Komatsu Engine SAA6D140E-5D 535823-UP Parts Catalog
Model: Komatsu SAA6D140E-5D (For HD325-7 HD405-7) Engine
Serial Number: 535823-UP
Number of Pages: 254 Pages
Cylinder Head Cover
Head Cover Mounting Bolt
Air Connection Air Cleaner Remote Mount Spec.
Air Connection (Air Cleaner Remote Mount Spec.)
Air Intake Manifold
Exhaust Manifold
Turbocharger
Turbocharger Mounting
Turbocharger Inner Parts
Turbocharger Lubrication Piping
Exhaust Gas Re-circulation (EGR) Valve Gasket
Exhaust Gas Re-circulation (EGR) Valve EGR Cooler Water Piping
Exhaust Gas Re-circulation (EGR) Valve Air Vent and Bypass Valve
Exhaust Gas Re-circulation (EGR) Valve Inner Parts EGR Oil Pump
Exhaust Gas Re-circulation (EGR) Valve EGR Oil Pump Lubricator
Exhaust Gas Re-circulation (EGR) Valve EGR Valve Oil Return Piping
Exhaust Gas Re-circulation (EGR) Valve Engine Front Hanger
Heat Shield
Cylinder Block Accessory
Cylinder Block Accessory Oil Filler and Sensor
Cylinder Block Accessory With Coolant Heater
Cylinder Block Accessory Oil Filler and Sensor (With Coolant Heater)
Front Cover
Front Cover Accessory
Front Cover Accessory Pointer and Breather Mounting
Idle Gears
Cam Follower Cover
Oil Pan and Suction Tube
Oil Pan and Suction Tube Cold Area Arrangement A (-30 thru 40deg C)With Coolant Heater
Oil Pan and Suction Tube (Cold Area Arrangement A (-30 thru 40deg C) With Coolant Heater)
Flywheel Housing
Flywheel
Engine Mounting
Vibration Damper
Piston and Connecting Rod
Crank Pulley
Crank Pulley Sandy and Dusty Terrain Spec.
Crank Pulley (Sandy and Dusty Terrain Spec.)
Camshaft
Camshaft Related Parts
Camshaft Related Parts Cam Follower and Push Rod
Camshaft Related Parts Road Liner
Front PTO (Power Take Off)
Front PTO (Power Take Off) Sandy and Dusty Terrain Spec.
Front PTO (Power Take Off) (Sandy and Dusty Terrain Spec.)
ENGINE LUBRICATION SYSTEM
Lubrication Oil Pump
Engine Oil Filter and Piping
ENGINE FUEL SYSTEM
Fuel Supply Pump
Fuel Supply Pump Drive Gear
Fuel Supply Pump Inner Parts Pump
Fuel Supply Pump Inner Parts Feed Pump
Fuel Supply Pump Mounting
Fuel Supply Pump Common Rail
Fuel Supply Pump Fuel Piping
Fuel Supply Pump Bracket and Piping
Fuel Supply Pump Bracket and Piping (1 2)
Fuel Supply Pump Bracket and Piping (2 2)
Fuel Supply Pump Lubricator
Fuel Filter and Fuel Priming Pump
Fuel Filter Cartridge
Fuel Filter Cartridge (1)
Fuel Prefilter
Fuel Injection Nozzle
Fuel Return
ENGINE COOLING SYSTEM
Water Pump Air Vent and Thermostat
Water Pump Inner Parts
Cooling Fan
Fan Pulley and V-Belt
Fan Pulley and V-Belt Sandy and Dusty Terrain Spec.
Fan Pulley and V-Belt (Sandy and Dusty Terrain Spec.)
Fan Drive and Tension Pulley
Fan Drive and Tension Pulley Sandy and Dusty Terrain Spec.
Fan Drive and Tension Pulley (Sandy and Dusty Terrain Spec.)
Corrosion Resistor Hard Water Area Arrangement Spec.
Corrosion Resistor (Hard Water Area Arrangement Spec.)
Corrosion Resistor Without Corrosion Resistor
Corrosion Resistor (Without Corrosion Resistor)
Coolant Filter
ENGINE ELECTRICAL SYSTEM
Alternator 60Amp.
Alternator Inner Parts (60Amp.)
Alternator Mounting (60Amp.)
Alternator 75Amp.
Alternator Inner Parts (75Amp.)
Alternator Mounting (75Amp.)
Alternator 60Amp.Sandy and Dusty Terrain Spec.
Alternator Inner Parts (60Amp. Sandy and Dusty Terrain Spec.)
Alternator Mounting (60Amp. Sandy and Dusty Terrain Spec.)
Alternator 75Amp.For Sandy and Dusty Terrain Arrangement
Alternator Inner Parts (75Amp. For Sandy and Dusty Terrain Arrangement)
Alternator Mounting (75Amp. For Sandy and Dusty Terrain Arrangement)
Alternator 60Amp.For EU Safety Regulation
Alternator Inner Parts (60Amp. For EU Safety Regulation)
Alternator Mounting (60Amp. For EU Safety Regulation)
Alternator 60Amp.For Sandy and Dusty Terrain ArrangementEU Safety Regulation
Alternator Inner Parts (60Amp. For Sandy and Dusty Terrain Arrangement EU Safety Regulation)
Alternator Mounting (60Amp. For Sandy and Dusty Terrain Arrangement EU Safety Regulation)
Alternator 75Amp.For EU Safety Regulation
Alternator Inner Parts (75Amp. For EU Safety Regulation)
Alternator Mounting (75Amp. For EU Safety Regulation)
Alternator 75Amp.For Sandy and Dusty Terrain ArrangementEU Safety Regulation
Alternator Inner Parts (75Amp. For Sandy and Dusty Terrain Arrangement EU Safety Regulation)
Alternator Mounting (75Amp. For Sandy and Dusty Terrain Arrangement EU Safety Regulation)
Starting Motor 11KW
Starting Motor Inner Parts (11KW)
Starting Motor Inner Parts Starting Motor (11KW)
Starting Motor Mounting (11KW)
Wiring Harness
Wiring Harness Wiring Harness (1 4)
Wiring Harness Wiring Harness (2 4)
Wiring Harness Wiring Harness (3 4)
Wiring Harness Wiring Harness (4 4)
ENGINE ACCESSORIES AND OTHERS
Engine Controller
Sensor PM-Clinic Spec.
Sensor (PM-Clinic Spec.)
ENGINE MARKS AND PLATES
Name Plate and Caution Plate Japanese-English
Name Plate and Caution Plate (Japanese-English)
Name Plate and Caution Plate For North America EPA and EU RegulationsEnglish
Name Plate and Caution Plate (For North America EPA and EU Regulations English)
Name Plate and Caution Plate For North America EPA 3rd RegulationsEU Exhaust Emissions 3rd RegulationsChina 2nd EX-Gas Regula
Name Plate and Caution Plate (For North America EPA 3rd Regulations EU Exhaust Emissions 3rd Regulations China 2nd EX-Gas Reg
Name Plate and Caution Plate For China 2nd EX-Gas Regulation Arrangement
Name Plate and Caution Plate (For China 2nd EX-Gas Regulation Arrangement)
Name Plate and Caution Plate For EU Exhaust Emissions 3rd RegulationsEU Safety Regulation
Name Plate and Caution Plate (For EU Exhaust Emissions 3rd Regulations EU Safety Regulation)
Name Plate and Caution Plate For EU Safety Regulation
Name Plate and Caution Plate (For EU Safety Regulation)
Name Plate and Caution Plate For EU Safety Regulation (1)
Name Plate and Caution Plate For EPA Regulations TPEM
Name Plate and Caution Plate (For EPA Regulations TPEM)
Name Plate and Caution Plate For EU Regulations Flexibility SchemeEU Safety Regulation
Name Plate and Caution Plate (For EU Regulations Flexibility Scheme EU Safety Regulation)
Name Plate and Caution Plate For EU Safety RegulationNon EU Territory
Name Plate and Caution Plate (For EU Safety Regulation Non EU Territory)
Name Plate and Caution Plate For EU Safety RegulationTurkey Exhaust Emissions 3rd Regulations
Name Plate and Caution Plate (For EU Safety Regulation Turkey Exhaust Emissions 3rd Regulations)
Name Plate and Caution Plate For Except Japan
Name Plate and Caution Plate (For Except Japan)
Name Plate and Caution Plate For Canada Exhaust Gas TPEM
Name Plate and Caution Plate (For Canada Exhaust Gas TPEM)
Name Plate and Caution Plate For China 3rd EX-Gas Regulation Arrangement
Name Plate and Caution Plate (For China 3rd EX-Gas Regulation Arrangement)
Name Plate and Caution Plate For Turkey 3A UNECER96 Certified
Name Plate and Caution Plate (For Turkey 3A UNECER96 Certified)
Name Plate and Caution Plate For Except Japan (1)
Cylinder Head Cover
Air Intake Manifold
Exhaust Manifold
Turbocharger
Heat Shield
Front Cover
Idle Gears
Cam Follower Cover
Flywheel Housing
Flywheel
Engine Mounting
Vibration Damper
Crank Pulley
Camshaft
ENGINE FUEL SYSTEM
Fuel Supply Pump
Fuel Prefilter
Fuel Return
Cooling Fan
Coolant Filter
Alternator 60Amp.
Alternator 75Amp.
Starting Motor 11KW
Wiring Harness
Engine Controller
- KOMATSU Fault Codes
