Komatsu Engine SAA12V140E-7 800004-UP Parts Catalog
Model: Komatsu SAA12V140E-7 (For WA900-8) Engine
Serial Number: 800004-UP
Number of Pages: 329 Pages
Front Hanger
Rear Hanger
Cylinder Head Cover
Komatsu Closed Crankcase Ventilation (KCCV) Breather
Komatsu Closed Crankcase Ventilation (KCCV) Ventilator
Komatsu Closed Crankcase Ventilation (KCCV) Ventilator Piping
Komatsu Closed Crankcase Ventilation (KCCV) Return Piping
Komatsu Closed Crankcase Ventilation (KCCV) Water Piping (1 2)
Komatsu Closed Crankcase Ventilation (KCCV) Water Piping (2 2)
Air Intake Unit
Air Intake Unit Air Intake Manifold
Air Intake Unit Connector
Air Intake Unit Sensor
Air Intake Unit Air Intake Tube
Air Cleaner Support
Exhaust Manifold
Exhaust Manifold Mounting Parts
Exhaust Manifold Temperature Sensor
Variable Geometry Turbocharger (VGT) Mounting L.H.
Variable Geometry Turbocharger (VGT) Mounting R.H.
Variable Geometry Turbocharger (VGT) Connector L.H.
Variable Geometry Turbocharger (VGT) Connector R.H.
Variable Geometry Turbocharger (VGT) Lubricating Oil Piping (1 2)
Variable Geometry Turbocharger (VGT) Lubricating Oil Piping (2 2)
Variable Geometry Turbocharger (VGT) Variable Geometry Turbocharger (VGT) Piping
Variable Geometry Turbocharger (VGT) Water Piping (1 3)
Variable Geometry Turbocharger (VGT) Water Piping (2 3)
Variable Geometry Turbocharger (VGT) Water Piping (3 3)
Variable Geometry Turbocharger (VGT) Doser Cover
Exhaust Gas Re-circulation (EGR) Valve EGR Cooler Mounting
Exhaust Gas Re-circulation (EGR) Valve EGR Inlet Connector
Exhaust Gas Re-circulation (EGR) Valve EGR Outlet Connector
Exhaust Gas Re-circulation (EGR) Valve EGR Valve
Exhaust Gas Re-circulation (EGR) Valve Inner Parts EGR Oil Pump
Exhaust Gas Re-circulation (EGR) Valve EGR Oil Pump Lubricator (1 3)
Exhaust Gas Re-circulation (EGR) Valve EGR Oil Pump Lubricator (2 3)
Exhaust Gas Re-circulation (EGR) Valve EGR Oil Pump Lubricator (3 3)
Exhaust Gas Re-circulation (EGR) Valve EGR Oil Drain
Exhaust Gas Re-circulation (EGR) Valve EGR Oil Cooler Water Inlet
Exhaust Gas Re-circulation (EGR) Valve EGR Oil Cooler Water Outlet L.H.
Exhaust Gas Re-circulation (EGR) Valve EGR Oil Cooler Water Outlet R.H.
Exhaust Gas Re-circulation (EGR) Valve EGR Air Vent L.H.
Exhaust Gas Re-circulation (EGR) Valve EGR Air Vent R.H.
Heat Shield
Heat Shield Exhaust Manifold
Heat Shield Variable Geometry Turbocharger (VGT)
Komatsu Diesel Particulate Filter (KDPF)
Komatsu Diesel Particulate Filter (KDPF) Komatsu Diesel Particulate Filter (KDPF) A Mounting (1 2)
Komatsu Diesel Particulate Filter (KDPF) Komatsu Diesel Particulate Filter (KDPF) A Mounting (2 2)
Komatsu Diesel Particulate Filter (KDPF) Komatsu Diesel Particulate Filter (KDPF) B Mounting (1 2)
Komatsu Diesel Particulate Filter (KDPF) Komatsu Diesel Particulate Filter (KDPF) B Mounting (2 2)
Komatsu Diesel Particulate Filter (KDPF) Drain Piping
Komatsu Diesel Particulate Filter (KDPF) Exhaust Piping
Cylinder Block Accessory
Cylinder Block Accessory (1)
Front Cover
Front Cover Accessory
Idle Gears
Cam Follower Cover
Engine Oil Filler
Engine Oil Pan For Cold Area Specification A (-30 deg C)
Engine Oil Pan Suction Tube
Engine Oil Pan Oil Level Gauge (For Cold Area Specification A (-30 deg C))
Engine Oil Pan For Cold Area Specification A (-30 deg C)Engine Oil Quick Charge
Engine Oil Pan Suction Tube (1)
Engine Oil Pan Oil Level Gauge (For Cold Area Specification A (-30 deg C) Engine Oil Quick Charge)
Engine Oil Pan For Engine Oil Quick Charge
Engine Oil Pan Suction Tube (2)
Engine Oil Pan Oil Level Gauge (For Engine Oil Quick Charge)
Engine Oil Pan
Engine Oil Pan Suction Tube (3)
Flywheel Housing
Flywheel
Engine Support
Vibration Damper
Piston and Connecting Rod
Crank Pulley
Camshaft
Camshaft Related Parts
Camshaft Related Parts Cam Follower
Camshaft Related Parts Rocker Arm
ENGINE LUBRICATION SYSTEM
Engine Oil Pump
Engine Oil Filter
Engine Oil Filter Oil Filter
Engine Oil Filter Connector
Engine Oil Filter Oil Filter Piping
Engine Oil Cooler
Engine Oil Cooler Cold Area Specification A (-30 deg C)For North America EPA 4th RegulationsKOWA Sampling Points
Engine Oil Cooler (Cold Area Specification A (-30 deg C) For North America EPA 4th Regulations KOWA Sampling Points)(#800004-
Pre Lubrication
ENGINE FUEL SYSTEM
Fuel Supply Pump
Fuel Supply Pump Inner Parts Fuel Supply Pump L.H.
Fuel Supply Pump Inner Parts Feed Pump L.H.
Fuel Supply Pump Mounting Parts (1 3)
Fuel Supply Pump Inner Parts Fuel Supply Pump R.H.
Fuel Supply Pump Inner Parts Feed Pump R.H.
Fuel Supply Pump Mounting Parts (2 3)
Fuel Supply Pump Mounting Parts (3 3) (R.H.)
Fuel Supply Pump Common Rail L.H.
Fuel Supply Pump Common Rail R.H.
Fuel Supply Pump Bracket and Piping
Fuel Supply Pump Piping
Fuel Supply Pump Piping Supply Pump to Common Rail
Fuel Supply Pump Piping Common Rail - Injector
Fuel Supply Pump Piping Bracket and Clamp (1 4)
Fuel Supply Pump Piping Bracket and Clamp (2 4)
Fuel Supply Pump Piping Bracket and Clamp (3 4)
Fuel Supply Pump Piping Bracket and Clamp (4 4)
Fuel Supply Pump Piping Injection Piping Cover
Fuel Supply Pump Lubricator
Fuel Supply Pump Drive
Fuel Filter Fuel Filter and Bracket
Fuel Filter Fuel Block Related Parts L.H.
Fuel Filter Fuel Block Related Parts R.H.
Fuel Filter Priming Pump and Piping L.H.
Fuel Filter Priming Pump and Piping R.H.
Fuel Filter Cooling Piping
Fuel Filter Fuel Supply Pump Piping L.H.
Fuel Filter Fuel Supply Pump Piping R.H.
Fuel Filter Fuel Piping Center
Fuel Filter Fuel Piping (1 2)
Fuel Filter Fuel Piping (2 2)
Fuel Filter Fuel Doser Piping L.H. (1 2)
Fuel Filter Fuel Doser Piping L.H. (2 2)
Fuel Filter Fuel Doser Piping R.H. (1 2)
Fuel Filter Fuel Doser Piping R.H. (2 2)
Fuel Prefilter
Fuel Prefilter Fuel Prefilter
Fuel Prefilter Fuel Prefilter Piping
Fuel Injection Nozzle
Fuel Return
ENGINE COOLING SYSTEM
Thermostat Housing
Thermostat Housing (1)
Water Pump Inner Parts and Mounting
Water Pump Bypass Tube
Water Pump Air Vent and Water Outlet Tube
Water Pump Cold Area Specification A (-30 deg C)
Water Pump Inner Parts and Mounting (Cold Area Specification A (-30 deg C))
Water Pump Bypass Tube (Cold Area Specification A (-30 deg C))
Water Pump Air Vent and Water Outlet Tube (Cold Area Specification A (-30 deg C))
ENGINE ELECTRICAL SYSTEM
Alternator 140 Amp.
Alternator Inner Parts (140 Amp.)
Alternator Mounting Parts (1 2) (140 Amp.)
Alternator Mounting Parts (2 2) (140 Amp.)
Alternator Wiring Harness (140 Amp.)
Alternator Drive
Starting Motor 2-11.0KW
Starting Motor Inner Parts (1 2) (2-11.0KW) (Upper)
Starting Motor Mounting Parts (1 2) (2-11.0KW)
Starting Motor Inner Parts (2 2) (2-11.0KW) (Lower)
Starting Motor Mounting Parts (2 2) (2-11.0KW)
Wiring Harness
Wiring Harness Injector Wiring Harness
Wiring Harness Main Wiring Harness L.H. (1 3)
Wiring Harness Main Wiring Harness L.H. (2 3)
Wiring Harness Main Wiring Harness L.H. (3 3)
Wiring Harness Main Wiring Harness R.H. (1 4)
Wiring Harness Main Wiring Harness R.H. (2 4)
Wiring Harness Main Wiring Harness R.H. (3 4)
Wiring Harness Main Wiring Harness R.H. (4 4)
ENGINE ACCESSORIES AND OTHERS
Engine Controller
Engine Controller Mounting
Engine Controller Cover
Engine Controller (1)
Engine Controller For North America EPA 4th Regulations
Engine Controller Mounting (For North America EPA 4th Regulations)
ENGINE MARKS AND PLATES
Name Plate and Caution Plate For North America EPA 4th Regulations
Name Plate and Caution Plate (For North America EPA 4th Regulations)
Front Hanger
Rear Hanger
Cylinder Head Cover
Air Intake Unit
Air Cleaner Support
Exhaust Manifold
Heat Shield
Front Cover
Idle Gears
Cam Follower Cover
Engine Oil Filler
Engine Oil Pan
Flywheel Housing
Flywheel
Engine Support
Vibration Damper
Crank Pulley
Camshaft
Engine Oil Pump
Engine Oil Filter
Engine Oil Cooler
Pre Lubrication
ENGINE FUEL SYSTEM
Fuel Supply Pump
Fuel Prefilter
Fuel Return
Thermostat Housing
Alternator 140 Amp.
Alternator Drive
Wiring Harness
Engine Controller
- KOMATSU Fault Codes
