Komatsu Engine SA6D170E-3A-7 310043-UP Parts Catalog
Model: Komatsu SA6D170E-3A-7 Engine
Serial Number: 310043-UP
Number of Pages: 300 Pages
SA6D170E-3A-7 S N 310043-UP
ENGINE
ENGINE (1)
CYLINDER HEAD
ROCKER ARM HOUSING COVER
HEAD COVER RELATED PARTS
AIR INTAKE MANIFOLD
AFTER COOLER WATER PIPING
AIR HEATER
HEATER SWITCH
HEATER SWITCH (WITHOUT CORROSION RESISTOR)
HEATER SWITCH (EXTREMELY BAD FUEL GROUND SPEC.)
AIR CLEANER MOUNTING
AIR CLEANER MOUNTING (WATER-COOLED TURBOCHARGER SPEC.)
EXHAUST MANIFOLD
EXHAUST MANIFOLD (WITH VEHICLE HEALTH MONITOR SYSTEM)
TURBOCHARGER MOUNTING
TURBOCHARGER MOUNTING (WATER-COOLED TURBOCHARGER SPEC.)
TURBOCHARGER MOUNTING (EXTREMELY BAD FUEL GROUND SPEC.)
TURBOCHARGER (KTR110L-987A) (INNER PARTS)
TURBOCHARGER (KTR110L-897A) (WATER-COOLED TURBOCHARGER SPEC.) (INNER PARTS)
TURBOCHARGER (KTR110L-897A) (EXTREMELY BAD FUEL GROUND SPEC.) (INNER PARTS)
TURBOCHARGER OIL PIPING
TURBOCHARGER OIL PIPING (WATER-COOLED TURBOCHARGER SPEC.)
TURBOCHARGER OIL PIPING (EXTREMELY BAD FUEL GROUND SPEC.)
TURBOCHARGER WATER PIPING (WATER-COOLED TURBOCHARGER SPEC.)
TURBOCHARGER WATER PIPING (EXTREMELY BAD FUEL GROUND SPEC.)
HEAT SHIELD
HEAT SHIELD (WATER-COOLED TURBOCHARGER SPEC.)
MUFFLER BRACKET
MUFFLER BRACKET (WATER-COOLED TURBOCHARGER SPEC.)
MUFFLER EJECTOR PIPING (EXTREMELY BAD FUEL GROUND SPEC.)
THERMOSTAT HOUSING
THERMOSTAT HOUSING (WATER-COOLED TURBOCHARGER SPEC.)
THERMOSTAT HOUSING BLIND PLUG
CYLINDER BLOCK
CYLINDER BLOCK BLIND COVER
CYLINDER BLOCK MOUNTING (COOLANT HEATER SPEC.)
CYLINDER BLOCK BLIND COVER AND SENSOR (WITH VEHICLE HEALTH MONITOR SYSTEM)
CYLINDER BLOCK BLIND COVER AND SENSOR (WITH VEHICLE HEALTH MONITOR SYSTEM) (COOLANT HEATER SPEC.)
FRONT COVER
FRONT COVER MOUNTING
FRONT COVER MOUNTING (COOLANT HEATER SPEC.)
IDLER GEAR
CAM FOLLOWER COVER AND BREATHER
CAM FOLLOWER COVER AND BREATHER (WITH VEHICLE HEALTH MONITOR SYSTEM)
OIL FILLER
OIL PAN AND SUCTION TUBE
OIL PAN AND SUCTION TUBE (COOLANT HEATER SPEC.)
OIL LEVEL GAUGE
OIL LEVEL GAUGE (COOLANT HEATER SPEC.)
FLYWHEEL HOUSING
FLYWHEEL
ENGINE MOUNTING
CRANKSHAFT
DAMPER
PISTON
CRANK PULLEY
ROCKER ARM AND HOUSING
CAMSHAFT
OIL PUMP
OIL FILTER
OIL COOLER
OIL COOLER MOUNTING
OIL COOLER MOUNTING (WITH VEHICLE HEALTH MONITOR SYSTEM)
FUEL INJECTION PUMP MOUNTING
FUEL INJECTION PUMP (INNER PARTS)
FUEL INJECTION PUMP REPAIR KIT
INJECTION BRACKET AND PIPING
FUEL INJECTION PUMP DRIVE
FUEL FILTER MOUNTING
FUEL FILTER MOUNTING (BAD FUEL GROUND SPEC.)
FUEL FILTER MOUNTING (WITH V.H.M.S.) (WATER-COOLED TURBOCHARGER SPEC.) (BAD FUEL GROUND SPEC.)
FUEL FILTER MOUNTING (WATER-COOLED TURBOCHARGER SPEC.) (HIGH ALTITUDE SPEC.)
FUEL FILTER MOUNTING (EXTREMELY BAD FUEL GROUND SPEC.)
FUEL INJECTOR
FUEL RETURN
CONTROL VALVE AND MOUNTING
CONTROL VALVE AND MOUNTING (NORTH AMERICA EPA 2ND REGULATION AND EU 2ND EXHAUST GAS REGULATION)
FUEL CONTROL VALVE (HIGH ALTITUDE SPEC.)
CONTROL VALVE AND MOUNTING (2% UP)
CONTROL VALVE AND MOUNTING (4200M HIGH ALTITUDE SPEC.)
CONTROL VALVE AND MOUNTING (FOR CHILE HIGH ALTITUDE.)
FUEL CONTROL VALVE (INNER PARTS)
FUEL CONTROL VALVE (NORTH AMERICA EPA 2ND REGULATION¤ EU 2ND EXHAUST GAS REGULATION) (INNER PARTS)
FUEL CONTROL VALVE (HIGH ALTITUDE SPEC.) (INNER PARTS)
FUEL CONTROL VALVE (2% UP) (INNER PARTS)
FUEL CONTROL VALVE (4200M HIGH ALTITUDE SPEC.) (INNER PARTS)
FUEL CONTROL VALVE (FOR CHILE HIGH ALTITUDE.) (INNER PARTS)
DISC PROGRAM AND CONTROLLER (SERVICE ONLY)
DISC PROGRAM AND CONTROLLER (SERVICE ONLY) (HIGH ALTITUDE SPEC.)
DISC PROGRAM AND CONTROLLER (SERVICE ONLY) (HIGH ALTITUDE SPEC.) (FOR USA)
DISC PROGRAM AND CONTROLLER (SERVICE ONLY) (POWER UP SPEC.)
DISC PROGRAM AND CONTROLLER (SERVICE ONLY) (FOR CHILE HIGH ALTITUDE)
FUEL CONTROL HARNESS MOUNTING (1 3)
FUEL CONTROL HARNESS MOUNTING (2 3)
FUEL CONTROL HARNESS MOUNTING (3 3)
WATER PUMP
WATER PUMP (WATER-COOLED TURBOCHARGER SPEC.)
AIR VENT
AIR VENT (WATER-COOLED TURBOCHARGER SPEC.)
TENSION PULLEY
TENSION PULLEY (EXTREMELY BAD FUEL GROUND SPEC.)
TENSION GREASE TUBE
TENSION GREASE TUBE (EXTREMELY BAD FUEL GROUND SPEC.)
CORROSION RESISTOR
WATER LINE PLUG (WITHOUT CORROSION RESISTOR)
CORROSION RESISTOR (EXTREMELY BAD FUEL GROUND SPEC.)
ALTERNATOR MOUNTING (60A)
ALTERNATOR MOUNTING (75A)
ALTERNATOR MOUNTING (75A) (COOLANT HEATER SPEC.)
ALTERNATOR MOUNTING (60A) (COOLANT HEATER SPEC.)
ALTERNATOR MOUNTING (90A)
ALTERNATOR MOUNTING (90A) (COOLANT HEATER SPEC.)
ALTERNATOR MOUNTING (75A) (FREON COMPRESSOR LESS)
ALTERNATOR MOUNTING (90A) (FREON COMPRESSOR LESS)
ALTERNATOR MOUNTING (60A) (WITH AIR COMPRESSOR)
ALTERNATOR (75A) (COOLANT HEATER SPEC.) (INNER PARTS)
ALTERNATOR (60A) (COOLANT HEATER SPEC.) (INNER PARTS)
ALTERNATOR (90A) (INNER PARTS)
ALTERNATOR (90A) (COOLANT HEATER SPEC.) (INNER PARTS)
ALTERNATOR (75A) (FREON COMPRESSOR LESS) (INNER PARTS)
ALTERNATOR (90A) (FREON COMPRESSOR LESS) (INNER PARTS)
ALTERNATOR (60A) (WITH AIR COMPRESSOR) (INNER PARTS)
COMPRESSOR (AIR CONDITIONER) (INNER PARTS) (FOR 75A ALTERNATOR)
COMPRESSOR (AIR CONDITIONER) (INNER PARTS) (FOR 75A ALTERNATOR COOLANT HEATER)
COMPRESSOR (AIR CONDITIONER) (INNER PARTS) (FOR 90A ALTERNATOR)
COMPRESSOR (AIR CONDITIONER) (INNER PARTS) (FOR 90A ALTERNATOR COOLANT HEATER)
ALTERNATOR DRIVE
STARTING MOTOR MOUNTING (7
STARTING MOTOR (7
STARTING MOTOR (7 (1)
WATER HEATER AND PIPING
WATER HEATER WIRING (1 2)
WATER HEATER WIRING (2 2)
WIRING (1 3) (FOR 60A¤ 75A¤ 90A ALTERNATOR)
WIRING (1 3) (FOR 75A¤ 90A ALTERNATOR) (WITH AIR COMPRESSOR)
WIRING (1 3) (FOR 75A¤ 90A ALTERNATOR) (WITH AIR COMPRESSOR) (ROT PREVENTION WIRE HARNESS)
WIRING (1 3) (FOR 75A¤ 90A ALTERNATOR) (WITH AIR COMPRESSOR AND VEHICLE HEALTH MONITOR SYSTEM)
WIRING (1 3) (FOR 75A¤ 90A ALTERNATOR) (WITH A C AND V.H.M.S.) (ROT PREVENTION WIRE HARNESS)
WIRING (1 3) (FOR 60A¤ 75A¤ 90A ALTERNATOR) (WITH VEHICLE HEALTH MONITOR SYSTEM)
WIRING (2 3) (FOR 60A¤ 75A¤ 90A ALTERNATOR)
WIRING (2 3) (FOR 75A¤ 90A ALTERNATOR) (WITH AIR COMPRESSOR)
WIRING (2 3) (FOR 75A¤ 90A ALTERNATOR) (WITH AIR COMPRESSOR) (ROT PREVENTION WIRE HARNESS)
WIRING (2 3) (FOR 75A¤ 90A ALTERNATOR) (WITH AIR COMPRESSOR AND VEHICLE HEALTH MONITOR SYSTEM)
WIRING (2 3) (FOR 75A¤ 90A ALTERNATOR) (WITH A C AND V.H.M.S.) (ROT PREVENTION WIRE HARNESS)
WIRING (2 3) (FOR 60A¤ 75A¤ 90A ALTERNATOR) (WITH VEHICLE HEALTH MONITOR SYSTEM)
WIRING (3 3) (FOR 60A¤ 75A¤ 90A ALTERNATOR)
WIRING (3 3) (FOR 75A¤ 90A ALTERNATOR) (WITH AIR COMPRESSOR)
WIRING (3 3) (FOR 75A¤ 90A ALTERNATOR) (WITH AIR COMPRESSOR) (ROT PREVENTION WIRE HARNESS)
WIRING (3 3) (FOR 75A¤ 90A ALTERNATOR) (WITH AIR COMPRESSOR AND VEHICLE HEALTH MONITOR SYSTEM)
WIRING (3 3) (FOR 75A¤ 90A ALTERNATOR) (WITH A C AND V.H.M.S.) (ROT PREVENTION WIRE HARNESS)
WIRING (3 3) (FOR 60A¤ 75A¤ 90A ALTERNATOR) (WITH VEHICLE HEALTH MONITOR SYSTEM)
SAFETY GUARD (FOR 60A ALTERNATOR)
SAFETY GUARD (FOR 75A ALTERNATOR)
SAFETY GUARD (FOR 90A ALTERNATOR)
CYLINDER HEAD GASKET KIT
CYLINDER BLOCK GASKET KIT
WATER PUMP GASKET KIT
NAME PLATE AND CAUTION PLATE (EU EXHAUST GAS REGULATION 2ND)
NAME PLATE AND CAUTION PLATE (NORTH AMERICA EPA 2ND REGULATION AND EU EXHAUST GAS REGULATION 2ND)
NAME PLATE AND CAUTION PLATE (NORTH AMERICA EPA 2ND REGULATION) (FOR KA)
ENGINE NAME PLATE (ENGLISH)
NAME PLATE AND CAUTION (EPA DEREGULATION ACTION SPEC.)
EXHAUST TEMPERATURE SENSOR (PM-CLINIC SPEC.)
CAUTION (ENGLISH)
FAN BELT (REVERSIBLE SPEC.)
AIR CLEANER CAP (AIR INTAKE ON HOOD SPEC.)
COOLING FAN
MUFFLER
MUFFLER DRAIN PIPING
MUFFLER EJECTOR
HEAT SHIELD (FOR MUFFLER)
EXHAUST PIPE
SPARE PARTS (NORTH AMERICA EPA 2ND REGULATION)
MUFFLER PIPING
HOOD (AIR INTAKE)
CAUTION PLATE (ENGLISH)
FAN BELT (NOISE REGULATION SPEC. FOR EU AND WATER SEPARATOR)
SPARE PARTS (EU EXHAUST GAS REGULATION 2ND)
SPARE PARTS
WATER HEATER PIPING RELATED PARTS
HEAT SHIELD (FOR MUFFLER) (WATER-COOLED TURBOCHARGER SPEC.)
ENGINE
ENGINE (1)
CYLINDER HEAD
AIR INTAKE MANIFOLD
AIR HEATER
HEATER SWITCH
EXHAUST MANIFOLD
HEAT SHIELD
MUFFLER BRACKET
THERMOSTAT HOUSING
CYLINDER BLOCK
FRONT COVER
IDLER GEAR
OIL FILLER
OIL LEVEL GAUGE
FLYWHEEL HOUSING
FLYWHEEL
ENGINE MOUNTING
CRANKSHAFT
DAMPER
PISTON
CRANK PULLEY
CAMSHAFT
OIL PUMP
OIL FILTER
OIL COOLER
OIL COOLER MOUNTING
FUEL INJECTOR
FUEL RETURN
WATER PUMP
AIR VENT
TENSION PULLEY
TENSION GREASE TUBE
CORROSION RESISTOR
ALTERNATOR DRIVE
STARTING MOTOR (7
CAUTION (ENGLISH)
COOLING FAN
MUFFLER
MUFFLER EJECTOR
EXHAUST PIPE
MUFFLER PIPING
HOOD (AIR INTAKE)
SPARE PARTS
- KOMATSU Fault Codes
