Komatsu Engine SAA6D140E-5B-01 530001-UP Parts Catalog
Model: Komatsu SAA6D140E-5B-01 Engine
Serial Number: 530001-UP
Number of Pages: 221 Pages
SAA6D140E-5B-01 S N 530001-U
ENGIN
CYLINDER HEA
CYLINDER HEAD COVE
HEAD COVER MOUNTING BOL
AIR INTAKE MANIFOLD AND CONNECTIO
AIR CONNECTION (AIR CLEANER REMOTE MOUNT SPEC.
EXHAUST MANIFOL
TURBOCHARGER MOUNTING AND LUBRICATO
TURBOCHARGER (KTR110M-432A) (INNER PARTS
EXHAUST GAS RECIRCULATION VALVE (1 7) (EGR VALVE AND COOLER MOUNTING
EXHAUST GAS RECIRCULATION VALVE (1 6) (EGR VALVE AND COOLER MOUNTING
EXHAUST GAS RECIRCULATION VALVE (1 6) (EGR VALVE AND COOLER MOUNTING) (EU 3RD REGULATION
EXHAUST GAS RECIRCULATION VALVE (1 7) (EGR VALVE AND COOLER MOUNTING) (EU 3RD REGULATION
EXHAUST GAS RECIRCULATION VALVE (2 7) (EGR COOLER WATER PIPING
EXHAUST GAS RECIRCULATION VALVE (2 6) (EGR COOLER WATER PIPING
EXHAUST GAS RECIRCULATION VALVE (2 6) (EGR COOLER WATER PIPING) (EU 3RD REGULATION
EXHAUST GAS RECIRCULATION VALVE (2 7) (EGR COOLER WATER PIPING) (EU 3RD REGULATION
EXHAUST GAS RECIRCULATION VALVE (3 7) (EGR COOLER AIR VENT AND BYPASS VALVE PIPING
EXHAUST GAS RECIRCULATION VALVE (3 6) (EGR COOLER AIR VENT AND BYPASS VALVE PIPING
EXHAUST GAS RECIRCULATION VALVE (3 6) (AIR VENT AND BYPASS VALVE PIPING) (EU 3RD REGULATION
EXHAUST GAS RECIRCULATION VALVE (3 7) (AIR VENT AND BYPASS VALVE PIPING) (EU 3RD REGULATION
EXHAUST GAS RECIRCULATION VALVE (4 7) (EGR OIL PUMP LUBRICATOR
EXHAUST GAS RECIRCULATION VALVE (4 6) (EGR OIL PUMP LUBRICATOR
EXHAUST GAS RECIRCULATION VALVE (4 6) (EGR OIL PUMP LUBRICATOR) (EU 3RD REGULATION
EXHAUST GAS RECIRCULATION VALVE (4 7) (EGR OIL PUMP LUBRICATOR) (EU 3RD REGULATION
EXHAUST GAS RECIRCULATION VALVE (5 7) (EGR VALVE OIL RETURN PIPING
EXHAUST GAS RECIRCULATION VALVE (5 6) (EGR VALVE OIL RETURN PIPING
EXHAUST GAS RECIRCULATION VALVE (5 6) (EGR VALVE OIL RETURN PIPING) (EU 3RD REGULATION
EXHAUST GAS RECIRCULATION VALVE (5 7) (EGR VALVE OIL RETURN PIPING) (EU 3RD REGULATION
EXHAUST GAS RECIRCULATION VALVE (6 7) (ENGINE FRONT HANGER
EXHAUST GAS RECIRCULATION VALVE (6 6) (ENGINE FRONT HANGER
EXHAUST GAS RECIRCULATION VALVE (6 6) (ENGINE FRONT HANGER) (EU 3RD REGULATION
EXHAUST GAS RECIRCULATION VALVE (6 7) (ENGINE FRONT HANGER) (EU 3RD REGULATION
EXHAUST GAS RECIRCULATION VALVE (7 7) (EGR SENSOR GROUP
EXHAUST GAS RECIRCULATION OIL PUMP (EGR SENSOR GROUP) (INNER PARTS
EXHAUST GAS RECIRCULATION OIL PUMP (EU 3RD REGULATION) (INNER PARTS
EXHAUST GAS RECIRCULATION VALVE (7 7) (EGR SENSOR GROUP) (EU 3RD REGULATION
EXHAUST GAS RECIRCULATION OIL PUMP (INNER PARTS
HEAT SHIEL
MUFFLE
CYLINDER BLOC
CYLINDER BLOCK ACCESSORY (UNDER FRAME AND OIL FILLER
CYLINDER BLOCK ACCESSORY (UNDER FRAME AND OIL FILLER) (RADIO CONTROL SPEC.
FRONT COVE
FRONT COVER ACCESSORY (POINTER AND BREATHER MOUNTING
IDLER GEA
CAMFOLLOWER COVE
OIL PAN AND SUCTION TUB
FLYWHEEL HOUSIN
FLYWHEE
ENGINE FRONT SUPPOR
CRANKSHAF
VIBRATION DAMPE
PISTON AND CONNECTING RO
DAMPER FLANG
CAMSHAF
CAMFOLLOWER AND PUSH RO
ROCKER AR
FRONT POWER TAKE OF
FRONT POWER TAKE OFF (HARDENING PULLEY
LUBRICATING OIL PUM
OIL FILTER AND PIPIN
OIL COOLE
FUEL SUPPLY PUMP AND COMMON RAIL MOUNTIN
COMMON RAIL (INNER PARTS
FUEL SUPPLY PUMP (PUMP) (INNER PARTS
FUEL SUPPLY PUMP (FEED PUMP) (INNER PARTS
FUEL SUPPLY PUMP BRACKET AND PIPIN
FUEL SUPPLY TUBE JOINT SUPPOR
FUEL SUPPLY PUMP LUBRICATO
FUEL FILTER AND PRIMING PUM
FUEL FILTER CARTRIDGE (SERVICE ONLY
PRE FILTER (SERVICE ONLY
FUEL INJECTOR AND SPILL TUB
FUEL RETUR
FUEL INJECTION CONTROLLE
THERMOSTAT AND AIR VEN
WATER PUM
WATER PUMP (1
CORROSION RESISTO
WATER LINE PLUG (WITHOUT CORROSION RESISTOR
ALTERNATOR MOUNTING (FOR 90A ALTERNATOR
ALTERNATOR MOUNTING (FOR 50A AND 60A ALTERNATOR
ALTERNATOR MOUNTING (FOR 60A ALTERNATOR
ALTERNATOR MOUNTING (FOR 75A ALTERNATOR) (WITH NON HARDENING PULLEY
ALTERNATOR MOUNTING (FOR 90A ALTERNATOR) (WITH HARDENING PULLEY
ALTERNATOR MOUNTING (FOR 60A ALTERNATOR) (SANDY AND DUSTY SPEC.
ALTERNATOR MOUNTING (FOR 90A ALTERNATOR) (FOR EU SAFETY REGULATION
ALTERNATOR MOUNTING (FOR 70A ALTERNATOR) (SANDY AND DUSTY SPEC.) (FOR EU SAFETY REGULATION
ALTERNATOR (FOR 90A ALTERNATOR) (INNER PARTS
ALTERNATOR (FOR 50A AND 60A ALTERNATOR) (INNER PARTS
ALTERNATOR (FOR 60A ALTERNATOR) (INNER PARTS
ALTERNATOR (FOR 75A ALTERNATOR) (WITH NON HARDENING PULLEY) (INNER PARTS
ALTERNATOR (FOR 90A ALTERNATOR ) (WITH HARDENING PULLEY) (INNER PARTS
ALTERNATOR (FOR 60A ALTERNATOR) (SANDY AND DUSTY SPEC.) (INNER PARTS
ALTERNATOR (FOR 90A ALTERNATOR) (FOR EU SAFETY REGULATION) (INNER PARTS
ALTERNATOR (FOR 90A ALTERNATOR)(SANDY AND DUSTY SPEC.)(FOR EU SAFETY REGULATION) (INNER PARTS
STARTING MOTOR MOUNTING (11KW
WIRING HARNESS (1 5
WIRING HARNESS (2 5
WIRING HARNESS (3 5
WIRING HARNESS (4 5
WIRING HARNESS (5 5
NAME PLATE AND CAUTION PLATE (JAPANESE-ENGLISH
NAME PLATE AND CAUTION PLATE (ENGLISH) (REGULATION OF EPA AND EU
NAME PLATE AND CAUTION (CHINA EXHAUST GAS 2ND REGULATION
AIR CLEANER (CHASSIS MOUNT
ENGIN
CYLINDER HEA
CYLINDER HEAD COVE
EXHAUST MANIFOL
HEAT SHIEL
MUFFLE
CYLINDER BLOC
FRONT COVE
IDLER GEA
CAMFOLLOWER COVE
FLYWHEEL HOUSIN
FLYWHEE
ENGINE FRONT SUPPOR
CRANKSHAF
VIBRATION DAMPE
DAMPER FLANG
CAMSHAF
ROCKER AR
FRONT POWER TAKE OF
LUBRICATING OIL PUM
OIL COOLE
FUEL RETUR
WATER PUM
WATER PUMP (1
CORROSION RESISTO
WIRING HARNESS (1 5
WIRING HARNESS (2 5
WIRING HARNESS (3 5
WIRING HARNESS (4 5
WIRING HARNESS (5 5
- KOMATSU Fault Codes
