Komatsu Engine SAA12V140E-3B 500001-UP Parts Catalog
Model: Komatsu SAA12V140E-3B Engine
Serial Number: 500001-UP
Number of Pages: 152 Pages
SAA12V140E-3B S N 500001-UP
ENGINE
CYLINDER HEAD
HEAD COVER
AIR INTAKE MANIFOLD
AIR INTAKE CONNECTION AND SENSOR
PRE-HEATER SWITCH (PRE-LUB SPEC.)
PRE-HEATER SWITCH
EXHAUST MANIFOLD (WITH EXHAUST TEMPERATURE SENSOR)
EXHAUST MANIFOLD (WITH EXHAUST TEMPERATURE SENSOR) (PRE-LUB SPEC.)
TURBOCHARGER AND LUBRICATING OIL PIPING
TURBOCHARGER WATER PIPING
TURBOCHARGER (KTR110L-F85PW) (INNER PARTS)
HEAT SHIELD
EXHAUST BRAKE AND MOUNTING
EXHAUST BRAKE (INNER PARTS)
THERMOSTAT AND THERMOSTAT HOUSING
CYLINDER BLOCK
CYLINDER BLOCK ACCESSORY (BLIND COVER AND SENSOR)
CYLINDER BLOCK ACCESSORY (OIL SENSOR¤ SWITCH AND WATER HEATER)
CYLINDER BLOCK ACCESSORY (BLIND COVER AND SENSOR) (PRE-LUB SPEC.)
CYLINDER BLOCK ACCESSORY (EXTREMELY BAD FUEL AND POOR FUEL ARRANGEMENT SPEC.) (WATER+DUST)
FRONT COVER
GEAR CASE AND FRONT COVER ACCESSORY
BREATHER AND BLOWBY SENSOR WIRING
IDLER GEAR
CAMFOLLOWER COVER
OIL FILLER
OIL PAN AND SUCTION TUBE
OIL PAN AND SUCTION TUBE (COLD TERRAIN SPEC.)+(PM CLINIC SPEC.)
OIL PAN AND SUCTION TUBE (PRE-LUB SPEC.)
OIL LEVEL SENSOR
OIL LEVEL SENSOR (COLD TERRAIN SPEC.)+(PM CLINIC SPEC.)
OIL LEVEL SENSOR (PRE-LUB SPEC.)
OIL LEVEL GAUGE
OIL LEVEL GAUGE (COLD TERRAIN SPEC.)+(PM CLINIC SPEC.)
FLYWHEEL HOUSING (WITH BARING AND REVOLUTION SENSOR)
FLYWHEEL
FRONT SUPPORT AND BRACKET
CRANKSHAFT
DAMPER
PISTON
CRANK PULLEY (PULLEY DIAMETER 182MM)
CAMSHAFT
CAMFOLLOWER
ROCKER ARM
OIL PUMP
OIL FILTER
OIL ADAPTER
OIL COOLER
OIL COOLER (COLD TERRAIN SPEC.)+(PM CLINIC SPEC.)
FUEL INJECTION PUMP MOUNTING
COMMON RAIL (L.H.) (INNER PARTS)
COMMON RAIL (R.H.) (INNER PARTS)
FUEL SUPPLY PUMP (L.H.) (PUMP) (INNER PARTS)
FUEL SUPPLY PUMP (R.H.) (PUMP) (INNER PARTS)
FUEL SUPPLY PUMP (L.H.) (FEED PUMP) (INNER PARTS)
FUEL SUPPLY PUMP (R.H.) (FEED PUMP) (INNER PARTS)
FUEL SUPPLY PUMP BRACKET AND RAIL RETURN PIPING
FUEL INJECTION PIPING (1 4) (COMMON RAIL - INJECTOR)
FUEL INJECTION PIPING (2 4) (INJECTION PIPING SUPPORT)
FUEL INJECTION PIPING (3 4) (INJECTION PIPING COVER)
FUEL INJECTION PIPING (4 4) (SUPPLY PUMP - COMMON RAIL)
FUEL INJECTION PUMP DRIVE
FUEL PIPING (R.H. BANK)
FUEL PIPING (L.H. BANK)
FUEL FILTER (1-5 8) (SERVICE ONLY)
FUEL INJECTION NOZZLE AND SPILL PIPE
FUEL RETURN
FUEL CONTROLLER
WATER PUMP (HARD WATER AREA ARRANGEMENT SPEC.)
WATER PUMP BYPASS PIPING
AIR VENT PIPING AND WATER OUTLET
COOLING FAN (SUCTION TYPE)
FAN PULLEY AND DRIVE BELT
FAN DRIVE
TENSION PULLEY
CORROSION RESISTOR
ALTERNATOR MOUNTING (90A)
ALTERNATOR (90A) (INNER PARTS)
ALTERNATOR DRIVE
STARTING MOTOR MOUNTING (7
STARTING MOTOR (7
ELECTRICAL WIRING (1 3) (INJECTOR HARNESS GROUP)
ELECTRICAL WIRING (1 3) (INJECTOR HARNESS GROUP) -30
ELECTRICAL WIRING (2 3) (PRESSURE AND TEMPERATURE SENSOR GROUP)
ELECTRICAL WIRING (2 3) (PRESSURE AND TEMPERATURE SENSOR GROUP) (C0LD TERRAIN SPEC.)
ELECTRICAL WIRING (3 3) (MAIN HARNESS GROUP)
ELECTRICAL WIRING (3 3) (MAIN HARNESS GROUP) (C0LD TERRAIN SPEC.)
PRE LUBRICATION PIPING
NAME PLATE AND CAUTION (REGULATION OF EPA 2ND)
FUEL FILTER (1-5 8)
FUEL PRE-FILTER (1-1 4)
PRIMING PUMP
SWITCH AND PLATE
WATER SEPARATOR AND SENSOR
ENGINE
CYLINDER HEAD
HEAD COVER
AIR INTAKE MANIFOLD
PRE-HEATER SWITCH
HEAT SHIELD
CYLINDER BLOCK
FRONT COVER
IDLER GEAR
CAMFOLLOWER COVER
OIL FILLER
OIL LEVEL SENSOR
OIL LEVEL GAUGE
FLYWHEEL
CRANKSHAFT
DAMPER
PISTON
CAMSHAFT
CAMFOLLOWER
ROCKER ARM
OIL PUMP
OIL FILTER
OIL ADAPTER
OIL COOLER
FUEL RETURN
FUEL CONTROLLER
FAN DRIVE
TENSION PULLEY
CORROSION RESISTOR
ALTERNATOR DRIVE
STARTING MOTOR (7
FUEL FILTER (1-5 8)
PRIMING PUMP
SWITCH AND PLATE
- KOMATSU Fault Codes
