Komatsu Engine SAA6D140E-3H-8 110003-UP Parts Catalog
Model: Komatsu SAA6D140E-3H-8 Engine
Serial Number: 110003-UP
Number of Pages: 112 Pages
SAA6D140E-3H-8 S N 110003-U
ENGIN
CYLINDER HEA
HEAD COVE
HEAD COVER BOL
AIR INTAKE MANIFOL
EXHAUST MANIFOL
TURBOCHARGER AND OIL PIPIN
TURBOCHARGER AND OIL PIPING (WATER COOLING TURBOCHARGER SPEC.
TURBOCHARGER (KTR110L-585E) (INNER PARTS
TURBOCHARGER (KTR110L-585EW) (WATER COOLING TURBOCHARGER SPEC.) (INNER PARTS
TURBOCHARGER WATER PIPING (WATER COOLING TURBOCHARGER SPEC.
HEAT SHIEL
CYLINDER BLOC
CYLINDER BLOCK COVER AND OIL FILLER (WITH VANDALISM PROTECTION
CYLINDER BLOCK COVER AND OIL FILLER (COLD TERRAIN SPEC.
CYLINDER BLOCK COVER AND OIL FILLER (EXTREME COLD TERRAIN SPEC.
FRONT COVE
FRONT COVER MOUNTING AND BREATHE
IDLER GEA
CAMFOLLOWER COVE
OIL PAN AND SUCTION TUB
OIL LEVEL GAUG
FLYWHEEL HOUSIN
FLYWHEE
ENGINE MOUNTIN
CRANKSHAF
VIBRATION DAMPE
PISTO
CRANK PULLE
CAMSHAF
ROCKER AR
CAMFOLLOWE
OIL PUM
OIL FILTER AND PIPIN
OIL COOLE
FUEL SUPPLY PUMP AND COMMON RAIL MOUNTIN
FUEL PUMP SUPPLY AND RETURN PIPIN
FUEL SUPPLY PUMP (PUMP) (INNER PARTS
FUEL SUPPLY PUMP (FEED PUMP) (INNER PARTS
COMMON RAIL (INNER PARTS
FUEL SUPPLY PUMP BRACKET AND CONNECTION COVE
FUEL PIPIN
FUEL SUPPLY PUMP LUBRICATO
FUEL FILTER (THREAD 1-1 4
FUEL FILTER (THREAD 1-5 8
FUEL FILTER (THREAD 1-5 8) (LARGE CAPACITY PRIMMING) (1 2
FUEL FILTER (THREAD 1-5 8) (LARGE CAPACITY PRIMMING) (2 2
FUEL FILTER CARTRIDGE (SERVICE ONLY
FUEL INJECTO
FUEL RETUR
FUEL CONTROL (CHASSIS MOUNT
FUEL CONTROL (CHASSIS MOUNT) (FUEL CUT GAUGE
WATER PUM
WATER PUMP (WATER COOLING TURBOCHARGER SPEC.
THERMOSTAT AND WATER CONNECTO
WATER PUMP (WATER COOLING TURBOCHARGER SPEC.) (1
AIR VEN
WATER PUMP (WATER COOLING TURBOCHARGER SPEC.) (2
COOLING FA
FAN PULLEY AND V-BEL
FAN DRIV
CORROSION RESISTO
ALTERNATOR MOUNTING (75A
ALTERNATOR (75A) (INNER PARTS
STARTING MOTOR MOUNTING (11KW
STARTING MOTOR (11KW) (INNER PARTS) (1
WIRING (1 3) SWITCH AND HEATE
WIRING (2 3) FUEL INJECTO
WIRING (3 3) SENSO
CYLINDER HEAD GASKET KI
CYLINDER BLOCK GASKET KI
WATER PUMP GASKET KI
NAME PLATE AND CAUTION PLATE (JAPANESE-ENGLISH
NAME PLATE AND CAUTION PLATE (JAPANESE-ENGLISH) (REGULATION OF EPA AND EU
AFTER COOLER (CHASSIS MOUNT
CONTROLLER (CHASSIS MOUNT
ENGIN
CYLINDER HEA
HEAD COVE
HEAD COVER BOL
AIR INTAKE MANIFOL
EXHAUST MANIFOL
HEAT SHIEL
CYLINDER BLOC
FRONT COVE
IDLER GEA
CAMFOLLOWER COVE
OIL LEVEL GAUG
FLYWHEEL HOUSIN
FLYWHEE
ENGINE MOUNTIN
CRANKSHAF
VIBRATION DAMPE
PISTO
CRANK PULLE
CAMSHAF
ROCKER AR
CAMFOLLOWE
OIL PUM
OIL COOLE
FUEL PIPIN
FUEL INJECTO
FUEL RETUR
WATER PUM
AIR VEN
COOLING FA
FAN DRIV
CORROSION RESISTO
WIRING (3 3) SENSO
- KOMATSU Fault Codes
