Komatsu Engine SAA12V140E-3C 501918-UP Parts Catalog
Model: Komatsu SAA12V140E-3C (For PC2000-8) Engine
Serial Number: 501918-UP
Number of Pages: 458 Pages
Cylinder Head Cover
Air Intake Unit
Air Intake Unit Intake Manifold
Air Intake Unit Air Intake Connection and Sensor
Turbocharger
Turbocharger Inner Parts (1 2)
Turbocharger Inner Parts (2 2)
Turbocharger Lubricating Oil Piping
Turbocharger Water Piping
Heat Shield
Exhaust Muffler
Exhaust Elbow Mounting
Cylinder Block Accessory Blind Cover and Sensor
Cylinder Block Accessory (Blind Cover and Sensor)
Cylinder Block Accessory Cold Area Arrangement (-30deg C)
Cylinder Block Accessory Temperature Sensor and Pressure Sensor (Cold Area Arrangement (-30deg C))
Front Cover
Front Gear Train Case
Front Gear Train Case Accessory Parts
Front Gear Train Case Breather and Blowby Sensor
Front Gear Train Case Cold Area Arrangement (-30deg C)
Front Gear Train Case Accessory Parts (Cold Area Arrangement (-30deg C))
Front Gear Train Case Breather and Blowby Sensor (Cold Area Arrangement (-30deg C))
Idle Gears
Cam Follower Cover
Engine Oil Filler
Engine Oil Filler Extremely Bad Fuel and Poor Fuel Arrangement Spec. Water+Dust
Engine Oil Filler (Extremely Bad Fuel and Poor Fuel Arrangement Spec. Water+Dust)
Engine Oil Filler (1)
Engine Oil Filler Oil Filter
Engine Oil Filler Adapter
Engine Oil Pan Mounting
Engine Oil Pan Mounting Oil Pan
Engine Oil Pan Mounting Oil Level Sensor
Engine Oil Pan Mounting Suction Tube
Engine Oil Pan Mounting Extremely Bad Fuel and Poor Fuel Arrangement Spec. Water+Dust
Engine Oil Pan Mounting Oil Pan (Extremely Bad Fuel and Poor Fuel Arrangement Spec. Water+Dust)
Engine Oil Pan Mounting Oil Level Sensor (Extremely Bad Fuel and Poor Fuel Arrangement Spec. Water+Dust)
Engine Oil Pan Mounting Suction Tube (Extremely Bad Fuel and Poor Fuel Arrangement Spec. Water+Dust)
Engine Oil Pan Mounting Cold Area Arrangement (-30deg C)Extremely Bad Fuel and Poor Fuel Arrangement Spec. Water+Dust
Engine Oil Pan Mounting Oil Pan (Cold Area Arrangement (-30deg C) Extremely Bad Fuel and Poor Fuel Arrangement Spec. Water+Dus
Engine Oil Pan Mounting Oil Level Sensor (Cold Area Arrangement (-30deg C) Extremely Bad Fuel and Poor Fuel Arrangement Spec.
Engine Oil Pan Mounting Suction Tube (Cold Area Arrangement (-30deg C) Extremely Bad Fuel and Poor Fuel Arrangement Spec. Wate
Engine Oil Pan Mounting Heater (Cold Area Arrangement (-30deg C) Extremely Bad Fuel and Poor Fuel Arrangement Spec. Water+Dust
Engine Oil Pan Mounting Oil Pan (Cold Area Arrangement (-30deg C))
Engine Oil Pan Mounting Oil Level Sensor (Cold Area Arrangement (-30deg C))
Engine Oil Pan Mounting Suction Tube (Cold Area Arrangement (-30deg C))
Engine Oil Pan Mounting Heater (Cold Area Arrangement (-30deg C))
Flywheel Housing
Flywheel Housing (1)
Flywheel Housing Seal
Flywheel
Engine Support
Vibration Damper
Piston and Connecting Rod
Camshaft
Camshaft Related Parts
Camshaft Related Parts Cam Follower
ENGINE LUBRICATION SYSTEM
Engine Oil Pump
Engine Oil Cooler
Engine Oil Cooler Cold Area Arrangement (-30deg C)
Engine Oil Cooler (Cold Area Arrangement (-30deg C))
ENGINE FUEL SYSTEM
Fuel Supply Pump
Fuel Supply Pump Inner Parts Fuel Supply Pump L.H.
Fuel Supply Pump Inner Parts Feed Pump L.H.
Fuel Supply Pump Mounting Parts (1 2)
Fuel Supply Pump Inner Parts Fuel Supply Pump R.H.
Fuel Supply Pump Inner Parts Feed Pump R.H.
Fuel Supply Pump Mounting Parts (2 2)
Fuel Supply Pump Common Rail L.H.
Fuel Supply Pump Common Rail R.H.
Fuel Supply Pump Common Rail Mounting Parts
Fuel Supply Pump Bracket
Fuel Supply Pump Bracket Extremely Bad Fuel and Poor Fuel Arrangement Spec. Water+Dust
Fuel Supply Pump Bracket (Extremely Bad Fuel and Poor Fuel Arrangement Spec. Water+Dust)
Fuel Supply Pump Piping
Fuel Supply Pump Piping Common Rail - Injector
Fuel Supply Pump Piping Bracket and Clamp
Fuel Supply Pump Piping Injection Piping Cover
Fuel Supply Pump Piping Supply Pump to Common Rail
Fuel Supply Pump Lubricator
Fuel Supply Pump Lubricator For Extra Bad Fuel and Poor Fuel Specification Water+Dust Additional Filter
Fuel Supply Pump Lubricator (For Extra Bad Fuel and Poor Fuel Specification Water+Dust Additional Filter)
Fuel Supply Pump Drive
Fuel Piping
Fuel Piping L.H. Bank
Fuel Piping R.H. Bank
Fuel Piping Priming Pump L.H. Bank
Fuel Piping Priming Pump R.H. Bank
Fuel Piping Fuel Filter
Fuel Piping Extra Bad Fuel and Poor Fuel Specification Water+Dust Additional Filter
Fuel Piping R.H. Bank (Extra Bad Fuel and Poor Fuel Specification Water+Dust Additional Filter)
Fuel Piping L.H. Bank (Extra Bad Fuel and Poor Fuel Specification Water+Dust Additional Filter)
Fuel Piping Fuel Filter R.H. Bank (Extra Bad Fuel and Poor Fuel Specification Water+Dust Additional Filter)
Fuel Piping Fuel Filter L.H. Bank (Extra Bad Fuel and Poor Fuel Specification Water+Dust Additional Filter)
Fuel Piping Air Vent R.H. (Extra Bad Fuel and Poor Fuel Specification Water+Dust Additional Filter)
Fuel Piping Air Vent L.H. (Extra Bad Fuel and Poor Fuel Specification Water+Dust Additional Filter)
Fuel Piping Fuel Priming Pump (Extra Bad Fuel and Poor Fuel Specification Water+Dust Additional Filter)
Fuel Piping Cold Area Specification A (-30 deg C)
Fuel Piping L.H. Bank (Cold Area Specification A (-30 deg C))
Fuel Piping R.H. Bank (Cold Area Specification A (-30 deg C))
Fuel Piping Priming Pump L.H. Bank (Cold Area Specification A (-30 deg C))
Fuel Piping Priming Pump R.H. Bank (Cold Area Specification A (-30 deg C))
Fuel Piping Fuel Filter (Cold Area Specification A (-30 deg C))
Fuel Piping Extremely Bad Fuel and Poor Fuel Arrangement Spec. Water+DustCold Area Arrangement (-30deg C)
Fuel Piping R.H. Bank (Extremely Bad Fuel and Poor Fuel Arrangement Spec. Water+Dust Cold Area Arrangement (-30deg C))(#502106
Fuel Piping L.H. Bank (Extremely Bad Fuel and Poor Fuel Arrangement Spec. Water+Dust Cold Area Arrangement (-30deg C))(#502106
Fuel Piping Fuel Filter R.H. Bank (Extremely Bad Fuel and Poor Fuel Arrangement Spec. Water+Dust Cold Area Arrangement (-30de
Fuel Piping Fuel Filter L.H. Bank (Extremely Bad Fuel and Poor Fuel Arrangement Spec. Water+Dust Cold Area Arrangement (-30de
Fuel Piping Air Vent R.H. (Extremely Bad Fuel and Poor Fuel Arrangement Spec. Water+Dust Cold Area Arrangement (-30deg C))(#5
Fuel Piping Air Vent L.H. (Extremely Bad Fuel and Poor Fuel Arrangement Spec. Water+Dust Cold Area Arrangement (-30deg C))(#5
Fuel Piping Priming Pump (Extremely Bad Fuel and Poor Fuel Arrangement Spec. Water+Dust Cold Area Arrangement (-30deg C))(#502
Fuel Piping Priming Pump (Extremely Bad Fuel and Poor Fuel Arrangement Spec. Water+Dust Cold Area Arrangement (-30deg C))(#507
Fuel Piping Extra Bad Fuel and Poor Fuel Specification Water+Dust Additional FilterBiodiesel Fuel B20
Fuel Piping R.H. Bank (Extra Bad Fuel and Poor Fuel Specification Water+Dust Additional Filter Biodiesel Fuel B20)
Fuel Piping L.H. Bank (Extra Bad Fuel and Poor Fuel Specification Water+Dust Additional Filter Biodiesel Fuel B20)
Fuel Piping Fuel Filter R.H. Bank (Extra Bad Fuel and Poor Fuel Specification Water+Dust Additional Filter Biodiesel Fuel B
Fuel Piping Fuel Filter L.H. Bank (Extra Bad Fuel and Poor Fuel Specification Water+Dust Additional Filter Biodiesel Fuel B
Fuel Piping Air Vent R.H. (Extra Bad Fuel and Poor Fuel Specification Water+Dust Additional Filter Biodiesel Fuel B20)(#502
Fuel Piping Air Vent L.H. (Extra Bad Fuel and Poor Fuel Specification Water+Dust Additional Filter Biodiesel Fuel B20)(#502
Fuel Piping Fuel Priming Pump (Extra Bad Fuel and Poor Fuel Specification Water+Dust Additional Filter Biodiesel Fuel B20)(#
Fuel Filter Cartridge
Fuel Filter Cartridge Extremely Bad Fuel and Poor Fuel Arrangement Spec. Water+Dust
Fuel Filter Cartridge (Extremely Bad Fuel and Poor Fuel Arrangement Spec. Water+Dust)
Fuel Injection Nozzle
Fuel Return
Fuel Return For Bad Fuel and Poor Fuel Specification Water+Dust
Fuel Return (For Bad Fuel and Poor Fuel Specification Water+Dust)
ENGINE COOLING SYSTEM
Thermostat and Thermostat Housing
Thermostat and Thermostat Housing Cold Area Arrangement (-30deg C)Poor Fuel Arrangement Spec.
Thermostat and Thermostat Housing (Cold Area Arrangement (-30deg C) Poor Fuel Arrangement Spec.)
Water Pump For Hard Water Area Arrangement
Water Pump (For Hard Water Area Arrangement)
Water Pump Air Vent and Water Outlet Tube (For Hard Water Area Arrangement)
Water Pump For Cold Area Specification A (-30 deg C)Hard Water Area Arrangement
Water Pump (For Cold Area Specification A (-30 deg C) Hard Water Area Arrangement)
Water Pump Air Vent and Water Outlet Tube (For Cold Area Specification A (-30 deg C) Hard Water Area Arrangement)
Water Pump Cover (For Cold Area Specification A (-30 deg C) Hard Water Area Arrangement)
Water Pump Cold Area Specification A (-30 deg C)For Coolant Heater Fuel Combustion Type
Water Pump (Cold Area Specification A (-30 deg C) For Coolant Heater Fuel Combustion Type)
Water Pump Air Vent and Water Outlet Tube (Cold Area Specification A (-30 deg C) For Coolant Heater Fuel Combustion Type)(#50
Water Pump Cover (Cold Area Specification A (-30 deg C) For Coolant Heater Fuel Combustion Type)
Water Pump (1)
Water Pump (2)
Water Pump (1)
Water Pump Air Vent and Water Outlet Tube (1)
Water Pump Cover
Corrosion Resistor
Coolant Filter
Cooling Fan Drive Pulley
ENGINE ELECTRICAL SYSTEM
Alternator For 90Amp.Hard Water Area Arrangement
Alternator Inner Parts (For 90Amp. Hard Water Area Arrangement)
Alternator Inner Parts Alternator (For 90Amp. Hard Water Area Arrangement)
Alternator Mounting Parts (1 2) (For 90Amp. Hard Water Area Arrangement)
Alternator Wiring Harness (For 90Amp. Hard Water Area Arrangement)
Alternator Mounting Parts (2 2) (For 90Amp. Hard Water Area Arrangement)
Alternator 2-90Amp.
Alternator Inner Parts (2-90Amp.)
Alternator Inner Parts Alternator (2-90Amp.)
Alternator Mounting Parts (1 2) (2-90Amp.)
Alternator Wiring Harness (2-90Amp.)
Alternator Mounting Parts (2 2) (2-90Amp.)
Alternator 2-90Amp.For Bad Fuel and Poor Fuel Specification Water+Dust
Alternator Inner Parts (2-90Amp. For Bad Fuel and Poor Fuel Specification Water+Dust)
Alternator Inner Parts Alternator (2-90Amp. For Bad Fuel and Poor Fuel Specification Water+Dust)
Alternator Mounting Parts (1 2) (2-90Amp. For Bad Fuel and Poor Fuel Specification Water+Dust)
Alternator Wiring Harness (2-90Amp. For Bad Fuel and Poor Fuel Specification Water+Dust)
Alternator Mounting Parts (2 2) (2-90Amp. For Bad Fuel and Poor Fuel Specification Water+Dust)
Alternator 2-90Amp.For Cold Area Specification A (-30 deg C)
Alternator Inner Parts (2-90Amp. For Cold Area Specification A (-30 deg C))
Alternator Inner Parts Alternator (2-90Amp. For Cold Area Specification A (-30 deg C))
Alternator Mounting Parts (1 2) (2-90Amp. For Cold Area Specification A (-30 deg C))
Alternator Wiring Harness (2-90Amp. For Cold Area Specification A (-30 deg C))
Alternator Mounting Parts (2 2) (2-90Amp. For Cold Area Specification A (-30 deg C))
Alternator 2-90Amp.For Cold Area Specification A (-30 deg C)Bad Fuel and Poor Fuel Specification Water+Dust
Alternator Inner Parts (2-90Amp. For Cold Area Specification A (-30 deg C) Bad Fuel and Poor Fuel Specification Water+Dust)(
Alternator Inner Parts (2-90Amp. For Cold Area Specification A (-30 deg C) Bad Fuel and Poor Fuel Specification Water+Dust)( (1)
Alternator Inner Parts Alternator (2-90Amp. For Cold Area Specification A (-30 deg C) Bad Fuel and Poor Fuel Specification
Alternator Mounting Parts (1 2) (2-90Amp. For Cold Area Specification A (-30 deg C) Bad Fuel and Poor Fuel Specification Wat
Alternator Wiring Harness (2-90Amp. For Cold Area Specification A (-30 deg C) Bad Fuel and Poor Fuel Specification Water+Dus
Alternator Mounting Parts (2 2) (2-90Amp. For Cold Area Specification A (-30 deg C) Bad Fuel and Poor Fuel Specification Wat
Alternator 2-90Amp.For EU Safety Regulation
Alternator Inner Parts (2-90Amp. For EU Safety Regulation)
Alternator Inner Parts Alternator (2-90Amp. For EU Safety Regulation)
Alternator Mounting Parts (1 2) (2-90Amp. For EU Safety Regulation)
Alternator Wiring Harness (2-90Amp. For EU Safety Regulation)
Alternator Mounting Parts (2 2) (2-90Amp. For EU Safety Regulation)
Alternator 2-90Amp.For Extra Bad Fuel and Poor Fuel Specification Water+Dust Additional FilterEU Safety Regulation
Alternator Inner Parts (2-90Amp. For Extra Bad Fuel and Poor Fuel Specification Water+Dust Additional Filter EU Safety Regu
Alternator Inner Parts (2-90Amp. For Extra Bad Fuel and Poor Fuel Specification Water+Dust Additional Filter EU Safety Regu (1)
Alternator Inner Parts Alternator (2-90Amp. For Extra Bad Fuel and Poor Fuel Specification Water+Dust Additional Filter EU
Alternator Mounting Parts (1 2) (2-90Amp. For Extra Bad Fuel and Poor Fuel Specification Water+Dust Additional Filter EU Sa
Alternator Wiring Harness (2-90Amp. For Extra Bad Fuel and Poor Fuel Specification Water+Dust Additional Filter EU Safety R
Alternator Mounting Parts (2 2) (2-90Amp. For Extra Bad Fuel and Poor Fuel Specification Water+Dust Additional Filter EU Sa
Alternator 2-90Amp.For Cold Area Specification A (-30 deg C)EU Safety Regulation
Alternator Inner Parts (2-90Amp. For Cold Area Specification A (-30 deg C) EU Safety Regulation)
Alternator Inner Parts Alternator (2-90Amp. For Cold Area Specification A (-30 deg C) EU Safety Regulation)
Alternator Mounting Parts (1 2) (2-90Amp. For Cold Area Specification A (-30 deg C) EU Safety Regulation)
Alternator Wiring Harness (2-90Amp. For Cold Area Specification A (-30 deg C) EU Safety Regulation)
Alternator Mounting Parts (2 2) (2-90Amp. For Cold Area Specification A (-30 deg C) EU Safety Regulation)
Alternator Drive For 90Amp.
Alternator Drive (For 90Amp.)
Alternator Drive For 90Amp.Provision For EU Safety Regulation
Alternator Drive (For 90Amp. Provision For EU Safety Regulation)
Starting Motor 11KW
Starting Motor Inner Parts (11KW)
Starting Motor Mounting (11KW)
Wiring Harness
Wiring Harness Injector Wiring Harness
Wiring Harness Main Wiring Harness L.H.
Wiring Harness Main Wiring Harness R.H.
Wiring Harness Heater Unit Wiring Harness
Wiring Harness For Bad Fuel and Poor Fuel Specification Water+Dust
Wiring Harness Injector Wiring Harness (For Bad Fuel and Poor Fuel Specification Water+Dust)
Wiring Harness Main Line L.H. (For Bad Fuel and Poor Fuel Specification Water+Dust)
Wiring Harness Main Line R.H. (For Bad Fuel and Poor Fuel Specification Water+Dust)
Wiring Harness Heater Unit Wiring Harness (For Bad Fuel and Poor Fuel Specification Water+Dust)
Wiring Harness For Cold Area Specification A (-30 deg C)Bad Fuel and Poor Fuel Specification Water+Dust
Wiring Harness Injector Wiring Harness (For Cold Area Specification A (-30 deg C) Bad Fuel and Poor Fuel Specification Water+
Wiring Harness Main Line L.H. (For Cold Area Specification A (-30 deg C) Bad Fuel and Poor Fuel Specification Water+Dust)(#5
Wiring Harness Main Line R.H. (For Cold Area Specification A (-30 deg C) Bad Fuel and Poor Fuel Specification Water+Dust)(#5
Wiring Harness Heater Unit Wiring Harness (For Cold Area Specification A (-30 deg C) Bad Fuel and Poor Fuel Specification Wat
Wiring Harness Injector Wiring Harness (For Cold Area Specification A (-30 deg C))
Wiring Harness Main Line L.H. (For Cold Area Specification A (-30 deg C))
Wiring Harness Main Wiring Harness R.H. (For Cold Area Specification A (-30 deg C))
Wiring Harness Heater Unit Wiring Harness (For Cold Area Specification A (-30 deg C))
ENGINE ACCESSORIES AND OTHERS
Engine Controller
Engine Controller For Bad Fuel and Poor Fuel Specification Water+Dust
Engine Controller (For Bad Fuel and Poor Fuel Specification Water+Dust)
ENGINE MARKS AND PLATES
Name Plate and Caution Plate For Bad Fuel and Poor Fuel Specification Water+Dust
Name Plate and Caution Plate (For Bad Fuel and Poor Fuel Specification Water+Dust)
Name Plate and Caution Plate For North America EPA 2nd Regulations
Name Plate and Caution Plate (For North America EPA 2nd Regulations)
Name Plate and Caution Plate Provision For EU Safety Regulation
Name Plate and Caution Plate (Provision For EU Safety Regulation)
Name Plate and Caution Plate For Extra Bad Fuel and Poor Fuel Specification Water+Dust Additional Filter
Name Plate and Caution Plate (For Extra Bad Fuel and Poor Fuel Specification Water+Dust Additional Filter)
Name Plate and Caution Plate For EU Safety Regulation
Name Plate and Caution Plate (For EU Safety Regulation)
Name Plate and Caution Plate For Extra Bad Fuel and Poor Fuel Specification Water+Dust Additional FilterEU Safety Regulation
Name Plate and Caution Plate (For Extra Bad Fuel and Poor Fuel Specification Water+Dust Additional Filter EU Safety Regulati
Name Plate and Caution Plate For EPA Regulations TPEM
Name Plate and Caution Plate (For EPA Regulations TPEM)
Name Plate and Caution Plate For Extra Bad Fuel and Poor Fuel Specification Water+Dust Additional FilterNorth America EPA 2n
Name Plate and Caution Plate (For Extra Bad Fuel and Poor Fuel Specification Water+Dust Additional Filter North America EPA
Name Plate and Caution Plate For Canada Exhaust Gas TPEM
Name Plate and Caution Plate (For Canada Exhaust Gas TPEM)
Caution Plates Provision For Extra Bad Fuel and Poor Fuel Specification Water+Dust Additional FilterEU Safety Regulation
Caution Plates (Provision For Extra Bad Fuel and Poor Fuel Specification Water+Dust Additional Filter EU Safety Regulation)(
CHASSIS TRANSFER PARTS
Engine Related Parts For Extra Bad Fuel and Poor Fuel Specification Water+Dust Additional Filter
Engine Related Parts Fan (For Extra Bad Fuel and Poor Fuel Specification Water+Dust Additional Filter)
Engine Related Parts Sensor (For Extra Bad Fuel and Poor Fuel Specification Water+Dust Additional Filter)
Engine Related Parts Prefilter (For Extra Bad Fuel and Poor Fuel Specification Water+Dust Additional Filter)
Engine Related Parts Muffler (For Extra Bad Fuel and Poor Fuel Specification Water+Dust Additional Filter)
Engine Related Parts Rain Cap (For Extra Bad Fuel and Poor Fuel Specification Water+Dust Additional Filter)
Engine Related Parts Seal Ring and Clamp (For Extra Bad Fuel and Poor Fuel Specification Water+Dust Additional Filter)(#50210
Engine Related Parts Air Cleaner and Pre-cleaner (For Extra Bad Fuel and Poor Fuel Specification Water+Dust Additional Filter
Engine Related Parts Timer and Connector (For Extra Bad Fuel and Poor Fuel Specification Water+Dust Additional Filter)(#50210
Engine Related Parts Fuel Filter and Water Separator (For Extra Bad Fuel and Poor Fuel Specification Water+Dust Additional Fi
Cylinder Head Cover
Air Intake Unit
Turbocharger
Heat Shield
Exhaust Muffler
Front Cover
Idle Gears
Cam Follower Cover
Engine Oil Filler
Flywheel Housing
Flywheel
Engine Support
Vibration Damper
Camshaft
Engine Oil Pump
Engine Oil Cooler
ENGINE FUEL SYSTEM
Fuel Supply Pump
Fuel Piping
Fuel Return
Water Pump (1)
Water Pump (2)
Water Pump (1)
Water Pump Cover
Corrosion Resistor
Coolant Filter
Alternator 2-90Amp.
Starting Motor 11KW
Wiring Harness
Engine Controller
- KOMATSU Fault Codes
