118
6,911
Komatsu Engine SAA6D140E-5E-01 530001-UP Parts Catalog
Model: Komatsu SAA6D140E-5E-01 Engine
Serial Number: 530001-UP
Number of Pages: 199 Pages
SAA6D140E-5E-01 S N 530001-U
ENGIN
CYLINDER HEA
CYLINDER HEAD COVE
HEAD COVER MOUNTING BOL
AIR INTAKE MANIFOLD AND CONNECTIO
AIR CONNECTION (AIR CLEANER REMOTE MOUNT SPEC.
EXHAUST MANIFOL
TURBOCHARGER MOUNTING AND LUBRICATO
TURBOCHARGER (KTR110M-532A) (INNER PARTS
EXHAUST GAS RECIRCULATION VALVE (1 7) (COOLER AND VALVE MOUNTING) (WITH BYPASS VALVE
EXHAUST GAS RECIRCULATION VALVE (1 6) (COOLER AND VALVE MOUNTING) (WITH BYPASS VALVE
EXHAUST GAS RECIRCULATION VALVE (2 7) (EGR COOLER WATER PIPING
EXHAUST GAS RECIRCULATION VALVE (2 6) (EGR COOLER WATER PIPING
EXHAUST GAS RECIRCULATION VALVE (3 7) (AIR VENT AND BYPASS VALVE PIPING
EXHAUST GAS RECIRCULATION VALVE (3 6) (AIR VENT AND BYPASS VALVE PIPING
EXHAUST GAS RECIRCULATION VALVE (4 7) (EGR OIL PUMP LUBRICATOR
EXHAUST GAS RECIRCULATION VALVE (4 6) (EGR OIL PUMP LUBRICATOR
EXHAUST GAS RECIRCULATION VALVE (5 7) (EGR VALVE OIL RETURN PIPING
EXHAUST GAS RECIRCULATION VALVE (5 6) (EGR VALVE OIL RETURN PIPING
EXHAUST GAS RECIRCULATION VALVE (6 7) (ENGINE FRONT HANGER
EXHAUST GAS RECIRCULATION VALVE (6 6) (ENGINE FRONT HANGER
EXHAUST GAS RECIRCULATION VALVE (7 7) (EGR SENSOR GROUP
EXHAUST GAS RECIRCULATION OIL PUMP (INNER PARTS
HEAT SHIELD (1 2) (TURBOCHARGER AND EXHAUST MANIFOLD
HEAT SHIELD (2 2) (EGR PIPING AND COOLER
CYLINDER BLOC
CYLINDER BLOCK ACCESSORY (UNDER FRAME AND OIL FILLER
CYLINDER BLOCK ACCESSORY (UNDER FRAME AND OIL FILLER) (WITH VANDALISM PROTECTION
FRONT COVE
FRONT COVER ACCESSORY (POINTER AND BREATHER MOUNTING
IDLER GEA
CAMFOLLOWER COVE
OIL PAN AND SUCTION TUB
FLYWHEEL HOUSIN
FLYWHEE
ENGINE SUPPOR
CRANKSHAF
VIBRATION DAMPE
PISTON AND CONNECTING RO
CRANK PULLEY (SANDY AND DUSTY SPEC.
CRANK PULLEY (NON HARDENING SPEC.
CAMSHAF
CAMFOLLOWER AND PUSH RO
ROCKER AR
FRONT POWER TAKE OF
FRONT POWER TAKE OFF (HARDENING PULLEY
LUBRICATING OIL PUM
OIL FILTER AND PIPIN
OIL COOLE
FUEL SUPPLY PUMP AND COMMON RAIL MOUNTIN
FUEL PUMP SUPPLY AND RETURN PIPIN
COMMON RAIL (INNER PARTS
FUEL SUPPLY PUMP (PUMP) (INNER PARTS
FUEL SUPPLY PUMP (FEED PUMP) (INNER PARTS
FUEL SUPPLY PUMP BRACKET AND PIPIN
FUEL SUPPLY TUBE JOINT SUPPOR
FUEL SUPPLY PUMP LUBRICATO
FUEL FILTER AND FUEL PRIMING PUM
FUEL FILTER CARTRIDGE (SERVICE ONLY
PRE FILTER (SERVICE ONLY
FUEL INJECTOR AND SPILL TUB
FUEL RETUR
FUEL INJECTION CONTROLLE
THERMOSTAT AND AIR VEN
WATER PUM
COOLING FAN (SUCTION TYPE
FAN PULLEY AND V-BEL
FAN PULLEY AND V-BELT (SANDY AND DUSTY SPEC.
FAN DRIVE AND TENSION PULLE
FAN DRIVE AND TENSION PULLEY (SANDY AND DUSTY SPEC.
CORROSION RESISTO
WATER LINE PLUG (WITHOUT CORROSION RESISTOR
ALTERNATOR MOUNTING (FOR 50A ALTERNATOR) (WITH NON HARDENING PULLEY
ALTERNATOR MOUNTING (FOR 75A ALTERNATOR) (WITH NON HARDENING PULLEY
ALTERNATOR MOUNTING (FOR 60A ALTERNATOR) (SANDY AND DUSTY SPEC
ALTERNATOR MOUNTING (FOR 75A ALTERNATOR) (SANDY AND DUSTY SPEC.
ALTERNATOR MOUNTING (FOR 60A ALTERNATOR) (FOR EU SAFETY REGULATION
ALTERNATOR MOUNTING (FOR 60A ALTERNATOR)(SANDY AND DUSTY SPEC.)( FOR EU SAFETY REGULATION
ALTERNATOR MOUNTING (FOR 75A ALTERNATOR) (FOR EU SAFETY REGULATION
ALTERNATOR MOUNTING (FOR 60A ALTERNATOR) (SANDY AND DUSTY SPEC.) (FOR EU SAFETY REGULATION
ALTERNATOR (FOR 50A ALTERNATOR) (WITH NON HARDENING PULLEY) (INNER PARTS
ALTERNATOR (FOR 75A ALTERNATOR) (WITH NON HARDENING PULLEY) (INNER PARTS
ALTERNATOR (FOR 60A ALTERNATOR) (SANDY AND DUSTY SPEC.) (INNER PARTS
ALTERNATOR (FOR 75A ALTERNATOR) (SANDY AND DUSTY SPEC.) (INNER PARTS
ALTERNATOR (FOR 60A ALTERNATOR) (FOR EU SAFETY REGULATION) (INNER PARTS
ALTERNATOR (FOR 60A ALTERNATOR)(SANDY AND DUSTY SPEC.)(FOR EU DAFETY REGULATION) (INNER PARTS
ALTERNATOR (FOR 75A ALTERNATOR) (FOR EU SAFETY REGULATION) (INNER PARTS
ALTERNATOR (FOR 75A ALTERNATOR)(SANDY AND DUSTY SPEC.)(FOR EU DAFETY REGULATION) (INNER PARTS
STARTING MOTOR MOUNTING (11KW
STARTING MOTOR (11KW) (INNER PARTS
WIRING HARNESS (1 4
WIRING HARNESS (1 4) (FOR EC REGULATION
WIRING HARNESS (2 4
WIRING HARNESS (2 4) (FOR EC REGULATION
WIRING HARNESS (3 4
WIRING HARNESS (3 4) (FOR EC REGULATION
WIRING HARNESS (4 4
WIRING HARNESS (4 4) (FOR EC REGULATION
NAME PLATE AND CAUTION PLATE (JAPANESE-ENGLISH
NAME PLATE AND CAUTION PLATE (ENGLISH) (REGULATION OF EPA AND EU
NAME PLATE AND CAUTION (ENGLISH) (EPA AND EU SAFETY REGULATION
OIL FILTER AND AIR CLEANER (CHASSIS MOUNT
