Komatsu Engine SA6D170-A-1Q-H 13144-UP Parts Catalog
Model: Komatsu SA6D170-A-1Q-H Engine
Serial Number: 13144-UP
Number of Pages: 99 Pages
SA6D170-A-1Q-H S N 13144-UP
CYLINDER HEAD
CYLINDER HEAD (1)
ROCKER ARM AND HOUSING
ROCKER ARM HOUSING COVER
AIR INTAKE MANIFOLD AND AFTER COOLER
AIR CLEANER AND MOUNTING (EXTREME COLD TERRAIN SPEC.)
EXHAUST MANIFOLD AND TURBOCHARGER (1 2)
EXHAUST MANIFOLD AND TURBOCHARGER (2 2)
TURBOCHARGER (EXCEPT JAPAN)
MUFFLER AND MOUNTING
MUFFLER EJECTOR PIPING
WATER MANIFOLD AND THERMOSTAT
WATER PIPING
CYLINDER BLOCK
CYLINDER BLOCK (1)
CYLINDER BLOCK COVER
FRONT COVER AND FRONT SUPPORT
GEAR CASE COVER AND GEAR
OIL PAN (EXTREME COLD TERRAIN SPEC.)
FLYWHEEL AND FLYWHEEL HOUSING
CRANKSHAFT
PISTON AND CONNECTING ROD
CAMSHAFT AND CAM FOLLOWER
LUBRICATING OIL SYSTEM
LUBRICATING OIL PUMP AND SUCTION PIPE
LUBRICATING OIL FILTER (EXTREME COLD TERRAIN SPEC.)
OIL BY-PASS FILTER (EXTREME COLD TERRAIN SPEC.)
MECHANICAL PUMP AND PIPING
LUBRICATING OIL COOLER (EXTREME COLD TERRAIN SPEC.)
FUEL SYSTEM
FUEL INJECTION PUMP AND MOUNTING
FUEL INJECTION PUMP AND PIPING (1 2)
FUEL INJECTION PUMP AND PIPING (2 2)
ENGINE STOP MOTOR AND MOUNTING
FUEL FILTER AND PIPING (EXTREME COLD TERRAIN SPEC.)
FUEL NOZZLE AND SPILL PIPE
AUTO PRIMING SYSTEM
FUEL INJECTION PUMP (PUMP) (1 2) (EXTREME COLD TERRAIN SPEC.)
FUEL INJECTION PUMP (PUMP) (2 2) (EXTREME COLD TERRAIN SPEC.)
FUEL INJECTION PUMP (GOVERNOR) (1 2) (EXTREME COLD TERRAIN SPEC.)
FUEL INJECTION PUMP (GOVERNOR) (2 2) (EXTREME COLD TERRAIN SPEC.)
FUEL INJECTION PUMP (COUPLING) (EXTREME COLD TERRAIN SPEC.)
FUEL INJECTION PUMP (FEED PUMP) (EXTREME COLD TERRAIN SPEC.)
COOLING SYSTEM
WATER PUMP (EXTREME COLD TERRAIN SPEC.)
COOLING FAN AND MOUNTING (EXTREME COLD TERRAIN SPEC.)
TENSION PULLEY (EXTREME COLD TERRAIN SPEC.)
CORROSION RESISTOR
ELECTRICAL SYSTEM
ALTERNATOR AND MOUNTING
ALTERNATOR DRIVE
STARTING MOTOR AND MOUNTING
ALTERNATOR (75A) (WITH HARDENING PULLEY) (EXTREME COLD TERRAIN SPEC.)
ACCESSORY
AIR COMPRESSOR AND MOUNTING
AIR COMPRESSOR PIPING (1 3) (EXTREME COLD TERRAIN SPEC.)
AIR COMPRESSOR PIPING (2 3) (EXTREME COLD TERRAIN SPEC.)
AIR COMPRESSOR PIPING (3 3) (EXTREME COLD TERRAIN SPEC.)
AIR COMPRESSOR
TOOL AND KIT
GASKET KIT (EXTREME COLD TERRAIN SPEC.)
CYLINDER HEAD
CYLINDER HEAD (1)
WATER PIPING
CYLINDER BLOCK
CYLINDER BLOCK (1)
CRANKSHAFT
FUEL SYSTEM
AUTO PRIMING SYSTEM
COOLING SYSTEM
CORROSION RESISTOR
ELECTRICAL SYSTEM
ALTERNATOR DRIVE
ACCESSORY
AIR COMPRESSOR
TOOL AND KIT
- KOMATSU Fault Codes
