Komatsu Engine SAA6D125E-3K-8K 310001-UP Parts Catalog
Model: Komatsu SAA6D125E-3K-8K Engine
Serial Number: 310001-UP
Number of Pages: 132 Pages
KOMATSU SAA6D125E-3K-8K S N 310001-UP
HEAD COVER ACCESSORY (OIL FILLER)
HEATER SWITCH (FUEL PRE FILTER SPEC.)
TURBOCHARGER AND OIL PIPING
THERMOSTAT AND THERMOSTAT HOUSING
CYLINDER BLOCK ACCESSORY PARTS (OIL PRESSURE SWITCH AND BLIND COVER)
FRONT COVER ACCESSORY PARTS
CAMFOLLOWER COVER (WITH BREATHER)
OIL PAN AND SUCTION TUBE (SENTER SUMP SPEC.)
OIL LEVEL GAUGE (SENTER SUMP SPEC.)
CAMSHAFT AND CAMFOLLOWER
CAMSHAFT ACCESSORY (TACHOMETER DRIVE)
OIL FILTER AND PIPING
OIL COOLER MOUNTING PARTS
COOLING WATER DRAIN VALVE
FUEL SUPPLY PUMP AND COMMON RAIL
FUEL SUPPLY AND FUEL RETURN PIPING (COMMON RAIL)
FUEL SUPPLY PUMP (1 2) (PUMP) (INNER PARTS)
FUEL SUPPLY PUMP (2 2) (FEED PUMP) (INNER PARTS)
COMMON RAIL (INNER PARTS)
FUEL SUPPLY PUMP BRACKET AND LUBRICATING OIL PIPING
FUEL INJECTION PIPING
FUEL SUPPLY PUMP DRIVE
FUEL FILTER AND MOUNTING (THREAD 1-1 4)
PRE FILTER MOUNTING (LOW QUALITY FUEL SPEC.)
FUEL INJECTOR
FUEL CONTROLLER (CHASSIS MOUNT) (FOR REGULATION OF EPA 2ND AND EU 2ND)
AIR VENT
COOLING FAN (SUCTION TYPE)
FAN PULLEY
CORROSION RESISTOR (EXCEPT JAPAN)
ALTERNATOR AND MOUNTING (50A)
STARTING MOTOR MOUNTING (7
STARTING MOTOR MOUNTING (11KW)
WIRING (1 2) POWER LINE
WIRING (2 2) SENSOR AND SWITCH
WATER PUMP GASKET KIT
NAME PLATE AND CAUTION (ENGLISH) (REGULATION OF EPA AND EU)
FUEL INJECTOR
AIR VENT
FAN PULLEY
