Komatsu Engine SAA12V140E-3B-02 500001-UP Parts Catalog
Model: Komatsu SAA12V140E-3B-02 Engine
Serial Number: 500001-UP
Number of Pages: 239 Pages
SAA12V140E-3B-02 S N 500001-UP
ENGINE
CYLINDER HEAD
HEAD COVER
AIR INTAKE MANIFOLD
AIR INTAKE CONNECTION AND SENSOR
PRE-HEATER SWITCH (PRE-LUB SPEC.)
PRE-HEATER SWITCH
EXHAUST MANIFOLD (WITH EXHAUST TEMPERATURE SENSOR)
EXHAUST MANIFOLD (WITH EXHAUST TEMPERATURE SENSOR) (PRE-LUB SPEC.)
TURBOCHARGER AND LUBRICATING OIL PIPING
TURBOCHARGER AND LUBRICATING OIL PIPING (HI-ALTITUDE ARRANGE . PASCUA)
TURBOCHARGER WATER PIPING
TURBOCHARGER WATER PIPING (HI-ALTITUDE ARRANGE . PASCUA)
TURBOCHARGER (KTR110L-F85PW) (INNER PARTS)
TURBOCHARGER (KTR110L-F85PW) (HI-ALTITUDE ARRANGE . PASCUA) (INNER PARTS)
HEAT SHIELD
EXHAUST BRAKE AND MOUNTING
EXHAUST BRAKE (WITHOUT EXHAUST BRAKE SPEC.)
EXHAUST BRAKE (INNER PARTS)
THERMOSTAT AND THERMOSTAT HOUSING
THERMOSTAT AND THERMOSTAT HOUSING (EXTREMELY BAD FUEL AND POOR FUEL ARRANGEMENT SPEC.) (WATER+DUST)
CYLINDER BLOCK
CYLINDER BLOCK ACCESSORY (BLIND COVER AND SENSOR)
CYLINDER BLOCK ACCESSORY (BLIND COVER AND SENSOR) (ADDITIONAL FUEL FILTER SPEC.)
CYLINDER BLOCK ACCESSORY (OIL SENSOR¤ SWITCH AND WATER HEATER)
CYLINDER BLOCK ACCESSORY (BLIND COVER AND SENSOR) (PRE-LUB SPEC.)
CYLINDER BLOCK ACCESSORY (EXTREMELY BAD FUEL AND POOR FUEL ARRANGEMENT SPEC.) (WATER+DUST)
CYLINDER BLOCK ACCESSORY (BLIND COVER AND SENSOR) (EX
FRONT COVER
GEAR CASE AND FRONT COVER ACCESSORY
GEAR CASE AND FRONT COVER ACCESSORY (EXTREMELY BAD FUEL AND POOR FUEL ARRANGEMENT SPEC.)(WATER+DUST)
BREATHER AND BLOWBY SENSOR WIRING
BREATHER AND BLOWBY SENSOR WIRING (EXTREMELY BAD FUEL AND POOR FUEL ARRANGEMENT SPEC.) (WATER+DUST)
IDLER GEAR
CAMFOLLOWER COVER
OIL FILLER
OIL PAN AND SUCTION TUBE
OIL PAN AND SUCTION TUBE (COLD TERRAIN SPEC.)+(PM CLINIC SPEC.)
OIL PAN AND SUCTION TUBE (PRE-LUB SPEC.)
OIL PAN AND SUCTION TUBE (FAST OIL FILL ENGINE T M BRK WIGGINGS)
OIL PAN AND SUCTION TUBE (PRE-LUB SPEC.) (FAST OIL FILL ENGINE T M BRK WIGGINGS)
OIL PAN AND SUCTION TUBE (PRE-LUB SPEC.) (COLD AREA ARRANGEMENT (-30 THRU 40)
OIL LEVEL SENSOR
OIL LEVEL SENSOR (COLD TERRAIN SPEC.)+(PM CLINIC SPEC.)
OIL LEVEL SENSOR (PRE-LUB SPEC.)
OIL LEVEL SENSOR (FAST OIL FILL ENGINE T M BRK WIGGINGS)
OIL LEVEL SENSOR (PRE-LUB SPEC.) (FAST OIL FILL ENGINE T M BRK WIGGINGS)
OIL LEVEL SENSOR (PRE-LUB SPEC.) (COLD AREA ARRANGEMENT (-30 THRU -40)
OIL LEVEL GAUGE
OIL LEVEL GAUGE (COLD TERRAIN SPEC.)+(PM CLINIC SPEC.)
OIL LEVEL GAUGE (PRE-LUB SPEC.)
OIL LEVEL GAUGE (FAST OIL FILL ENGINE T M BRK WIGGINGS)
OIL LEVEL GAUGE (PRE-LUB SPEC.) (FAST OIL FILL ENGINE T M BRK WIGGINGS)
OIL LEVEL GAUGE (PRE-LUB SPEC.) (COLD AREA ARRANGEMENT (-30 THRU 40)
FLYWHEEL HOUSING (WITH BARING AND REVOLUTION SENSOR)
FLYWHEEL HOUSING (WITH BARING AND REVOLUTION SENSOR AND PICK-UP SENSOR)
FLYWHEEL
FRONT SUPPORT AND REAR BRACKET (SERVICE ONLY)
FRONT SUPPORT AND BRACKET
CRANKSHAFT
DAMPER
PISTON
CRANK PULLEY (PULLEY DIAMETER 182MM)
CAMSHAFT
CAMFOLLOWER
ROCKER ARM
OIL PUMP
OIL FILTER
OIL ADAPTER
OIL COOLER
OIL COOLER (COLD TERRAIN SPEC.)+(PM CLINIC SPEC.)
FUEL INJECTION PUMP MOUNTING
COMMON RAIL (L.H.) (INNER PARTS)
COMMON RAIL (R.H.) (INNER PARTS)
FUEL SUPPLY PUMP (L.H.) (PUMP) (INNER PARTS)
FUEL SUPPLY PUMP (R.H.) (PUMP) (INNER PARTS)
FUEL SUPPLY PUMP (L.H.) (FEED PUMP) (INNER PARTS)
FUEL SUPPLY PUMP (R.H.) (FEED PUMP) (INNER PARTS)
FUEL SUPPLY PUMP BRACKET AND RAIL RETURN PIPING
SUPPLY PUMP BRACKET AND RAIL PIPING (EXTREMELY BAD FUEL AND POOR FUEL ARRANGEMENT SPEC.)(WATER+DUST)
FUEL INJECTION PIPING (1 4) (COMMON RAIL - INJECTOR)
FUEL INJECTION PIPING (2 4) (INJECTION PIPING SUPPORT)
FUEL INJECTION PIPING (3 4) (INJECTION PIPING COVER)
FUEL INJECTION PIPING (4 4) (SUPPLY PUMP - COMMON RAIL)
FUEL SUPPLY PUMP LUBRICATOR
FUEL SUPPLY PUMP LUBRICATOR (EXTREMELY BAD FUEL AND POOR FUEL ARRANGEMENT SPEC.) (WATER+DUST)
FUEL INJECTION PUMP DRIVE
FUEL PIPING (R.H. BANK)
FUEL PIPING (EXTREMELY BAD FUEL AND POOR FUEL ARRANGEMENT SPEC.) (WATER+DUST)
FUEL PIPING (L.H. BANK)
FUEL CONNECTION (EXTREMELY BAD FUEL AND POOR FUEL ARRANGEMENT SPEC.) (WATER+DUST)
FUEL FILTER (EXTREMELY BAD FUEL AND POOR FUEL ARRANGEMENT SPEC.) (WATER+DUST)
FUEL AIR VENT (R.H. BANK) (EXTREMELY BAD FUEL AND POOR FUEL ARRANGEMENT SPEC.) (WATER+DUST)
FUEL AIR VENT (L.H. BANK) (EXTREMELY BAD FUEL AND POOR FUEL ARRANGEMENT SPEC.) (WATER+DUST)
FUEL PRIMING PUMP (EXTREMELY BAD FUEL AND POOR FUEL ARRANGEMENT SPEC.) (WATER+DUST)
FUEL PRIMING PUMP COVER (EXTREMELY BAD FUEL AND POOR FUEL ARRANGEMENT SPEC.) (WATER+DUST)
FUEL FILTER (1-5 8) (SERVICE ONLY)
FUEL INJECTION NOZZLE AND SPILL PIPE
FUEL RETURN
FUEL CONTROLLER
FUEL CONTROLLER (EXTREMELY BAD FUEL AND POOR FUEL ARRANGEMENT SPEC.) (WATER+DUST)
FUEL CONTROLLER (EXTREMELY POOR FUEL AND EPA 2ND REGULATION SPEC.)
FUEL CONTROLLER (HI-ALTITUDE ARRANGE . PASCUA)
WATER PUMP (HARD WATER AREA ARRANGEMENT SPEC.)
WATER PUMP
WATER PUMP (EXTREMELY BAD FUEL AND POOR FUEL ARRANGEMENT SPEC.) (WATER+DUST)
WATER PUMP BYPASS PIPING
WATER PUMP BYPASS PIPING (1)
WATER PUMP BYPASS PIPING (EXTREMELY BAD FUEL AND POOR FUEL ARRANGEMENT SPEC.) (WATER+DUST)
AIR VENT PIPING AND WATER OUTLET
AIR VENT PIPING AND WATER OUTLET (1)
AIR VENT PIPING AND WATER OUTLET (ADDITIONAL FUEL FILTER SPEC.)
COOLING FAN (SUCTION TYPE)
FAN PULLEY AND DRIVE BELT
FAN DRIVE
TENSION PULLEY
CORROSION RESISTOR
CORROSION RESISTOR (EXTREMELY BAD FUEL AND POOR FUEL ARRANGEMENT SPEC.) (WATER+DUST)
ALTERNATOR MOUNTING (90A)
ALTERNATOR MOUNTING (90A) (EXTREMELY BAD FUEL AND POOR FUEL ARRANGEMENT SPEC.) (WATER+DUST)
ALTERNATOR MOUNTING (90A) (EU SAFTY REGULATION)
ALTERNATOR (90A) (INNER PARTS)
ALTERNATOR (90A) (INNER PARTS) (1)
ALTERNATOR (90A) (INNER PARTS) (EU SAFTY REGULATION)
ALTERNATOR DRIVE
ALTERNATOR DRIVE (EU SAFTY REGULATION)
STARTING MOTOR MOUNTING (7
STARTING MOTOR (7
ELECTRICAL WIRING (1 3) (INJECTOR HARNESS GROUP)
ELECTRICAL WIRING (1 3) (INJECTOR HARNESS GROUP) -30
ELECTRICAL WIRING (2 3) (PRESSURE AND TEMPERATURE SENSOR GROUP)
ELECTRICAL WIRING (2 3) (PRESSURE AND TEMPERATURE SENSOR GROUP) (C0LD TERRAIN SPEC.)
ELECTRICAL WIRING (3 3) (MAIN HARNESS GROUP)
ELECTRICAL WIRING (3 3) (MAIN HARNESS GROUP) (C0LD TERRAIN SPEC.)
CYLINDER HEAD GASKET KIT (FOR HD785-7)
CYLINDER BLOCK GASKET KIT (FOR HD785-7)
WATER PUMP GASKET KIT (FOR HD785-7)
PRE LUBRICATION PIPING
NAME PLATE AND CAUTION (REGULATION OF EPA 2ND)
NAME PLATE AND CAUTION (ENGLISH)
NAME PLATE AND CAUTION (EU SAFTY REGULATION)
PM-CLINIC ACCESSORY
PM-CLINIC ACCESSORY (1)
FUEL FILTER (1-5 8) (POOR FUEL ARRANGEMENT SPEC.)
FUEL PRE-FILTER (1-1 4) (POOR FUEL ARRANGEMENT SPEC.)
JOINT (POOR FUEL ARRANGEMENT SPEC.)
SWITCH AND PLATE (POOR FUEL ARRANGEMENT SPEC.)
WATER SEPARATOR AND SENSOR (POOR FUEL ARRANGEMENT SPEC.)
ENGINE
CYLINDER HEAD
HEAD COVER
AIR INTAKE MANIFOLD
PRE-HEATER SWITCH
HEAT SHIELD
CYLINDER BLOCK
FRONT COVER
IDLER GEAR
CAMFOLLOWER COVER
OIL FILLER
OIL LEVEL SENSOR
OIL LEVEL GAUGE
FLYWHEEL
CRANKSHAFT
DAMPER
PISTON
CAMSHAFT
CAMFOLLOWER
ROCKER ARM
OIL PUMP
OIL FILTER
OIL ADAPTER
OIL COOLER
FUEL RETURN
FUEL CONTROLLER
WATER PUMP
FAN DRIVE
TENSION PULLEY
CORROSION RESISTOR
ALTERNATOR DRIVE
STARTING MOTOR (7
PM-CLINIC ACCESSORY
- KOMATSU Fault Codes
