Komatsu Engine SAA6D140E-5F 536267-UP Parts Catalog
Model: Komatsu SAA6D140E-5F Engine
Serial Number: 536267-UP
Number of Pages: 266 Pages
Cylinder Head Cover
Head Cover Mounting Bolt
Air Intake Manifold
Exhaust Manifold
Turbocharger
Turbocharger Mounting
Turbocharger Turbocharger
Turbocharger Lubrication Piping
Turbocharger Water Piping
Exhaust Gas Re-circulation (EGR) Valve EGR Valve and Cooler Mounting
Exhaust Gas Re-circulation (EGR) Valve EGR Cooler Water Piping
Exhaust Gas Re-circulation (EGR) Valve Air Vent and Bypass Valve Piping
Exhaust Gas Re-circulation (EGR) Valve Inner Parts EGR Oil Pump
Exhaust Gas Re-circulation (EGR) Valve EGR Oil Pomp Lubricator Mounting
Exhaust Gas Re-circulation (EGR) Valve EGR Valve Oil Return Piping
Exhaust Gas Re-circulation (EGR) Valve Engine Front Hanger
Exhaust Gas Re-circulation (EGR) Valve After Minor Change
Exhaust Gas Re-circulation (EGR) Valve EGR Valve and Cooler Mounting (After Minor Change)
Exhaust Gas Re-circulation (EGR) Valve EGR Cooler Water Piping (1)
Exhaust Gas Re-circulation (EGR) Valve Air Vent and Bypass Valve Piping (After Minor Change)
Exhaust Gas Re-circulation (EGR) Valve Inner Parts EGR Oil Pump (1)
Exhaust Gas Re-circulation (EGR) Valve EGR Oil Pomp Lubricator Mounting (1)
Exhaust Gas Re-circulation (EGR) Valve EGR Valve Oil Return Piping (After Minor Change)
Exhaust Gas Re-circulation (EGR) Valve Engine Front Hanger (After Minor Change)
Heat Shield
Exhaust Muffler
Air Cleaner Mounting and Air Connection
Air Cleaner Mounting and Air Connection Inner Parts
Air Cleaner Mounting and Air Connection Air Cleaner Related Parts
Cylinder Block Accessory
Cylinder Block Accessory For Cold Area Specification A (-30 deg C)
Cylinder Block Accessory (For Cold Area Specification A (-30 deg C))
Front Cover
Idle Gears
Cam Follower Cover
Front Cover Accessory and Breather
Oil Pan and Suction Tube
Oil Pan and Suction Tube Oil Pan
Oil Pan and Suction Tube Oil Level Gauge
Oil Pan and Suction Tube For Cold Area Specification A (-30 deg C)
Oil Pan and Suction Tube Oil Pan (For Cold Area Specification A (-30 deg C))
Oil Pan and Suction Tube Oil Level Gauge (For Cold Area Specification A (-30 deg C))
Oil Pan and Suction Tube With Coolant FilterFor Cold Area Specification A (-30 deg C)
Oil Pan and Suction Tube Oil Pan (With Coolant Filter For Cold Area Specification A (-30 deg C))
Oil Pan and Suction Tube Oil Level Gauge (With Coolant Filter For Cold Area Specification A (-30 deg C))
Flywheel Housing
Flywheel
Engine Support
Vibration Damper
Piston and Connecting Rod
Damper Flange
Camshaft
Camshaft Related Parts
Camshaft Related Parts Cam Follower and Push Rod
Camshaft Related Parts Rocker Arm
Front PTO (Power Take Off)
Front PTO (Power Take Off) For Sandy and Dusty Terrain Arrangement
Front PTO (Power Take Off) (For Sandy and Dusty Terrain Arrangement)
Cooling Fan and Oil Filter
ENGINE LUBRICATION SYSTEM
Lubrication Oil Pump
Engine Oil Filter Bracket
ENGINE FUEL SYSTEM
Fuel Supply Pump
Fuel Supply Pump Drive Gear
Fuel Supply Pump Inner Parts Pump
Fuel Supply Pump Inner Parts Feed Pump
Fuel Supply Pump Pump Mounting
Fuel Supply Pump Inner Parts Common Rail
Fuel Supply Pump Fuel Piping
Fuel Supply Pump Bracket and Piping
Fuel Supply Pump Bracket and Piping Piping and Bracket
Fuel Supply Pump Bracket and Piping Fuel Piping Joint
Fuel Supply Pump Lubricator
Fuel Filter Cartridge
Fuel Injection Nozzle
Fuel Return
ENGINE COOLING SYSTEM
Water Pump Air Vent and Thermostat
Water Pump Water Pump
Water Pump For Cold Area Specification A (-30 deg C)
Water Pump Air Vent and Thermostat (For Cold Area Specification A (-30 deg C))
Water Pump Water Pump (For Cold Area Specification A (-30 deg C))
Coolant Filter
Water Piping Plug
Water Piping Plug Without Corrosion Resister
ENGINE ELECTRICAL SYSTEM
Alternator 60Amp.
Alternator Inner Parts (60Amp.)
Alternator Mounting (60Amp.)
Alternator 60Amp.For Sandy and Dusty Terrain Arrangement
Alternator Inner Parts (60Amp. For Sandy and Dusty Terrain Arrangement)
Alternator Mounting (60Amp. For Sandy and Dusty Terrain Arrangement)
Alternator 90Amp.
Alternator Inner Parts (90Amp.)
Alternator Mounting (90Amp.)
Alternator 90Amp.For Sandy and Dusty Terrain Arrangement
Alternator Inner Parts (90Amp. For Sandy and Dusty Terrain Arrangement)
Alternator Inner Parts Alternator (90Amp. For Sandy and Dusty Terrain Arrangement)
Alternator Mounting (90Amp. For Sandy and Dusty Terrain Arrangement)
Starting Motor 11KW
Starting Motor Inner Parts (11KW)
Starting Motor Mounting (11KW)
Wiring Harness
Wiring Harness (1 5)
Wiring Harness (2 5)
Wiring Harness (3 5)
Wiring Harness (4 5)
Wiring Harness (5 5)
Wiring Harness For Cold Area Specification A (-30 deg C)
Wiring Harness (1 5) (For Cold Area Specification A (-30 deg C))
Wiring Harness (2 5) (For Cold Area Specification A (-30 deg C))
Wiring Harness (3 5) (For Cold Area Specification A (-30 deg C))
Wiring Harness (4 5) (For Cold Area Specification A (-30 deg C))
Wiring Harness (5 5) (For Cold Area Specification A (-30 deg C))
ENGINE ACCESSORIES AND OTHERS
Engine Controller
ENGINE MARKS AND PLATES
Name Plate and Caution Plate For North America EPA Interim 4th RegulationsNorth America EPA 3rd Regulations
Name Plate and Caution Plate (For North America EPA Interim 4th Regulations North America EPA 3rd Regulations)
Name Plate and Caution Plate For EU Safety Regulation
Name Plate and Caution Plate (For EU Safety Regulation)
Name Plate and Caution Plate For China 2nd EX-Gas Regulation Arrangement
Name Plate and Caution Plate (For China 2nd EX-Gas Regulation Arrangement)
Name Plate and Caution Plate For EU Exhaust Emissions 3rd RegulationsEU Safety Regulation
Name Plate and Caution Plate (For EU Exhaust Emissions 3rd Regulations EU Safety Regulation)
Name Plate and Caution Plate For EU Safety Regulation (1)
Name Plate and Caution Plate For EU Safety Regulation (2)
Name Plate and Caution Plate For China 2nd EX-Gas Regulation Arrangement (1)
Name Plate and Caution Plate For China 2nd EX-Gas Regulation Arrangement (2)
Name Plate and Caution Plate For EPA Regulations TPEM
Name Plate and Caution Plate (For EPA Regulations TPEM)
Name Plate and Caution Plate For EU Safety RegulationNon EU Territory
Name Plate and Caution Plate (For EU Safety Regulation Non EU Territory)
Name Plate and Caution Plate For EU Safety RegulationTurkey Exhaust Emissions 3rd Regulations
Name Plate and Caution Plate (For EU Safety Regulation Turkey Exhaust Emissions 3rd Regulations)
Name Plate and Caution Plate For North America EPA 3rd Regulations
Name Plate and Caution Plate (For North America EPA 3rd Regulations)
Name Plate and Caution Plate For Canada Exhaust Gas TPEM
Name Plate and Caution Plate (For Canada Exhaust Gas TPEM)
Name Plate and Caution Plate For BRAZIL Noise Regulation
Name Plate and Caution Plate (For BRAZIL Noise Regulation)
Name Plate and Caution Plate For China 3rd EX-Gas Regulation Arrangement
Name Plate and Caution Plate (For China 3rd EX-Gas Regulation Arrangement)
Name Plate and Caution Plate (1)
Name Plate and Caution Plate (2)
Cylinder Head Cover
Air Intake Manifold
Exhaust Manifold
Turbocharger
Heat Shield
Exhaust Muffler
Front Cover
Idle Gears
Cam Follower Cover
Flywheel Housing
Flywheel
Engine Support
Vibration Damper
Damper Flange
Camshaft
ENGINE FUEL SYSTEM
Fuel Supply Pump
Fuel Return
Coolant Filter
Water Piping Plug
Alternator 60Amp.
Alternator 90Amp.
Starting Motor 11KW
Wiring Harness
Engine Controller
- KOMATSU Fault Codes
