Komatsu Engine SAA6D125E-3G-8W 310314-UP Parts Catalog
Model: Komatsu SAA6D125E-3G-8W Engine
Serial Number: 310314-UP
Number of Pages: 145 Pages
SAA6D125E-3G-8W S N 310314-U
ENGIN
CYLINDER HEA
HEAD COVE
HEAD COVER ACCESSORY (BREATHER
AIR INTAKE MANIFOLD AND CONNECTIO
HEATER SWITC
EXHAUST MANIFOL
TURBOCHARGER MOUNTING AND LUBRICATO
TURBOCHARGER (INNER PARTS
EXHAUST BRAKE AND MOUNTIN
EXHAUST BRAKE (INNER PARTS
THERMOSTAT AND THERMOSTAT HOUSIN
WATER TEMPERATURE SENSO
CYLINDER BLOC
CYLINDER BLOCK ACCESSORY (OIL PRESSURE SWITCH AND BLIND COVER
CYLINDER BLOCK ACCESSORY (OIL PRESSURE SWITCH AND BLIND COVER) (COLD TERRAIN SPEC.
FRONT COVE
FRONT COVER ACCESSORY (POWER TAKE OFF COVER AND POINTER
IDLER GEA
CAM FOLLOWER COVER (WITH OIL FILLER
CAMFOLLOWER COVER (WITH OIL FILLER
OIL PAN AND SUCTION TUBE (WITH OIL LEVEL SENSOR
OIL LEVEL GAUGE (WITH OIL LEVEL SENSOR
FLYWHEEL HOUSIN
FLYWHEE
ENGINE MOUNTIN
CRANKSHAF
DAMPE
PISTON AND CONNECTING RO
CRANK PULLE
ROCKER ARM AND HOUSIN
CAMSHAFT AND CAM FOLLOWE
CAMSHAFT ACCESSORY (TACHOMETER DRIVE
OIL PUM
OIL FILTER AND PIPIN
OIL COOLE
OIL COOLER MOUNTING BOL
WATER DRAIN VALV
FUEL SUPPLY PUMP AND COMMON RAI
FUEL SUPPLY PUMP AND COMMON RAIL (LOW VISCOSITY FUEL SPEC.
FUEL SUPPLY PUMP AND COMMON RAIL (FOR REGULATION OF EPA 2ND AND EU 2ND
FUEL SUPPLY AND RETURN PIPIN
FUEL SUPPLY AND RETURN PIPING (LOW VISCOSITY FUEL SPEC.
FUEL SUPPLY AND RETURN PIPING (FOR REGULATION OF EPA 2ND AND EU 2ND
FUEL SUPPLY PUMP (1 2) (PUMP) (INNER PARTS
FUEL SUPPLY PUMP (1 2) (PUMP) (INNER PARTS) (1
FUEL SUPPLY PUMP (2 2) (FEED PUMP) (INNER PARTS
FUEL SUPPLY PUMP (2 2) (FEED PUMP) (INNER PARTS) (1
COMMON RAIL (INNER PARTS
COMMON RAIL (INNER PARTS) (1
FUEL SUPPLY PUMP BRACKET AND LUBRICATING OIL PIPIN
FUEL INJECTION PIPIN
FUEL SUPPLY PUMP DRIV
FUEL FILTER AND PIPING (THREAD 1-1 4
FUEL FILTER AND PIPING (THREAD 1-5 8
FUEL FILTER CARTRIDGE (THREAD 1-5 8) (SERVICE ONLY
FUEL FILTER CARTRIDGE (THREAD 1-1 4) (SERVICE ONLY
FUEL INJECTOR AND FUEL RETURN PIPIN
FUEL RETURN PIPIN
ENGIN CONTROLLER (CHASSIS MOUNTING) (FOR REGULATION OF EPA 2ND AND EU 2ND
WATER PUM
AIR VENT PIPIN
COOLING FAN (SUCTION TYPE
FAN PULLE
FAN DRIV
CORROSION RESISTO
ALTERNATOR AND MOUNTING (50A
ALTERNATOR (50A) (INNER PARTS
STARTING MOTOR MOUNTING (
STARTING MOTOR (
STARTING MOTOR (7 (1
WIRING (1 3) POWER TRAIN HARNES
WIRING (2 3) ENGINE R.H. (SENSOR AND SWITCH
WIRING (3 3) ENGINE L.H. (SENSOR AND SWITCH
SAFETY GUARD (1 2) (FOR EXHAUST MANIFOLD
SAFETY GUARD (FOR EXHAUST MANIFOLD
SAFETY GUARD (2 2) (FOR EXHAUST BRAKE
CYLINDER HEAD GASKET KI
CYLINDER BLOCK GASKET KI
WATER PUMP GASKET KI
NAME PLATE AND CAUTION (ENGLISH) (REGULATION OF EPA AND EU
NAME PLATE AND CAUTION (ENGLISH) (REGULATION OF EU 2ND
NAME PLATE AND CAUTION (ENGLISH) (STD) (-40ßC SPEC.
AFTERCOOLE
HAKUEN TAISAKUKI
CAUTION PLATE (ENGLISH
CAUTION PLATE (GERMAN
CAUTION PLATE (FRENCH
CAUTION PLATE (SPANISH
CAUTION PLATE (CHINESE
CAUTION PLATE (INDONESIAN
CAUTION PLATE (ITALIAN
CAUTION PLATE (PERSIAN
ENGIN
CYLINDER HEA
HEAD COVE
HEATER SWITC
EXHAUST MANIFOL
CYLINDER BLOC
FRONT COVE
IDLER GEA
FLYWHEEL HOUSIN
FLYWHEE
ENGINE MOUNTIN
CRANKSHAF
DAMPE
CRANK PULLE
OIL PUM
OIL COOLE
WATER DRAIN VALV
FUEL RETURN PIPIN
WATER PUM
AIR VENT PIPIN
FAN PULLE
FAN DRIV
CORROSION RESISTO
STARTING MOTOR (
AFTERCOOLE
HAKUEN TAISAKUKI
- KOMATSU Fault Codes
