Komatsu Engine SA6D95L-1C 35398-UP Parts Catalog
Model: Komatsu SA6D95L-1C Engine
Serial Number: 35398-UP
Number of Pages: 126 Pages
SA6D95L-1C S N 35398-UP
CYLINDER HEAD
CYLINDER HEAD (1)
ROCKER ARM
CYLINDER HEAD COVER
AIR INTAKE MANIFOLD AND CONNECTION (FOR BOOST COMPENSATE TYPE FUEL INJECTION PUMP)
AFTER COOLER AND PIPING
AIR CLEANER AND CONNECTION (SINGLE ELEMENT TYPE)
AIR CLEANER AND CONNECTION (DOUBLE ELEMENT TYPE)
AIR CLEANER AND CONNECTION (COLD TERRAIN SPEC.)
EXHAUST MANIFOLD AND TURBOCHARGER
TURBOCHARGER
MUFFLER AND MOUNTING
CYLINDER BLOCK
CYLINDER BLOCK (1)
FRONT COVER AND GEAR
OIL PAN
OIL PAN (COLD TERRAIN SPEC.)
FLYWHEEL AND FLYWHEEL HOUSING
FLYWHEEL AND FLYWHEEL HOUSING (COLD TERRAIN SPEC.)
CRANKSHAFT
PISTON AND CONNECTING ROD
CAMSHAFT AND TAPPET
LUBRICATING OIL SYSTEM
LUBRICATING OIL PUMP AND SUCTION PIPE
LUBRICATING OIL FILTER
LUBRICATING OIL FILTER (COLD TERRAIN SPEC.)
LUBRICATING OIL COOLER
LUBRICATING OIL COOLER (LARGE CAPACITY TYPE)
FUEL SYSTEM
FUEL INJECTION PUMP AND PIPING
FUEL INJECTION PUMP AND PIPING (COLD TERRAIN SPEC.)
FUEL INJECTION PUMP AND PIPING (BOOST COMPENSATE TYPE)
FUEL FILTER AND PIPING
WATER SEPARATOR
ADDITIONAL FUEL FILTER
FUEL NOZZLE AND SPILL PIPE
FUEL NOZZLE AND SPILL PIPE (FOR BOOST COMPENSATE TYPE FUEL INJECTION PUMP)
FUEL INJECTION PUMP (PUMP) (1 2)
FUEL INJECTION PUMP (PUMP) (2 2)
FUEL INJECTION PUMP (PUMP) (1 2) (FOR EMERGENCY STOP SYSTEM)
FUEL INJECTION PUMP (PUMP) (2 2) (FOR EMERGENCY STOP SYSTEM)
FUEL INJECTION PUMP (PUMP) (1 2) (COLD TERRAIN SPEC.)
FUEL INJECTION PUMP (PUMP) (2 2) (COLD TERRAIN SPEC.)
FUEL INJECTION PUMP (GOVERNOR) (1 2)
FUEL INJECTION PUMP (GOVERNOR) (2 2)
FUEL INJECTION PUMP (GOVERNOR) (1 2) (FOR EMERGENCY STOP SYSTEM)
FUEL INJECTION PUMP (GOVERNOR) (2 2) (FOR EMERGENCY STOP SYSTEM)
FUEL INJECTION PUMP (GOVERNOR) (1 2) (COLD TERRAIN SPEC.)
FUEL INJECTION PUMP (GOVERNOR) (2 2) (COLD TERRAIN SPEC.)
FUEL INJECTION PUMP (FEED PUMP)
FUEL INJECTION PUMP (FEED PUMP) (FOR EMEGRENCY STOP SYSTEM)
FUEL INJECTION PUMP (FEED PUMP) (COLD TERRAIN SPEC.)
COOLING SYSTEM
WATER PUMP AND MOUNTING
COOLING FAN
COOLING FAN (SANDY AND DUSTY SPEC.)
CORROSION RESISTOR AND PIPING
ELECTRICAL SYSTEM
ALTERNATOR AND MOUNTING (25A)
ALTERNATOR AND MOUNTING (25A) (WITH COVER)
ALTERNATOR AND MOUNTING (25A¤ 35A) (BRUSH-LESS TYPE)
STARTING MOTOR AND MOUNTING (5
ALTERNATOR (25A)
ALTERNATOR (35A) (BRUSH-LESS TYPE)
ALTERNATOR (25A) (BRUSH-LESS TYPE)
STARTING MOTOR (5
ELECTRICAL WIRING
ELECTRICAL WIRING (BRUSH-LESS ALTERNATOR TYPE)
ELECTRICAL WIRING (COLD TERRAIN SPEC.)
ENGINE KIT
GASKET KIT
