118
6,911
Komatsu Engine SAA12V140E-3D-02 500001-UP Parts Catalog
Model: Komatsu SAA12V140E-3D-02 Engine
Serial Number: 500001-UP
Number of Pages: 190 Pages
SAA12V140E-3D-02 S N 500001-UP
ENGINE
CYLINDER HEAD
HEAD COVER
AIR INTAKE MANIFOLD
AIR INTAKE CONNECTION AND SENSOR
PRE-HEATER SWITCH (VHMS SPEC.)
PRE-HEATER SWITCH
EXHAUST MANIFOLD (WITHOUT SENSOR)
EXHAUST MANIFOLD (VHMS SPEC.)
EXHAUST MANIFOLD (WITHOUT VHMS SPEC.)
TURBOCHARGER AND LUBRICATING OIL PIPING
TURBOCHARGER WATER PIPING
TURBOCHARGER (KTR110L-F64PW) (INNER PARTS)
HEAT SHIELD
MUFFLER MOUNTING BRACKET AND DRAIN PIPING
MUFFLER MOUNTING (VHMS SPEC.)
THERMOSTAT AND THERMOSTAT HOUSING
CYLINDER BLOCK
CYLINDER BLOCK ACCESSORY (OIL SENSOR¤ SWITCH AND WATER LINE BLIND COVER) (PRE-LUB SPEC.)
FRONT COVER
FRONT COVER (EXTREMELY BAD FUEL AND POOR FUEL ARRANGEMENT SPEC.) (WATER+DUST)
GEAR CASE AND FRONT COVER ACCESSORY
GEAR CASE AND FRONT COVER ACCESSORY (WITHOUT VHMS SPEC.)
GEAR CASE AND FRONT COVER ACCESSORY (EXTREMELY BAD FUEL AND POOR FUEL ARRANGEMENT SPEC.)(WATER+DUST)
GEAR CASE AND FRONT COVER ACCESSORY (EXTRA POOR FUEL AND HEAD WATER AREA ARRANGEMENT)
BREATHER AND BLOWBY SENSOR WIRING
BREATHER MOUNTING (WITHOUT VHMS SPEC.)
BREATHER AND BLOWBY SENSOR WIRING (EXTREMELY BAD FUEL AND POOR FUEL ARRANGEMENT SPEC.) (WATER+DUST)
BREATHER MOUNTING (EXTRA POOR FUEL AND HEAD WATER AREA ARRANGEMENT)
IDLER GEAR
CAMFOLLOWER COVER
OIL FILLER
OIL FILLER (EXTREMELY BAD FUEL AND POOR FUEL ARRANGEMENT SPEC.) (WATER+DUST)
OIL PAN AND SUCTION TUBE
OIL PAN AND SUCTION TUBE (EXTREMELY BAD FUEL AND POOR FUEL ARRANGEMENT SPEC.) (WATER+DUST)
OIL LEVEL GAUGE
OIL LEVEL GAUGE (EXTREMELY BAD FUEL AND POOR FUEL ARRANGEMENT SPEC.) (WATER+DUST)
FLYWHEEL HOUSING
FLYWHEEL
FRONT SUPPORT AND REAR BRACKET
CRANKSHAFT
DAMPER
PISTON
CRANK PULLEY (PULLEY DIAMETER 182MM)
CAMSHAFT
CAMFOLLOWER
ROCKER ARM
OIL PUMP
OIL FILTER
OIL FILTER AND PIPING
OIL ADAPTER
OIL COOLER
FUEL INJECTION PUMP MOUNTING
COMMON RAIL (L.H.) (INNER PARTS)
COMMON RAIL (R.H.) (INNER PARTS)
FUEL SUPPLY PUMP (L.H.) (PUMP) (INNER PARTS)
FUEL SUPPLY PUMP (R.H.) (PUMP) (INNER PARTS)
FUEL SUPPLY PUMP (L.H.) (FEED PUMP) (INNER PARTS)
FUEL SUPPLY PUMP (R.H.) (FEED PUMP) (INNER PARTS)
FUEL SUPPLY PUMP BRACKET AND RAIL RETURN PIPING
FUEL INJECTION PIPING (1 4) (COMMON RAIL - INJECTOR)
FUEL INJECTION PIPING (1 4) (EXTREMELY BAD FUEL AND POOR FUEL ARRANGEMENT SPEC.) (WATER+DUST)
FUEL INJECTION PIPING (2 4) (INJECTION PIPING SUPPORT)
FUEL INJECTION PIPING (2 4) (EXTREMELY BAD FUEL AND POOR FUEL ARRANGEMENT SPEC.) (WATER+DUST)
FUEL INJECTION PIPING (3 4) (INJECTION PIPING COVER)
FUEL INJECTION PIPING (3 4) (EXTREMELY BAD FUEL AND POOR FUEL ARRANGEMENT SPEC.) (WATER+DUST)
FUEL INJECTION PIPING (4 4) (SUPPLY PUMP - COMMON RAIL)
FUEL INJECTION PIPING (4 4) (EXTREMELY BAD FUEL AND POOR FUEL ARRANGEMENT SPEC.) (WATER+DUST)
FUEL SUPPLY PUMP LUBRICATOR
FUEL INJECTION PUMP DRIVE
FUEL PIPING (L.H. BANK)
FUEL PIPING (R.H. BANK) (EXTREMELY BAD FUEL AND POOR FUEL ARRANGEMENT SPEC.) (WATER+DUST)
FUEL PIPING (L.H. BANK) (EXTREMELY BAD FUEL AND POOR FUEL ARRANGEMENT SPEC.) (WATER+DUST)
FUEL PRIMING PUMP (L.H. BANK)
FUEL CONNECTION AND PRIMING PUMP (L.H. BANK) (EXTREMELY BAD FUEL ARRANGEMENT SPEC.) (WATER+DUST)
FUEL PRIMING PUMP (R.H. BANK)
FUEL CONNECTION AND PRIMING PUMP (R.H. BANK) (EXTREMELY BAD FUEL ARRANGEMENT SPEC.) (WATER+DUST)
FUEL FILTER
FUEL FILTER (L.H. BANK) (EXTREMELY BAD FUEL ARRANGE MENT SPEC.) (WATER+DUST)
FUEL CROSS PIPING (L.H. BANK - R.H. BANK)
FUEL FILTER (R.H. BANK) (EXTREMELY BAD FUEL ARRANGE MENT SPEC.) (WATER+DUST)
FUEL AIR VENT (L.H. BANK) (EXTREMELY BAD FUEL AND POOR FUEL ARRANGEMENT SPEC.) (WATER+DUST)
FUEL AIR VENT (R.H. BANK) (EXTREMELY BAD FUEL AND POOR FUEL ARRANGEMENT SPEC.) (WATER+DUST)
FUEL FILTER (1-5 8) (SERVICE ONLY)
PRE FILTER AND PIPING
PRE FILTER AND PIPING (EU SAFTY REGULATION)
PRE FUEL FILTER (1-1 4) (SERVICE ONLY)
FUEL INJECTION NOZZLE AND SPILL PIPE
FUEL RETURN (EXTREMELY BAD FUEL AND POOR FUEL ARRANGEMENT SPEC.) (WATER+DUST)
FUEL RETURN
FUEL RETURN (TIRE INFLATION KIT)
FUEL CONTROLLER (FOR WA900-3)
WATER PUMP
WATER PUMP (WITHOUT CORROSION RESISTOR)
WATER PUMP (EXTREMELY BAD FUEL AND POOR FUEL ARRANGEMENT SPEC.) (WATER+DUST)
AIR VENT PIPING AND WATER OUTLET
AIR VENT PIPING AND WATER OUTLET (WITHOUT CORROSION RESISTOR)
AIR VENT PIPING AND WATER OUTLET (EXTREMELY BAD FUEL AND POOR FUEL ARRANGEMENT SPEC.) (WATER+DUST)
COOLING FAN (PUSH TYPE)
FAN PULLEY AND DRIVE BELT
FAN DRIVE
TENSION PULLEY (REMOTE GREASING TYPE)
TENSION PULLEY GREASE PIPING (REMOTE GREASING TYPE)
CORROSION RESISTOR
CORROSION RESISTOR (HEAD WATER AREA AND EXTRA POOR FUEL AND EPA 2ND REGULATION ARANGEMENT SPEC)
ALTERNATOR MOUNTING (90A)
ALTERNATOR MOUNTING (90A) (EXTREMELY BAD FUEL AND POOR FUEL ARRANGEMENT SPEC.) (WATER+DUST)
ALTERNATOR MOUNTING (90A) (EU SAFTY REGULATION)
ALTERNATOR (90A) (INNER PARTS)
ALTERNATOR (90A) (INNER PARTS) (EXTREMELY BAD FUEL AND POOR FUEL ARRANGEMENT SPEC.) (WATER+DUST)
ALTERNATOR (90A) (INNER PARTS) (EU SAFTY REGULATION)
ALTERNATOR DRIVE
ALTERNATOR DRIVE (EU SAFTY REGULATION)
STARTING MOTOR MOUNTING (7
STARTING MOTOR (7
ELECTRICAL WIRING (1 3) (INJECTOR HARNESS GROUP)
ELECTRICAL WIRING (2 3) (L.H. BANK)
ELECTRICAL WIRING (3 3) (R.H. BANK)
CYLINDER HEAD GASKET KIT (FOR WA900-3¤WA800-3)
CYLINDER BLOCK GASKET KIT (FOR WA900-3¤WA800-3)
WATER PUMP GASKET KIT (FOR D475A-5¤PC2000-8 AND WA900-3¤WA800-3)
PRE LUBRICATION PIPING
NAME PLATE AND CAUTION (REGULATION OF EPA 2ND)
NAME PLATE AND CAUTION (EU SAFTY REGULATION)
AIR CLEANER AND MUFFLER¤ WATER SEPARATOR¤ SENSOR
