Komatsu Engine SA6D170-B-1J-R 13551-UP Parts Catalog
Model: Komatsu SA6D170-B-1J-R (-50cent. SPEC.) Engine
Serial Number: 13551-UP
Number of Pages: 109 Pages
SA6D170-B-1J-R S N 13551-UP (-50cent. SPEC.
CYLINDER HEA
CYLINDER HEAD (1
ROCKER ARM AND HOUSIN
ROCKER ARM HOUSING COVE
AIR INTAKE MANIFOLD AND AFTER COOLE
AIR CLEANER AND MOUNTING (COLD WEATHER (B) SPEC.
EXHAUST MANIFOLD AND TURBOCHARGE
TURBOCHARGE
MUFFLER AND MOUNTIN
MUFFLER PIPIN
WATER MANIFOLD AND THERMOSTAT (COLD WEATHER (B) SPEC.
WATER PIPIN
WATER HEATER AND PIPING (COLD WEATHER (B) SPEC.
CYLINDER BLOC
CYLINDER BLOCK (1
CYLINDER BLOCK COVE
FRONT COVER AND FRONT SUPPOR
GEAR CASE COVER AND GEA
OIL PAN (WITH OIL PAN COVER TYPE) (COLD WEATHER (B) SPEC.
OIL PAN (OIL PAN COVER LESS TYPE) (COLD WEATHER (B) SPEC.
FLYWHEEL AND FLYWHEEL HOUSIN
CRANKSHAF
PISTON AND CONNECTING RO
CAMSHAFT AND CAM FOLLOWE
LUBRICATING OIL SYSTE
LUBRICATING OIL PUMP AND SUCTION PIP
LUBRICATING OIL FILTE
TURBOCHARGER LUBRICATING OIL PIPIN
MECHANICAL PUMP AND PIPIN
LUBRICATING OIL COOLER (COLD WEATHER (B) SPEC.
FUEL SYSTE
FUEL INJECTION PUMP AND MOUNTING (COLD WEATHER (B) SPEC.
FUEL INJECTION PUMP PIPING (1 2
FUEL INJECTION PUMP PIPING (2 2) (COLD WEATHER (B) SPEC.
FUEL FILTER AND PIPIN
FUEL NOZZLE AND SPILL PIP
AUTO PRIMING SYSTE
FUEL INJECTION PUMP (PUMP) (1 2) (COLD WEATHER (B) SPEC.
FUEL INJECTION PUMP (PUMP) (2 2) (COLD WEATHER (B) SPEC.
FUEL INJECTION PUMP (GOVERNOR) (1 2) (COLD WEATHER (B) SPEC.
FUEL INJECTION PUMP (GOVERNOR) (2 2) (COLD WEATHER (B) SPEC.
FUEL INJECTION PUMP (COUPLING) (COLD WEATHER (B) SPEC.
FUEL INJECTION PUMP (FEED PUMP) (COLD WEATHER (B) SPEC.
COOLING SYSTE
WATER PUMP AND MOUNTIN
COOLING FAN AND V-BELT (COLD WEATHER (B) SPEC.
TENSION PULLE
CORROSION RESISTOR AND PIPIN
ELECTRICAL SYSTE
ALTERNATOR AND MOUNTING (50A¤ 75A
ALTERNATOR DRIV
STARTING MOTOR AND MOUNTIN
ALTERNATOR (50A) (COLD WEATHER (B) SPEC.
STARTING MOTOR (11KW) (COLD WEATHER (B) SPEC.
WATER HEATER WIRING (COLD WEATHER (B) SPEC.
ACCESSOR
FRONT ACCESSORY DRIV
TOOL AND KI
GASKET KIT (COLD WEATHER (B) SPEC.
