Komatsu Engine SAA6D102E-2 30382612-UP Parts Catalog
Model: Komatsu SAA6D102E-2 Engine
Serial Number: 30382612-UP
Number of Pages: 90 Pages
KOMATSU SAA6D102E-2 S N 30382612-UP
ENGINE
CYLINDER HEAD
HEAD COVER
ENGINE LIFTING BRACKET
AIR CONNECTOR
AIR INTAKE HEATER
AIR INTAKE COVER
EXHAUST CONNECTOR CLAMP
EXHAUST MANIFOLD GASKET AND BOLT
EXHAUST MANIFOLD
TURBOCHARGER OIL PIPING
TURBOCHARGER OUT CONNECTION
TURBOCHARGER MOUNTING
TURBOCHARGER MOUNTING (1)
THERMOSTAT HOUSING
THERMOSTAT
OIL PRESSURE SWITCH
CYLINDER BLOCK
DUST SEAL
FRONT COVER
CAMFOLLOWER COVER
BREATHER HOSE
CYLINDER BLOCK COVER (OIL FILLER AND BRACKET)
OIL PAN BOLT
FLUID LEVEL SENSOR (WITHOUT OIL LEVER SENSOR)
REMOTE ENGINE OIL DRAIN
OIL PAN AND SUCTION TUBE
OIL LEVER GAUGE
FLYWHEEL HOUSING
FLYWHEEL
CRANKSHAFT
DAMPER
PISTON
ROCKER ARM
TAPPET
CAMSHAFT
FRONT GEAR TRAIN COVER
FAN PULLEY
TACHOMETER DRIVE COVER
UNDER PLATE
OIL PUMP
OIL COOLER AND OIL FILLER
FUEL INJECTION PUMP
FUEL INJECTION PUMP (1 2) (INNER PARTS)
FUEL INJECTION PUMP (2 2) (INNER PARTS)
FUEL INJECTION PUMP (GOVERNOR) (1 3) (INNER PARTS)
FUEL INJECTION PUMP (GOVERNOR) (2 3) (INNER PARTS)
FUEL INJECTION PUMP(GOVERNOR) (3 3) (INNER PARTS)
BOOST TUBE
FUEL INJECTION PUMP MOUNTING
FUEL FILTER
FUEL FILTER PIPING
FUEL PIPING
CYLINDER BLOCK BLIND COVER AND PIPING
INJECTION NOZZLE
FUEL JOINT
WATER PUMP
WATER CONNECTOR
WATER CONNECTOR PLUG
WATER PUMP (1)
FAN DRIVE PULLEY
COLLING FAN BOLT
FAN PILOT SPACER
BELT TENSIONER (FOR 35¤ 60A ALTERNATOR)
ALTERNATOR MOUNTING (FOR 35A¤ 60A ALTERNATOR)
BELT GUARD
STARTING MOTOR MOUNTING (4
REPAIR PARTS (1 2) (CYLINDER HEAD)
REPAIR PARTS (2 2) (CYLINDER BLOCK)
CYLINDER HEAD GASKET KIT
CYLINDER BLOCK GASKET KIT
GLOW TIMER
SPARE PARTS
SPARE PARTS (FOR 35A¤ 60A ALTERNATOR)
ENGINE
CYLINDER HEAD
HEAD COVER
AIR CONNECTOR
AIR INTAKE HEATER
AIR INTAKE COVER
EXHAUST MANIFOLD
THERMOSTAT HOUSING
THERMOSTAT
OIL PRESSURE SWITCH
CYLINDER BLOCK
DUST SEAL
FRONT COVER
CAMFOLLOWER COVER
BREATHER HOSE
OIL PAN BOLT
OIL LEVER GAUGE
FLYWHEEL HOUSING
FLYWHEEL
CRANKSHAFT
DAMPER
PISTON
ROCKER ARM
TAPPET
CAMSHAFT
FAN PULLEY
UNDER PLATE
OIL PUMP
FUEL INJECTION PUMP
BOOST TUBE
FUEL FILTER
FUEL FILTER PIPING
FUEL PIPING
INJECTION NOZZLE
FUEL JOINT
WATER PUMP
WATER CONNECTOR
WATER PUMP (1)
FAN DRIVE PULLEY
COLLING FAN BOLT
FAN PILOT SPACER
BELT GUARD
GLOW TIMER
SPARE PARTS
- KOMATSU Fault Codes
