118
6,911
Komatsu Engine SAA12V140E-3C-02 500001-UP Parts Catalog
Model: Komatsu SAA12V140E-3C-02 Engine
Serial Number: 500001-UP
Number of Pages: 244 Pages
SAA12V140E-3C-02 S N 500001-UP
ENGINE
CYLINDER HEAD
HEAD COVER
AIR INTAKE MANIFOLD
AIR INTAKE CONNECTION AND SENSOR
EXHAUST MANIFOLD
TURBOCHARGER AND LUBRICATING OIL PIPING
TURBOCHARGER WATER PIPING
TURBOCHARGER (KTR110L-F84PW) (INNER PARTS)
HEAT SHIELD
EXHAUST ELBOW MOUNTING
THERMOSTAT AND THERMOSTAT HOUSING
THERMOSTAT AND THERMOSTAT HOUSING (COLD TERRAIN AND POOR FUEL ARRANGEMENT SPEC.)
CYLINDER BLOCK
CYLINDER BLOCK ACCESSORY (BLIND COVER AND SENSOR)
CYLINDER BLOCK ACCESSORY (TEMPERATURE¤ PRESSUER SENSOR AND WATER HEATER) (COLD TERRAIN SPEC.)
FRONT COVER
GEAR CASE AND FRONT COVER ACCESSORY
GEAR CASE AND FRONT COVER ACCESSORY (COLD TERRAIN SPEC.)
BREATHER AND BLOWBY SENSOR WIRING
BREATHER AND BLOWBY SENSOR WIRING (COLD TERRAIN SPEC.)
IDLER GEAR
CAMFOLLOWER COVER
OIL FILLER
OIL FILLER (POOR FUEL ARRANGEMENT SPEC.)
OIL PAN AND SUCTION TUBE
OIL PAN AND SUCTION TUBE (POOR FUEL ARRANGEMENT SPEC.)
OIL PAN AND SUCTION TUBE (COLD TERRAIN AND POOR FUEL ARRANGEMENT SPEC.)
OIL PAN AND SUCTION TUBE (COLD TERRAIN SPEC.)
OIL LEVEL GAUGE AND SENSOR
OIL LEVEL GAUGE AND SENSOR (POOR FUEL ARRANGEMENT SPEC.)
OIL LEVEL GAUGE AND SENSOR (COLD TERRAIN AND POOR FUEL ARRANGEMENT SPEC.)
OIL LEVEL GAUGE AND SENSOR (COLD TERRAIN SPEC.)
OIL PAN HEATER (COLD TERRAIN AND POOR FUEL ARRANGEMENT SPEC.)
OIL PAN HEATER (COLD TERRAIN SPEC.)
FLYWHEEL HOUSING
FLYWHEEL
ENGINE SUPPORT AND BRACKET
CRANKSHAFT
DAMPER
PISTON
CRANK PULLEY
CAMSHAFT
CAMFOLLOWER
ROCKER ARM
OIL PUMP
OIL FILTER
OIL ADAPTER
OIL COOLER
OIL COOLER (COLD TERRAIN SPEC.)
FUEL INJECTION PUMP MOUNTING
COMMON RAIL (L.H.) (INNER PARTS)
COMMON RAIL (R.H.) (INNER PARTS)
FUEL SUPPLY PUMP (L.H.) (PUMP) (INNER PARTS)
FUEL SUPPLY PUMP (R.H.) (PUMP) (INNER PARTS)
FUEL SUPPLY PUMP (L.H.) (FEED PUMP) (INNER PARTS)
FUEL SUPPLY PUMP (R.H.) (FEED PUMP) (INNER PARTS)
FUEL INJECTION PUMP BRACKET
FUEL INJECTION PUMP BRACKET (POOR FUEL ARRANGEMENT SPEC.)
FUEL INJECTION PIPING (1 4) (COMMON RAIL - INJECTOR)
FUEL INJECTION PIPING (2 4) (INJECTION PIPING SUPPORT)
FUEL INJECTION PIPING (3 4) (INJECTION PIPING COVER)
FUEL INJECTION PIPING (4 4) (SUPPLY PUMP - COMMON RAIL)
FUEL SUPPLY PUMP LUBRICATOR
FUEL INJECTION PUMP DRIVE
FUEL PIPING (L.H. BANK)
FUEL PIPING (R.H. BANK) (POOR FUEL ARRANGEMENT SPEC.)
FUEL PIPING (L.H. BANK) (COLD TERRAIN SPEC.)
FUEL PIPING (R.H. BANK) (COLD TERRAIN AND POOR FUEL ARRANGEMENT SPEC.)
FUEL PIPING (L.H. BANK) (POOR FUEL ARRANGEMENT SPEC.)
FUEL PIPING (R.H. BANK) (COLD TERRAIN SPEC.)
FUEL PIPING (L.H. BANK) (COLD TERRAIN AND POOR FUEL ARRANGEMENT SPEC.)
FUEL PRIMING PUMP (L.H. BANK)
FUEL FILTER (R.H. BANK) (POOR FUEL ARRANGEMENT SPEC.)
FUEL PRIMING PUMP (L.H. BANK) (COLD TERRAIN SPEC.)
FUEL FILTER (R.H. BANK) (COLD TERRAIN AND POOR FUEL ARRANGEMENT SPEC.)
FUEL PRIMING PUMP (R.H. BANK)
FUEL FILTER (L.H. BANK) (POOR FUEL ARRANGEMENT SPEC.)
FUEL PRIMING PUMP (R.H. BANK) (COLD TERRAIN SPEC.)
FUEL FILTER (L.H. BANK) (COLD TERRAIN AND POOR FUEL ARRANGEMENT SPEC.)
FUEL FILTER
FUEL AIR VENT (R.H. BANK) (POOR FUEL ARRANGEMENT SPEC.)
FUEL FILTER (COLD TERRAIN SPEC.)
FUEL AIR VENT (R.H. BANK) (COLD TERRAIN AND POOR FUEL ARRANGEMENT SPEC.)
FUEL AIR VENT (L.H. BANK) (POOR FUEL ARRANGEMENT SPEC.)
FUEL AIR VENT (L.H. BANK) (COLD TERRAIN AND POOR FUEL ARRANGEMENT SPEC.)
FUEL PRIMING PUMP (POOR FUEL ARRANGEMENT SPEC.)
FUEL PRIMING PUMP (COLD TERRAIN AND POOR FUEL ARRANGEMENT SPEC.)
FUEL FILTER (1-5 8) (SERVICE ONLY)
FUEL INJECTION NOZZLE AND SPILL PIPE
FUEL RETURN
FUEL RETURN (POOR FUEL ARRANGEMENT SPEC.)
FUEL CONTROLLER
FUEL CONTROLLER (POOR FUEL ARRANGEMENT SPEC.)
WATER PUMP
WATER PUMP (WITHOUT CORROSION RESISTOR)
WATER PUMP (COLD TERRAIN SPEC.)
AIR VENT PIPING AND WATER OUTLET
AIR VENT PIPING AND WATER OUTLET (WITHOUT CORROSION RESISTOR)
AIR VENT PIPING AND WATER OUTLET (COLD TERRAIN SPEC.)
CORROSION RESISTOR
ALTERNATOR MOUNTING (90A) (HEAD WATER AREA ARANGEMENT SPEC.)
ALTERNATOR MOUNTING (90A) (POOR FUEL ARRANGEMENT SPEC.)
ALTERNATOR MOUNTING (90A) (COLD TERRAIN AND POOR FUEL ARRANGEMENT SPEC.)
ALTERNATOR MOUNTING (90A) (COLD TERRAIN AND POOR FUEL ARRANGEMENT SPEC.) (1)
ALTERNATOR MOUNTING (90A) (COLD TERRAIN -30ßC SPEC.)
ALTERNATOR WIRING
ALTERNATOR WIRING (POOR FUEL ARRANGEMENT SPEC.)
ALTERNATOR WIRING (COLD TERRAIN AND POOR FUEL ARRANGEMENT SPEC.)
ALTERNATOR WIRING (COLD TERRAIN AND POOR FUEL ARRANGEMENT SPEC.) (1)
ALTERNATOR WIRING (COLD TERRAIN -30ßC SPEC.)
ALTERNATOR (90A) (INNER PARTS)
ALTERNATOR (90A) (POOR FUEL ARRANGMENT SPEC.) (INNER PARTS)
ALTERNATOR (90A) (COLD TERRAIN AND POOR FUEL ARRANGMENT SPEC.) (INNER PARTS)
ALTERNATOR (90A) (COLD TERRAIN AND POOR FUEL ARRANGMENT SPEC.) (INNER PARTS) (1)
ALTERNATOR (90A) (COLD TERRAIN -30ßC SPEC.) (INNER PARTS)
ALTERNATOR DRIVE
ELECTRICAL WIRING (1 4) (INJECTOR HARNESS GROUP)
ELECTRICAL WIRING (1 4) (INJECTOR HARNESS GROUP) (POOR FUEL ARRANGEMENT SPEC.)
ELECTRICAL WIRING (1 4) (INJECTOR HARNESS) (COLD TERRAIN AND P00R FUEL ARRANGEMENT SPEC.)
ELECTRICAL WIRING (1 4) (INJECTOR HARNESS) (COLD TERRAIN SPEC.)
ELECTRICAL WIRING (2 4) (MAIN HARNESS GROUP) (L.H. BANK)
ELECTRICAL WIRING (2 4) (MAIN HARNESS GROUP) (L.H. BANK) (POOR FUEL ARRANGEMENT SPEC.)
ELECTRICAL WIRING (2 4) (MAIN HARNESS) (L.H. BANK) (COLD TERRAIN AND POOR FUEL ARRANGEMENT SPEC.)
ELECTRICAL WIRING (2 4) (MAIN HARNESS) (L.H. BANK) (COLD TERRAIN SPEC.)
ELECTRICAL WIRING (3 4) (MAIN HARNESS GROUP) (R.H. BANK)
ELECTRICAL WIRING (3 4) (MAIN HARNESS GROUP) (R.H. BANK) (POOR FUEL ARRANGEMENT SPEC.)
ELECTRICAL WIRING (3 4) (MAIN HARNESS) (R.H. BANK) (COLD TERRAIN AND POOR FUEL ARRANGEMENT SPEC.)
ELECTRICAL WIRING (3 4) (MAIN HARNESS) (R.H. BANK) (COLD TERRAIN SPEC.)
ELECTRICAL WIRING (4 4) (HEATER HARNESS GROUP)
ELECTRICAL WIRING (4 4) (HEATER HARNESS GROUP) (POOR FUEL ARRANGEMENT SPEC.)
ELECTRICAL WIRING (4 4) (HEATER HARNESS) (COLD TERRAIN AND P00R FUEL ARRANGEMENT SPEC.)
ELECTRICAL WIRING (4 4) (HEATER HARNESS) (COLD TERRAIN SPEC.)
CYLINDER HEAD GASKET KIT (FOR PC2000-8)
CYLINDER BLOCK GASKET KIT (FOR PC2000-8)
WATER PUMP GASKET KIT (FOR D475A-5¤PC2000-8 AND WA900-3¤WA800-3)
NAME PLATE AND CAUTION (FOR EPA) (ADDITIONAL FILTER)
NAME PLATE AND CAUTION (REGULATION OF EPA 2ND)
COOLING FAN (MOTOR DRIVE)
COOLING FAN (MOTOR DRIVE) (POOR FUEL ARRANGEMENT SPEC.)
SENSOR (FOR INTAKE AIR TEMPERATURE)
SENSOR (FOR INTAKE AIR TEMPERATURE) (POOR FUEL ARRANGEMENT SPEC.)
FUEL PRE-FILTER (1-1 4)
FUEL PRE-FILTER (1-1 4) (POOR FUEL ARRANGEMENT SPEC.)
MUFFLER
MUFFLER (POOR FUEL ARRANGEMENT SPEC.)
RAIN CAP (FOR EXHAUST PIPE)
RAIN CAP (FOR EXHAUST PIPE) (POOR FUEL ARRANGEMENT SPEC.)
SEAL RING AND CLAMP (FOR MUFFLER MOUNTING)
SEAL RING AND CLAMP (FOR MUFFLER MOUNTING) (POOR FUEL ARRANGEMENT SPEC.)
AIR CLEANER AND PRE CLEANER
AIR CLEANER AND PRE CLEANER (POOR FUEL ARRANGEMENT SPEC.)
TIMER AND CONNECTOR
TIMER AND CONNECTOR (POOR FUEL ARRANGEMENT SPEC.)
FUEL FILTER AND WATER SEPARATOR (POOR FUEL ARRANGEMENT SPEC.)
