Komatsu Engine SAA6D140E-3N-8 110001-UP Parts Catalog
Model: Komatsu SAA6D140E-3N-8 Engine
Serial Number: 110001-UP
Number of Pages: 190 Pages
KOMATSU SAA6D140E-3N-8 S N 110001-U
ENGIN
CYLINDER HEA
HEAD COVE
HEAD COVER BOL
AIR INTAKE MANIFOL
AIR CLEANE
AIR CLEANER (INNER PARTS
EXHAUST MANIFOL
TURBOCHARGER AND OIL PIPIN
TURBOCHARGER (KTR110L-584E) (INNER PARTS
HEAT SHIELD (1 2) TURBOCHARGER AND EXHAUST MANIFOL
HEAT SHIELD (2 2) MUFFLER AND FUEL PIPIN
MUFFLE
CYLINDER BLOC
CYLINDER BLOCK COVER AND OIL FILLE
CYLINDER BLOCK COVER AND OIL FILLER (COLD TERRAIN SPEC.
FRONT COVER (FRONT POWER TAKE OFF SPEC.
FRONT COVER MOUNTING AND BREATHE
IDLER GEA
CAMFOLLOWER COVE
OIL PAN AND SUCTION TUB
OIL PAN AND SUCTION TUBE (COLD TERRAN SPEC.
OIL LEVEL GAUG
OIL LEVEL GAUGE (COLD TERRAN SPEC.
FLYWHEEL HOUSIN
FLYWHEE
ENGINE SUPPOR
CRANKSHAF
VIBRATION DAMPE
PISTO
CRANK PULLEY (SANDY AND DUSTY SPEC.
CRANK PULLE
CRANK PULLEY (HARDENING PULLEY
CAMSHAF
ROCKER AR
CAMFOLLOWE
FRONT POWER TAKE OF
FRONT POWER TAKE OFF (SANDY AND DUSTY SPEC.
OIL PUM
OIL COOLE
FUEL SUPPLY PUMP AND COMMON RAIL MOUNTING (LOW-VISCOSITY FUEL SPEC.) (REGULATION OF EPA AND EU 2ND
FUEL SUPPLY PUMP AND COMMON RAIL MOUNTING (REGULATION OF EPA AND EU 2ND
FUEL PUMP SUPPLY AND RETURN PIPING (LOW-VISCOSITY FUEL SPEC.) (REGULATION OF EPA AND EU 2ND
FUEL PUMP SUPPLY AND RETURN PIPING (REGULATION OF EPA AND EU 2ND
FUEL SUPPLY PUMP (PUMP) (LOW-VISCOSITY FUEL SPEC.) (REGULATION OF EPA AND EU 2ND) (INNER PARTS
FUEL SUPPLY PUMP (PUMP) (REGULATION OF EPA AND EU 2ND) (INNER PARTS
FUEL SUPPLY PUMP (FEED PUMP) (LOW-VISCOSITY FUEL SPEC.) (REGULATION OF EPA AND EU 2ND) (INNER PARTS
FUEL SUPPLY PUMP (FEED PUMP) (REGULATION OF EPA AND EU 2ND) (INNER PARTS
COMMON RAIL (LOW-VISCOSITY FUEL SPEC.) (REGULATION OF EPA AND EU 2ND) (INNER PARTS
COMMON RAIL (REGULATION OF EPA AND EU 2ND) (INNER PARTS
FUEL SUPPLY PUMP BRACKET AND CONNECTION COVE
FUEL PIPIN
FUEL SUPPLY PUMP LUBRICATO
FUEL FILTE
FUEL INJECTO
FUEL RETUR
FUEL CONTROL (CHASSIS MOUNT
WATER PUM
WATER PUMP (COLD TERRAN SPEC.
AIR VENT AND WATER TEMPERATURE SENSO
AIR VENT AND WATER TEMPERATURE SENSOR (COLD TERRAIN SPEC.
TENSION PULLE
TENSION PULLEY (SANDY AND DUSTY SPEC.
CORROSION RESISTO
WATER LINE PLUG (WITHOUT CORRO.RSTR.
ALTERNATOR MOUNTING (75A
ALTERNATOR MOUNTING (75A) (SANDY AND DUSTY SPEC.
ALTERNATOR MOUNTING (50A
ALTERNATOR MOUNTING (60A) (SANDY AND DUSTY SPEC.
ALTERNATOR (90A) (INNER PARTS
ALTERNATOR (90A) (SANDY AND DUSTY SPEC.) (INNER PARTS
ALTERNATOR (50A) (INNER PARTS
ALTERNATOR (60A) (SANDY AMD DUSTY SPEC.) (INNER PARTS
STARTING MOTOR MOUNTING (11KW
WIRING (1 3) SWITCH AND HEATE
WIRING (1 3) SWITCH AND HEATER (COLD TERRAIN SPEC.
WIRING (2 3) FUEL INJECTO
WIRING (2 3) FUEL INJECTOR (COLD TERRAIN SPEC.
WIRING (3 3) SENSOR AND SWITC
WIRING (3 3) SENSOR (COLD TERRAIN SPEC.
CYLINDER HEAD GASKET KI
CYLINDER BLOCK GASKET KI
WATER PUMP GASKET KI
NAME PLATE AND CAUTION PLATE (JAPANESE-ENGLISH) (REGULATION OF EPA AND EU
NAME PLATE AND CAUTION PLATE (ENGLISH
AFTER COOLER (CHASSIS MOUNT
OIL FILTE
COOLING FAN (SUCTION
FUEL CONTROL (CHASSIS MOUNT) (1
ENGIN
CYLINDER HEA
HEAD COVE
HEAD COVER BOL
AIR INTAKE MANIFOL
AIR CLEANE
EXHAUST MANIFOL
MUFFLE
CYLINDER BLOC
IDLER GEA
CAMFOLLOWER COVE
OIL LEVEL GAUG
FLYWHEEL HOUSIN
FLYWHEE
ENGINE SUPPOR
CRANKSHAF
VIBRATION DAMPE
PISTO
CRANK PULLE
CAMSHAF
ROCKER AR
CAMFOLLOWE
FRONT POWER TAKE OF
OIL PUM
OIL COOLE
FUEL PIPIN
FUEL FILTE
FUEL INJECTO
FUEL RETUR
WATER PUM
TENSION PULLE
CORROSION RESISTO
OIL FILTE
- KOMATSU Fault Codes
