118
6,911
Komatsu Engine SAA12V140E-3A 500001-UP Parts Catalog
Model: Komatsu SAA12V140E-3A Engine
Serial Number: 500001-UP
Number of Pages: 229 Pages
SAA12V140E-3A S N 500001-UP
ENGINE
CYLINDER HEAD
HEAD COVER
AIR INTAKE MANIFOLD
AIR INTAKE CONNECTION AND SENSOR
AIR CLEANER SUPPORT
AIR CLEANER SUPPORT (EXTREMELY BAD FUEL AND POOR FUEL ARRANGEMENT SPEC.) (WATER+DUST)
EXHAUST MANIFOLD (WITHOUT SENSOR)
EXHAUST MANIFOLD (WITH SENSOR)
EXHAUST MANIFOLD (WITH SENSOR) (EXTREMELY BAD FUEL AND POOR FUEL ARRANGEMENT SPEC.)(WATER+DUST)
TURBOCHARGER AND LUBRICATING OIL PIPING
TURBOCHARGER WATER PIPING
TURBOCHARGER (KTR110L-F84PW) (INNER PARTS)
HEAT SHIELD
MUFFLER
THERMOSTAT AND THERMOSTAT HOUSING
CYLINDER BLOCK
CYLINDER BLOCK ACCESSORY (OIL SENSOR¤ SWITCH AND WATER LINE BLIND COVER)
CYLINDER BLOCK ACCESSORY (OIL SENSOR¤ SWITCH AND WATER LINE HEATER)
FRONT COVER
GEAR CASE AND FRONT COVER ACCESSORY
GEAR CASE AND FRONT COVER ACCESSORY (WITHOUT VHMS SPEC.)
BREATHER AND BLOWBY SENSOR WIRING
BREATHER AND BLOWBY SENSOR WIRING (WITHOUT VHMS SPEC.)
IDLER GEAR
CAMFOLLOWER COVER
OIL FILLER
OIL FILLER (EXTREMELY BAD FUEL AND POOR FUEL ARRANGEMENT SPEC.) (WATER+DUST)
OIL PAN AND SUCTION TUBE
OIL PAN AND UNDER PLATE (C0LD TERRAIN SPEC.)
OIL PAN AND SUCTION TUBE (OIL QUICK CHARGE TYPE)
OIL PAN AND UNDER PLATE (C0LD TERRAIN SPEC.) (PRE-LUB SPEC.) (ENGINE OIL SENSOR)
OIL LEVEL GAUGE
OIL LEVEL GAUGE (C0LD TERRAIN SPEC.)
OIL OUICK CHARGE
OIL LEVEL GAUGE (C0LD TERRAIN SPEC.) (PRE-LUB SPEC.) (ENGINE OIL SENSOR)
OIL LEVEL SENSOR
SUCTION PIPE AND OIL PAN HEATER (C0LD TERRAIN SPEC.)
OIL LEVEL GAUGE (OIL QUICK CHARGE TYPE)
SUCTION PIPE AND OIL PAN HEATER (C0LD TERRAIN SPEC.) (PRE-LUB SPEC.) (ENGINE OIL SENSOR)
OIL LEVEL SENSOR (OIL QUICK CHARGE TYPE)
OIL LEVEL SENSOR (C0LD TERRAIN SPEC.) (PRE-LUB SPEC.) (ENGINE OIL SENSOR)
FLYWHEEL HOUSING (WITH BARING AND REVOLUTION SENSOR)
FLYWHEEL
FRONT SUPPORT AND BRACKET
CRANKSHAFT
DAMPER
PISTON
CRANK PULLEY (ADAPTER TYPE)
CAMSHAFT
CAMFOLLOWER
ROCKER ARM
OIL PUMP
OIL FILTER
OIL ADAPTER
OIL COOLER
OIL COOLER (COLD TERRAIN SPEC.)
FUEL INJECTION PUMP MOUNTING
COMMON RAIL (L.H.) (INNER PARTS)
COMMON RAIL (R.H.) (INNER PARTS)
FUEL SUPPLY PUMP (L.H.) (PUMP) (INNER PARTS)
FUEL SUPPLY PUMP (R.H.) (PUMP) (INNER PARTS)
FUEL SUPPLY PUMP (L.H.) (FEED PUMP) (INNER PARTS)
FUEL SUPPLY PUMP (R.H.) (FEED PUMP) (INNER PARTS)
FUEL INJECTION PUMP BRACKET
FUEL INJECTION PUMP BRACKET (POOR FUEL ARRANGEMENT SPEC.)
FUEL INJECTION PUMP PIPING
FUEL INJECTION PUMP PIPING (BRACKET AND CLAMP)
FUEL INJECTION PUMP PIPING (CAP)
FUEL INJECTION PUMP PIPING (COMMON RAIL PIPING)
FUEL SUPPLY PUMP LUBRICATOR
FUEL SUPPLY PUMP LUBRICATOR (EXTREMELY BAD FUEL AND POOR FUEL ARRANGEMENT SPEC.) (WATER+DUST)
FUEL INJECTION PUMP DRIVE
FUEL FILTER AND PIPING (L.H. BANK)
FUEL PIPING (L.H. BANK) (EXTREMELY BAD FUEL AND POOR FUEL ARRANGEMENT SPEC.) (WATER+DUST)
FUEL FILTER AND PIPING (R.H. BANK)
FUEL PIPING (R.H. BANK) (EXTREMELY BAD FUEL AND POOR FUEL ARRANGEMENT SPEC.) (WATER+DUST)
FUEL PRIMING PUMP (L.H. BANK)
FUEL BLOCK (L.H. BANK) (EXTREMELY BAD FUEL AND POOR FUEL ARRANGEMENT SPEC.) (WATER+DUST)
FUEL PRIMING PUMP (R.H. BANK)
FUEL PRIMING PUMP (EXTREMELY BAD FUEL AND POOR FUEL ARRANGEMENT SPEC.) (WATER+DUST)
FUEL FILTER
FUEL BLOCK (R.H. BANK) (EXTREMELY BAD FUEL AND POOR FUEL ARRANGEMENT SPEC.) (WATER+DUST)
FUEL FILTER (L.H. BANK) (EXTREMELY BAD FUEL AND POOR FUEL ARRANGEMENT SPEC.) (WATER+DUST)
FUEL FILTER (R.H. BANK) (EXTREMELY BAD FUEL AND POOR FUEL ARRANGEGEMENT SPEC.) (WATER+DUST)
FUEL AIR VENT (L.H. BANK) (EXTREMELY BAD FUEL AND POOR FUEL ARRANGEMENT SPEC.) (WATER+DUST)
FUEL AIR VENT (R.H. BANK) (EXTREMELY BAD FUEL AND POOR FUEL ARRANGEMENT SPEC.) (WATER+DUST)
FUEL FILTER (1-5 8) (SERVICE ONLY)
FUEL FILTER (1-5 8) (SERVICE ONLY) (EXTREMELY BAD FUEL AND POOR FUEL ARRANGEMENT SPEC.) (WATER+DUST)
PRE FILTER AND PIPING
PRE FILTER (1 2) (EXTREMELY BAD FUEL AND POOR FUEL ARRANGEMENT SPEC.) (WATER+DUST)
PRE FILTER AND PIPING (FOR EU)
PRE FILTER (2 2) (EXTREMELY BAD FUEL AND POOR FUEL ARRANGEMENT SPEC.) (WATER+DUST)
PRE FUEL FILTER (1-1 4) (SERVICE ONLY)
FUEL INJECTION NOZZLE AND SPILL PIPE
FUEL RETURN
FUEL CONTROLLER
WATER PUMP
AIR VENT
CORROSION RESISTOR (HEAD WATER AREA ARANGEMENT SPEC)
CORROSION RESISTOR (HEAD WATER AREA AND EXTRA POOR FUEL AND EPA 2ND REGULATION ARANGEMENT SPEC)
ALTERNATOR MOUNTING (90A)
ALTERNATOR MOUNTING (90A) (FOR EU)
ALTERNATOR (90A) (INNER PARTS)
ALTERNATOR (90A) (INNER PARTS) (FOR EU)
ALTERNATOR DRIVE
ALTERNATOR DRIVE (EU SAFTY REGULATION)
STARTING MOTOR MOUNTING (7
STARTING MOTOR (7
ELECTRICAL WIRING (1 6)
ELECTRICAL WIRING (1 6) (EPA 2ND REGULATION ARRANGEMENT)
ELECTRICAL WIRING (1 7) (EXTRA POOR FUEL AND EPA 2ND REGULATION SPEC.)
ELECTRICAL WIRING (2 6)
ELECTRICAL WIRING (2 6) (EPA 2ND REGULATION ARRANGEMENT)
ELECTRICAL WIRING (2 7) (EXTRA POOR FUEL AND EPA 2ND REGULATION SPEC.)
ELECTRICAL WIRING (3 6)
ELECTRICAL WIRING (3 6) (EPA 2ND REGULATION ARRANGEMENT)
ELECTRICAL WIRING (3 7) (EXTRA POOR FUEL AND EPA 2ND REGULATION SPEC.)
ELECTRICAL WIRING (4 6)
ELECTRICAL WIRING (4 6) (EPA 2ND REGULATION ARRANGEMENT)
ELECTRICAL WIRING (4 7) (EXTRA POOR FUEL AND EPA 2ND REGULATION SPEC.)
ELECTRICAL WIRING (5 6)
ELECTRICAL WIRING (5 6) (EPA 2ND REGULATION ARRANGEMENT)
ELECTRICAL WIRING (5 7) (EXTRA POOR FUEL AND EPA 2ND REGULATION SPEC.)
ELECTRICAL WIRING (6 6)
ELECTRICAL WIRING (6 6) (EPA 2ND REGULATION ARRANGEMENT)
ELECTRICAL WIRING (6 7) (EXTRA POOR FUEL AND EPA 2ND REGULATION SPEC.)
ELECTRICAL WIRING (7 7) (EXTRA POOR FUEL AND EPA 2ND REGULATION SPEC.)
CYLINDER HEAD GASKET KIT (FOR D475A-5)
CYLINDER BLOCK GASKET KIT (FOR D475A-5)
WATER PUMP GASKET KIT (FOR D475A-5¤PC2000-8 AND WA900-3¤WA800-3)
PRE LUBRICATION PIPING
PRE LUBRICATION PIPING (EXTREMELY BAD FUEL AND POOR FUEL ARRANGEMENT SPEC.) (WATER+DUST)
NAME PLATE AND CAUTION (FOR EPA) (ADDITIONAL FILTER)
NAME PLATE AND CAUTION (EU SAFTY REGULATION)
PM-CLINIC ACCESSORY
AIR CLEANER AND COOLING FAN¤ MUFFLER¤ RAIN CAP¤ SWITCH
AIR CLEANER AND MUFFLER¤ RAIN CAP¤ COOLING FAN¤ WATER SEPARATOR¤ SWITCH
