Komatsu Engine SA6D170-A-1T 14203-UP Parts Catalog
Model: Komatsu SA6D170-A-1T Engine
Serial Number: 14203-UP
Number of Pages: 138 Pages
SA6D170-A-1T S N 14203-UP
CYLINDER HEAD
CYLINDER HEAD (1)
ROCKER ARM AND HOUSING
ROCKER ARM HOUSING COVER
AIR INTAKE MANIFOLD AND AFTER COOLER
AIR INTAKE MANIFOLD AND AFTER COOLER (FOR PM-CLINIC)
AIR INTAKE CONNECTOR AND TUBE
EXHAUST MANIFOLD AND TURBOCHARGER
EXHAUST MANIFOLD AND TURBOCHARGER (FOR PM-CLINIC)
TURBOCHARGER (EXCEPT JAPAN)
EXHAUST BRAKE AND MOUNTING
EXHAUST BRAKE AND MOUNTING (1 2)
EXHAUST BRAKE AND MOUNTING (2 2)
EXHAUST CONNECTOR (FOR WITHOUT EXHAUST BRAKE)
EXHAUST BRAKE
WATER MANIFOLD AND THERMOSTAT
WATER PIPING
CYLINDER BLOCK
CYLINDER BLOCK (1)
CYLINDER BLOCK COVER
FRONT COVER AND FRONT SUPPORT
GEAR CASE COVER AND GEAR
OIL PAN
FLYWHEEL AND FLYWHEEL HOUSING
CRANKSHAFT
PISTON AND CONNECTING ROD
CAMSHAFT AND CAM FOLLOWER
LUBRICATING OIL SYSTEM
LUBRICATING OIL PUMP AND SUCTION PIPE
LUBRICATING OIL FILTER AND MOUNTING
LUBRICATING OIL FILTER PIPING
TURBOCHARGER LUBRICATING OIL PIPING (FOR PM-CLINIC)
MECHANICAL PUMP AND PIPING
LUBRICATING OIL COOLER
LUBRICATING OIL COOLER (FOR PM-CLINIC)
FUEL SYSTEM
FUEL INJECTION PUMP AND MOUNTING
FUEL INJECTION PUMP AND MOUNTING (HIGH ALTITUDE PERU SPEC.)
FUEL INJECTION PUMP AND MOUNTING (HIGH ALTITUDE INDONESIA SPEC.)
FUEL INJECTION PUMP DRIVE
FUEL INJECTION PUMP PIPING (1 2)
FUEL INJECTION PUMP PIPING (2 2)
FUEL FILTER
FUEL NOZZLE AND SPILL PIPE
FUEL INJECTION PUMP (PUMP) (1 2)
FUEL INJECTION PUMP (PUMP) (2 2)
FUEL INJECTION PUMP (PUMP) (1 2) (HIGH ALTITUDE PERU SPEC.)
FUEL INJECTION PUMP (PUMP) (2 2) (HIGH ALTITUDE PERU SPEC.)
FUEL INJECTION PUMP (PUMP) (1 2) (HIGH ALTITUDE INDONESIA SPEC.)
FUEL INJECTION PUMP (PUMP) (2 2) (HIGH ALTITUDE INDONESIA SPEC.)
FUEL INJECTION PUMP (GOVERNOR) (1 2)
FUEL INJECTION PUMP (GOVERNOR) (2 2)
FUEL INJECTION PUMP (GOVERNOR) (1 2) (HIGH ALTITUDE PERU SPEC.)
FUEL INJECTION PUMP (GOVERNOR) (2 2) (HIGH ALTITUDE PERU SPEC.)
FUEL INJECTION PUMP (GOVERNOR) (1 2) (HIGH ALTITUDE INDONESIA SPEC.)
FUEL INJECTION PUMP (GOVERNOR) (2 2) (HIGH ALTITUDE INDONESIA SPEC.)
FUEL INJECTION PUMP (COUPLING)
FUEL INJECTION PUMP (COUPLING) (HIGH ALTITUDE PERU SPEC.)
COUPLING (FOR ELECTRICAL GOVERNOR) (HIGH ALTITUDE INDONESIA SPEC.)
FUEL INJECTION PUMP (FEED PUMP)
FUEL INJECTION PUMP (FEED PUMP) (HIGH ALTITUDE PERU SPEC.)
FEED PUMP (FOR ELECTRICAL GOVERNOR) (HIGH ALTITUDE INDONESIA SPEC.)
INJECTION PUMP (TIMER)
INJECTION PUMP (TIMER) (HIGH ALTITUDE PERU SPEC.)
INJECTION PUMP (TIMER) (HIGH ALTITUDE INDONESIA SPEC.)
COOLING SYSTEM
WATER PUMP AND MOUNTING
COOLING FAN AND MOUNTING
TENSION PULLEY
CORROSION RESISTOR AND PIPING
ELECTRICAL SYSTEM
ALTERNATOR AND MOUNTING
ALTERNATOR DRIVE
STARTING MOTOR AND MOUNTING
ALTERNATOR (50A)
STARTING MOTOR¤ L.H. (7
STARTING MOTOR¤ R.H. (7
ACCESSORY
AIR COMPRESSOR AND MOUNTING
AIR COMPRESSOR PIPING (1 2)
AIR COMPRESSOR PIPING (2 2)
AIR COMPRESSOR
TOOL AND KIT
GASKET KIT
CYLINDER HEAD
CYLINDER HEAD (1)
EXHAUST BRAKE
WATER PIPING
CYLINDER BLOCK
CYLINDER BLOCK (1)
OIL PAN
CRANKSHAFT
FUEL SYSTEM
FUEL FILTER
COOLING SYSTEM
TENSION PULLEY
ELECTRICAL SYSTEM
ALTERNATOR DRIVE
ALTERNATOR (50A)
ACCESSORY
AIR COMPRESSOR
TOOL AND KIT
GASKET KIT
- KOMATSU Fault Codes
