118
6,911
Komatsu Engine SAA6D140E-5E 535052-UP Parts Catalog
Model: Komatsu SAA6D140E-5E (For HM350-2) Engine
Serial Number: 535052-UP
Number of Pages: 267 Pages
Cylinder Head Cover
Air Intake Manifold and Connection
Head Cover Mounting Bolt
Air Connection
Exhaust Manifold
Turbocharger
Turbocharger Mounting
Turbocharger Inner Parts
Turbocharger Lubricating Oil Piping
Exhaust Gas Re-circulation (EGR) Valve EGR Valve and Cooler Mounting
Exhaust Gas Re-circulation (EGR) Valve EGR Cooler Water Piping
Exhaust Gas Re-circulation (EGR) Valve Air Vent and Bypass Valve Piping
Exhaust Gas Re-circulation (EGR) Valve Inner Parts
Exhaust Gas Re-circulation (EGR) Valve EGR Oil Pump Lubricator
Exhaust Gas Re-circulation (EGR) Valve EGR Valve Oil Return Piping
Exhaust Gas Re-circulation (EGR) Valve Engine Front Hanger
Cylinder Block Accessory
Cylinder Block Accessory With Vandalism Protection Lock
Cylinder Block Accessory (With Vandalism Protection Lock)
Front Cover
Idle Gears
Cam Follower Cover
Front Cover Accessory and Breather
Oil Pan and Suction Tube
Flywheel Housing
Flywheel
Engine Support
Vibration Damper
Piston and Connecting Rod
Crank Pulley
Crank Pulley Sandy and Dusty Terrain Spec.
Crank Pulley (Sandy and Dusty Terrain Spec.)
Camshaft
Camshaft Related Parts
Camshaft Related Parts Cam Follower
Camshaft Related Parts Rocker Arm
Front PTO (Power Take Off)
Front PTO (Power Take Off) Sandy and Dusty Terrain Spec.
Front PTO (Power Take Off) (Sandy and Dusty Terrain Spec.)
ENGINE LUBRICATION SYSTEM
Lubrication Oil Pump
Engine Oil Filter
ENGINE FUEL SYSTEM
Fuel Supply Pump
Fuel Supply Pump Drive Gear
Fuel Supply Pump Inner Parts Pump (1 2)
Fuel Supply Pump Inner Parts Pump (2 2)
Fuel Supply Pump Common Rail
Fuel Supply Pump Mounting
Fuel Supply Pump Bracket and Piping
Fuel Supply Pump Bracket and Piping Lubricating Oil Piping
Fuel Supply Pump Bracket and Piping Fuel Piping
Fuel Supply Pump Lubricator
Fuel Filter (1)
Fuel Filter Cartridge
Fuel Filter Cartridge (1)
Fuel Prefilter
Fuel Injection Nozzle
Fuel Return
Fuel Filter and Water Separator
Fuel Filter and Water Separator (1)
Fuel Filter and Water Separator (2)
Fuel Filter and Water Separator (3)
ENGINE COOLING SYSTEM
Water Pump Air Vent and Thermostat
Water Pump Inner Parts
Cooling Fan
Fan Pulley and V-Belt
Fan Pulley and V-Belt Sandy and Dusty Terrain Spec.
Fan Pulley and V-Belt (Sandy and Dusty Terrain Spec.)
Fan Drive and Tension Pulley
Fan Drive and Tension Pulley Sandy and Dusty Terrain Spec.
Fan Drive and Tension Pulley (Sandy and Dusty Terrain Spec.)
Corrosion Resistor For Hard Water Area Arrangement
Corrosion Resistor (For Hard Water Area Arrangement)
Parts For Less Corrosion Resistor
ENGINE ELECTRICAL SYSTEM
Alternator 60Amp.
Alternator Inner Parts (60Amp.)
Alternator Mounting (60Amp.)
Alternator 75Amp.
Alternator Inner Parts (75Amp.)
Alternator Mounting (75Amp.)
Alternator 60Amp.Sandy and Dusty Terrain Spec.
Alternator Inner Parts (60Amp. Sandy and Dusty Terrain Spec.)
Alternator Mounting (60Amp. Sandy and Dusty Terrain Spec.)
Alternator 75Amp.Sandy and Dusty Terrain Spec.
Alternator Inner Parts (75Amp. Sandy and Dusty Terrain Spec.)
Alternator Mounting (75Amp. Sandy and Dusty Terrain Spec.)
Alternator 60Amp.For EU Safety Regulation
Alternator Inner Parts (60Amp. For EU Safety Regulation)
Alternator Mounting (60Amp. For EU Safety Regulation)
Alternator 60Amp.For Sandy and Dusty Terrain ArrangementEU Safety Regulation
Alternator Inner Parts (60Amp. For Sandy and Dusty Terrain Arrangement EU Safety Regulation)
Alternator Mounting (60Amp. For Sandy and Dusty Terrain Arrangement EU Safety Regulation)
Alternator 75Amp.For EU Safety Regulation
Alternator Inner Parts (75Amp. For EU Safety Regulation)
Alternator Mounting (75Amp. For EU Safety Regulation)
Alternator 75Amp.For Sandy and Dusty Terrain ArrangementEU Safety Regulation
Alternator Inner Parts (75Amp. For Sandy and Dusty Terrain Arrangement EU Safety Regulation)
Alternator Mounting (75Amp. For Sandy and Dusty Terrain Arrangement EU Safety Regulation)
Starting Motor 11KW
Starting Motor Inner Parts (11KW)
Starting Motor Inner Parts Starting Motor (11KW)
Starting Motor Mounting (11KW)
Wiring Harness
Wiring Harness (1 4)
Wiring Harness (2 4)
Wiring Harness (3 4)
Wiring Harness (4 4)
Wiring Harness For EC Noise Regulation
Wiring Harness (1 4) (For EC Noise Regulation)
Wiring Harness (2 4) (For EC Noise Regulation)
Wiring Harness (3 4) (For EC Noise Regulation)
Wiring Harness (4 4) (For EC Noise Regulation)
ENGINE ACCESSORIES AND OTHERS
Engine Controller
ENGINE MARKS AND PLATES
Name Plate and Caution Plate
Name Plate and Caution Plate North America EPA 3rd RegulationsEU Exhaust Emissions 3rd Regulations
Name Plate and Caution Plate (North America EPA 3rd Regulations EU Exhaust Emissions 3rd Regulations)
Name Plate and Caution Plate For North America EPA 3rd RegulationsEU Exhaust Emissions 3rd RegulationsEU Safety Regulation
Name Plate and Caution Plate (For North America EPA 3rd Regulations EU Exhaust Emissions 3rd Regulations EU Safety Regulation
Name Plate and Caution Plate For EU Safety Regulation
Name Plate and Caution Plate (For EU Safety Regulation)
Name Plate and Caution Plate For EU Safety Regulation (1)
Name Plate and Caution Plate For EPA Regulations TPEM
Name Plate and Caution Plate (For EPA Regulations TPEM)
Name Plate and Caution Plate For EU Regulations Flexibility SchemeEU Safety Regulation
Name Plate and Caution Plate (For EU Regulations Flexibility Scheme EU Safety Regulation)
Name Plate and Caution Plate For EU Safety RegulationNon EU Territory
Name Plate and Caution Plate (For EU Safety Regulation Non EU Territory)
Name Plate and Caution Plate (1)
Name Plate and Caution Plate (2)
Name Plate and Caution Plate For Except Japan
Name Plate and Caution Plate (For Except Japan)
Name Plate and Caution Plate For Except Japan (1)
CHASSIS TRANSFER PARTS
Fuel Filter and Water Separator (4)
Fuel Filter and Water Separator (5)
