118
6,911
Komatsu Engine SAA12V140E-3A 502127-UP Parts Catalog
Model: Komatsu SAA12V140E-3A (For D475A-5 D475A-5E0D 475ASD-5 D475ASD-5E0) Engine
Serial Number: 502127-UP
Number of Pages: 511 Pages
Cylinder Head Cover
Air Cleaner Support
Air Cleaner Support For Extra Bad Fuel and Poor Fuel Specification Water+Dust Additional Filter
Air Cleaner Support (For Extra Bad Fuel and Poor Fuel Specification Water+Dust Additional Filter)
Air Intake Manifold
Air Intake Manifold Air Intake Manifold and Air Connection
Air Intake Manifold Air Intake Connection and Sensor
Exhaust Manifold With Sensor
Exhaust Manifold (With Sensor)
Exhaust Manifold Without Sensor
Exhaust Manifold (Without Sensor)
Exhaust Manifold Extremely Bad Fuel and Poor Fuel Arrangement Spec. Water+Dust
Exhaust Manifold With Sensor (Extremely Bad Fuel and Poor Fuel Arrangement Spec. Water+Dust)
Turbocharger
Turbocharger Inner Parts (1 2)
Turbocharger Inner Parts (2 2)
Turbocharger Lubricating Oil Piping
Turbocharger Water Piping
Turbocharger For Hot and High Altitude Specification
Turbocharger Inner Parts (1 2) (For Hot and High Altitude Specification)
Turbocharger Inner Parts (2 2) (For Hot and High Altitude Specification)
Turbocharger Lubricating Oil Piping (For Hot and High Altitude Specification)
Turbocharger Water Piping (For Hot and High Altitude Specification)
Heat Shield
Exhaust Muffler
Engine Mounting Parts
Cylinder Block Accessory
Cylinder Block Accessory Without Engine Oil Pan and Coolant HeaterCold Area Specification A (-30 deg C)
Cylinder Block Accessory (Without Engine Oil Pan and Coolant Heater Cold Area Specification A (-30 deg C))
Front Cover
Idle Gears
Cam Follower Cover
Cam Follower Cover (1)
Engine Oil Filler For Engine Oil Level Sensor
Engine Oil Filler (For Engine Oil Level Sensor)
Engine Oil Filler
Engine Oil Filler For Extra Bad Fuel and Poor Fuel Specification Water+Dust Additional FilterEngine Oil Level Sensor
Engine Oil Filler (For Extra Bad Fuel and Poor Fuel Specification Water+Dust Additional Filter Engine Oil Level Sensor)(#502
Engine Oil Filler (For Extra Bad Fuel and Poor Fuel Specification Water+Dust Additional Filter)
Oil Pan and Suction Tube
Oil Pan and Suction Tube Oil Pan
Oil Pan and Suction Tube Oil Level Gauge
Oil Pan and Suction Tube Oil Level Sensor
Oil Pan and Suction Tube Without Sensor
Oil Pan and Suction Tube Oil Pan (Without Sensor)
Oil Pan and Suction Tube Oil Level Gauge (Without Sensor)
Oil Pan and Suction Tube Suction Tube
Oil Pan and Suction Tube For Engine Pre-lubrication System
Oil Pan and Suction Tube Oil Pan (For Engine Pre-lubrication System)
Oil Pan and Suction Tube Oil Level Gauge (For Engine Pre-lubrication System)
Oil Pan and Suction Tube Oil Level Sensor (For Engine Pre-lubrication System)
Oil Pan and Suction Tube For Cold Area Specification A (-30 deg C)
Oil Pan and Suction Tube Oil Pan (For Cold Area Specification A (-30 deg C))
Oil Pan and Suction Tube Oil Level Gauge (For Cold Area Specification A (-30 deg C))
Oil Pan and Suction Tube Suction Pipe and Oil Pan Heater (For Cold Area Specification A (-30 deg C))
Oil Pan and Suction Tube Oil and Coolant Quick Charge
Oil Pan and Suction Tube Oil Pan Heater
Oil Pan and Suction Tube Oil Level Gauge (Oil and Coolant Quick Charge)
Oil Pan and Suction Tube Cold Area Specification A (-30 deg C)Engine Pre-lubrication System
Oil Pan and Suction Tube Oil Pan (Cold Area Specification A (-30 deg C) Engine Pre-lubrication System)
Oil Pan and Suction Tube Oil Level Gauge (Cold Area Specification A (-30 deg C) Engine Pre-lubrication System)
Oil Pan and Suction Tube Suction Pipe and Oil Pan Heater (Cold Area Specification A (-30 deg C) Engine Pre-lubrication System)
Oil Pan and Suction Tube For Cold Area Specification A (-30 deg C)Engine Pre-lubrication SystemEngine Oil Level Sensor
Oil Pan and Suction Tube Oil Pan (For Cold Area Specification A (-30 deg C) Engine Pre-lubrication System)
Oil Pan and Suction Tube Oil Level Gauge (For Cold Area Specification A (-30 deg C) Engine Pre-lubrication System Engine Oil
Oil Pan and Suction Tube Suction Pipe and Oil Pan Heater (For Cold Area Specification A (-30 deg C) Engine Pre-lubrication Sys
Oil Pan and Suction Tube Oil Level Sensor (For Cold Area Specification A (-30 deg C) Engine Pre-lubrication System)
Oil Pan and Suction Tube For Cold Area Specification A (-30 deg C)Engine Pre-lubrication SystemOil and Coolant Quick Charge
Oil Pan and Suction Tube Oil Pan Heater (For Cold Area Specification A (-30 deg C))
Oil Pan and Suction Tube Quick Charge Related Parts
Oil Pan and Suction Tube Oil Level Gauge (For Cold Area Specification A (-30 deg C) Engine Pre-lubrication System)
Oil Pan and Suction Tube Suction Pipe and Oil Pan Heater (For Cold Area Specification A (-30 deg C) Engine Pre-lubrication Sys (1)
Oil Pan and Suction Tube Oil Level Sensor (For Cold Area Specification A (-30 deg C) Engine Pre-lubrication System) (1)
Oil Pan and Suction Tube For Cold Area Specification A (-30 deg C)Oil and Coolant Quick ChargeEngine Pre-lubrication System
Oil Pan and Suction Tube Oil Level Gauge (For Cold Area Specification A (-30 deg C) Oil and Coolant Quick Charge Engine Pre-l
Oil Pan and Suction Tube Suction Pipe and Oil Pan Heater (For Cold Area Specification A (-30 deg C) Engine Pre-lubrication Sys (2)
Oil Pan and Suction Tube Related Parts (For Cold Area Specification A (-30 deg C) Oil and Coolant Quick Charge Engine Pre-lub
Oil Pan and Suction Tube Engine Pre-lubrication SystemOil and Coolant Quick ChargeFor Engine Pre-lubrication System
Oil Pan and Suction Tube Oil Pan (Engine Pre-lubrication System Oil and Coolant Quick Charge)
Oil Pan and Suction Tube Quick Charge Related Parts (Engine Pre-lubrication System Oil and Coolant Quick Charge)
Oil Pan and Suction Tube Oil Level Gauge (Oil and Coolant Quick Charge For Engine Pre-lubrication System)
Oil Pan and Suction Tube Suction Tube (Engine Pre-lubrication System Oil and Coolant Quick Charge)
Oil Pan and Suction Tube Oil and Coolant Quick Charge (1)
Oil Pan and Suction Tube Plug (Oil and Coolant Quick Charge)
Front Gear Case Cover
Front Gear Case Cover Cover Gear Case
Front Gear Case Cover Breather and Blowby Sensor
Front Gear Case Cover Without Vehicle Health Monitoring System (VHMS)
Front Gear Case Cover Cover Gear Case (Without Vehicle Health Monitoring System (VHMS))
Front Gear Case Cover Breather and Blowby Sensor (Without Vehicle Health Monitoring System (VHMS))
Flywheel Housing
Flywheel
Front Support and Bracket
Vibration Damper
Piston and Connecting Rod
Crank Pulley
Camshaft
Camshaft Related Parts
Camshaft Related Parts Cam Follower
Camshaft Related Parts Road Liner
ENGINE LUBRICATION SYSTEM
Engine Oil Pump
Engine Oil Filter
Engine Oil Filter Oil Filler
Engine Oil Filter Regulator
Engine Oil Filter Oil Filter Piping
Engine Oil Cooler
Engine Oil Cooler Cold Area Specification
Engine Oil Cooler (Cold Area Specification)
Pre Lubrication Piping
Pre Lubrication Piping For Extra Bad Fuel and Poor Fuel Specification Water+Dust Additional Filter
Pre Lubrication Piping (For Extra Bad Fuel and Poor Fuel Specification Water+Dust Additional Filter)
ENGINE FUEL SYSTEM
Fuel Injection Piping
Fuel Injection Piping Common Rail - Injector
Fuel Injection Piping Bracket and Clamp
Fuel Injection Piping Injection Piping Cover
Fuel Supply Pump
Fuel Supply Pump Inner Parts L.H. (1 2)
Fuel Supply Pump Inner Parts Feed Pump (1 2)
Fuel Supply Pump Mounting (1 3)
Fuel Supply Pump Inner Parts R.H.
Fuel Supply Pump Inner Parts Feed Pump (2 2)
Fuel Supply Pump Mounting (2 3)
Fuel Supply Pump Inner Parts L.H. (2 2)
Fuel Supply Pump Inner Parts Common Rail
Fuel Supply Pump Mounting (3 3)
Fuel Supply Pump Bracket
Fuel Supply Pump Bracket For Extra Bad Fuel and Poor Fuel Specification Water+Dust Additional Filter
Fuel Supply Pump Bracket (For Extra Bad Fuel and Poor Fuel Specification Water+Dust Additional Filter)
Fuel Supply Pump Lubricator
Fuel Supply Pump Lubricator For Extra Bad Fuel and Poor Fuel Specification Water+Dust Additional Filter
Fuel Supply Pump Lubricator (For Extra Bad Fuel and Poor Fuel Specification Water+Dust Additional Filter)
Fuel Supply Pump Drive
Fuel Control
Fuel Control High Altitude Area Arrangement For Chile
Fuel Control (High Altitude Area Arrangement For Chile)
Fuel Control For Hot and High Altitude Specification
Fuel Control (For Hot and High Altitude Specification)
Fuel Piping
Fuel Piping L.H. Bank (1 2)
Fuel Piping R.H. Bank (1 2)
Fuel Piping Fuel Filter
Fuel Piping With Engine Oil Level SensorFor Cold Area Specification A (-30 deg C)Engine Oil Pan and Coolant Heater
Fuel Piping L.H. Bank (1 2) (With Engine Oil Level Sensor For Cold Area Specification A (-30 deg C) Engine Oil Pan and Coolan
Fuel Piping L.H. Bank (1 2) (With Engine Oil Level Sensor For Cold Area Specification A (-30 deg C) Engine Oil Pan and Coolan (1)
Fuel Piping L.H. Bank (1 2) (With Engine Oil Level Sensor For Cold Area Specification A (-30 deg C) Engine Oil Pan and Coolan (2)
Fuel Piping L.H. Bank (1 2) (With Engine Oil Level Sensor For Cold Area Specification A (-30 deg C) Engine Oil Pan and Coolan (3)
Fuel Piping R.H. Bank (1 2) (With Engine Oil Level Sensor For Cold Area Specification A (-30 deg C) Engine Oil Pan and Coolan
Fuel Piping R.H. Bank (1 2) (With Engine Oil Level Sensor For Cold Area Specification A (-30 deg C) Engine Oil Pan and Coolan (1)
Fuel Piping R.H. Bank (1 2) (With Engine Oil Level Sensor For Cold Area Specification A (-30 deg C) Engine Oil Pan and Coolan (2)
Fuel Piping L.H. Bank (2 2)
Fuel Piping R.H. Bank (2 2)
Fuel Piping For Extra Bad Fuel and Poor Fuel Specification Water+Dust Additional Filter
Fuel Piping L.H. Bank (1 3) (For Extra Bad Fuel and Poor Fuel Specification Water+Dust Additional Filter)
Fuel Piping R.H. Bank (1 3) (For Extra Bad Fuel and Poor Fuel Specification Water+Dust Additional Filter)
Fuel Piping L.H. Bank (2 3) (For Extra Bad Fuel and Poor Fuel Specification Water+Dust Additional Filter)
Fuel Piping Priming Pump (For Extra Bad Fuel and Poor Fuel Specification Water+Dust Additional Filter)
Fuel Piping R.H. Bank (2 3) (For Extra Bad Fuel and Poor Fuel Specification Water+Dust Additional Filter)
Fuel Piping L.H. Bank (3 3) (For Extra Bad Fuel and Poor Fuel Specification Water+Dust Additional Filter)
Fuel Piping R.H. Bank (3 3) (For Extra Bad Fuel and Poor Fuel Specification Water+Dust Additional Filter)
Fuel Piping Air Vent L.H. (For Extra Bad Fuel and Poor Fuel Specification Water+Dust Additional Filter)
Fuel Piping Air Vent R.H. (For Extra Bad Fuel and Poor Fuel Specification Water+Dust Additional Filter)
Fuel Piping (1)
Fuel Piping For Cold Area Specification A (-30 deg C)Engine Oil Pan and Coolant Heater
Fuel Piping L.H. Bank (1 2) (For Cold Area Specification A (-30 deg C) Engine Oil Pan and Coolant Heater)
Fuel Piping R.H. Bank (1 2) (For Cold Area Specification A (-30 deg C) Engine Oil Pan and Coolant Heater)
Fuel Piping L.H. Bank (2 2) (1)
Fuel Piping R.H. Bank (2 2) (1)
Fuel Piping Fuel Filter (1)
Fuel Filter Cartridge
Fuel Prefilter
Fuel Prefilter For Extra Bad Fuel and Poor Fuel Specification Water+Dust Additional Filter
Fuel Prefilter (For Extra Bad Fuel and Poor Fuel Specification Water+Dust Additional Filter)
Fuel Prefilter Piping (For Extra Bad Fuel and Poor Fuel Specification Water+Dust Additional Filter)
Fuel Prefilter For EU Safety Regulation
Fuel Prefilter (For EU Safety Regulation)
Fuel Prefilter (1)
Fuel Prefilter (1)
Fuel Injection Nozzle
Fuel Return
ENGINE COOLING SYSTEM
Thermostat and Thermostat Housing
Water Pump Air Vent
Corrosion Resistor For Hard Water Area Arrangement
Corrosion Resistor (For Hard Water Area Arrangement)
Corrosion Resistor
Corrosion Resistor Without Corrosion Resister
Corrosion Resistor For Hard Water Area ArrangementExtra Bad Fuel and Poor Fuel Specification Water+Dust Additional Filter
Corrosion Resistor (For Hard Water Area Arrangement Extra Bad Fuel and Poor Fuel Specification Water+Dust Additional Filter)
Coolant Filter For Extra Bad Fuel and Poor Fuel Specification Water+Dust Additional Filter
Coolant Filter (For Extra Bad Fuel and Poor Fuel Specification Water+Dust Additional Filter)
ENGINE ELECTRICAL SYSTEM
Alternator 90Amp.
Alternator Inner Parts (90Amp.)
Alternator Mounting (90Amp.)
Alternator 90Amp.For EU Safety Regulation
Alternator Inner Parts (90Amp. For EU Safety Regulation)
Alternator Inner Parts Alternator (90Amp. For EU Safety Regulation)
Alternator Mounting (90Amp. For EU Safety Regulation)
Alternator Drive
Alternator Drive For EU Safety Regulation
Alternator Drive (For EU Safety Regulation)
Starting Motor 7
Starting Motor Inner Parts Starting Motor (7
Starting Motor Inner Parts Starting Motor (7 (1)
Starting Motor Motor Mounting (7
Wiring Harness For Engine Oil Level SensorVHMS
Wiring Harness (1 6)
Wiring Harness (2 6)
Wiring Harness (3 6)
Wiring Harness (4 6) (For Engine Oil Level Sensor)
Wiring Harness (5 6) (For VHMS Engine Oil Level Sensor)
Wiring Harness (6 6)
Wiring Harness For VHMS
Wiring Harness (1 6) (1)
Wiring Harness (2 6) (1)
Wiring Harness (3 6) (1)
Wiring Harness (5 6) (For VHMS)
Wiring Harness (6 6) (1)
Wiring Harness For VHMS Provision
Wiring Harness (1 6) (2)
Wiring Harness (2 6) (For VHMS Provision)
Wiring Harness (3 6) (2)
Wiring Harness (4 6) (1)
Wiring Harness (5 6) (For VHMS Provision)
Wiring Harness (6 6) (For VHMS Provision)
Wiring Harness For Extra Bad Fuel and Poor Fuel Specification Water+Dust Additional Filter
Wiring Harness (1 7)
Wiring Harness (2 7) (For Extra Bad Fuel and Poor Fuel Specification Water+Dust Additional Filter)
Wiring Harness (3 7) (For Extra Bad Fuel and Poor Fuel Specification Water+Dust Additional Filter)
Wiring Harness (4 7) (For Extra Bad Fuel and Poor Fuel Specification Water+Dust Additional Filter)
Wiring Harness (5 7) (For Extra Bad Fuel and Poor Fuel Specification Water+Dust Additional Filter)
Wiring Harness (6 7) (For Extra Bad Fuel and Poor Fuel Specification Water+Dust Additional Filter)
Wiring Harness (7 7)
Wiring Harness For Cold Area Specification A (-30 deg C)Extra Bad Fuel and Poor Fuel Specification Water+Dust Additional Fil
Wiring Harness (1 7) (For Cold Area Specification A (-30 deg C))
Wiring Harness (3 7) (For Extra Bad Fuel and Poor Fuel Specification Water+Dust Additional Filter Cold Area Specification A
Wiring Harness (4 7) (For Cold Area Specification A (-30 deg C))
Wiring Harness (5 7) (For Cold Area Specification A (-30 deg C) Extra Bad Fuel and Poor Fuel Specification Water+Dust Additi
Wiring Harness (5 7) (For Cold Area Specification A (-30 deg C) Extra Bad Fuel and Poor Fuel Specification Water+Dust Additi (1)
Wiring Harness (6 7) (For Cold Area Specification A (-30 deg C) Extra Bad Fuel and Poor Fuel Specification Water+Dust Additi
Wiring Harness (6 7) (For Cold Area Specification A (-30 deg C) Extra Bad Fuel and Poor Fuel Specification Water+Dust Additi (1)
Wiring Harness For VHMS ORBCOMM and GPS
Wiring Harness (1 7) (For VHMS ORBCOMM and GPS)
Wiring Harness (2 7) (For VHMS ORBCOMM and GPS)
Wiring Harness (3 7) (For VHMS ORBCOMM and GPS)
Wiring Harness (4 7) (For VHMS ORBCOMM and GPS)
Wiring Harness (5 7) (For VHMS ORBCOMM and GPS)
Wiring Harness (6 7) (For VHMS ORBCOMM and GPS)
Wiring Harness (7 7) (1)
Wiring Harness For Cold Area Specification A (-30 deg C)Extra Bad Fuel and Poor Fuel Specification Water+Dust Additional Fil (1)
Wiring Harness (1 7) (For Cold Area Specification A (-30 deg C)) (1)
Wiring Harness (2 7) (For Extra Bad Fuel and Poor Fuel Specification Water+Dust Additional Filter) (1)
Wiring Harness (3 7) (For Extra Bad Fuel and Poor Fuel Specification Water+Dust Additional Filter Cold Area Specification A (1)
Wiring Harness (4 7) (For Cold Area Specification A (-30 deg C)) (1)
Wiring Harness (5 7) (For Cold Area Specification A (-30 deg C) Extra Bad Fuel and Poor Fuel Specification Water+Dust Additi (2)
Wiring Harness (5 7) (For Cold Area Specification A (-30 deg C) Extra Bad Fuel and Poor Fuel Specification Water+Dust Additi (3)
Wiring Harness (6 7) (For Cold Area Specification A (-30 deg C) Extra Bad Fuel and Poor Fuel Specification Water+Dust Additi (2)
Wiring Harness (6 7) (For Cold Area Specification A (-30 deg C) Extra Bad Fuel and Poor Fuel Specification Water+Dust Additi (3)
ENGINE ACCESSORIES AND OTHERS
Pm-Clinic Accessory Parts
ENGINE MARKS AND PLATES
Name Plate and Caution Plate For North America EPA 2nd Regulations
Name Plate and Caution Plate (For North America EPA 2nd Regulations)
Name Plate and Caution Plate For Extra Bad Fuel and Poor Fuel Specification Water+Dust Additional FilterNorth America EPA 2n
Name Plate and Caution Plate (For Extra Bad Fuel and Poor Fuel Specification Water+Dust Additional Filter North America EPA
Name Plate and Caution Plate For EU Safety RegulationNorth America EPA 2nd Regulations
Name Plate and Caution Plate (For EU Safety Regulation North America EPA 2nd Regulations)
Name Plate and Caution Plate (For Extra Bad Fuel and Poor Fuel Specification Water+Dust Additional Filter)
Name Plate and Caution Plate (For EU Safety Regulation)
Name Plate and Caution Plate For EPA Regulations TPEM
Name Plate and Caution Plate (For EPA Regulations TPEM)
Name Plate and Caution Plate For North America EPA 2nd Regulations (1)
Name Plate and Caution Plate For Extra Bad Fuel and Poor Fuel Specification Water+Dust Additional FilterNorth America EPA 2n (1)
Name Plate and Caution Plate (For Extra Bad Fuel and Poor Fuel Specification Water+Dust Additional Filter North America EPA (1)
Name Plate and Caution Plate For Canada Exhaust Gas TPEM
Name Plate and Caution Plate (For Canada Exhaust Gas TPEM)
Name Plate and Caution Plate For Extra Bad Fuel and Poor Fuel Specification Water+Dust Additional FilterChina 3rd EX-Gas Reg
Name Plate and Caution Plate (For Extra Bad Fuel and Poor Fuel Specification Water+Dust Additional Filter China 3rd EX-Gas R
Name Plate and Caution Plate For EU Safety Regulation (1)
