Komatsu Engine SAA6D140E-3C-8 110003-UP Parts Catalog
Model: Komatsu SAA6D140E-3C-8 (Front Engine)
Serial Number: 110003-UP
Number of Pages: 164 Pages
SAA6D140E-3C-8 S N 110003-UP (Front Engine
ENGIN
CYLINDER HEA
HEAD COVER BOL
AIR INTAKE MANIFOLD (FRONT ENGINE
AIR CONNECTION AND SENSO
EXHAUST MANIFOL
TURBOCHARGER AND OIL PIPIN
TURBOCHARGER (KTR110L-584E¤ 585E) (INNER PARTS
HEAT SHIELD (2 2) FUEL LIN
EXHAUST CONNECTIO
CYLINDER BLOC
CYLINDER BLOCK COVER AND OIL FILLER (1 2
CYLINDER BLOCK COVER AND OIL FILLER (COLD TERRAIN SPEC.
CYLINDER BLOCK COVER AND OIL FILLER (2 2
FRONT COVER (AIR COMPRESSOR SPEC.) (FOR PC1800-6 FRONT ENGINE
FRONT COVER MOUNTING AND BREATHER (FOR PC1800-6 FRONT ENGINE
CAMFOLLOWER COVE
OIL PAN AND SUCTION TUB
OIL PAN AND SUCTION TUBE (COLD TERRAIN SPEC.
OIL LEVEL GAUGE (COLD TERRAIN SPEC.
FLYWHEEL HOUSIN
FLYWHEE
ENGINE SUPPOR
CRANKSHAF
VIBRATION DAMPE
PISTO
CRANK PULLE
CAMSHAF
ROCKER AR
CAMFOLLOWE
OIL PUM
OIL FILTER AND PIPIN
OIL COOLE
FUEL SUPPLY PUMP AND COMMON RAIL MOUNTIN
FUEL SUPPLY PUMP AND COMMON RAIL MOUNTING (LOW-VISCOSITY FUEL SPEC.) (REGULATION OF EPA AND EU 2ND
FUEL PUMP SUPPLY AND RETURN PIPIN
FUEL PUMP SUPPLY AND RETURN PIPING (LOW-VISCOSITY FUEL SPEC.) (REGULATION OF EPA AND EU 2ND
FUEL SUPPLY PUMP (PUMP) (INNER PARTS
FUEL SUPPLY PUMP (PUMP) (LOW-VISCOSITY FUEL SPEC.) (REGULATION OF EPA AND EU 2ND) (INNER PARTS
FUEL SUPPLY PUMP (FEED PUMP) (INNER PARTS
FUEL SUPPLY PUMP (FEED PUMP) (LOW-VISCOSITY FUEL SPEC.) (REGULATION OF EPA AND EU 2ND) (INNER PARTS
COMMON RAIL (INNER PARTS
COMMON RAIL (LOW-VISCOSITY FUEL SPEC.) (REGULATION OF EPA AND EU 2ND) (INNER PARTS
FUEL PIPIN
FUEL SUPPLY PUMP LUBRICATO
FUEL FILTER (THREAD 1-1 4
FUEL FILTER (THREAD 1-5 8
FUEL FILTER CARTRIDGE (SERVICE ONLY
WATER SEPARATOR (BAD FUEL GROUND SPEC.
PRE FILTER MOUNTING (THREAD 1-1 4
FUEL INJECTO
FUEL RETUR
FUEL CONTROL (CHASSIS MOUNT) (TROPICAL AND SANDY SPEC.
WATER PUM
WATER PUMP (COLD TERRAIN SPEC.
AIR VENT AND WATER TEMPERATURE SENSO
AIR VENT AND WATER TEMPERATURE SENSOR (COLD TERRAIN SPEC.
TENSION PULLEY (SANDY AND DUSTY SPEC.
TENSION PULLE
CORROSION RESISTO
WATER LINE PLUG (WITHOUT CORROSION RESISTOR
ALTERNATOR MOUNTING (75A) (SANDY AND DUSTY SPEC.
ALTERNATOR MOUNTING (90A) (WITH HARDENING PULLEY
ALTERNATOR MOUNTING (90A) (WITH NON HARDENING PULLEY
ALTERNATOR (75A) (INNER PARTS
ALTERNATOR (90A) (WITH HARDENING PULLEY) (INNER PARTS
ALTERNATOR (75A) (WITH NON HARDENING PULLEY) (INNER PARTS
ALTERNATOR (75A) (INNER PARTS) (HARDENING PULLEY
STARTING MOTOR MOUNTING (11KW
STARTING MOTOR MOUNTING (11KW) (SEA WATER-RSSISTANT SPEC.
WIRING (1 3) SWITCH AND HEATE
WIRING (2 3) FUEL INJECTO
WIRING (3 3) SENSOR AND SWITC
AIR COMPRESSOR MOUNTING (FRONT ENGINE
PIPING AND VALVE (FRONT ENGINE) (INNER PARTS
CYLINDER HEAD GASKET KI
CYLINDER BLOCK GASKET KI
WATER PUMP GASKET KI
AIR COMPRESSOR GASKET KI
NAME PLATE AND CAUTION PLATE (ENGLISH) (REGULATION OF EPA NORTH AMERICA
NAME PLATE AND CAUTION PLATE (JAPANESE-ENGLISH) (REGULATION OF EPA AND EU
WATER CONNECTION GASKET (TROPICAL SPEC.
COOLING FAN (SUCTION
AFTER COOLER (CHASSIS MOUNT
AMPLIFIER (TROPICAL SPEC.
RAIN CAP (TROPICAL SPEC.
MUFFLER (FOR PC1800-6
FAN BELT (FOR PC1800-6
SPARE PARTS (TROPICAL SPEC.
AFTER COOLER RELATED PARTS (CHASSIS MOUNT
SPARE PARTS (AIR ELEMENT AND CARTRIDGE
AIR CLEANER (FOR PC1800-6
ENGIN
CYLINDER HEA
HEAD COVER BOL
EXHAUST MANIFOL
EXHAUST CONNECTIO
CYLINDER BLOC
CAMFOLLOWER COVE
FLYWHEEL HOUSIN
FLYWHEE
ENGINE SUPPOR
CRANKSHAF
VIBRATION DAMPE
PISTO
CRANK PULLE
CAMSHAF
ROCKER AR
CAMFOLLOWE
OIL PUM
OIL COOLE
FUEL PIPIN
FUEL INJECTO
FUEL RETUR
WATER PUM
TENSION PULLE
CORROSION RESISTO
- KOMATSU Fault Codes
