Plate and Caution Plate (For EU Exhaust Emissions 3rd Regulations North America EPA Interim 4th Regulations Korea EX-Gas
Name Plate and Caution Plate For EU Exhaust Emissions 3rd RegulationsEU Safety Regulation
Name Plate and Caution Plate (For EU Exhaust Emissions 3rd Regulations EU Safety Regulation)
Name Plate and Caution Plate For China 2nd EX-Gas Regulation Arrangement
Name Plate and Caution Plate (For China 2nd EX-Gas Regulation Arrangement)(#536515-537607)
Name Plate and Caution Plate For China 2nd EX-Gas Regulation Arrangement (1)
Name Plate and Caution Plate (For EU Safety Regulation)(#536515-537607)
Name Plate and Caution Plate For EU Safety Regulation (1)
Name Plate and Caution Plate For Korea EX-Gas Regulation Arrangement
Name Plate and Caution Plate (For Korea EX-Gas Regulation Arrangement)(#536515-537607)
Name Plate and Caution Plate For Korea EX-Gas Regulation Arrangement (1)
Name Plate and Caution Plate For EPA Regulations TPEM
Name Plate and Caution Plate (For EPA Regulations TPEM)
Name Plate and Caution Plate For EU Safety RegulationNon EU Territory
Name Plate and Caution Plate (For EU Safety Regulation Non EU Territory)
Name Plate and Caution Plate For EU Safety RegulationTurkey Exhaust Emissions 3rd Regulations
Name Plate and Caution Plate (For EU Safety Regulation Turkey Exhaust Emissions 3rd Regulations)
Name Plate and Caution Plate For North America EPA 3rd Regulations
Name Plate and Caution Plate (For North America EPA 3rd Regulations)
Name Plate and Caution Plate Except Japan
Name Plate and Caution Plate (Except Japan)
Name Plate and Caution Plate For Canada Exhaust Gas TPEM
Name Plate and Caution Plate (For Canada Exhaust Gas TPEM)
Name Plate and Caution Plate For Turkey Exhaust Emissions 3rd Regulations
Name Plate and Caution Plate (For Turkey Exhaust Emissions 3rd Regulations)
Name Plate and Caution Plate Except Japan (1)
Name Plate and Caution Plate For BRAZIL Noise Regulation
Name Plate and Caution Plate (For BRAZIL Noise Regulation)
Name Plate and Caution Plate For China 3rd EX-Gas Regulation Arrangement
Name Plate and Caution Plate (For China 3rd EX-Gas Regulation Arrangement)
Name Plate and Caution Plate Except Japan (2)
Cylinder Head Cover
Air Intake Manifold
Exhaust Manifold
Turbocharger
Heat Shield
Exhaust Muffler
Front Cover
Idle Gears
Cam Follower Cover
Engine Oil Filler
Engine Oil Pan
Flywheel Housing
Flywheel
Engine Mounting
Vibration Damper
Damper Flange
Camshaft
ENGINE FUEL SYSTEM
Fuel Supply Pump
Fuel Filter (1)
Fuel Prefilter
Fuel Return
Cooling Fan
Corrosion Resistor
Alternator 75Amp.
Alternator 90Amp.
Starting Motor 11KW
Wiring Harness
- KOMATSU Fault Codes
