Komatsu Engine SAA6D140E-5F-KU 530043-UP Parts Catalog
Model: Komatsu SAA6D140E-5F-KU Engine
Serial Number: 530043-UP
Number of Pages: 145 Pages
KOMATSU SAA6D140E-5F-KU S N 530043-U
A0 ENGIN
CYLINDER HEA
HEAD COVE
HEAD COVER BOL
AIR INTAKE MANIFOL
AIR CLEANER (INNER PARTS
AIR CLEANE
EXHAUST MANIFOL
TURBOCHARGER MOUNTIN
TURBOCHARGER (KTR110M-D32AW) (INNER PARTS
TURBOCHARGER (KTR110M-D32AW) (INNER PARTS) (1
TURBOCHARGER OIL PIPIN
TURBOCHARGER WATER PIPIN
EXHAUST GAS RECIRCULATION VALVE (1 7
EXHAUST GAS RECIRCULATION VALVE (2 7
EXHAUST GAS RECIRCULATION VALVE (3 7
EXHAUST GAS RECIRCULATION VALVE (4 7
EXHAUST GAS RECIRCULATION VALVE (5 7
EXHAUST GAS RECIRCULATION VALVE (6 7
EXHAUST GAS RECIRCULATION VALVE (7 7
HEAT SHIEL
MUFFLE
CYLINDER BLOC
CYLINDER BLOCK ACCESSORY AND FILLE
FRONT COVE
FRONT COVER ACCESSORY AND BREATHE
IDLER GEA
CAMFOLLOWER COVE
OIL PAN AND SUCTION TUB
OIL LEVEL GAUGE AND SENSO
FLYWHEEL HOUSIN
FLYWHEE
ENGINE SUPPOR
CRANKSHAF
VIBRATION DAMPE
PISTON AND CONNECTING RO
DAMPER FLANG
CAMSHAF
CAMFOLLOWER AND PUSH RO
ROCKER AR
FRONT POWER TAKE OF
LUBRICATING OIL PUM
OIL FILTER (SHASSIS MOUNT SPEC.
OIL COOLE
FUEL SUPPLY PUMP AND COMMON RAIL MOUNTIN
FUEL SUPPLY PUMP BRACKET AND PIPIN
FUEL SUPPLY TUBE JOINT SUPPOR
FUEL SUPPLY PUMP LUBRICATO
FUEL FILTER (THREAD 1-5 8
FUEL FILTER CARTRIDGE (SERVICE ONLY
FUEL INJECTOR AND SPILL TUB
FUEL RETUR
FUEL INJECTION CONTROLLE
THERMOSTAT AND AIR VEN
WATER PUM
CORROSION RESISTO
ALTERNATOR MOUNTING (90A
ALTERNATOR (90A) (INNER PARTS
ALTERNATOR MOUNTING (90A) (WITH HARDENING PULLEY
ALTERNATOR (90A) (WITH HARDENING PULLEY) (INNER PARTS
ALTERNATOR (90A) (INNER PARTS) (1
ALTERNATOR (90A) (WITH HARDENING PULLEY) (INNER PARTS) (1
STARTING MOTOR MOUNTING (11KW
STARTING MOTOR (11KW) (INNER PARTS) (1
WIRING (1 5
WIRING (2 5
WIRING (3 5
WIRING (4 5
WIRING (5 5
NAME PLATE AND CAUTION PLATE (ENGLISH) (REGULATION OF EPA AND EU
A0 ENGIN
CYLINDER HEA
HEAD COVE
HEAD COVER BOL
AIR INTAKE MANIFOL
AIR CLEANE
EXHAUST MANIFOL
HEAT SHIEL
MUFFLE
CYLINDER BLOC
FRONT COVE
IDLER GEA
CAMFOLLOWER COVE
FLYWHEEL HOUSIN
FLYWHEE
ENGINE SUPPOR
CRANKSHAF
VIBRATION DAMPE
DAMPER FLANG
CAMSHAF
ROCKER AR
FRONT POWER TAKE OF
LUBRICATING OIL PUM
OIL COOLE
FUEL RETUR
WATER PUM
CORROSION RESISTO
WIRING (1 5
WIRING (2 5
WIRING (3 5
WIRING (4 5
WIRING (5 5
- KOMATSU Fault Codes
